Hey about the squeaking, are you sure it's coming from the exterior. I've had an irritating squeak for a while now, but I think I've pinpointed it down to the driver side seat belt. Right where it rotates and is connected to the actual seat. I'm gonna spray some WD-40 in there and that should fix the problem.
Thanks for the suggestion. It seems to come from the rear (as if from the trunk), low down. Seems to be speed-dependent (coinciding with what I THINK is the rotation of the wheels), but only at low speeds. It's mostly gone away. It comes up only once in a while now. When the weather warms up a bit, I'll check for it with the windows rolled down. May even ask my wife to drive it while I pace it (how's that for AR?).
There may have been posts in the past concerning this, but I do not have time to browse through them. My 2000 ES has 27,000 miles on it...all 4 tires are almost completely worn on the inside of the tire. The outside looks like new! They are also worn evenly on each tire. I had my car realigned at the dealer around 10,000 miles, but this seems odd. Should I take it back to the dealer, or just have an independent shop reallign the car? Also, should I just get new tires, or have someone swap them on the rims? Thanks for any help.
Sounds like the tires are riding on their inside edges. If the springs are too short or too low a spring rate, they can allow the tires to do this.
Is there any evidence of scrubbing across the tread? This would suggest misalignment.
What's your inflation pressure? Under-pressure would put more wear near the sides of the tread. Over-pressure puts more wear on the center of the tread.
Thanks for the response MALTB. Are you writing from Guyana or have you been there lately? I was in Central America recently (PANAMA) and was amazed by the popularity of the 323 down there--and the prices were great. It seems that air bags are an optional but otherwise, they look just like the Protege.
I had my timing belt replaced today at my local garage. They changed all the belts including the timing belt for a little less than $ 220. Not as bad as I had thought.
Have any of you out there with late-model Proteges broken 60,000? Is there much need to adjust the valves unless there is a lot of noise coming form the engine?
I usually keep it between 30-35 psi depending on the temp outside. I have noticed that the handling has deteriorated recently, but I just assumed it was a combo of wear on my shocks, and the tires. Well, I think I will take it back to the dealer that re-alligned my P, and see what they say. The worst thing that can happen is nothing...
Silent Guilt, the only people that I have heard saying that mixing synthetic and conventional oil is a bad move work at oil change shops. They have an interest in keeping your car on synthetic oil because of the high profit margin. After reading the Consumer Reports article on synthetic oil and the marginal benefits of using it I switched back to natural oil. If I remember the article correctly, synthetic oil seems only more beneficial in extremely cold (arctic) climates.
Some of the quick lube places claim that switching back to natural oil will cause your car to burn more oil...this kind of reminds of the warning about traveling to foreign countries and having your kindey stolen and waking up in a tub full of ice...
Have any of you out there gotten the letter from Mazda concerning the 1999-2000 Proteges with the 1.6L engine and the possibility of a malfuncitioning Mass Airflow Sensor? I got mine today.
I have had an engine ping that has baffled me for 30,000 miles now but it only occurs when I burn 89 or lower octane fuel. The Mazda mechanics in my town say that they cannot hear it. Anyway, is there a connection between the Mass Airflow Sensor and pinging? The letter from Mazda mentions symptoms such as uneven idle, lack of power, hesitation, and a Check Engine light, but there is no mention of pinging. Any comments would be appreciated. Thanks.
I had a pinging problem with a 1994 Mazda B2300 pickup truck, and even though my troubles ran deeper than the MAF, the MAF was one item they swapped out immediately. It senses the amount of air coming into the throttle body and adjusts the fuel mixture accordingly. If it's bad, it can cause the mixture to be too lean. Lean mixture = pinging. There are other factors that can cause pinging (which is predetonation -- fuel combusting before it's supposed to inside the cylinder) but the MAF is one potential cause.
Here's the letter from Mazda in Rich Text Format. Let me know how to post pictures and I can post the origninal letter as a gif or jpeg.
