Ford Focus Hatchback ZX3 - Part IX
16781012
  • SporinSporin Member Posts: 1,066
    The whole "Change the oil out at 500 miles to get rid of the metal shavings is completely antiquated. Modern engines are built to MUCH higher tolerances then 15 years ago. This has been proven by test after test.
    In my VW, you are explicitely told NOT to change your oil for at least 5k miles. This is to allow proper setting of the piston rings, seals, etc. The factory fill is a special low detergent oil. After that, VW calls for 5k mile intervals with dino, 7500+ for Synth.
    If it makes you feel better to do it, then by all means, go ahead. But you're only padding someone else's pockets. I don't think many of us are qualified to second-guess teh engineers who designed and builty the car.
    I have GOT to remember to close those tags!
  • kubus_gtkubus_gt Member Posts: 31
    This is probably the stupidest thing that You all have heard but....
    Just another day I went to the Ford dealer to see the Focus. One of My friends let me test drive his and the car was everything I needed. I checked it out on the Web and even got the Ford Credit approval for a loan. I went into a dealer and picked a black one with 5 speed, abs, ac, antitheft, power door locks. Now the only thing that was missing were power windows. The salesman told me that the ZX3 (which I wanted) did not have power windows even as an option. I check all the car websites that I could find and everyone lists power package including the power windows. What's up with that. I need someone to tell me and prove me right that there is ZX3 with power windows. Is it maybe in CA sold cars? I'm in PA. Please help.
    Kubus_gt@yahoo.com
  • tognetertogneter Member Posts: 245
    Sporin--
    Nobody suggested 500 miles. I did my first change at 2500. While it is true that modern engines produce fewer shavings than older ones, it is NOT true that they produce no shavings. It is still a good idea to change the oil earlier than your normal interval the first time...just no absurdly early. I have done a lot of research on this. Even Click and Clack agree... =]
    zx3--
    5000 miles is a good interval for ANY car, unless you put the engine under undue load (like towing a lot of stuff. 3000 miles is quite literally an invention of the oil companies. Just think, if you could convince people that they needed your product 40% more often, you'd do it too. It can't hurt to do it more often, but it doesn't really help either. I've consulted many a mechanic friend on this.
    Are DEFINITELY an option. If your dealer said they weren't, I'd insist that they install them at original option price, not what they'd charge you for an add on. This will mean you'd be missing you car for a while, but I'd also insist on a loaner, since all of this was necessitated by the dealer either:
    a) lying to get you into the car he had on the lot, or
    b) not knowing what the hell h was talking about.
    Either way...they owe you...
    thanks.
    Right after the post I went on to the Ford Website and "build my own car". The first option that I got was "power package" with power windows and mirrors. The funny part was that with the options that I selected the price matched exactly the sticker price of the car I was dealing on with the dealer. So I called him. Told him what I found and asked what he thinks about that. He said he will check out when the PW will be added as an option and will call me back. He didn't say the anything about the price.
    The web site mentioned late avalability, I hope that late is already now. ZX3 is really nice but too bad about rear drums, I'd rather have the disks.
    kubus_gt
    Yeah...I thought the same thing, but have since been impressed with the balance of the braking system. It's really nice and has received rave reviews. If you look back in this forum (maybe part VII?) silver-bullet and I discuss this exact thing. Now...discs may LOOK cooler, but the performance of the disc/drum combo is very nice.
    PW has been available since at least January. I think your dealer needs to get off the pipe.
  • rathstarrathstar Member Posts: 12
    also if you need to, you can tell your dealer that rathstar over in CO has a zx3 with power windows that came with the car. in fact, tell him that rathstar is so used to the old crank sytle that with thie new car of his, he forgets to put them up before he turns the car off, and then has to put the key back to the 'on' position, just so that he can use his power window switch to power up the power window!
    good luck with the z -
    (rs)
  • segacidesegacide Member Posts: 15
    I went to my dealer (I have an American ZX3 in Germany with the Air Force) and explained to him how I wanted him to paint the black molding body color and was looking into rear discs from the Euro version being installed in mine.
