Subaru Legacy/Outback
14243454748230
  • evilizardevilizard Member Posts: 195
    The Allroad is nice but its much more expensive and the reliability is not up there. Keep in mind not only how much the car costs to buy but how much it costs to maintian (if this amount of money is an object to you). To me outbacks are much more comfortable to drive than 4-runners (no perchy/lurchy feeling).
    As far as that cargo net goes they usually come with instructions or templates. If not go down to the dealership with a tape measure and measure the spot from a reliable index point. Placement is not that critical as long as you don't get to enthusiastic with the drill. I know its hard to drill holes in your new car.
    1 of these things is not like the others...
    4-runner is a totally different vehicle. Off-road it will walk all over the all-road and the OB, on road it won't handle as well. Towing the 4-runner will walk all over the other 2 as well. Personally I find the 4-runner to be a ripoff. I was shopping for a legacy GT wagon, and was about to buy one. Then I put 5 full sized adults in it, and it had no get-up-and-go, and would never have towed my 2000lb boat trailer with 4 or 5 adults in it. Got a 2000 Trooper for about $3K over the price of the GT wagon, and with a ton more features.
    The all-road with it's funky suspension I wouldn't consider, because I have a subaru XT6. I kiled the air-bag suspension in it, and it cost me about 6 months research to get the proper parts to replace the air-bags with non-air suspension.
    -mike
  • originalbitmanoriginalbitman Member Posts: 920
    The install instructions for the Cargo Net are posted here:
    http://www.bitman.com/soobinstall/
    There is a blow up of the hole location following the full page instructions.
    bit
  • pmagspmags Member Posts: 11
    I'll throw up some digital pics of my dealer installed cargo net hooks later this evening if that would help.
    --Paul
  • pkl88pkl88 Member Posts: 8
    Hi Guys,
    I've been thinking about getting a Subie wagon. WRX is really my personal favorite but it's too small for mia familia. So I'm considering L/OB wagons.
    It seems like the two models are very similar. Are they essentially the same car/wagon or are there substantial differences?
    This issue has probably been discussed earlier and so if you can point me the discussion links, I'll also appreciate it!
    TIA!
    - Paul
    They are basically the same car. The biggest functional difference is the raised suspension, bigger tires and more headroom. It's going to give you a more comfortable ride, handle shocks better and be easier to get in and out of. Other than that the OB comes stock with a bunch of accessories that would be extra on a base legacy (trim, mudflaps, bumper matt etc). I think it looks better. But if your the true pragmatic type and don't have a desire for the OB image or accessories the legacy will do just fine for less money. I think its worth the extra $$$
    No additional headroom in the OB.
    Tires are bigger, giving a softer ride, and the raised suspension will give you a more tippay feeling, but will give easier step in and more clearance.
    The shocks are actually the same shocks with the mounts lower which is kinda funny.
    -mike
    I'm not so sure you can say the ride is better in the OB. Different but not necessarily better. The GT has a more firm suspension than either and handles accordingly. It also has about a 1 inch lower ride height than the OB.
    L does not get:
    Limited slip rear differential
    Drivers seat lumbar adjustment
    6 way drivers power seat
    No sunroof option
    In glass antenna
    16 inch alloy wheels (has 15 inch steel wheels)
    variable intermittent wipers
    Fog lights
    Body color door handles and side molding (cladding on OB and black on L)
    Engine, tranny and body are the same. I have the GT and chose it over the OB because it has a lower ride height, monochrome paint with no cladding, handles better on the road and doesn't have the body cladding. At the time I believe the L didn't have rear disc brakes. Here's my GT:
    http://www.bitman.com/gt/
    bit
  • goosegoggoosegog Member Posts: 206
    originalbitman and cardhu1:
    Nice of you to post the instructions Bit, but I can't make out figure 1 at all. I don't even recognise what part of the car it is supposed to be. I don't have my 2000 OB wagon here in front of me but I don't remember tail light access doors anywhere except in the tailgate. They break regularly so I'm intimately familiar with them. But I believe I was wrong once before, in 1979, so I could be wrong again.
    Maybe these instructions are for the sedan?
    There is a hard plastic access cover on the side of the cargo area... just inside the hatch. Not sure what is behind it but it is about 1 1/2 inches square. That is what the blob like line drawing is in the diagram. The hole you drill goes halfway between that cover and where the plastic trim panel bends and about 3/4 inch up from the seam of the plastic panel and the fabric below it.
