Visitor Agreement.
"http://www.nytimes.com/2001/03/20/business/20GM.html"
I am so frustrated I don't think I ever want to purchase another General Motor's Product. First of all not to long after I got her I had some paint chip on my hood. They repaired it instantly and no problems after that. Well after that I had to twice repair the driver seatbelt b/c it would lock up when you stepped on the brakes as it should but the belt would then break. That damn plastic piece kept cracking. Next I sent off my cassette player twice and it still doesn't function right and I gave up on that one since I have the CD it isn't necessary really. Then my power window motor unit went out on the passenger side and it was replaced (all of this under warranty). I also replaced an alternator as well.
Now my warranty is long out. Since then last Aug I had to do another alternator (went with a private dealer who rebuilds them with lifetime guarantees). Then that Oct the damn fuel pump went out and that was a around 750.00 to replace. Now I had to get new brake pads which is common and two new front tires which I can understand since I have the original tires on her. I also did my usual maintenance of oil change, new oil filter, new air filter and I had the transmission fluid flushed and changed (I used Jiffy Lube and I am NEVER using them again!)300 miles later the damn engine light goes on. I take it to Pep Boys (won't be using them anymore either) and the diagnostic test came back with nothing other than the transmission is slipping. Okay. They tell me to take her to a transmission specialist to see if they can figure out the mystery. Well I do and he states it might be Jiffy Lube's crappy flushing system that caused the problem. Okay so he reserviced it with the drop pan method and tuned the transmission and put in a new transmission filter as well. Well light came back on 30 miles later. The transmission specialist said he looked at the tranny and she appears perfectly fine other than she keeps slipping. Now I have to take her in yet again ($1,000 later) to see if the valves are having problems perhaps and my brakes I just got done are giving me problems now as well. Gee lovely.
It seems no one can figure out what is wrong with her than maybe the driver but it is so obvious when you drive her. When you start her up the rpm waivers greatly. You have to let her sit for about a minute and rev the engine a bit. If you don't when you put her into drive or forward she doesn't want to move when you give her the gas. You can press the pedal half way down and she barely goes. After about 15 sec of this it stops and everything is fine for now. She is getting gas b/c you can hear it. It feels like I am driving with a brake on at the same time then after the engine heats up it is over with minus the engine light. Then when I slow down and hit between 5-10 mile per hour she gives this little shake. SO slight you barely notice it.
So now I must decide to take her back in and let the mechanic explore some more and tell me maybe he needs to rebuild the transmission after already sinking in 2,000 in the last few months or I can trade her in and go with a Japanese model, lol. DO you have any idea what might be wrong with her or have heard of this? Any info you can share with me would be greatly appreciated. Thanks
Jenn
In addition to the head gasket, I've had many way too many problems for a low mileage car (57,000 now). They include: broken motor mount, burnt out ignition system, broken seat control, broken window regulators (both doors!), bad alternator. I am really looking forward to the transmission problems noted here by others! My advice, and my mechanic's, is to stay away from any GM product!
You must be knocking GM on every forum in cyber world.
I have had no other problems with my Grand Am. I enjoy driving it and have been very please with it.
If you are having problems with your Grand Am and your dealer is uncooperative, I would suggest down loading these complaints and showing them to your dealer. It certainly helped me get cooperation from my dealer.
Comments and suggestions will be greatly appreciated.
83-15-24 DEC 98
Windnoise or Roadnoise Coming from Top of Door Trim Pad.
2 of them,one is the technical bulletin and the other is the warranty bulletin.
The detail of the TSBs though is much appreciated, you can't get it from Alldata.com unless you pay for it.