    About the molding he said he'd have to research the plastic to see if it would hold the paint longer than a few months without bubbling and cracking.
    But the rear discs he said that I'd have to replace most of the rear wheel assembly, such as the axle and such. And since I have ABS there would have to be a specially programmed ECU for my setup. All in all, far too expensive for my "bolt-on" budget.
  • hatchqueenhatchqueen Member Posts: 27
    Hey, just got back on a long Discussion-board binge. What ever happened to the board they were going to set up here? Speaking of oil changes, I did my first at 3125 an damn, that filter was on TIGHT. I was cursing louder than David Hasselhof during a "Knight-Rider" out take!
  • focusfanaticfocusfanatic Member Posts: 42
    If you'd really like rear-discs, check into bolting on the contour's setup. I understand it is very similar to the focus'. (Actually, I think that's what they did for the focus R concept) Also, Baer, a reputable aftermarket brake manufacturer, is now working on a complete brake package including rear discs and some sort of adapter so that the e-brake will work. (Check out the latest issue of SCC for details) As to painting the plastic moldings, there should be replacements available soon for the zinc yellow color (I think it has body-colored moldings)- you could just buy those and paint 'em since they'd be capable of holding the paint.
    I have a 91 VW Passat currently and it has 4 disc. What's funny is that in Europe this model had drums in the back. While I was in Poland two weeks ago I saw a lot Focuses and all (almost) ZX3 had discs in the back. I wish they would have them here also. Rear Drums are enough for a light car like this one but with discs it would be even better. Oh yeah add the sunroof too.
  • norwaydougnorwaydoug Member Posts: 249
    I am going to change my oil every 4000 miles. I drive highway miles mostly and this will translate to about every 9 weeks or so. I think that will be fine.
    I can't imagine changing oil at 800 miles and again at 1000 miles. It won't hurt, that's for sure and I wouldn't deter anybody from doing it. Just do what you feel is right and you are happy about it. Anything between 3000 to 5000 seems reasonable to me. That's why I picked 4000.
    ND
  • judasjudas Member Posts: 217
    Where the heck is the guy that was taking his ZX3 to the drags last weekend? Did I miss him? I want to know what that thing turned for times. I'm afraid I'm going to be disappointed.
    Anybody know of lightweight 15 or 16'' wheels that fit the focus? How 'bout Volk? Or Racinghart? Couldn't find an email adress for either. The lightest wheels I've found are 15'' Konig Reigns. 15''=15.7 lbs each, 16''=18.3 lbs each, 17''=20.4 lbs each. Pretty good deal too- 15''=$90 each, 16''=$100 each, 17''=$125. (From http://www.discounttiredirect.com/) Thanks for any info you can offer!
  • zx3beastzx3beast Member Posts: 661
    back in the 60's, there were guys who would
    never change the oil. they would change the
    the filter and add oil as needed. im not recommending this by no means. of course,
    they were all driving a v8 and putting over
    150k + doing this with no adverse effects.
    the fuel was leaded also.todays engine is a
    whole different animal, a regular oil + filter
    change is essential to longevity. following the previous posts is good advice 3000 to 5000
    sounds very reasonable.
  • silver_bulletsilver_bullet Member Posts: 1,339
    They aren't cheap, but the Tire Rack has SSR 16" forged wheels with the correct bolt pattern and offset for the Focus. Give them a call and see how much they weigh.
  • drebe73drebe73 Member Posts: 243
    The ZX3 on the lot that you were looking at may have been built before february 2000 when power windows were not available. Yes they are available now but you will may have to order. I bought mine off of the lot in january and power windows, tilt steering, and, I think, ABS options were not available at that time. At this point, if you plan to order, then wait for the 2001 where I here more options will be available. I really would have loved power windows and a sun roof. The Zx3 you described sounds just like mine.