    I tweaked the diagram a bit and labeled a few things:
    http://www.bitman.com/soobinstall/cargo_net2.html
    bit
    Wow! Fast work and a big improvement over Subaru's effort. I'll check mine when I get home but I'm sure you're right and I'll have to chalk up a second mistake.
    Both my 2001 and 2000 GT looked the same and they are identical to OBs. I installed the net in the 2001. It took about 1/2 hour. That was 20 minutes of getting up the nerve to drill the hole and 10 minutes to do the actual install.
    bit
  • johnmeijohnmei Member Posts: 44
    Last winter I decided to purchase either a 4WD or AWD vehicle to traverse some steep hills and switchbacks in wet snow/icey roads of rural Maine.
    Decided to investigate the Hyundai Santa Fe, Mazda Tribute/Ford Escape V-6, 2002 Ford Explorer, and the Subaru Outback Wagon with 2.5 4 cylinder engine, automatic transmission. These vehicles were selected because of decent reviews, price and value to some extent, capacity, handling, cruising at 65 to 80mph, quality and opinions offered by many on various net sites, and last in importance trailering or towing ability. I currently own a Toyota Avalon and an 18+ year old 4 x 4 3/4 ton pickup rusty which is hardly used but operable.
    My wife and I drove each "test" vehicle at least twice in different weather conditions. Here are our biased opinions.
    My wife thought the 2002 Ford Explorer had no real styling as in the Santa Fe, for example. The Explorer she thought looks like a box. She thought it lacked power and its mass above 70mph make the engine work to maintain that speed or a greater speed. We also thought the interior was okay but nothing special and that the coin holder was basically unusable while driving. Fit and finish seemed good; however the vehicle handled like a big lumbering oaf. We decided it was too large for us, got fairly poor gas mileage, lacked styling inside and out and probably would have difficulty getting out of its own way in an emergency handling situation and had Ford "reliability" or lack thereof. Lastly, the Explorer XLT (2001 version in this instance)is a 4WD vehicle not an AWD vehicle and the Subaru Outback Wagon beats ALL in the snow. NO CONTEST. Last winter I test drove the 2001 Outback in an empty mall parking lot which was basically sheet ice and hard packed wet snow. I COULD NOT GET THE OUTBACK TO GO INTO AN UNCONTROLLED SPIN NO MATTER HOW I TRIED TO ABUSE THIS VEHICLE. I MEAN IT! TALK ABOUT GIVING A PERSON CONFIDENCE!
    We then drove the 4WD Mazda Tribute V6 and Ford Escape V6. We both were impressed with the power. It is a lively vehicle to say the least. However it is NOT a AWD but a 4WD vehicle and will not perform as well as an OUtback in the snow. It emits a fair amount of engine and road noise. As all SUV it does not give us the feeling of safety or confidence in an emergency handing situation with the center of gravity significantly high. Perhaps a great view of the road in a SUV but I don't want to flip if I have to perform an emergency swerve. In additon to the powerplant another strong point is the Tribute's/Escape's 3500 lb. towing capacity compared to the Subaru's 2000 pound capacity. Gas mileage fairly decent, interior straightforward and plain vanilla. The Tribute's/Escape's doors seems to lack any heft and felt rather "tinny" which probably added to the road noise.
    The Santa Fe AWD in our view wins the exterior and interior design award. We drove 2 different AWD Santa Fes. We were very impressed. The ride was excellent and was similar to the ride we experience in our Toyota Avalon. The fit and finish were excellent. For an SUV there was a minimum of lateral swaying. The engine could use more power and it supposedly doesn't tow over 1500 pounds in the AWD model. It is VERY WELL EQUIPPED. However, the down side is that there was a noticeable smell similar to something burning when we existed one of the 2 vehicles. The salesperson tried to blow it off but we found similar comments re the Santa Fe on the net. Further we decided against it because of few dealers and limited dealer support, very limited numbers of Santa Fes for the marketplace and in many cases a premium of $1000 added to the MSRP. NO THANK YOU. I AM NOT A FOOL. I do belive that Hyundai is a real comer in the global quality marketplace.
