93-95 Ford Probe
Just wondering if anyone has one of these.
Planning on purchasing one in a few weeks and was
wondering how satisfied you are with them. If
someone would be so kind as to list the pros and
cons.
By the way, I'm looking into the 5speed model.
cons.
Sure enough, I found a discussion in the Coupes area that I think will answer some questions for you. Other discussions were listed as well. Try it and see.
Of course, we're still interested in hearing from current Probe owners here in this topic! Can anyone share his own experience?
care of it.She traded it in for a Jeep Wrangler the following year.I ran into an old friend of mine a while back and he purchased a used 93 Probe GT and was very unhappy with it.It had about 60K on it and he claimed the alternator went out on it and the price for a new one is VERY expensive, somewhere around 600 bucks?He also had to replace his front wheel brake disks and they where very expensive also.He claimed all parts for the Probe
are expensive cause they are all MAZDA parts.
The cure was to rev the engine very high for about
five minutes. Now it does not happen anymore. The exhaust system has been replaced from the cat. converter to the muffler, it was only 195.00 installed. It moves pretty well and is great on gas. I am looking to add a few more ponies. Any ideas?
But it looks great, sounds great, and is a blast to drive.
carlady/host
Thanks!!!
Please e-mail me at meyer_b@rocketmail.com
peak hp - 164 at the crank, about 133 at the wheels
peak torque - 160 at the crank
0-60 - everyone seems to have it pegged at 7.5 sec
1/4 mile - I've seen anywhere from 15.8 - 15.3.
I love the car and have very few problems other than the "normal" problems all 93-95 PGT owners typically have! (bad plug wires, locking parking brake level, rattles.) It's a reasonably quick car with a very high "fun-to-drive" factor.
Also, mine is "Teal" (light metallic blue) color. The paint has started to "dissolve" in two spots on the hatch. It's allot more than normal oxidation, it's actually gone almost down to the metal. I've seen two other 93-96 probes with the same paint that have the same problem. Anyone have Probe paint experience?
Paul
My friends has a couple problems that has me baffled. Both occur when in gear. It has an automatic transmission. When in drive and you hit about 1200 rpm or above there is a ticking in the area of the throttle position sensor(the ticking sounds like a cracked plug boot that is arching, but the plug wires are fine.)
The second problem is at a stop with the brakes applied and in any gear except park or neutral the front of the car shakes and shakes the steering wheel. I think this might be engine mounts. the car has 130K on it. does anyone have any suggestions?
Steering has a clanking sound when first started and cold out. After some minutes of operation it subsides, has been looked at but no solution.
Love the car, my second Probe
Oh, and I left our the burning rubber smell that's emitted from the heater - since 11,000 miles. Great car -- please note that Ford officially told me my car is not a lemon.
Sure sounds like a Lemon to me. Too bad they were able to fix most of the problems the first time or right away. You could 've had a new car. Lemon laws should also include "the frequency at which parts break down" instead of just how many times you have to go back for the "same" failure/part..
That's too bad, I feel sorry for you.
Looks like the car is not under warranty anymore and you're still having problems like bad smells and thumping sounds, etc. I 'd trade it if I were you. I mean you 've had all kinds of problems like electrical, mechanical, gaskets, smells, noises, what are you waiting for? I 'd be scared the tranny or the motor might go any minute..
It's these stories I hear all the time that keeps me from buying American sorry to say. I like the Probe a lot but reliability is always #1 for me.
I hope those Cobra owners that filed the class action suit against Ford win big..
'06 Civic LX coupe
'11 BMW 335i coupe xDrive
'13 Honda Accord sedan (wife's car)
I think I had the one that was making the circuit around the car shows at the end of 92. As soon as I got it I noticed bad build quality. Ran fine for a while but had many warranty claims. Leaks, the exhaust system fell off, power seats never worked right, etc. As soon as the warranty wore off the real expensive parts started to fail, O2 sensor, idle sensor, brake calipers rusted out (not the disks, the calipers, >300 dollars each). Noticed more looming problems and decided to trade it in. If you want a zippy little hatchback, buy an Acura Integra. Not quite the low end grunt but much better engineering / build quality.
I used to own a 95 Probe GT, till I wrecked it in 1997. I kept many of the parts in hopes of buying a new one, but the 97 models were stripped down (no power antenna, lighted visor vanity mirrors, door side moldings, etc.)
