Visitor Agreement.
IIRC you have to disconnect the AC power and the antennae, but it's easy.
Legacy was harder. You have to pry apart some of the console trim and you need a long screw driver with a magnetic head to access this one far back bolt.
I think bit had pictures? Or Pat? I used advice from both to do it.
-juice
Later...AH
Tuckerdog
HTH, Owen
TWRX
Hows the OBS mileage? My WRX has crept up to where I can get the 27 epa estimate on most highway runs.
Another curious thing I noticed is that the mileage is significantly better with premium fuel. The mileage dips to around 21mpg with regular. I get around 325 miles or so with premium fuel and the tank fills upto 13 gallons. With regular, I hardly exceed 275 miles with the tank filling upto 13 gallons. Very noticeable. Also, the power seems smoother with premium. I always fill premium in my OBS nowadays.
Later...AH
One thing I've noticed is that the fuel gauge seems very conservative. I squeezed that 12.4 gallons (46.8 litres) into the tank with the needle just touching the top of the white bar at 'E', but with it being a 60-litre tank it was still at least 20% full. Seems to have been designed to encourage you to fill up with a wide safety margin. I haven't seen the low fuel light come on yet, but I believe the manual says it comes with about 9 litres left (15% of capacity).
-juice
What is it exactly anyway?I think there is about 2 gallons left when the low fuel light first appears.
DD
The struts in my '97 were worn enough at 115K that it was beginning to affect tire wear.
The front axle carries 55-60% of the weight, so I'm not surprised they wore out first.
Not sure about the PS system, though.
-juice
Thanks to Ozman62 & Atexeria for your input on my question some time back about towing with the OBS. I finally decided to get the towbar installed. Should be in next week. I do recommend that anyone that wants to add this, shop around. The prices I was quoted were all over the place. The high end was almost $500, and the low was $195.
Tuckerdog
-juice
Pictures 3-6 show the ASC model 750 on our 2002 Legacy L. It's 17"x30".
-juice
More info on the moonroof is here: http://www.inalfasunroofs.com/moonroof.html
-Brian
I read the archives here and there was a pretty clear consensus that this was to be done at 90K (105K with California emissions). However, the documentation I was shown by the mechanic indicated that 2.2L Imprezzas and OBS call for a replacement at 60K --although Cal models still get to go up to to 105K (!). It also appears that 2.5 L engines (in '99, I believe that's only one model) have the recommended replacement at 90K.
Frankly, this distinction does not make a lot of sense to me, but I thought I'd post it for other's comments and in case anyone finds themselves with the same dilemna.
http://www.subaru.com/owners/care/schedules/middle.jsp?pageID=199- 9
It indicates that beginning in '99 the belt is OK for 105K, although prior to that year, it's 60K. At least for a '99, I do not see any indication that the engine size matters. I still think that this is a bit odd, however. Why the change in '99?
-mike
eric
When you reconnect, connect the red (positive) first, then the negative, and have your keyless fob ready to lock/unlock if the lights blink or if the alarm goes off.
-juice
car is an automatic. base model, hubcaps, etc.
anything special about this model/year? anything to run away from? repair/maint issues?
thanks.
I have a Miata as well, and let me say, the Subaru is the PERFECT car to complent the roadster. You always know what to drive, just check the weather.
I say go for it. It might even have some warranty left over. Call 800-SUBARU3 and ask them what they can tell you about that car's history, you'll need the VIN.
-juice
Tuckerdog
Out of curiosity, do you have the optional air filtration system? If so check that the filters are not clogged and that they are in the right place.
-juice
As a previous owner of 6 Brats and a GL sedan, I know older Subie's well, but have been away from them for a long time now...
The DW just totalled our '00 MPV and we have zeroed in on the '05 Impreza as a replacement.
One quick question that I haven't been able to clearly answer on Subaru's web site:
What are the differences between the 2.5RS wagon, and the OBS for 2005? The OBS has the lower cladding of course, but the 2.5RS appears to have been upgraded with seats, steering wheel, and stereo from the WRX, while the OBS gets the first two, but the stereo is a carryover.
Otherwise, is there a suspension difference, or anything else with the OBS? The OBS is $800 more, and I'm trying to justify exactly why.