    All in all, the Subaru Outback looks and feels like a quality vehicle. It rides and handles superbly. The interior is tasteful and appealing bordering on plush, 2 tone dash with complimentary tan/creme colors and nice tan fabric seats. Fit and finish are excellent thoroughout. The specs are great. The OUTBACK is 14 inches longer (& more stable) than the Tribute/Escape and 10 inches longer than the Santa Fe. The 2002 Ford Explorer is only 2" longer than the Outback, hard to believe. The Outback has 4 wheel disc brakes and the Tribute/Escape do not. Pickup and accleration are certainly decent. The Subaru Outback can cruise better and handle the road better and has a better top end than the other vehicles in this comparison plus it gets far superior gas mileage and is the clear winner in snow/ice conditions. Thus we chose the 2002 Subaru Outback, tried and true 2.5H 4 cylinder engine, auto transmission, All weather package (including heated seats), comfortable rear seats, a nice heavy duty cupped rubber mat for the rear cargo area. I feel I am getting the same vehicle for around $23k that would cost over 30k if I ordered the leather seats and 6 cylinder engine. In my mind, a great vehicle and even better value.
    Perhaps this evaluation will help a few folks decide.
  • 99gs99gs Member Posts: 109
    Thanks for posting your experiences with all the competition. I too am at the point of buying but didn't drive all the vehicals you did. The Outback won me over also. I drove the 4h and I definetly would have bought it 4 years ago, if I would have taken one for a test drive. I ended up buying a CR-V.
    Jack - Ohio
  • bucky10bucky10 Member Posts: 5
    We have a 1999 Outback Wagon that has a feature that we believe isn't normal. When going down a hill, if you tap the brake, the car automatically down shifts. This is annoying. When we spoke to the dealer, they said this was normal. I spoke to other people with the same vehicle and they did not have the problem. Does anyone know if this was standard in 1999 or this a problem with my car?
    thanks,
    Bucky
  • pattim3pattim3 Member Posts: 533
    What you are experiencing is called slope control. Some customers hated the degree of downshifting so there is a modified TCU for it. Have your dealer call our tech. line. Or, call us if they do not understand at 1-800-SUBARU3. We can take it from there.
    Patti
  • cardhu1cardhu1 Member Posts: 9
    Thanks originalbitman!
    A definite improvement over the photocopied instructions I received with the net....I will take a look at my OB tonight and give it a shot...I am sure that the hardest thing will be getting up the nerve to drill into a brand new car!
    -tac
  • dragonfly238dragonfly238 Member Posts: 7
    I have an automatic 98 Outback.
    From day one the car has vibrated everytime I stop at a light or stop sign.
    I can feel it in the mostly through the accelerator, then autoshifter and steering wheel.
    I was told it would go away after the car broke in. Still vibrated at 24K KM. At 48K I had the major tune up, the car was in perfect tune according to the computer and it never vibrated so bad. Then they told me to use premium fuel. I told them I already was.
    I'm now at 72K but the 20 other warrantee problems (actually over 20 according to Subaru Canada customer service)I had with the car has distracted me from the vibration. Now that they are out of the way I can resume my focus on this problem.
    I would appreciate if anyone else could let me know if they've had this problem and how they solved it.
  • nygregnygreg Member Posts: 1,936
    John - great write-up and decision. Someone that can type that much is certainly at the level to join us on our weekly chat (Thurs 9AM ET). Please do. Good choice. As one who has a 01 OB H4 (AWP, auto, cd, security, leather knob, rear bar) I can tell you it is a great car and very solid even at 90MPH! Have you decided on a color? I hear the new red is nice. Thinking of my options, one of the best (and cheapest) is the rear bar which makes closing the hatch so much easier - I highly recommend it.
    Bucky - Downshift is normal. Its stated in the manual. This would help with braking especially in snow. I don't even notice it in my OB, maybe I have the modified TCU.
    Alec - Good luck with your vibration. I can't imagine it's something a good mechanic can't fix. What were some of the other warrantee items?
    Greg
    last night that the OB does not have any lighted indication at the gear selector of which gear you are in. It is only lit on the dash. Your first instinct is look at the gear selector on the console. Patti - need to add this to subaru's list. It only took me 3 months to notice it so it's probably not a big deal.
    Greg
    I would think it's lit down on the console, although on my dad's '97 it's only on the console, wish it were on the dash like my '88 XT6, and how the current ones have it.
