Subaru Justy
billybreathes
Member Posts: 14
Upon looking for a new Honda Civic hatchback, I
was set to buy one until I saw this 1991 Subaru
Justy GL on the lot. I drove it and was amazed- it
was $1500, compared to $12,000 for the Civic, and
it drove just as good, not to mention it has a
tach, rear wiper, cargo cover, and a stereo. The
interior even looks better. It has 89k, no a/c,
but here in NH, it's only hot for a month or so.
So I bought it instead, much to the dealer's
chagrin, and I love it so far. I have owned
Subarus in the past and they have always had great
fit and finish and good reliability.
However, it does burn a bit of oil (1/2 qt. every
500 miles) at 90k, which my old prelude didn't burn
at 161k. Also I have heard that 3-cylinders are
not as long lasting as a four cylinder. A mechanic
told me a 4-cylinder could get 150k average, but I
shouldn't expect more than 100k out of a 3
cylinder. Logically, it seems that doesn't make
sense, but has anyone else known this to be true?
I like this car a lot and hope to keep it a while.
3 cylinder Metros are often used as around town delivery cars. These cars are abused and worked very hard and they often last 150k-200k before needing an engine overhaul. So, I don't think you need to worry about your small little engine Just be glad Subaru offered a larger 3 cylinder than the Metro and actually gave it some respectable horsepower numbers. I think the Subaru has 1.2 liters with either 66 or 70 hp, whereas the Metro only has a 1.0 liter engine with 55 hp. By the way, what kind of fuel economy are you getting?
I'm glad that you said a 3-cylinder will last as long as a 4. The engine really doesn't seem to work hard to move the car- it's only 1700 lbs. Mine has 76 horsepower in the fuel injection model, the carbuerated version has 66 I believe. I am getting 41 mpg on the highway, 36 around town, but I don't push the car over 60 mph to keep the revs under 3000. Surprisingly, the car is about as peppy as the new Civic I drove, which has 106 hp, but more weight to move.
The car does still run smooth and does not smoke. Is there an oil that I should use that will prevent the car from burning oil? Right now I am using regular 10W-30 for the summer. I am reluctant to use synthetic or a thicker oil. I wonder if that Valvoline Max Life is worth the extra money?
Definitely do not use synthetic on a car that has accumulated as much mileage as yours already has. It would only accelerate the oil burning and lead to leaks from what I have heard. However, why are you reluctant to use thicker weight oils? I live in Florida, so it gets much hotter here than where you are, but I have found straight 30W oil works best in my 84 VW Rabbit GTI during most of the year. I switch to 10W-30 for the 3 coldest months of the year to aid in starting. When using the 30W, the engine stays quieter for a longer period of time, runs noticeably smoother, and appears to use less oil (only 1/4-1/2 of a quart disappears between oil changes, mostly due to a small leak around the valve cover).
I know there are mixed reviews about oil additives, but I have been using one specific one for almost 2 years now and believe it really makes a difference. I use a product called Lucas oil stabilizer. It claims to reduce wear on the engine during startup by keeping the oil from draining down into the pan, protects the oil from thermal breakdown so that it lasts longer, and seals up worn out valve guides and other internal seals so that the engine burns less oil. Since my engine really didn't burn oil before I started using it, I cannot say for sure whether it would slow down your oil burning problem. But, it does make my engine run smoother on startup and keeps the engine running smooth and quiet longer than just using regular oil. You might want to give that a try and see what happens. It can't hurt to try. It costs $8 a bottle and is good for 2 oil changes.
I'm still confused about the high revs meaning quicker engine failure. Some VTEC Hondas have 8500 redlines, yet these cars easily last 200k or more. After all, the oil prevents metal to metal contact, except when the car is started. Those old Caviliers rev to about 4500 and often fail after 100k.
Also it seems that I should trust the car manual since the manual suggests oil viscosity based on the tolerances within the engine. In todays engines, I hear it's important to use thinner oil because of the tight tolerances in the engine, the thin oil can wedge in between the metal.
Since I absolutely love this little car, I went ahead and put in a new transmission, or I should say they rebuilt the transmission, because there were no "new" ones. Approximately $1,800 and 3,000 miles later, a valve burned up on the engine. Now I'm really sick. Unless I want to spend anywhere from $4,000 to $4,900, I have a car body in excellent shape and a transmission with only 3,000 miles---but, not engine.
