If only they read the Subaru board!
Colin
Thanks for any suggestions!
Ken in (chomp-chomp) Seattle
-mike
I traded my 99 Odyssey EX for the 2001 LL Bean. I replaced the tires on the 99 Ody around 35,000 miles with Bridgestone RE910s and it got much quieter. I STILL think that the LL Bean is a little quieter. I'll bet if I were to swap the OEM tires on the LL Bean for a nice set of Bridgestones (or some such) it would be even quieter. Good luck! I only slightly miss the utility of the Odyssey but I love the LL Bean!
Wednesday we take it in for 7,500 mile service. They are supposed to fix the squealing brakes. They are REALLY loud first thing in the morning.
Enjoy!
Paul in MN.
In the last 2 years, I've had 2 alignments and the struts seem to be fine.
Has anyone had any trouble with Legacys and tire noise? Is this something that happens to Michelins?
-bobby
-mike
Alland
Nematode what is your engine knock issue . Just curious because of my noise .
mike k
That makes the score Daves (fill in an entirely unlikely high number here), Pauls 2.
But we're gaining!
Bobby: "Scalloped" or "cupped" tires can also be a result of worn shocks/struts. They can "seem" OK and still be bad. If balance & alignment are both OK, that's another potential cause.
Ken: your varmint story reminded me of the day I went out to start my 78 GL (many moons ago) after a snow/windstorm. Mashed the throttle to set the automatic choke, and the pedal just stayed on the floor. Started the car, engine raced, shut it off. Popped the hood & couldn't see the engine for all the snow that had compacted in there! Had to use my blow dryer (told you it was a long time ago - still had hair!) to melt it all. Obviously too cold for your critters!
Now...please.. no stories about animals under hoods tangling with moving parts! Eeeeewww!
Cheers!
Paul
In other news, I got an 02 LL Bean today!! What an awesome car. I paid $100 over invoice at Pence Subaru in Richmond VA (they matched the Fitzgerald price I printed out), and had a very pleasant buying experience. The dealership has an excellent selection, with tons of Foresters, Outbacks, and Imprezas in stock. I was tempted by a nice blue WRX wagon, but stuck to the plan and got the Bean. Same color as my 00 Outback (Timberline), so I won't draw too much attention from the neighbors (except the 16 year old motorhead across the street, who knew right away).
The car is a great cruiser, and very quiet. Hard to tell from the VDC I drove a few weeks ago, so I don't think there is much difference in noise levels.
I had a couple of goofs when I kept trying to find a clutch pedal and shift gears, but otherwise I don't miss the 5-spd at all. The H6 engine is really wonderful, and among the smoothest engines I have experienced.
Everything about the car is great -- all of the utility and versatility of my 00 Outback, with some nice ammenities. I'll post back with more comments as time wears on.
Craig
Bob
-Dave
When the head unit loses power (service, theft etc.) you must insert the "key" CD before it will work again. Installation is a cinch with a wiring adapter - it plugs into the factory harness and has all the correct color wires for the head unit. Very easy with, tougher without.
Be Advised that you will hear more static from FM with an after market head unit, they have better (higher) response than factory stereos. But CDs sound great. :~)
My friend who owns a stereo shop says that to get significant upgrade from factory stereos it often runs $600 or more ($200 for the head unit, $250 for 4 speakers + install (not including an amp)) but a head unit makes a big difference and there is always christmas for speakers (for your wife!)
hope the long post helps.
Steve-V
Before everyone starts yelling at me, it was 6 in the morning, no one on the road (I'm pretty far out west past civilization) and once in a while you just have to let this baby CRANK! As soon as it hit that speed, I immediately slowed back down to 70 mph, and let the adrenaline slowly exit my system. The car is just so smooth, even at that speed.
And- I'm glad you didn't have to drive to DC!
David
HomeDepot sells gallon size jugs of it....you buy a gallon and fill a generic pump spray bottle...makes for very handy engine/wheel/bicycle drive train....etc. cleaner!
-r
I have the subwoofer in my 01 Bean and I love it...it really brings out the nice deep base you miss out on with the regular speakers. I also have the 6-CD changer....love that as well!
BTW look on the rear most pillars...see those little grilles?...those are rear tweeters for the rear speakers!
-r
Hope this helps,
Steve
As regards aftermarket head units, JVC, Clarion. Pioneer, and Kenwood, all make combined am/fm cassette/cd units that are a direct fit in Subarus I also have the Subaru subwoofer and am very happy with it.
Cheers Pat.