    -mike
    Thanks Greg.Perhaps I'll get involved in the weekly chat. 9AM...AM Is that correct? RE the color, I'm afraid that the color choices are the achilles heel for us. We would have bought the Limited in Black Exterior or Dark Blue as long as the interior was in Tan or Beige, a beautiful complimentary color that really would provide the needed contrast to show off the vehicle nicely. Instead both vehicles have a dark charcoal interior with in our view makes the entire vehicle look uninviting and un appealing. Subaru should look at the premium vehicles and get with it re interior contrasting colors.... you know light with dark, etc. BMW/Mercedes/etc./etc. could teach the Subaru folks a thing or 2 about interior decorating. Anyway we had 2 choices.... winetrgreen which is close in color to another vehicle of ours and Timberline, a darker green which unfortunately some yellow in it. We are not thrilled about the color but we felt we had no other choice except to go to another brand of vehicle.
    You could have had the inside re-done, but I guess vanity is more important. I personally like a darker interior, doesn't show the dirt as much as a lighter color.
    -mike
    Sorry, the chat is 9PM EDT not AM. My mistake. Our OB is in Winestone. My daughter was trying to get us to buy the Wintergreen. We also liked the blue and the black. Of course, the black only comes in the limited, bean and vdc versions. My wife made the final decision on Winestone. We like the tan interior I just hope it holds up well over the years. All the colors are nice though. Good luck choosing.
    Greg
  • pugdadmattpugdadmatt Member Posts: 1
    I've been enjoying my 2001 L wagon for almost a week now. From reading this forum, I know most of you have the higher end models, but I didn't want a car payment so I bought the used L.
    For what it's worth, my other car is a 95 Accord EX Wagon (4 cylinder). The Accord seems a little bit more refined to me, but of course they don't sell the wagon in the US any more and no AWD.
    On to the point. As I mentioned the Legacy is an L model with the 2.5L engine and automatic transmission. I have experienced what I would call shudder and what I've seen called stutter on this forum. It's just a couple of mild kicks, and then away we go.
    I used to work on electric vehicles (mainly transit buses) and they had a similar problem. Eventually, we determined that what was happening was that the driveshaft would literally wind up when the accelerator was applied. The shudder was caused by the resonance of the system as the driveshaft unwound. I believe the mechanical engineers call this torsional force.
    As is often the case, the solution to the mechanical problem was a software fix. In an electric vehicle is was straightforward to fix this. Without boring you any further, basically, we fed back a mirror image of the shudder to the torque regulator and it knocked it right out.
    So I'm wondering if there are any firmware upgrades to the transmission control computer that help alleviate this annoyance. (I realize I'm comparing apples to oranges here.)
    Also, I read in another message that someone had gotten around this problem by using premium fuel (93 octane). If that is true, it blows driveshaft winding theory totally out of the water. Personally, I'm so cheap that I'll just change my driving habits to avoid the shudder rather than buying premium fuel. :-)
    As a post script, another way to induce shudder in some vehicles is to accelerate hard and then instantly release the accelerator. For you engineers out there, what your looking at is the step response of the system to a change in torque reference.
    Thanks for the answers regarding the "slope control". However, I still dislike the feature.
    The dealer offered to sell the 2001Outback limited, demo car. The question is....How much should be taken off the sticker for a used car(even if it is only 6000 miles)? My understanding is once the car has some mileage, the cost goes down considerably. What would be a fair value? I know these cars hold their value. Thanks
    Bucky
  • tocatoca Member Posts: 147
    KBB's Private Party price is $26K for a Limited Wagon AT w/ 6000 miles.
    Splurge and buy an '02.
    I have a similar feature on my Trooper. If I'm heading downhill and totally let my foot off the gas, it will downshift to 3rd to apply engine breaking. Very nice feature. If I keep my foot ever so slightly on the gas it won't downshift though.
    -mike
    I've never heard of this feature but it sounds great to me. I wonder why they dropped it.
    If the 2000 had offered it I might have gone for the OB Ltd with the coveted (by us) sun roofs and side air bags. I did so much want the sun roofs but in Canada the Ltd was (still is?) auto only, so I passed in favour of a regular OB with 5 spd and saved myself $$$ as well. Only in Canada, eh?
    I hate that "running away downhill" feeling of automatics; I feel I don't have full control of the car when I'm on the brakes 50% of the time. There are many longish hills in Vancouver with a 50 kph limit where an unchecked automatic can hit 90-100 kph and there's photo radar halfway down. Oops, not any more...the new govt cancelled that. I can see that the feature might get in the way on the open road but in town it seems very handy. All you'd need is a switch to turn the feature on/off, like cruise.
