Saab 900 / 9000
Is $2500 a good deal or...?
Revka
Hatchbacks & Wagons Host
Help/advice would be appreciated. Thanks!
-CSE in Maryland
I have a 95 900se v6 w/ 82k and just recently w/ the cold weather in the east the "check gearbox" light comes on. After the car seems to warmup or drive about 10 miles, shuting the car off and restarting it, the light does not come on. Can anyone help me, what could be the problem, besides I need a new transmission? The fluid level seems to be ok. Any ideas? Thanks
Revka
Does anyone have any other suggestions as to what might be causing the interior to fog up so badly?
Nagesh
my 1990 900S is intermittently stalling. it runs great while it's running and then without warning, it stalls out and wont start for approx 8 hours, then it starts up and runs great for 15-20 mins. and then stalls again.
i have found that even though there is spark on both terminals of the coil when i disconnect the coil wire to the distributor cap and hold it to the block and crank i dont get spark (hence it doesn't start). i have checked and do get juice at the injectors.
my car has 153,000 mile and has been well maintained.
i would appreciate help on this problem so i can drive my vehicle again.
thank you
russ
Note - we simply called the indy. We didn't even take the car over. It may not be the case for your car, but worth making a phone call or two and describing the situation.