  • bjammin2bjammin2 Member Posts: 42
    I'm at 8600 as of today when I took the car in to be fixed. Had it since December. Another problem to add, I folded down the back seat the other day, and it won't go back up now. They have to order a new center seat belt...
  • trevatreva Member Posts: 39
    .....ultra-cool-looking forest green zx3.
    Picked it up last week, and can't wait for the
    weekends to come. Who cares about the increasing gas prices....I'm outta here.
    I decided on the zx3 with power and convenience packages, with a/c, abs and side air-bags. I did check out carsdirect, carorder dot coms, etc. but found that a local dealer here in the Bay Area had just the one I was after. But it was automatic. I was a bit reluctant, having always preferred a 5-speed, but was very pleasantly surprised with the auto. So I bought it.
    I dunno if you all realize that most of these internet sites end up going through a dealership close to your address. So if you're like me and can't wait for a factory-prep, doing a good scan of your local dealers will give you an idea of what's out there in your neighborhood.
    Anyway, got a good deal (I think) at $15.2k, with the 4.9% Ford financing, straight from the lot.
    Pros : I love that stereo system, but would prefer a 6-disc changer or something like that.
    The automatic volume control is very cool.
    The engine is sweet, once I get above 2000rpm; and it corners as if on rails. Gottaloveit.
    The first couple of tanks are giving me 25mpg, but I'm not over 1000miles yet.
    And plain-and-simple it's just a great design shape. Makes it stand out so much from all those jelly-moulds out there.
    Cons : (Not really cons). I decided on the convenience pacakge, coz my 6'2" frame put my hands way away from the wheel. The tilt/shimmy package improved that a lot.
    Question ? Why do they want the fog-lights to go off when you're on high-beam ? Safety ?
    I did do the "new-loving-owner' thing and waxed the car last weekend. In fact I've made the makers of Rain-X very rich. Pretty much used every product they make. And yes, I did get wax over the side mouldings, which looked yuck. But I found that Magic-Black restorer fixed that up a treat. Wipe-on-wipe-off.
    I'm checking up with this forum every couple of days and am very interested to hear the latest both on the oil-changes and the mods such as the superchip. Keep'em coming.
    It also keeps my international phone bills nice and high, when I compare my Focus with my brother's Puma he has in Britain.
    So what's coming out in 2001 then ?.....
    As their name implies, fog lights are used to improve visibility in foggy conditions -- when you don't use your high beams, folks. True fog lamps have a sharp cut-off that illuminates the road without lighting up all the water droplets in front of you and blinding you. Don't confuse fog lights with driving lights - a totally different light pattern. Federal law also prohibits the use of auxiliary lights in conjunction with high beams, hence the lock out on the switch.
  • pcleveland2pcleveland2 Member Posts: 516
    I'm running Mobil One Sync Oil. Beening running sync oil for years now. Doing about 100,000 in three years. Once warranty runs out (36000 miles) I will up my oil change interval to 10,000 miles between changes. Until then I will change at the 5000 miles Ford specifies. Never had a problem.
    A trucking company I know of "tested" a sync oil (they got it free to try out) in one of their road tractors. The oil was never changed, just filters and oil added as needed. The motor was tore down at one million miles and spec'ed. Everything was within "new" spec measurements. The OLD sync oil was put back in the motor and the motor was put back in the tractor and another million miles put on it under same conditions. The last I knew the tractor had been converted to a "city" tractor (pickup/dropoff in city) and was still going. The motor had in excess of 3 million miles on it without a motor problem. The company went out of business and lord knows where that tractor is now, but I imagine the motor is still going. It probably getting normal oil changes now because the owner doesn't know the history of it. Diesel engines don't get retired if there still running. The only reason I know this is because my wife's uncle was Shop Supervisor for the trucking company. At 10,000, a true sync oil has not began to break down. It's still new.
