car doors freezing shut.
Hi folks. got a question for you. what is the
best method to prevent car(or truck) doors from
freezing shut in midwest winters?
hope this helps
the upper midwest and used to live in apartments
where I had to park outside.
The only solutions I have found are first, don't
go to the car wash when there is going to be a cold snap. This is much easier said than done, because it always seems like when it is "warm", it snows, and when it clears up, it's COLD!
Second, what really solved the problem for me is
parking in a garage. The moisture seems to dry out better overnight, and although it's not heated it stays warm enough (usually) that I don't have trouble.
Then there's always the third option of moving
south. ;-)
Dave
Pat
Harry
Harry
Al