    Bucky10...why do you dislike it?
    I'mnot a fan of the dual roof. The Forester and my Trooper have one huge roof which rocks! The dual one doesn't open for the driver, just tilts up, that's a bummer.
    -mike
  • cptpltcptplt Member Posts: 1,075
    FWIW I bought a "program " 92 Legacy . these are the cars the management people drive around at the Subaru factory. It had 6K on it and the dealer sold it to me for 15K when a new one would have been close to 19. Not quite a dealer demo but close I guess though probably not as abused as much. It has been the most reliable of the 3 Legacys I have had/still have!
    the logic is still in our vehicles, it is just modified to not feel as obvious. I believe Bucky's Sube, has not been modified and that is why I was suggesting the TCU update.
    Patti
    Good Morning! If it is one of "our" demo's, you can be sure it is well maintained while we had it. It is required as part of our getting the cars and they make it easy for us to take care of.
    Patti
    The reason I dislike the slope control is that it downshifts to such an extent it almost makes the rpms go over 5000. It is,to me, very annoying. For those of you who want the feature, I suggest you try it first. As Patti stated, it is modified,(which it is, I didn't notice it at all on the demo), then it is ok. I think my car needs a modification.
    Next answer, Im not sure we want to splurge on a 2002, for the money, we'd probably get the Volvo cross country. The seats(which are very uncomfortable in any subaru), are one of the reasons. The Volvo is very comfortable.
    Patti, make you seats more comfortable, the rest of the care is fabulous!!
    Bucky
    Sorry about the typo's in the previous message. It's early.
    Bucky
    Are demos given the benefit of a good 1000 mile break-in period?
    bit
    I know a bunch of people who have done zero break in. Basically "drive it like you stole it" from the dealer lot, with no ill effects on the engine's life.
    -mike
    A slope control that allows the engine to rev in excess of 5K would be annoying. I don't blame you, Bucky, if it bothers you. Sounds like an easy fix though.
    As for seats, I was concerned that the seats would be too firm and uncomfortable due to some postings here. However, it turns out that I really like them and now find that the seats in my Sienna are too soft.
    Demo - doubt that demos get a good break in. That would be my #1 concern.
    Greg
    Just noticed yesterday that my H4 OB has a very slight whine at idle when warm. Kinda low pitch that I have heard some power steering systems sound like on other cars. Doesn't change pitch when I turn the wheel. Anyone else notice this? Wonder if the hot temps (100F) in NY are causing this. Will check into this further, but, any feedback would help.
    Greg
  • rgarbacciorgarbaccio Member Posts: 42
    Hey all -
    Just wanted some feedback...anyone own one of these? I'm in the market for a car, and according to Edmunds, for less than the price of a new Civic EX, I could get a low mileage 99 Legacy L and provide my family with a cargo car.
    Consumer Reports and Edmunds both say reliable. That would be my main concern...and not just engine, but the nickel and dime stuff that can kill you (as with VW i.m.o.)
    Thanks in advance
    My dad has a 97 legacly L, essentially the same car. No problems with it and he has like 75K miles.
    -mike
    Don't forget the purchase price of the XC is just the begining of your splurgeing. Over on the VW boards people are shocked to discover that the 30K maintence is around $1000 (I didn't slip a zero) plus a couple of hundred for new brake shoes every 12-20K. Those seats are nice though, I just couldn't justify the additional 5K for that and a few other nice things.
  • mikenkmikenk Member Posts: 281
    Although, it was not the cross country, my volvo 850turbowagon that I traded in on the Outback VDC was similar. The maintenance on the Volvo was very high; nothing on the engine, but brakes, AC, seat mechanism, broken steering column; not counting the routine service costs. The VDC is much quieter with a better ride and handling than I think you will find on the XC.
    Concerning seats, I agree that the look and feel of the Volvo and Audi seats are much nicer, but I recently took a long trip in the VDC; the long term driving comfort was about the same as the Volvo, both excellent, but they just don't look as expensive, nor does the interior in general; I hate that woody looking plastic.
    Mike from North Texas
  • mrdetailermrdetailer Member Posts: 1,118
    Quite frankly the biggest problem with Subarus is the tendency to overdrive them in bad weather. My repairmen does a number of wheel and steering repairs every winter.
