Firestone tire recall: Are mine a problem?
pocahontas
Member Posts: 802
I've noticed a number Firestone topics cropping up
throughout Town Hall, so I thought it would be a
good idea to create a general Firestone recall
topic here in the Maintenance & Repair Conference.
I'll link up other Firestone topics I see
throughout Town Hall to this topic, so people can
discuss their concerns and/or share information
here.
In addition, we can link important articles we see
,on the tire recall, to this topic. To start here
are a couple from Edmund's:
1. August 10, 2000: Update: Vehicles Equipped with
Firestone Tires.
2. August 9, 2000: Firestone Recalls Tires.
Check for other articles at Edmund's News You Can
Use.
Drive safely everyone. ;-)
Pocahontas,
Community Leader/Coupes, Convertibles, and
Sportscars Conference
here.
Firestone Tires.
Use.
Pocahontas,
I know that the Subaru Wilderness tires are not All Terrain tires - Subaru says they are car tires with the Wilderness nameplate stamped on them (are they really Wilderness HTs?). I also know that they do not have "VD" after the DOT label on the black side of the tire.
However, should I really stop worrying that these tires will have a tread separation problem now or a year or 2 from now? Can I trust that someone will let us know if there are incidents with these tires on Subaru Outbacks? It appears that if I want new tires I will have to foot the bill. Right now I am leaning towards keeping them but will buy new ones if I hear of problems on Subarus.
Got back the reply - standard boilerplate with FAQ. I'm off today to get new Michelin's. Good thing that their parent company has deep pockets, because this thing is not going away for a long time.
Good luck to all
1. ATX and Wilderness P235/75R15 have been OE on Ford Explorers, but also they have been used to replace tires on pick-up trucks, vans ect. 48 million of these tires have been produced. The majority of these accidents have involved only Explorers.
2. The P235/75R15 tire holds 2,028 lbs at 35psi and only 1,736 lbs at 26psi. Ford recommends 26psi. 26psi gives the Explorer a comfortable ride. Ford has now tested the Explorer at higher psi. The following is from the www.bridgestone-usa.com website.
"All vehicle owners using Wilderness tires should keep their tires inflated at the pressure recommended by the vehicle manufacturer. For owners of Ford Explorers or Mercury Mountaineers, with P235/75R15 ATX and Wilderness AT tires on their vehicles, Ford recommends these tires be maintained at a minimum of 26 psi. at the request of Firestone, Ford has evaluated the performance of these tires at 30 psi and has determined that the vehicles maintain good performance characteristics at this higher pressure. Ford recommends a tire pressure range of 26-30 psi. Firestone recommends a tire pressure of 30 psi."
The only real PERFORMANCE CHARACTERISTIC that will be affected by higher pressure, within reason, is RIDE.
3. The Ford Explorer Limited Edition 4X4 weighs 4,113 lbs add gasoline and it now weighs 4,275. GVW for it is 5,013,(These figures are from Edmunds.) In go 4 adults and luggage and that vehicle is overloaded.
4. Lower air pressure means more flexing of the sidewall and that leads to more heat. Heat destroys all tires. Michelin is thanking the tire gods for not being the OE supplier for the Explorer. Trust me.
5. Nylon cap ply is used in high speed tires to keep them from growing and hold the tire together. Nylon shrinks when it as it gets warmer. Most passenger tires Do Not use nylon caps. Would it have helped the ATX and Wilderness...maybe, but Mich, Bridgestone, Uniroyal,and BFG don't have nylon in passenger tires either.
6. Why is the Explorer rolling over and killing people when a tire throws it's cap or blows out? Vehicles have tires that blowout every day and don't roll over. Maybe some questions should be asked of Ford. The roll over is killing people not the tire.
7. Joan Claybrook doesn't work for a non profit public safety agency, but, works with a group of attorneys for profit. HMMMMM.
Long enough, I feel a bit better.
Anything out of this person should be included with a truck load of salt. Her association with trial lawyers adds a finishing touch to a distinguished career.
You can just click on that highlighted link to go there.
Pat
Not Michelin, not Goodyear but subsidary of Ford which is Firestone.
I believe Ford forced them(Firestone) to cover up their faulty design on SUVs. If Ford used recommended pressure on Firestone tires,Explorers and other family members would have failed on rollover test.
Edmund's News.
Pocahontas,
Town Hall Roving Host
If there has been problems with the FR680, Honda would have replaced those tires in literally a blink of an eye.
The Bridgestone RE910 and RE92 are actually well-liked tires and many Civic owners who originally had FR680's when they bought the car new swapped them for these Bridgestones.
Florida litigants press for expanded recall of Firestone tires
Pat
When this news first broke, I went out and checked my tires right away. I had one tire failure (98 Explorer) late last year and have been wary of these tires ever since. The replacement tire they put on was a W2 code. The other four were VD (including the spare) I inspected them closely and all of the VD tires had a large crack around the outer circumference of the tire where the tread meets the body. The drivers front was a W2 with no crack, the passengers front was a VD with the identical mileage and it had the worst crack. I kept my pressure at 35-40 psi all of the time. I have pics of all 4 tires and when I get the film developed I will post them on my website and link it here. There is clearly something going on with the VD tires. I also have a set of W2s on my Dodge van that have no signs of the crack.