~Mike
Chuck
The Outback Sport gets roof rack cross bars, an outside temp gauge (the OBS and STi are the only Imprezas to get this feature), rubber cargo mat, rear bumper step pad, different wheels, 2-tone paint, slightly raised HD suspension, different seat trim. The new-for-'05 Outback Sport SE also gets some other goodies such as 6-disk CD changer, a couple of unique colors, and a few other items that escape me at the moment.
Bob
-juice
I went through the same debate a bit when I got my '04 Outback Sport. After a year of ownership, I'll share my opinions.
Roof rack - Haven't used it.
Rear bumper pad - Love it. As a golfer, I'm always putting a foot up on the bumper to change shoes. I'd mark the bumper up badly without it.
Rubber cargo mat - A necessity in my book. It's great for keeping things from sliding around, like groceries.
Outside temp gauge - I kind of like it, especially in the winter.
Two-tone paint - I like the look, but to each his own.
Raised HD suspension - If you off-road at all, you'll appreciate it. It's not an SUV or truck, and really isn't meant for serious off-roading, but it IS designed to go where other cars can't, or shouldn't. I've taken it on some rough trails to get to good fishing spots, and I've appreciated the added capability of the OBS.
I'm not sure if the differences are worth $800, considering you can get most of those as options for the RS, but since my dealer had a better selection of Outback Sports as opposed to RS's, I was able to find a vehicle in the color I wanted right on the lot. And in truth, I like the look of the OBS much more than the RS.
Hope this helps. I'm sure you'll enjoy either way.
-Dan-
The cross bars help secure all that stuff in place. I don't think the RS wagon even has tie-down holes, the Outback Sport does.
I don't have a temp guage but my wife does - I think it's a neat feature that's I'd like to have on my next car.
-juice
I'm leaning towards the OBS, primarily because of my location (outside of Reno, NV) and at 5,200 feet in the mountains, we'll use it to deal with snow in the winter, plus take a fair share of dirt roads to get to out-fo-the-way fishing/camping spots. I like the idea of the covered rear bumper and cargo mat for the same reasons.
Now if it could only pull a small tent-trailer.... :-)
The dealer, as suspected, could not duplicate the problem. They said they went in the dash & everything checked out okay. And the problem has not occurred again...yet...And that's a concern I expressed to the dealer. I'm about 6,000 miles from going out of warranty. And if it's going to happen again, it'll likely be when I hit 6,001 miles.
He told me something I was unaware of. That if the problem was documented under warranty, but not corrected, I'm covered on that problem for another 12 months.
Fred
Bob
That peice breaks off when you install the filtration system, so if you *do* have it you'll see a metal cover with two screws holding it in place, and a rubber gasket to seal it.
If you can't figure it out lemme know and I'll e-mail you a picture from when I installed mine.
Fred: good to hear about the 12 month coverage. It's like a free extended warranty on that part.
-juice
Then again, I never have any rope in the car to tie-down items anyway, so I make do getting things in back. Lazy a**, I am. <g>
-Dan-
And "Yea" I was real pleased about the 12 month extension on that specific problem.
Thanks again,
Fred
First pic shows the cut-out, my knife is cutting it. The 2nd pic shows the filter I'm sliding in, then the cover that holds it up and seals it.
-juice
It's pretty cheap at one of the online parts places and is installed with double stick tape that it has on its underside.
TWRX
-juice
Owen
Fred
Yes.
Bob
At about 50k miles on my '02 Subaru Impreza Outback Sport I had to have a ball joint replaced (I believe on the front left side) because of a loud popping and clunking noise.
Anyway I was hoping to find out if this is something to be expected at 50k miles or what? I'm figuring this is due to the wreck I was in with it at the beginning of 2002. I'm still finding bugs in the car every so often. (A loose sway bar, a loose hub nut which caused it to involuntarily brake to the left . . . etc) but I figured I'd ask and hopefully find someone who could make an edumacated guess before I wrote it off as being due to the accident. :-)
It sounds like it was related to the accident. I've never heard of anyone replacing ball joints on Subarus especially at 50k miles.
FYI - I've had 4 Subarus (91k, 52k, 128k, & 35k).
DaveM