    As to the changing oil at early milage, to each his own.
    Pat
    The taxi cabs were in NYC. Taxi cabs in NYC don't ever get turned off to speak of. They keep running and running. Engine wear comes with starting a engine. We start our motors a lot more than NYC taxi cabs. Just ask any mechanic how many miles is taken off a motors life by starting it. I normally like Consumer Reports, BUT imo they didn't do their homework to well with that report.
    Pat
  • tuner1tuner1 Member Posts: 44
    The tan leather seats have been an option on the ZTS model from the very beginning.I wish charchaol leather was an option for my Z,hopefully katskin will make a leather seating kit for our car. Later Tuner1
  • torinopaddytorinopaddy Member Posts: 55
    Silver Bullet, yes, the round caps seen on many European cars are the covers over the tow hook attachment points. On another issue, it is law here as well that high beams and auxilliaries can not be used together.
    Alfaromeo, in Italy the Focus is not considered a small car. The Ka and Fiesta are both popular models here. The Puma is basically a sporty bodied Fiesta coupe. While the style of the Fiesta may seem a bit dated, it has just been given a Focus-style facelift. An all-new model should be with us soon. The "supermini" class is huge in Europe, the choice of most private buyers here in Italy. The Fiesta is actually great fun to drive. It wasn't always that way. It has really turned around in its last two incarnations. As for the Escort, it is really cheap and (here in Italy) only available as a Wagon.
    Nothing to report on my Focus. Everything working as it should. I'm a happy owner.
    Someone (I can't remember who) a good few posts back was complaining about parts manufacturers and how the change in car parts sourcing has in their opinion made cars less reliable. This is complete BS if you will excuse the language. Car's have never been as reliable nor as consistent. I worked for several years for the biggest parts supplier in the world. These guys know what they are doing and out-sourcing the components gives the manufacturers the opportunity to specify very high reliability requirements while keeping the price down and benefiting from the years of experience that these manufacturers have in their particular field. Cars of old weren't even half as complex as modern vehicles, emissions regulations, safety requirements and increased customer expectations have seen to that, but cars these days are extremely reliable consumer goods.
    Things do go wrong - defective parts can get by quality control and design flaws can show up down the line - but that has always been the case. If anything the feeling of disappointment when our cars go wrong or breakdown is confounded by the fact that in this day and age we expect our cars to be packed to the gills with the latest technology, but to run as clockwork. Thankfully they actually do most of the time, despite the fact that most drivers have no idea what is going on underneath the hood.
    I suspect that your complaint has little to do with car reliability however and a lot more to do with the fears of "the third world" encroachment on the US manufacturing base. It always makes me sad to read comments like this. We are all human beings and have the privilege to share this planet. We should not resent each other. Moreover, improvements in other countries' economies do not necessarily mean that the more developed countries have less. In fact it usually means that new markets are created for US (among others) goods creating an increase in wealth and well-being for all. I may get flamed or have my post hidden (sorry for the OT carlady) for this comment, but this attitude really bugs me.
    Back to the Focus and on the rear disk brake issue, I have rear disks and have no problems with them. I have no idea how they compare to the drums. However, I can't see how retro-fitting the disks from the Contour or from an external parts supplier could be cheaper than fitting the Focus disk-brake assembly from the Euro model.
    Talking about brakes, I read recently that Ford has released a part number here in Europe for a new seal for the rear drum brakes to eliminate the squealing noise that some customers were experiencing.
    Togneter, leather is a US$1000-1500 option on the Focus here. I've never seen it so I can't comment on the colours available.
  • jayinpajayinpa Member Posts: 6
    Anyone experimented yet with mud flaps, bug shields, or bras (of the car kind)? I commute 100 miles a day, and bugs and tar are abusing my car. Any suggestions?
    Jay
  • jamers85jamers85 Member Posts: 100
    thanx for the info....that was exactly what i was looking for....
