Ford Focus Hatchback ZX3 - Part IX
The goop on your gas cap is most likely some lubricant. Just wipe it off when you have a chance.
Remember when you close your cap to allow the cap to click a few clicks to ensure it is properly closed.
I agree with the other advice regarding the Focus name removal, the brakes (should not squeak, but let the car wear in a bit). I noticed on miine that the disk pads (appear very shiny) were quite uneven and slowly became very polished after about 1000 miles. Easy on the brakes.
Shifting is a bit of an art and perhaps you just have to get used to the 5 spd shifter. Just shift slowly and allow a bit more time for the clutch to be fully engaged prior to shifting. It may be that you are rushing it a bit. (Or have sensitive ears).
What options did you get. We like to know the colors (inside and out) of our new members.
You made a fine choice. I am thrilled with my z.
NorwayDoug
One feature I particularly like are the indoor hatch grab handles that allow you to close your hatch in a manner that prevents your hands to touch the outer paint surface of the hatch. Just open your hatch and see the grab handles on either side. (I did not see this in the owner's manual). The outside grab handle for the hatch is of course under the Ford Symbol. (I may be stating the obvious)
I can't stress it enough. You made a major purchase.
Drebe73: My badging idea about embossing the bumper would have both Focus and zx-3 on it and therefore you would know who makes the car and the model.
ND
Advice about waxing: Do not try to wax the black weather stripping. It will not come off!!! Just wax painted surfaces!! Take great care when applying the wax near the black stipping.
My Mother waxed all her black bumper guards and we were never able to remove it. She sold the car a few years back and so the peanut butter idea is moot for me.
("the little bumps are to keep your thumbs....")??
I'm dense, I didn't quite understand that.
Zgirrl.....
The "occasional rumbling" when shifting, could be if you didn't put the stick FULLY into the gear you were shifting into (2nd, 3rd, or whatever). I occasionally do it.
I use RainX "Self-Dry Spot Free Car Wash". 90% of water just drains off the car, no drying required. Works fine.
Just be SURE to follow the Instruction about doing your z ("a section at a time, rinsing the suds off with a hose that does NOT use a spray nozzle").
Just let the water pour out of the hose onto the suds, gentling washing them away. That section will now self-dry. Then go to next section of your z and repeat.
First, I do roof of my z. Then rear. Then front. Then left side. Then right side. Then (with whats left over in bucket) do wheels (RainX takes dirty brake-pad dust right off). Voila -- you're done.
"Peanut Butter" question (sorry, I forgot who asked it)........
I'll give it a shot tomorrow (if it doesn't rain) and post the results.
Finally......
A friend who owns a Body-Shop says he avoids using any kind of car wash (liquid or dry) on his newly-painted cars, for 30 days after he paints them ("that gleaming new paint is still soft, needs time to fully-harden").
Then he added:
"If I HAVE to wash it, I wash very gently, using a SMALL amount of mild liquid-dishwashing soap, the kind housewives hand-wash their dishes with (NOT the stuff used in dishwasher machines) in a BIG bucket of water, and rinse off."
And further added:
"And no way, do I use any wax or polish during those critical 30 days, that the paint is slowly curing to a diamond-hard finish."
That's not what I say or recommend (because I don't know). That's what he says. Other Paint-Pro's, might think/do differently.
zx3
raised bumps on underside of steering wheel is for ideal grip 10 + 2 position.your body shop buddy is right.however,by the time our z was delivered it
had been painted at least 6to8 weeks earlier.i be-
lieve he was referring to freshly painted repaired
vehicles or new re-paint jobs.seems like you are
still enjoying your z.
Of course I am passionate about my ZX3! What owner can't be?
oh, and ND, to answer your question...my ZX3 is:
**5 speed
**CD Silver
**Dark Charcoal interior
**A/C ( a must in IL muggy weather)
**Tilt/tele ( a must for my short being)
That wraps it up...
BUT...
The brakes pretty much whine every time I brake now. Not a groan, not scraping, not even a squeak really... just a high pitched whine. We'll see how that turns out, I guess.
Thanks again all.
I too got the white spots on the side black trim, but found that the spray-on-wipe-off clear magic worked perfectly at restoring the black color. It's remained so, even after further washing.
Has anyone considered the "California Brush" ??, that you wave like a magic-wand over the paintwork, and apparently collects all the dust. I've seen them in the shops, but have wondered whether it'll scrape the paintwork. I'm apprehensive about moving solid particles all over my shiny clearcoated beauty.
Is it a 2001 MY option or is it available in 2000 MY.
ND
Not bad looking, just not something I'd want. The new yellow is supposed to be "more vibrant"...from what I've heard. I think someone posted on that awhile ago.
carlady/host
