A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Only the computer knows....
Without the codes it would take an engineer/programmer several days to troubleshoot a Lexus.
ppb1
I would pass. Now, for $6,000, I'd take the chance and buy it.
I have a lexus ls400 1994 W/mileage of 145000.
when I turn on the car and start to drive and engine temp becomes normal the check engine lights turns on and the engine starts to vibrate,It seems that if the car using 5,6 cylanders not the full 8, then when I shut the car off and restart again everything is normal until about 3 or 4 minutes and then same problem occur again.can you please help me W/this problem. thank you
My cruise also acts strange. It surges a bit on hills.
when I turn on the car and start to drive and engine temp becomes normal the check engine lights turns on and the engine starts to vibrate,It seems that if the car using 5,6 cylanders not the full 8, then when I shut the car off and restart again everything is normal until about 3 or 4 minutes and then same problem occur again.can you please help me W/this problem. and now I did read the code,the code no is 55 I checked in the troublecodes.net,code 55=(KS signal)now I don't Know what is that .can any body help me .Thank you
I have Ls 400 1994,When I turn engine on my low pressure lamp go on , oil level is full and other thing is when I turn swich on and I did not stating the engine after 1 or 2 min lamp go on .can any one help me? thank you
You definitely need a shop manual and good spring compressors.
lexus ls400 1994 when I start the car my oil lamp (orange lamp) goes on and another problem is all of the lamps on the rear fenders left and right except the signal lamp don't work and I have one turned on light in my instrument that shows that they don't work I have checked the lamps and the fuse all of them were in good condition can somebody help me to fix my problems? also my oil is full
thank you
Sounds like a metal contact issue to me. Sounds like the metal contact contracts during the cold, and then expands once your heater kicks in. I had a similar problem with a Domestic car nearly ten years ago. Have a mechanic check all the connections. I doubt that's a serious issue.
As for the ES300 Shock issue..
Just get the parts from Irontoad.com or any dealer. The parts are inexpensive, and any competent independant mechanic can do the repair.
Hope this helps,
SV
thank you
Finally got the Engine Mounts replaced on the '92 LS. (Damaged in a 30 MPH side impact..Long story..) The dealer also found a cracked Coolant tank. The insurance company also agreed to fix it.
So I only got the car back two days ago. I was wonderfully amazed with how the car ran. After 6 visits to the dealer in 8 weeks, I was finally satisified with the post accident repairs. I'd gotten two engine mounts, a new front bumper, LF quarter panel, and whole Left Front suspension out of it.
Yesterday, I was driving, and the Tach Needle began to flicker, and with a puff of smoke shorted out. AHHHH! How much is this going to cost me this time? Or should I just sell the damn car?
It's hard to believe, given the mileage on this car (87K). I know plenty of LS owners with 100K+ that haven't had these sort of problems. I bet the Lexus service guys are going to have a laugh tomorrow when I call them yet again...They in fact told me to sell the car after the 90K service...
What do you LS owners think out there? Should I just pay up or replace it with something else?
Sorry to whine about this car continously, but as you can tell, I'm really annoyed..It was PERFECT before that lady hit it!!!!
SV
This year, however, the state of CA added the dreaded NOX test. This is the most expensive and obnoxious test yet. To make a long story not so long, my car failed the NOX.
Called around to the dealers and some independent shops and got quotes of $277 to $360 just to diagnose the problem and perhaps spend as much as $900 additionally if catalytic converters were needed. One shop even made the idiotic suggestion that I might need O2 sensors, another $600 to $900.
Fortunately, had the problem diagnosed and solved at Prestige Auto in S.F. They replaced my EGR modulator valve and vacuum control valve. They were great guys and the service was terrific. Total cost, $427.00 including a new smog certificate.
I have a 93 LS 400 that has 1 or 2 bulbs burned out. Some postings indicated owners had found this unit to be sealed and were unable to replace the bulbs. Can anyone confirm that the 93 LS a control unit with replaceable bulbs.
Also can anyone tell me where I can purchase these bulbs. It would be great if someone had a specific part number.
pcsbob
Love the car, just want it fixed.
