LeBaron stalling problem
I have a 94 LeBaron with 96,xxx miles on it. I
have put significant $$ into it in the past 15
months, replacing the fuel pump, alternator,
cooling system, convertible top motor, etc, etc,
etc.
Now, the car is stalling for no apparent reason.
I've had it in to a trusted mechanic 2 times and a
dealer once and they can't find anything wrong with
it.
The problem is intermittent. It's only actually
stalled once but behaves as if it's going to stall
- suddenly loses power, jerks, skips, misses. It's
similar to what would happen if the car was
running out of gas. (yes - unfortunately I know
that feeling!) I might drive 500 miles before it
happens then it might happen 3 times in two days.
There is no discernible pattern: dry or rainy,
cold or hot (engine and weather), full gas tank or
low, highway, side roads, fast, slow. I've even
limited my gas purchases to super unleaded and
reputable (?) stations - Amoco, Mobil, Shell.
Everyone tells me it sounds like the fuel pump but
the dealer and the other shop both attached
diagnostic monitoring equipment and couldn't find
anything wrong.
Has anyone else experienced similar problems with
this car or have any ideas on what could be causing
this?
Unfortunately, buying a new car right now is just
not an option.
Any help or insight is greatly appreciated.
thedish
etc.
it.
anything wrong.
this?
not an option.
thedish
I replaced the fuel pump, 02 sensor, computer,battery, and plugs. No help. I checked the service bulletins and found two possible causes. SB 180493 thet covers a throttle linkagr problem and SB 210294 that covers a trans. sensor problem. I will have these checked out the next time the stalling and missing re-appears, which may take one to thirty days.
Keep in touch and good luck
Check "www.allpar.com"
Mine was a clogged Fuel filter (always try the cheapest thing first). Well that was after I had the o2 sensor replaced $100. Replaced filter myself $20.00.
Ran excellent for a month. Started clogging again.
Replaced it again $15.00. Fine for two days. Finally had gas tank boiled three weeks ago $150. Fine for two weeks.
Now there an electric humming and was told that taking out the tank must have disrupted the pump and now that's going and the tank will have to be removed again. around $300.
Did I mention.... it has a new engine, tranny, paint (copper orange), top motor, roof (from junkyard, and many more!!!!
CAN ANYONE SPELL HONDA ACCORD???
I might just get one and keep the LeBaron as a second car.
Thanks - the dish
Remember the Punk group the Plasmatics?
Wendy O Williams (killed herself....must have owned a Chrysler)
blew up a Cadillac at a show on a pier in Manhattan years ago.
Should we have a double LeBaron explosion???
After this repair the problem seems to come back about every 40,000 miles. My '95 was done at 72,000, 115,000 and again at 168,000. Have nearly 200,000 on my blue baby and have loved every inch of driving her.