  • zx3zx3 Member Posts: 167
    The majority of this Board recommends changing oil at intervals "close to mfr's specs", rather than changing it more frequently.
    I've studied all answers, they seem very sound. Thank you.
    I'll change from petroleum oil to Mobil synthetic at 1000 mi.(when car is broken-in).
    Thereafter, I'll follow the recommended (by Ford and Mobil) intervals of 5-6K.
    One post told amazing story about an engine running millions of miles on synthetic. Made me I'm glad I'm switching to it.
    I agree with an Off-Topic comment someone posted.....
    Yes, very often foreign workers do some superb work. Look at the "quality/workmanship/detail" of the z that we drive. It's built in Mexico.
    We Americans should consider them and others, not as "threats" but an "incentive to do even better".
    As we already have. The quality of US cars has grown by leaps and bounds these past years.
    Not having bot a New car for 13 years -- I'm amazed and pleased by it. It's Proof that in the long run, competition did good not harm.
    zx3
  • silyboysilyboy Member Posts: 90
    Look in the July Issue of Sport Compact Car!! The Focus that graces their cover (which has a "lengthy" list of mods, largest being a Jackson Racing supercharger) does have a rear disc brake set and upgraded front discs. Their conversion package will be offered this fall and parts will be included for a required change in the hub to accomidate rear discs.
  • njzx3njzx3 Member Posts: 170
    hey fellow zx3 people... I finally, after months of reaserch decided that the Z was the perfect car for me... I ordered it in the end of may... my Twilight blue fully loaded Z is due to be in my posession by mid july!! I can not wait!! it will be the first car I have owned. Reading all your posts over the past months has made my decision an easy, and a smart one. I tried many different card, but when i got behind the wheel of that Z i knew that was where i was meant to be... I just hope that my car arrives when it is said to arrive... I have heard horror stories of people ordering a Z and waiting months for it... anyways, it's 3:40am and i have to work in a few hours, but I just wanted to say thanks to all of you who unknowingly aided my decision to buy my Z, and I hope you will be here to aid me in my maiden voyage a couple weeks from now... until next time,
    thanks,
    Kevin
    Ordering the exact zx-3 is the way to go! I hope you enjoy the car very much.
    ND
  • projectzx3projectzx3 Member Posts: 256
    7000 miles .... love the zx3! we didn't get to the dragway last week. i was called into work. yuck! anyway we're going to try for this saturday night. i will post the results... good, bad or indifferent when i have them. sorry for the delay.
    on an unrelated subject... a friend of my sons was killed in an car accident on the 19th of June. Drinking was involved. he was a passenger in an SUV that rolled. the kid was only 17 and a 'good' kid. we all make mistakes. my point for posting this? please don't drink and drive. take the keys if you must.
  • annie42annie42 Member Posts: 3
    Does anybody have the Kona edition? My local dealer has a few in stock with everything I want, and the price is quite good. Are the roofracks of good quality, and what exactly is the difference in the instrument panel? I need a bike and racks anyway, and I like the look. The only concern I have is that larger tires will cost a lot to replace when they wear out.
    Thanks for any info,
    Annie
    If you like the car, buy it. 16" tires are not necessarily more expensive than 15" tires - it depends on the brand, and where you buy them. Check out the Tire Rack at www.tirerack.com. I always get my tires from them, have them shipped (no sales tax!), and mounted locally for a nominal sum. Besides, you won't be buying tires all that often unless you are going to autocross the car, or drive like a nut.
    Is it just me, or does anyone else notice that the
    ZX3 seems at its best at higher speeds? The few
    times I have taken it on I-95 driving at 70mph, it
    just soars. I love how it just seems to grip the
    road. My only disapointment is that I seem to get
    uncomfortabe driving long distances. I could
    really use the tilt and telescoping steering wheel.
    I have the seat exactly where I need it for my
    legs but i really feel that I'm reaching with my
    right arm.