I have religiously changed the oil EVERY 3,000 miles and performed ALL recommended maintenance. It has been using (mentioned I didn't say burning because there has never been any smoke) 1 qt. of oil ever 1,000 miles or so, but the dealer (I still take it back to the dealer I bought it from because my whole family has been doing business with them for years) said that was normal for an older car. Anyway, I religiously checked the oil level and added when necessary. I've even used Slick 50 in it and recently had the engine cleaned internally. Gee! Maybe that's what went wrong. Anyway, I am heartsick.
I guess I could come to terms with this if the body had cancer but there is absolutely no rust.
"Ruby", as she was affectionately named, would go in all kinds of weather. She even climbed ice covered steep hills the Christmas the Baltimore Beltway came to a stand still. We were one of the few cars moving about.
Any suggestions or consolations?
The only thing I don't like is the size- here in NH, everyone has SUV's and this car demands no respect from SUV's- they cut me off, flash me when I can't pull away from a stoplight quick (hey, it's a 3 cylinder), etc. So as much as I like the car, it's not too safe here and I'll be moving on to something bigger in a few months.
It's too bad, I love spending $10 to fill it for 2 weeks.
carlady/host
it has 116K on it and it takes me any place. This is important since this is my driver for a daily basis I also have a 2000 Blazer and a 2000 Lexus
you can see why I would rather park the justy on the streets of philly. It does however use about 1 quart of oil between oil changes 3000K. I have opted to use Pennzoil 10W40 and it has helped a bit. I get about 40mpg on the hwy and love this car. It is my little HONDA KILLER''''''
me on how to do this it is not very expensive.
Mine uses a bit of oil too. I also use 10w40. How hard do you drive yours? I baby this car....
Mine, a 1988 AL 4WD and affectionately named SooBeRoo (pronounced as if Scooby-Doo were saying it!), bit the dust about 2 years ago. I had taken it back to the dealer (where I had had all maintenance done in the past) for replacement of the struts and some other maintenance that totalled ~$1400, and I think that someone must have loosened something that they weren't supposed to loosen. What resulted was the car running unusually rough after that. Mike had been driving the car 96 miles ONE WAY to school in Indianapolis every day and told me that the running problem was getting worse. When I finally drove it one weekend, I immediately made an appointment to take it in! By the time I had gotten it to the nearest mechanic, it was a gonner. The harmonic balancer wheel had become loose and, with all of Mike's driving, had actually worn a groove in the block. Anyway, the keyed camshaft finally gave way and the whole works blew. The car, running on battery power only (since the harmonic balancer also controls the belt to the alternator) and with NO OIL in it (because when the camshaft blew, it all leaked out), got us to the mechanic, but didn't make it any further. The real killer is that the motor was still running. That blew my mind. The car sat (almost 1 1/2 years) until this fall when I finally located a new (used) motor.
The new motor (had 80K miles on it) has been installed, not without considerable difficulty since the car sat for so long (my mechanic and his crew are affectionately referring to it as the "Rusty") and now the car runs like a top. However, since the car sat so long (and probably since, at 157K miles, it was overdue) the entire brake system has to be replaced. The cost will run about $800 which, when added to the $495 for the motor and the $500 for motor replacement and other work, almost doesn't seem worth it. You'll note that I say ALMOST. This car has been so GREAT! It has had the power to dart in and out of traffic on I465 (Mike calls this "playing in traffic") and you can literally park it ANYWHERE!
The exhaust upgrade you mentioned caught my attention. Mine was recalled early for an exhaust problem and the dealership had a really tough time working on it. I was told that if the exhaust ever had to be replaced, I'd best just trash the car. NOT ON YOUR LIFE!! And the added performance you got from this upgrade is appealing.
This car will be handed down to my next son this next year. My mechanic (no longer the dealership!) has been instructed to make sure that the car is mechanically sound and safe for driving before I take it home. He is capable of doing the exhaust upgrade you mentioned, and I'd really like to take him some specifics if you can provide them.
I was wondering ,chilno29, if that 110 is from the turbo engine model, and if you could post some info on what you did with your suspension, but I'm gussing all you did was put in stiffer struts and cut the springs and do some body work to the wheel wells. This is what I'm concidering doing based on the fact that custom ordering lowprofile tires is too expeinsive for 14x6 inch rims.