1999-2000 Protege with 1.6L Engine Mass Airflow Sensor Warranty Extension Program (Non-California Emission Control Warranty Only) [Special Service Program-SSP56] Dear Mazda Owner: Mazda Motor Corporation has decided to conduct a Special Service Program to extend the warranty coverage of the Mass Airflow Sensor on certain 1999-2000 Protege vehicles with the 1.6L engine and Non-California Emission Control Warranty. Although the potential for failure is unlikely, the extended warranty is available for 7 years from the original warranty start date or 70,000 miles, which ever occurs first. This warranty extension program is provided in the interest of customer satisfaction. IMPORTANT: If your vehicle is functioning normally, there is no need to contact your dealer. We suggest this letter is kept with the vehicle's warranty documents for future reference. Vehicles with a Mass Airflow Sensor malfunction may exhibit any of the following symptoms: illumination of the Check Engine Light (located on your vehicle's instrument panel), lack of power, hesitation, unstable idle. Should a symptom occur, please make an appointment with your Mazda dealer to have your vehicle diagnosed. If the malfunction is due to a failure of the Mass Airflow Sensor during the terms of this Warranty Extension, it will be repaired free of charge. Failure of the Mass Airflow Sensor will not cause the failure of any other components. However, other components can cause these symptoms and are not covered under this extended warranty. This extension Q.!}J.'i covers the Mass Airflow Sensor . To locate your nearest Mazda dealer, visit our Internet dealer locator at www.m8zdausa.com/dealers or- consult your local yellow pages. If you have already paid for the replacement of the Mass Airflow Sensor, Mazda will reimburse you for reasonable repair expenses, based on Mazda's repair standards. Please complete the enclosed Reimbursement Application form, include the required documents, and return it in the pre-addressed envelope provided. If you have moved or no longer own your Mazda Protege, please complete the enclosed pre-paid Information Change Card as soon as possible. This enables us to update our records and notify the current owner. If you are the lessor of a subject vehicle, we encourage you to forward this notification to the lessee to ensure the current driver of the vehicle is notified of this program. If you have any questions regarding this campaign, please contact our Customer Assistance Center at (800) 222-5500, option #4. Our goal at Mazda is to manufacture only the highest quality products. We hope this program will ensure your continued satisfaction with your Mazda Protege. Sincerely, ,,~,~5;:~;:::'f. Mazda North American Operations {~~~ ;';,:;"~~C"
How to post a picture, its sraight html - You can post a photo directly into the body of your message using HTML tags. While composing your post in the Post box, type in the location of the photo on the Internet with the img src="http://url-location-of-photo" enclosed in the < > characters.
2001 protege es 14k miles. no problems until last night. was shifting very awkwardly in overdrive, downshifting hard. Today wouldn't shift in to overdrive, overdrive light flashing also check engine light came on.
Took it to dealer immediately, service rep called for a rental car immediately, mechanic also suggested rental. told will call when the problem is found.
I hope this isn't the start of something. I bought this car because of its Japanese origin, due to realibility concerns. Anybody out there had this problem?
I assume you have the automatic tranny (yes the manual has an overdrive...5th gear). I haven't heard of this problem, but perhaps some of the others with the auto may know.
Sarcasm follows: BTW, what bad service...them getting you a rental car right away. I wouldn't expect that for your econobox. End Sarcasm.
After reading my manual, I determined that the reason the check engine light on my 2000 ES was on was because the gas cap was loose. Even though I've tightened it, the check engine light persists. The dealer says it can take 40 starts or more (weird) before it resets. Annoying!
Has this happened to anyone? Any quick fixes?
For the record, I have had 18,000 miles of flawless performance from my ES. Despite driving it somewhat hard (how can you help it, with a 5 speed), I still average 26 mpg for local suburban driving.
if you wait for the onboard computer to reset itself, it may take quite awhile because a number of variables must occur simultaneously before the computer will reset.
Where in my post do I mention bad service? The only reason for my post is to find out if anyone has had the same problem. Keep your sarcasm to yourself!!
The comment about sarcasm was not directed at you...Sorry if you thought so. I was trying to show that your dealership sounds like it had good service. However, don't try to tell me what to do...I'll give sarcasm out to whomever I see fit.
I own a 95 LX with the 5 spd. and would recommend it.
The clutch and trany are still strong at 144,000 miles. I treat the gearbox with care and don't hold the car on hills with the clutch or use the trany to slow down the car for routine braking. I prefer the 5 spd due to the lower initial price, better fuel mileage, and better control of engine power. The 1.5 and 1.6 liter engines in the 95-98 Proteges are somewhat weak and the manual trany lets you get the most out of the engines by revving up to the 3,000-6,000 RPM power band.
I rate the overall feel of the clutch and gearbox as very good. Maybe not quite as good as a Honda gearbox, but better than most.
The only place where I would not want a 5 spd is in stop-and-go freeway traffic. Good Luck.