Craig
Go to subaru-parts.com There you will find the installation instructions for the Subwoofer...pretty simple install.
-r
I'm not an audiophile either, but the single CD and the tweeter kit seems just fine for me. It delivers what you're looking for, good clear sound. You won't get the booming bass, but to me, it's just fine. My .02
David
BTW. Subarus factory unit is rated at 80 watts output into 4 speakers, not a lot, but then not too long ago the output on factory units was about 10 watts total.
cheers Pat.
The factory setup isn't bad however. In fact, I think it sounds pretty good. The tweeters helped - you'll notice that difference easily.
-Brian
Chris, it definitely makes a more competitive case (in terms of dollars) if you order the CD player online and install the CD player yourself. It comes with instructions, and is pretty easy to do. A number of folks here have done it, and we can offer help or advice on the install.
OK, back to the Bean! I can't believe how awesome that H6 is! What a sweet engine. Makes me think it's one of the best kept secrets in the auto industry, maybe in the whole world. I appreciated the rumble of the H4, but the H6 has it's own wonderful tune. Very refined, and almost soothing to my mechanical engineering ears.
I always thought the Bean and VDC were overpriced. That was from the standpoint of owning a base Outback, which I consider to be one of the best bargains around. All it took was a little cross shopping against a vehicle like the Acura MDX to make me realize how awesome the H6 wagons are. Subaru should go out and try to snag more of the customers in the high-end crowd; I really think the H6 wagons can hold their own against the big boys. As for a cheapskate like me, I feel like I got a luxury car with all the capabilities of my previous Outback. Definitely one of the best cars I have ever driven!
Craig
We have two concerns.
Its tires, Bridgestone Potenza RE 92, made the Not Recommended list in the 2001 Lemon-Aid New Car Guide. We had asked the salesman about them and he assured us Subaru only used top quality tires. Apparently not. We are a little worried here.
Also the heated seats smell a bit like rotten eggs. Will this go away soon??
P.S to Patti
Subaru Canada does not have a Mobil-It-Ease program. C'est la vie.
Sorry, couldn't resist...
K&N does make a filter for the 2.5 H4... I had the part number, but can't find it now. Ought to be readily available, perhaps at the K&N website.
Cheers!
Paul
The RE92s are not great tires, but I wouldn't replace them until they wore out. Our 626 had them and they were OK, just not the performance tires that I think the GT is worthy of. They are V-rated and carry the best heat resistance rating there is ("A").
You are describing Subaru's new car smell. It's the undercoating burning off the exhaust, and thankfully it goes away. Stinks, doesn't it?
-juice
juice - typing one handed is an important skill that you need when you have a sleeping toddler on your chest - and you need to keep up with the boards.
steve-v
This coming from someone who has had six Honda Accords and two Civics is high praise indeed.
Take everything that the Lemonaid cans with a grain of salt,If you have a look at the car recommendations he says the only thing to recommend the legacy is the all wheel drive otherwise it is an overpriced average car.
Until recent years he was still saying that the Honda Accord was not a great car, this is the opposite of just about anybody else in the world who wring out cars for a living.
Cheers Pat.
P. S. - Since it was my mistake, send in the receipt for the modifications to my attention. It is Subaru of America, Inc. P. O. Box 6000, Cherry Hill, NJ 08034
Patti
Cheers!
25-26 MPG is excellent, especially during break-in. I never got better than 24 MPG in mixed driving, and ocassionally hit 27-28 on long trips even after the car was broken in.
I think you can pretty much enjoy yourself with the engine now. Of course, there's not a whole lot going on north of about 4800RPM other than noise. Yes the engine will continue pulling strong, but I think the best part of the H4/5-spd combo is the grunt (and rumble) you get at lower revs. Subaru really improved this on the H4 in the current generation Outback -- there's just a whole lot of power down there now.
Craig
thanks,
Craig
-juice
I too have asked the same question about the ECON setting on the A/C...I got no real specific answers..just some guesses as to what it does. I am wondering if setting it to ECON changes how often the compressor kicks in...if so, and, if it is still able to maintain the desired temp, then why isn't econ the default setting? Unless, it isn't able to keep the desired temp setting in which case why have it as an option?
BTW I believe that when you turn the A/C on full Auto, if it is showing the a/c symbol then yes, it is running the compressor (that should be easy to verify by looking at the clutch on the compressor).
See, now I am guessing! Sorry, no conclusive answers here!
-r
-mike
> "P. S. - Since it was my mistake, send in the receipt for the modifications to my attention."