What is it about the Justy that has us all gushy and acting irrationally? Why are they so irresistably cute and lovable? I see a lot of you out there who, like me, have fallen for these little angels who are sometimes devils and who we love anyway.
--l.b.
I own a Subaru J10 1992 Model. I did some mods to it. I fitted 175/50/13 Dunlops SP2000. I have fitted a Peco Back Box, K&N Filter with an Aluminium pipe to get cool air from the external. I have fitted a lower tailgate spoiler at the back. Now what I intend to do is fit a Subaru Impresa scoop on the bonnet. I would like to know more on mods that you did.
Chileno29 I couldn't find your address.
My e-mail is raymond.a.muscat@magnet.mt
N.B: I am from Malta.
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
If anyone is here... I found a 1990 4dr/4wd, 5spd with 97,000 miles here locally for $500. They say the engine was replaced around 60k under warranty. It now has a problem with the rear diff (scraping noise). I am in need of a 'spare' car. This sounds perfect. (We had a 1990 2dr DL FWD new way back when. It was built like a vault.)
Are parts still readily available?
Comments/opinions?
Paul in MN.
Revka
Hatchbacks & Station Wagons Boards
I have a 1988 justy, that sadly I must put to rest. It was wonderful and reliable until the very end, and I'm so sad to see it go. Unfortunately there's quite a bit of wear on the body - rust and stuff, and the suspension is pretty much shot. Still, the engine runs great and I'm sure there are lots of great parts in there.
Interested parties out there????
If so, get in touch with me.
Revka
Hatchbacks & Wagons Boards
A bad bearing (lower end) would be more of a dull thump when you let off the gas.
I did have to replace the valve cover gasket, it was leaking, and I replaced the original cap, rotor, and wires (they had the 1989 date still stamped on them)and put platinum plugs in. I also had to put my Pioneer CD in it! They had records of every little thing done to this car, oil changes every 2,500 miles, everything! It has 106,000 miles on it, and it runs awesome. I've bought many a car in the past, but I have never found such a good little car for $500.
For a 3 cylinder engine it does move the car very well. I drove a 1991 Geo Metro once and it was OK, but this Justy is alot quicker, I had a 1985 Honda CRX Si that was'nt a whole lot faster. It's great around town in traffic, and you could pull a U-turn on a sidewalk if need be!!!
Now buying parts on the other hand... Not fun. Autozone has nothing in stock but spark plugs and a few other parts, but they can order most things. I like getting my parts on demand, not in a few days! This is how it goes in a rare car like this though, I'll deal with it.
I'm putting 20W50 in the car this weekend, that's what they have been putting in it since forever, so I better not change. This Florida climate is good for 20w50.
So I am now a Subaru Justy owner... I hope it lasts for a long time. Are there any "common" problems I need to watch out for?
-mike
Don
So what I'd suggest is a good throttle body and FI cleaning. They don't cost too much and after we did this to our Mazda 626 it drove like new.
The rattle is probaly a heat shield. If it was a bearing the noise would be speed dependent, but engine-rpm independent.
justynough: congrats. The population of Subies in Florida just doubled! LOL
-juice
How is your Legacy holding up?
Vocus
Our new Subie is fine, about 4k miles so far. Mods include 15" alloys from a Legacy Turbo, ASC power moonroof, full size spare tire, cargo area liner, and 6CD changer. Plus a leather shift knob.
It's lookin' nice, and my total investment is still just $19k. Hard to beat for everything I got, in fact impossible to beat because no mid-size AWD can come close.
-juice
When I got home, I turned off the engine, and pumped the brakes several times, and sure enough, the pedal whistles when you first apply it. I also noticed, that when parked and after pumping the brakes a few times, the pedal seems not to go down quite as far, and the pedal whistling disappeared!
Anybody got any idea what's going on?
Bob
As for the squeek, it's probably in the brake light switch possibly.
-mike
Bob
-juice
-mike
dad replaced battery, touched wrong wire. nothing works or turns over..but I have a strong doorchime. a mechanic told my dad to check the inline fuse. where is it?
Please email me at waltermahar@hotmail.com thanks!!!
-mike
