It Just DIED !!!!
                    I have a 1990 Dodge Dakota with w 3.9 V-6.  Coming
home from work yesterday at 55 mph it just shut
down. After waiting about 15 minutes, it started
back up amd I drove it home (approx. 3 miles). I
thought I might have got bad fuel as I had filled
up on my way to work. I replaced the fuel filter
and added some gas treatment. I started to work
the next day and only made it about 4 blocks and it
shut down again, will not start. I let it sit
until I got home from work, it started right up and
I drove it home. I let it sit in the driveway and
idle, after about 5 minutes it shut down, will not
restart until I let it sit. ANY ideas ?
I would recommend that you check for any computer codes. This may lead you to the cause of the problem.
Could be almost anything from a bad sensor to a plugged catalyst converter.
On my 86 ply. rel. there was a bad cat. conv. which gave similar symptoms.
I had a ford ranger which would die in the winter time, it turned out to be a bad damper valve which lets the hot air get to the carburator. The carb was freezing up on me.
www.allpar.com has lots of useful information on chrysler stuff.
good luck
Did you have to go to a mechanic or did you track down the problem yourself?
Thank you for coming back and posting the resolution of this problem.
You might find some assistance in this topic over in our Pickups conference:
Dodge Ram Problems (Topic #2441)
Check out the posts there. If you don't see anything helpful, it would be a great place to ask your questions.
Pat
