Ask Edmunds.com's Online Service Advisor
I originally thought the temp. gauge problem might have been caused by the incorrect mixture of engine coolant installed by the dealer, since the temp. gauge problem started right after the coolant was changed. But with the fuel gauge and radio problem also occuring at the same time, all of this smells like a bad instrument panel ground to me. Do you have any thoughts on this?
any help is greatly appreciated
gregg
My 95 Ford Windstar (3.8L V6) had the head gaskets replaced 4/1999, and the transmission replaced with a rebuilt one (including a steel forward clutch piston) in 6/2000.
Seems like the repair work was done well by the Ford dealership.
Given that, how long would you expect these repairs to last?
Ed
but I noticed driving home from the dealer that
the cruise control turned off once while driving over a bridge with a small bump. Is this normal? Can cruise be adjusted to stay on better?
http://www.edmunds.com/edweb/editorial/features/dealing_w_insurance/dealing_w_insurance.html
http://www.edmunds.com/edweb/editorial/features/total.your.vehicle/index.html
Both of these excellent articles should answer many of your questions. I am sorry your vehicle was damaged so badly, but happy to hear you came out in good shape. Modern vehicles do a much better of of protecting passengers in accidents, so be thankful you were not in your old 1979 Mustang.
Aloha
All has been fixed and when I saw the vehicle it looked like new and drove like new. There is some brown dust on the aluminum wheels which they told me was normal dust from the brakes. The owners are very good people I know but still I want to make sure there is nothing I am over looking. They gave me the insurance estimate for the repairs which included cover, front bumper, headlamp assembly, and aim, panel headlamp mt., fog lamp, crsmbr, rad pnl lower, radiator, condenser, front side member, reinf. side rail, front fender, clading, shield front, housing, frt shock abs, pan, engine oil, gasket, front wheel, one wheel center front, knuckle steering, upper arm control, lower arm control, shock absorber, front axle assembly, mldg, roker panel, front door outer panel repair and refinish, front door cladding, front dor plate, A/C charge and Freon and 4-wheel alignment.
That is quite a hit but the car 2000 Sienna Jeep looks like new and drives nice.
What should I be looking for before I buy? They have put around 1500 miles on the vehicle since it was repaired and have found nothing wrong. Do you think that is sufficient?
The price is adjusted for sale, I believe, because of the fact is was wrecked. The sticker shows it at $32,185 and they are asking $24,000 firm.
I would appreciate your opinion.
PressOn
Can you help me find one that will match the current radio and maintain the "original" theme of the car.
I have heard that the bottom end of a 5.0 Explorer intake is very good for induction properties.
Also where is the location to tap into the fuel system to check for fuel psi.and to bleed off the system?
Thanks in advance for your response Neil...
Joey
;Jason
They refused to return my deposit. The contract does say non-refundable on it, but I always thought there was a 3 day cancellation "out" in New Jersey.
What can I do? Thanks from someone who is totally stressed out...
Need to match up number - ACN50 104
1 X 16
this is the number on the current one on the vehicle, any help or leads would be most
appreciated. Live in southern Cal. area.
Nino
I consider myself a typical driver,but haven't had a car in years to use oil at that rate!Does any other production auto with a similar horsepower engine perform like this?The Cadillac customer relations were very responsive ,but I have difficulty finding this condition acceptable
I recently bought a 98 Millenia base (premium
pkg.) that will need its 30k service soon.
I called the local Mazda dealer and was quoted
$340. A reputable independant shop was about
$300.
However, he mentioned a couple of things that I
probably will pass on (air filter, I can do that;
rotate tires, not needed, just put new ones on
last
week).
By they way, when I got the dealer to pare his list down to just what the owners manual says (basically replace plugs and inspect everything else), it turned out to be $100 (he said they charge $7 each!!! for plugs).
Do those sound like resonable prices? Any reason
why I should go to the dealer for this?
Also, the owners manual indicates that a lot of
the items are to be "inspected". However, both
shops said that they would replace all fluids and
filters as part of this service. So, what is
actually necessary? Am I being scr$%#wed?
I did call the dealer already and they quoted a price for the original cd player at US$ 444 and for the separate cd changer at US$ 560. I would rather get the single CD player which is dashbaord mountable. The initial quote is a bit too pricey for me.
any additional thoughts?
I have spent already, and the potential upcoming cost, indicating that this car is not worth keeping and that it is time to look at the possibility of selling my used car? Or is my repair figure actually quite reasonable?
needhelpnow
Bonnie Rick
Conferences Manager, Edmunds.com Town Hall