    Transmissions are really expensive to fix, recommend changing to synthetic fluids if available, and servicing religiously every 30K Miles.
    Change timing belts on schedule, (Subaru makes a new stronger one) and make sure to change the cam and crankshaft seals at the same time to avoid duplicate repairs later (experience talking here).
    OEM CV boots don't last much beyond 75,000 miles. One of the few inferior parts on Japanese cars. If left neglected in the winter with a leak, the entire drive axels have to be replaced.
    Drain and fill the radiator yearly. It's twice the cost of a domestic radiator replacement.
    If you want to use extended oil drains, go to synthetic and change the filters at least every 3,200 miles.
    Change air filters often -- especially if you live in a dry climate.
    Follow the severe maintenence schedule.
    I have a 1991, and it generally still costs only about $600.00 a year in direct repairs and maintenence. This year it was a 120,000 mile checkup, replacement of brake, powersteering, and transmission fluids, and a solenoid.
    I realize some of my recommendations may be controversal, but I found out about 8 years ago that the if it aint broke don't fix it philosophy was in the long run a lot more expensive. Like my transmission that had to be overhauled because the fluid was never replaced.
    My ole Subie really loves the synthetic oil. Better gas mileage by 1-2 miles per gallon, smoother running, and easier starts.
    I am curious what routine maintence costs such as brakes, machining rotors, oil changes, belts and other "inspections and adjustments" for routine service cost for the Volvo. Can you enlighten me?
    I almost got a volvo but fled because of the costs (I knew they were higher but not by how much), I'd love to know the real costs.
  • crawdadkingcrawdadking Member Posts: 46
    When we bought our Bean in March we paid l little over 27k for it, and at the time I carefully considered every other wagon out there. Without going into great detail I found that the Volvo was a little over 10k more than acomparably equipped Bean. The seats in the Volvo were very good tho and I would dearly love to have them. What I find with the sube seats is that in a relatively short time (1 hour), a hard spot forms right under the bone of each cheek. I didn't try the cloth seat model, because we like all the bells and whistles, but I have a feeling they would be better. Anyway I am still trying to find that magic adjustment that will eliminate this problem.
    Let me ramble just a little more. We have 7500 miles on the Bean now and I can't believe how this car handles. I'm not a professional driver by any means but I have had some pretty fair handling cars including a 911 porsche and a new 1963 3000MkII Austin Healy ( see I really am old), and I would put this car up against any of them. I can't explain it but there is just something about the rock solid stability of this car. I loved our 91 Honda wagon because of it's wonderful reliability but in the handling department it was a clunker compared to this car. I can understand why people get in trouble in winter. If I'm not careful I may get in trouble in summer. I'm of the opinion that if everyone had to drive a car for 3 months before making up their mind there would be twice as many OB's on the road, and that's saying something around here since about every 10th car is already a Sube. Guess I'm beginning to sound like a SOA rep so I'll quit.
    Guy
    Would you therefore recommend buying a third party warranty on the car? Is about 1300 for 5 years bumper-to-bumper on a 99 Legacy. I know I'll get about 2 years powertrain when I buy it, and dealer may throw in 90 days bumper to bumper.
    Actually...the warranty probably won't cover about half of the things you mentioned (regular wear, services, fluids, timing belt replacement)...still would you recommend a warranty?
    It wasn't so much the costs of the services (Oil change, 30k, 60k), it was all the other things they found while doing them. I never had a just plain old service call to the Volvo dealer. The oil change would be 30 bucks, but the turbo oil leak they found was $200. I also remember that my 60K service was $1775; I don't remember all the details, but the bottom line will forever be etched in my mind. Before I traded it in at 78000 miles, an independent Volvo mechanic projected that over the next 30K miles, I should expect to replace the evaporator ($1200), rear seal ($1200), probably some serious transmission work and the radiator. The engine seems bulletproof, but when you continually keep adding everything else up, it got very expensive although I never really considered it unreliable.
    Actually, changing the oil at my Toyota dealer on my Supra was actually a few bucks more than on the Volvo, but that is all it ever was. The entire car was bullet proof. That is what I am hoping far on the Outback; so far so good.
    Mike
    IMO today's cars should go at least 100K without any expense outside of basic maintenance. Toyota does it, Subaru appears to do it and so does Honda. Why can't other auto manuf. do it?
    Greg
    But that's cause they are warrantied to do it ;)
    -mike