  • jsbxjsbx Member Posts: 18
    I am FINALLY getting my Z tonight.....but
    ...I have test driven 3 times (not the same but here is what I found)
    even though the height adjustment is a GREAT feature, I didnt want to have to push myself right up against that air bag so I decided the tilt and telescopic steering was a must. I have short arms (well i am short all over :) and felt myself really reaching for the wheel (the top part of it). It didnt seem like the most comfortable thing. It's my one of 2 options I got.
    Speed control was going to be my other option (besides tilt/and ac) but they couldn't find one in the area with all that so it's the one thing I have to do w/o. WHICH pertains to the high speed portion of your topic. I really wanted it to STOP myself from getting more tickets. I have noticed the Z really cruises and high speed and for me, that leads to more tickets.
    I guess a little self control won't hurt.
    Just my 2 cents......
    and i would have ordered the one with everything....a 2001 but I am on borrowed (car) time and didn't have the luxury of waiting.....
    but I am still happy so far!
    It isn't your imagination... the torque curve combined with the gearing makes the ZX3 a long-legged cruiser. It seems to hit its stride around 75-80 MPH, and just hunkers down and covers ground. I agree - long times spent behind the wheel make me kind of stiff, but I've never had a car that I could drive for more than two hours at a time without wanting to stop for a stretch.
  • audiolizardaudiolizard Member Posts: 35
    Annie,
    If you've found the Kona in stock with the features you want(a rarity) and at a good price, go for it! Especially since you need a bike and rack anyway. Don't let that opportunity pass you by because of a price difference between 15" and 16" tires! Everybody seems to like the Kona's special 16" wheels. Also, I believe the rack is bolted on, so it should be very sturdy.
    Thanks norway. im looking forward to driving my new baby, but the wait is killing me... especially since im 21, work full time, and still have to get rides to work from mom!! gets old real quick. but I know it'll be well worth the wait
    on another note. since this will be my first car ever, does anyone have any tips for me? ways to break it in, etc... any suggestions would be appreciated.
    thanks,
    kevin
    Best wishes with your new purchase we are looking forward to you joining the ZX3 family, you are in great company. My beatiful ZX3 is my first brand new car, and the first car purchased on my own. It was really exciting to finaly get a car that fits my style. Annie, if you do get the Kona edition, please-please-please take lots of pictures, especially of all the extra goodies you get, and post them for us to see.
    torinopaddy-please re-read post regarding sourcing
    of parts. there is nothing in that post that states
    out-sourcing is responsible for mfg.unreliable
    vehicles.the comment only had to do with a specific
    isolated component and not a reference to quality of the total build quality.quality control is the point no matter where the part is sourced.some mfg.
    make better parts than others.quality control has
    been an issue since the invention of the wheel.with
    all due respect you read more into that post than was actually there.i am actually very fond of european designs + mfg. techniques and their historical contributions are well-noted + documented.there was no politics intended,infered,
    or implied.quite frankly,i was suprised you took it that way.i am extending an olive branch.peace!
    drebe- i have found myself numerous times on i-95
    at speeds you mentioned with the same results.it is
    certainly a thrill!
    This dealer got 5 konas in yesterday and several more today, and expects more next week, in No. Calif. I'm kind of surprised to see so many at one dealer at the end of the model year. But I've never actually seen one on the road (kona that is) so perhaps they haven't shipped a lot of them until now? Then again, they may be the only dealer here that realized the popularity. I'm still conflicted a bit between the golf and the kona, but the more I look at it, I think the kona is the way to go--with the money I save I can go on a serious road trip. But the golf did have a nice ride, very smooth.
    If you purchase the kona zx3,i'll trade you my 15in.wheels+100 bucks for your 16's.I know,I know but it was worth a try!
  • whyfordwhyford Member Posts: 50
    N.D posted
    "#454 of 510: Why Ford? (norwaydoug) Tue 20 Jun '00 (06:58 PM)
    You are right. It might be 2002 when the 2.3 L
    comes.
