Visitor Agreement.
Wasn't it Yogi Berra who said "you can observe a lot by just looking"? ;-)
FORD rep., that the European models are the only ones that have them standard as well as different rear lenses. She told me that my body shop could order them for me if I wanted them. I may just forget about it all together because a buddy of mine just got his side markers stolen. I thought they are installed securely, but found out that they can be easily pried off of the car. I also don't want to cut huge holes in the car. If it was to be maybe a hole the size of a quarter I'd say ok, but the huge rectangular holes in my friends car has me thinking again about having it done to my hatchling.
By the way , projectzx3, no I haven't taken the class yet, I have to look into it. Oh and thanks for the support.
-Doc Watson
Also, FYI - because you seem to appreciate 'luxury' the same way I do - the ZX3 does not come with a center armrest. I have learned from these boards that you can easily install one, however. For that matter, apparently it is a simple thing to replace the standard dome light with a map light, and one posting said a dealer told him that the steering wheel is already wired for cruise, it's just a matter of replacing the unit, which is apparently much more expensive than ordering it as an option.
I was told my ZX3 would be here in 4-6 weeks. I'll keep everyone posted as I get updates.
Ok my other question: For those of you who have installed a changer under your passenger seat, did you have to remove the seat and how? Is the changer bolted on to the floor? Where did you run the wires to the FM modulator? I've never installed a changer before so I have no idea. Thanks in advance.
It helps cut down the heat build up in the summer and it saves your seats and interior. Twelve years ago it cost $125 installed and it has lasted. Sometimes you see where the mylar material has bubbled, came loose, disintegrated.
I will get the rear windows tinted on my Focus and I want to get the smoke color shades that run along the driver and passenger side windows. They protect you when the sun is low and you can crack the window when it is raining.
There is a panic button on the key fob which will beep the horn till you turn it off by pressing the little button again. Not sure about the lights as I set mine off by accident during the day in a busy parking lot. Oops!
Also, with mostly manual transmission cars, their traffic signals show a yellow light before a green, so drivers can gear up to move!
The mechanic stated that "customer heard noises in front end" as the comment for the work order. That's how they got the warranty to cover it. I hope this helps, good luck.
By the way, I noticed yet another little detail I really like about the ZX3--the rubber covering for the radio on/off/volume knob. It makes the whole unit seem of higher quality. I've also noticed another little "quirk," however--within the climate control unit, the system defaults to outside air flow, rather than interior air recirculation. This means that every time you turn on the A/C, you have to remember to also press the "Interior Air Recirculation" button; otherwise, you'll be cooling off outside air all the time. If any Ford engineers are reading these posts--guys and gals, I really think you should make the climate control system default to interior air recirculation.
In regards to the watch, I had called and Emailed Ford customer service inquiring about the watch offer and they said that it is not a Ford Motor Company promotion but possibly a regional dealer promotion. Which means if your particular dealership was participating in the promotion then you may have been eligible to receive the watch. All they could tell me was to ask my dealer if they were running the promotion. I have read other posts saying that those who have received the watch were told by their dealer that they would receive the gift if they sent back the dealership experience survey . My dealer mentioned the survey but never mentioned anything about the watch but I have been meaning to inquire about it.
1. Ford plans to issued "limited Edition" Foci ever 3 or 4 months. The first unit will be the Sony Edition which will come with a Sony Xplod System and a red and black paint scheme. In may or June they will issue the Kona Edition with a Kona Mountain bike and other stuff. (you go to the Kona dealer and get "sized" for you bike).
2. Ford has increased production at the Wayne, MI plant from 65 Foci per hour to 74 per hour. This provides 35,000 more cars than planned for MY2000. 70% sedan / 15% wagon and ZX3..The Ford Focus order bank currently sits at apx 195,000 cars.
3. Some Regions are selling 115% of projections. The Focus is almost outselling the Civic in some markets.
4. Ford is telling us they are working very hard on the parts problem. Some of these problems are regional and not national. So far we have been rather lucky.
5. 26% of Focus buyers are uder 25 years old. NO other car company have a higher percentage of younger buyers..median age is 35. (the escort was 46)..
enjoy.
Rich
I talked to some of the "car haulers" who told me that its hard to get to the right front tie-down to chain down the focus on the trailers. Wonder if some of them are cheating and hooking to something on the suspension/spring, etc, thereby damaging and weaking it. I believe that I can say this with some authority as my son has hauled cars, and some of the guys will hook anyplace that is easy to hook to rather than the proper tie-down. I know that the Neons have a problem with this also. They said it was only hard to get to on the right side of the Focus. You determine right from left while sitting in drivers seat, not by looking at it from the front. I really wonder about a pot-hole doing that kind of damage on a new vehicle, especially when there was no damage to tire or wheel. Think I'd be after the area Ford Rep. to be looking at this. Put on some pressure. Go over his head it you have to.
Good Luck!!!
Pat
While the sound system is powerful (460 watts), aesthetically the Sony headunit looks pretty aftermarket compared to the wonderfully integrated (IMHO!) factory radios.
One of the assembly guys at the Chicago Auto Show told me that the Mexico plant only does about 35 ZX3s per hour, vs. the 74 sedans and wagons per hour in the US. Guess that makes our Foci ZX3s a bit more exclusive!!
But you know what?? Who cares?? Ford is in business to sell cars and trucks, and from what I read on this board, the Focus is very successful overall, and to the target audience of 25 and under in particular. Maybe that age group could care less about a 20 page brochure - Ford's pre-sales marketing efforts probably indicated that the target audience would be bored with the traditional brochure. Whatever Ford is doing with its advertising - it's working !!
Europe is a whole different story. Cars like the Focus / Golf / MB A-Class / Audi A3 / Astra are in the mainstream of the Euro market, because of their fuel efficiency and size. The Focus is presented in a very serious, technical manner in the Irish brochure that I have. But you know what? The Focus, from what I read, is having a very difficult time in the Euro market!
The Focus is a serious car for real people, no matter where it's marketed. Perhaps Ford's marketing approach in the US, no matter how much we dislike it, is working.