I had always had good luck with the Firestone FR360s that came on the Rangers I owned. The Wilderness AT's let me down early on. I also think that the air pressure recommendation from Ford is fishy too. My experience blows that theory though. I kept mine at Firestone's recommended pressure or slightly above.
Good Luck to all that have yet to enjoy this replacement experience.
Personally, I recommend the Dunlop Grandtrek TG35s, if you can find them in the right size for your vehicle. They're quiet, have good traction in all weather, have a fairly high load rating, are able to go though some mild offroad conditions (more than any normal SUV owner will put the vehicle though) and are relatively cheap!
I don't intend this as humor, but a sad truth. Just this summer, while traveling through Arkansas, a woman in an Explorer passed us on the interstate outside of Hot Springs. Just a few minutes later, we came upon a large strip of tire tread and her Explorer on it's top, having obviously rolled several times. Others had already stopped to render aid, and I chose not to subject my young children to a horrific scene. I only hope that God was with that lady.
Jim
Drew
http://albums.photopoint.com/j/AlbumList?u=137587
other subjects, so:
-Hi jlflemmons, The likelyhood of roll over
increases with a higher center of gravity. You'll
find more discussion on this in Suv Topic 2262.
-For those interested in subject of general safety
and crash tests, here are some topics to read.
- -MB enthusiasts- Yep, nice suv. Let's continue
this discussion in Suv 1206, ML320.
AND now for the benefit of those that are effected by the Firestone recall, let's try to focus on issues that are directly related to this topic. ;-)
Pocahontas,
Pocahontas,
http://dailynews.yahoo.com/h/ap/20000829/ts/tire_deaths.html
Hope this is helpful.
Pocahontas,
Town Hall Community Leader
Scroll down to close to the bottom of the page to the section titled "Firestone Fiasco".
Pocahontas,
I especially like this part:
"I might suggest that a truck which rolls over so easily that a 4 psi difference in tire pressures makes a difference is a flawed design to start with."
Drew
P.S. Correct me if I'm wrong, but weren't you the Minivans host a while ago?
I posted the URL to the article because it had some very useful tips as to what to do in the event of a tire blowout. Who knows, if you remember and apply the tips, it may save you from a rollover.
Thanks for your time and drive safetly...
Floridian
If so, I'm sure other's would be interested in hearing about your experience. Thanks for everyone's participation.
Pocahontas,
Tjw & Aling- Thanks for your participation. You've both contributed some good information here. But can you two either shake hands and make-up, or just ignore each other's posts? Opinions (post 47) about someone's intentions, and opinions (post 49) about whether someone should sell their Ford Explorer... are not appropriate for this topic.
Everyone, let's try a little self monitoring. Read your message once it's posted: if it's off topic, please be considerate and delete it. If you're not sure... that it's on topic or not, then please hide it. Okay?
And now for the benefit of those that are personally effected by the Firestone recall, let's please continue this topic on a friendly note. Thank you.
Talk to everyone later. ;-)
Pocahontas,
recall? thanks.
sCoTt
The Texas accident in which a ten-year-old was killed was tragic. Even more tragic--it was a one-vehicle accident in which six were injured. 6+1=7. The Explorer has only six seatbelts. The death was preventable--by the driver.
Firestone tires are obviously a problem, as is Ford's apparently marginal suspension setup. I've just ordered a set of Michelins to replace my Wilderness HTs (not on the recall list--but on the NHTSA list of tires that should be). And I'm not happy with either Ford's or Firestone's response to the problem.
But let's also remember that drivers have some responsibility to operate their vehicles safely. Not all fatal accidents involving these tires are the fault of the tires alone.
As far as rollover, blow a tire on any SUV with a high center of gravity and it would roll, too.
As far as replacements go, I highly recommend the Michelin LTX M/S (X-radial LT or XC LT4). I've had them on an explorer and my current 99 Expedition and there is no comparison for ride and noise. And they don't separate.....
That's absolutely untrue. It is possible to blow a tire and still be able to maintain control. I know of a couple of people who have done that (albeit they were driving the M-class fitted with General Grabber ST tires - no thread seperation though) with no prior experience or training. Read the section titled "Firestone Fiasco" in this newsletter <<A HREF="http://www.curtrich.com/september2000.html">http://www.curtrich.com/september2000.html> for tips on what to do in the event of a blowout.
The person they were transporting died-not yet determined if the wait for the life flight helio was a factor.
BTW - when you put the moose in the tire, what do you do with the horns??
Yes, SUVs in general should not be driven like cars, despite how car-like they may feel. Unfortunately, the majority of owners treat them like high up cars. Personally, I have taken an SUV handling class, as well as a few other advanced driving courses. In fact, I'll be going to one sponsored and organised by BMW later this year. As such, I'm very comfortable and aware of the limits of my vehicle.
I agree that driver input/training has a lot to do with it too. If you yank the steering wheel to one side to try to (over)correct, that will definitely flip the already unstable vehicle. Avoid any sudden movements or stomping on the brakes.
Ford will probably need to change the name of their explorer to "the exterminator" and Firestone to "Gravestone" Just a little dark humor here.
Floridian
Firestone is not worth losing your life or compromising your security....after all $400.00 is a very, very small price to pay for a safe and reliable set of rubber.