The manual transmission in the 2000 LX with 1.6 liter if flawless. The 5-speed really gives the car a sporty feel and the ample power needed to pass. I have driven the same model with an automatic and was disappointed with the power, or lack thereof, hence the change to the 2.0 in the new models. Maybe some others out there have the smaller engine with the auto tranny who would like to comment.
FWIW, I have a 95 DX automatic, with 76K+ on it (bought it at 57K) - and its been flawless, knock on wood. A fun car to drive, lots of room (just like the 97, more than the 2000-onwards!) and a zippy engine. Yes, I have often wished I'd waited and bought a 5-speed too (the engine can be lacking in some/many situations!) - but when i saw the car, I had to snap it up!
Good luck, -ashu
ps: If you're not writing about a 'problem', lets limit posts to the 'main' board. Higher readership, and more info available there, too! And keeps the count ni the 'problems' board from ballooning unnecesarily!
I find that posts left in the main Protege board can get lost in the high volume of traffic there--it's approaching 11,000 about now. Much of what goes on in the main board borders on small talk and conversations that tend to leave others out. I will say, however, that some of the regulars on the main board have been helpful.
Having done about 32000KM on my 2000 protege 1.6L SE (Standard) I noticed an odd noise and feel from the pedal when the brake is depressed and when I am coming to a stop from a slow reversing of the car. The noise is not normal sounding, kind of a grinding noise Maybe bad contact is occuring with some brake component while in reverse? I had the pads estimated at 30% left at around 28000KM and have noticed normal brake harshness wear and tear during stops, but have not yet heard any indicator that the pads are wearing out.
Is it possible that I need to have new pads and service the rotors this soon?
Waiting on transmission,was mistakenly shipped to Canada. Service advisor couldn't specifically tell me the problem, stated that Mazda will not allow them to break the transmission down. Instructed to order new transmission and send old one to them.
I agree, you would think they would have some idea. They seemed surprised that this happened, maybe this is just an isolated incident,and I was the unfortunate one to get a bad transmission.
Oh by the way I'm still driving my rental, A dodge dakota. I'm allready tired of putting gas in it.........
I recently purchased a 2002 Protege LX, auto transmission. At speeds between 72-74MPH, and either keeping a constant speed or accelerating, I hear a high pitched whistling noise. It sounds like the noise you hear when the Emergency Broadcast System is testing on your television (only in a faint fashion). If I let off the gas even a little the noise stops. The noise doesn't appear to happen like this at any other speed.
This is in my opinion either a engine or transmission noise. The car has about 1,300 miles. The dealer said this is a "harmonic" noise and there is nothing they can do. I'm very disappointed in that this is the speed that I will do about 90% of my driving, and this noise will drive me totally crazy. Anyone have a similar experience?
That doesn't sound normal. Maybe you should drive another 2002 to see if it makes the same noise. If it doesn't then they should be obligated to find the problem.
I would change the pads, it's cheap and you will need to soon anyways. The rotors most likely don't need to be cut (turned) if there is still pad left. Good luck.
But I hear the high-pitched warbling between 60 and 65mph. Maybe Mazda changed the design of the weatherstripping to move the resonant wind speed up for the 2002s?
If you accelerate past that speed and allow your car to coast down through that range, do you still hear the sound?
Hi everyone. I am researching for more info on my problem. I tried already another discussion board. I have Protege, 97 LX. My automatic transmission is shifting (I believe, between 2 and 3 gears) with some sort of unexpected delay. The engine holds some extra revs before the gear shifts to the next step, with some jerky feel. Did someone else have this problem as well? If "yes", how bad that can be? Any experience? Thank you, folks. Dinabor
You mean that's not true?
Meade
Curt
Meade
Dear Mazda Owner:
Sincerely,
,,~,~5;:~;:::'f.
Sarcasm follows:
End Sarcasm.
Thanks for your help. Rob from Sterling, vA
Who's the dealership - Rosenthal Mazda?
Just thought I'd mention - a nice coincidence, I'm Ashu from Sterling, VA!
Dinu from Toronto 2001 ES auto
Actually both Rosenthal and Congressional offered the same, wait and see advice.
Thanks to everyone.
Good luck,
-ashu
Come on over and hang. We're trying to recruit fresh blood...I mean, encourage new folks to join us.
--Dale
Many Thanks
Mike
They gave you a Dakota for a rental? Anyway you can switch??
At least it is better than the rattling and growling associated with some of the worlds(read USA) best selling cars at any and all speeds...ha ha
why this obsession with 72-74 mph? try 71 or 75mph.
Thank you, folks.
Dinabor
or after the car has warmed up and u have 5 miles or more on ur odo?
