Looking for Strut Recommendations
tboner1965
Member Posts: 647
in General
I recently acquired a 1987 LeSabre with 54K miles.
Typical Little old Lady car since it was
purchased from my Grandmother. However, I like a
more firm ride than the Buick offers. I suspect
the car is still fitted with the factory struts. I
am looking for a recommendation.
For some additional background, I love the
handling that my Ford Contour offers. The Buick is
pretty close to driving a sofa.
So, who 'bout them strut recommendations.
Eventually, I plan to also replace the P205-75R14
tires with some 16" wheels and tires for the
summertime. However, I want to go with the struts
first since they probably already need replacement.
Cheers,
TB
Cheers,
TB
Harry
TB
Harry
I've been spending time on the other mechanicals of this beast, changing fluids, plugs, filters etc. On that front, just have the belts, hoses, thermostat and coolant to replace.
Of course, the tranny fluid was the messiest, couldn't get the pump down the dipstick to pump out all of the old fluid BEFORE I dropped the pan. Darn filter gets in the way.
Anyway, thanks again for all of the suggestions, and now I'm waiting to see if any of the e-tailers have the bits to firm up the sofa, er I mean the LeSabre.
Cheers,
TB
hmmm.. any guess at what i'd do?
-Chris
Cheers,
TB
not sure where else? try surfing a little, only place i'm sure i can find part numbers is from bmw tuners, but then again, that's the only place i look
-Chris
you made a recommendation, you might know something that wasn't published on the web. I've sent them an e-mail as well, but am not holding my breath.
Cheers,
TB
hmmm... you might have to (horrors!!!) try the old fashioned way and let your fingers do the walking through the yellow pages and call around to a couple speed shops in your area and see if they can get the part number for you...
-Chris
I really doubt that there are Bilsteins since their online fittement guide only lists shocks for the RWD LeSabre and no struts for the FWD.
One thing, but I doubt it, they do list other FWD Buicks, but those are smaller cars, so I doubt they will fit. Will do a "cross check" to see what Monroes are suggested for both vehicles. If the same Monroe, it MAY be reasonable to expect the same Bilstein to fit.
Cheers,
TB
So thanks all for the recommendations. I'll let you know how it goes and perhaps post some before and after pics showing the wheel choice.
Cheers,
TB