I have the original probe floor mats in grey (with the "Probe" embroidered o n them), K&N airfilter (about 300 miles on it, basicaly new),
and the instrument cluster, (showing about 40K miles I think)
I'll take the best offer for these parts if intertested.
angefran@isu.edu
Frank
10K: Had ford rebuild the cylinder head under a hidden warranty.
15K: Driver’s door inner panel did not stay snapped down. Complained to dealer and they did not fix it. Eventually this caught on the carpet and tore the bottom half of the panel off. Ford did not want to have anything to do with fixing this, and a new panel costs $400. I used small sheet metal screws and duct tape to put it back together and keep it from coming un-snapped.
80K Clutch started to go out, and completely failed at 100K. Not unusual for my driving.
Changed the timing belt at 80K (20K after it was required). Belt still seemed to be in good operating condition. This was expensive
80K Changed the valve cover gasket – like everyone else, it was leaking and ruined the spark plug wires. This was very expensive.
100K Changed the CV joints because the boots had worn out, and it is just as easy to replace the whole assembly.
90K. A/C clutch failed. I was told it would cost $2000 to repair the system (several things were leaking), so I still don’t have A/C.
120K: new water pump – original one was leaking.
120K: oil pressure gauge reads low. Compression checks out OK, but it burns about one quart per 700-900 miles. Hmm, someone said these cars could last 200,000 miles, but with oil changes every 3-4000 miles my car won’t last that long.
80K Exaust pieces began wearing out. When the pipe between cat and muffler wears out, the cat will drag on the ground and the car will be undrivable (unless you want to destroy the cat).
Right tail light fills with water. A ford Lighting engineer told me this is a common problem with Probes.
Other: Rewired the fog lights to allow them to turn on when I wanted them to, not when engineers wanted them to. Put Redline synthetic fluid in the transmission (shifts a bit smoother and adds lots of protection). Changed struts to Tokiko illumina 5-way adjustables at 30K. Much much better than stock. Car rides smoother and bottoms out less.
Rear brakes: When I had the rear brake pads replaced as 70K, the shop told me that both rear calipers had rusted and frozen, and I needed two by new ones (big bucks). The car drove fine, and I had a hard time believing this. Reading the Factory repair manual, I found that Ford hid the piston retracting screw under a fake bolt head. I saved $600 by telling the shop how to do my brake job. If a shop tells you the rear calipers are frozen, they may not know how to find this screw.
All in all, it hasn’t been a bad car. My biggest problem with the car is the A/C, and the fact that it costs at least $400 to have anything done under the hood. That big 4 cam engine is shoe horned in there, and you have to take a lot of stuff apart to reach whatever is wrong.
Everything else that has required the Probe to be in the shop for has been standard maintenance (cv boot was replaced)
I couldn't imagine having purchased a better performing car for the money. I highly recommend getting one.
The '95's are probably the best year as there are some issues with the '93-94 that got worked out (rear brake calipers freeze and buggy distributors) and they don't have all the extra emissions stuff that the '96-97 have making them a bit harder to work on (if you enjoy taking car of your car)
How do i know i have this?
My gt is black/turbo,rear wiper,service board, power windows, locks ,brakes, automatic, etc.
please help, need to know how much to sell it for, it is in mint showroom condition. Body and interior are perfect, let me know!!!
Bear in mind however, that there are regional variations to price. Take a look at your local paper and see what cars like yours are selling for in your area. And please, let us know how things go for you.
carlady/host
From what I know they have not had any any problems at all with the car and don't really want to sell it but they just don't need it anymore.
Was wondering if anyone would recommend buying it or if they would not recommend it.
Bought it used from a dealer in 02/99 with 42K
miles, my odometer now reads 56K.
2 weeks after I bought it the engine started
shutting off under hard acceleration and sometimes
even when cruising. I searched the net and found
the distributor to be the likely cause. Dealer
replaced free of charge. This solved the problem.
What is beginning to concern me now is an ever
louder knocking sound from the engine - I'm
guessing it's carbon buildup on the VALVES (???) -
has anyone had this and if so, is there some
inexpensive fix like a fuel additive or something?
I HAVE NOT HAD the other problems that I read
about in this conf - like the Spark plug wires or
Rear calipers.
I love the car. I call it Proberarri for its
stunning looks (in spite of the fading paint),
great handling and very decent performance.
Check out http://pupak.webjump.com for some
pictures and racing/autocrossing stories.
Did you ever think of checking the oil??