    Have you really bought a zx-3 or is your 'WhyFord'
    indicates otherwise?
    If you really bought a zx-3 and you already regret
    it: I suggest that you bought the wrong car and
    your approach of buying the car was not done with a
    cool and level head.
    Besides, I can't imagine a person who bought a
    zx-3 would sing the praises of a 15 year old 'Fox'
    body Mustang V-8. They are so dramatically
    different. A mustang is all about power and speed.
    The zx-3 is a compact economy car with a little
    zip and decent handling.
    Trading in a car after just a few months will cost
    you about 5 K.
    ND "
    My response...
    Yes ND i do own a new 2000 Focus ZX-3.
    I made an error about the Future 2.3 engine and i agree it MAY be 2002?
    Being that this is a Forum of words lacking any facial grins, smirks etal...i see that the printed word speaks.
    I was very serious about not being able to comfortably reach the steering wheel though. VERY serious!
    I thought that the Air Bag lawsuits that brought about lower powered Air Bags were a reason.
    Okay follow my thinking here...
    1/ Keep the driver back from the steering wheel?
    And that's all my free thinking brain could come up with.
    After the fact (i purchased the Focus before i read anything about it)
    Roadtests from some very reputable Magazines meantioned feeling huntched forward.....
    To reach the S.Wheel i DO FEEL HUNTCHED OVER!
    Now i will ask you.
    Is this an Ergonomic issue or a legal "let's cover our butts incase of an accident" issue?
    You questioned me.....if you doubt my honesty then post your e-mail (use HotMail or what ever) and i will show you my reciept and a digital picture of the car and myself standing next to it.
    I will include my phone/fax numbers etal.
    After all it is just an economy car.
    whyford :)
  • zx3rjbzx3rjb Member Posts: 1
    Is the kona roof rack available for other zx3's. I am interested in putting a roof rack on mine.
    zx3rjb
    At least when it comes to specifications. Several times I've seen it written that the ZX3 alloys are 15" x 5.5" -- wrong. I just finished installing the EBC Green Stuff Kevlar disc brake pads, and can report the following:
    1. I took time to clean my wheels inside and out, since the EBC pads aren't supposed to make much dust - I thought it would be nice to start off with clean wheels. Cast on the spokes on the inside are the wheel dimensions and offset, and it says 15" x 6"!! The offset is 52.5mm, BTW.
    2. If you've ever replaced disc pads before, you can do these in no time - they're a snap to install.
    3. Very impressive - our front disc brakes are made for Ford by ATE. ATE is a very high quality European brake manufacturer that is an OEM for BMW, Mercedes, and Audi. They make great brake components.
    4. I haven't bedded in the brakes yet, so I'll report on their performance after I've put on a few hundred miles... stay tuned :)
    Hey Whyford,
    Please accept my appologies!
    I do not doubt (at least now) that you are an owner of a zx-3. I was just wondering because of your name...Why Ford? To me, a name like Whyford is a name that questions the ownership of a Ford product and thus concerned me that you were not a true owner. It was a Shakespearean faux pas. (i.e. What's in a Name?....in your case....quite a bit.)
    I do not know anything about the legal aspects regarding seat backs and air bags and so I can't comment on your question.
    I assume Ford attempted to make a seat and sitting position comfortable for everybody as well as providing the driver with a safe car. It is unfortunate that the driving position doesn't suit you.
    I am still surprised that you would buy a car without any research. It is an important purchase and one not to take lightly. It is your transportation. You take your husband, wife, children, family, girl\boyfriend in it. If you needed tilt\telescoping wheel it was available since Feb 1, 2000 and you could have purchased it. It is pretty much impossible to retrofit such a set up now. Using the internet, I pretty much learned everything about the zx-3 before buying it. You seem very savy and I am surprised that you didn't do the same.
    I hope you can live with it. Again, except my appologies.
    ND
