Visitor Agreement.
I was traveling north on TSP through Putnam. The parkway had just been heavily salted with big chunks of rock salt (sounded like little stone pebbles hitting the windshield @ 70mph). Once I got off the parkway in Dutchess, my brakes stuck every time I came to a complete stop. I mean stuck! If I kept the wheels moving a little (inches) at a red light they didn't stick - once I stopped completely they became stuck.
Anyway, I got to my destination (~10 miles) and when I started up again after a couple hours it was gone. I figure it was the heavy salt, but I never had that happen with any other car. (I'm also VERY sensitive about these brakes. I had them re-surfaced at 10K miles (again, for free) because of warping.) They don't seem to like being asked to stop a 3700+lb. car going 80 mph off an exit ramp on a regular basis... :-o
I must slow down, but I like plowing around in my little black tank...
Ralph
I don't know what to tell you about the sticking brakes...that is weird.
As for the warped rotors. I had my dealer replace them under warranty and I suggest you do the same. Once rotors are cut down they are more prone to warping. I wouldn't worry so much about the affect of the salt on them (except of course if you lock up and keep moving). I would be more worried about what caused them to warp in the first place. Normally that is caused by running supper hot rotors through a cold puddle of water, but more commonly it can be caused by a wheel that is over torqued. My Honda was, and my Bean apparantly is, very sensitive to the torque of the wheel nuts. The correct torque is 70ftlbs. If the machanics use the air wrench to seat the nuts and then use a torque wrench to verify, by then the nuts are way tighter than the need to be. I insist they hand tighten the nuts before using the torque wrench.
Bottom line is, the rotors are covered for 36000mi. Get the rotors replaced so you don't have to deal with them again. They should replace rotors and pads at the same time.
-r
-juice
Greg
I 'made contact' with Lyn earlier this evening. Just went to 'callup' on VM, typed in Lyn / Subaru / Postmodern, and she popped right up!!! Well not really, but it makes for a good story.
Ralph, sorry to hear about your father. I bet he is much happier now that he is out.... (only kidding). It is really a decent place to work.
We should post on 'Meet the Members' and see who else is out there. Must be a bunch of Subaru owner up in BVT.
Steve
I am currently on my second rodeo with a lease that ends soon. I'm contemplating going with an Outback LLBean...I have not test drove yet. There is no particular reason why I might not get another Rodeo, I've had no problems over the past 6 years with 2 different vehicles.
My question is, what are your opinions on what I would gain or lose going with the Outback. We are a family of 4(2 kids 7,5). I live in RI, and Winter's have been mild the last few years, and I don't need the off road capabilities of a 4WD. I do like sitting up high and was wondering how high you are up in the outback(similiar to rodeo?) Also, any financing deals, rebates, or lease deals going on?
If you want to stay in the Isuzu family, I'd go with the Axiom, because it has full-time AWD which is better for on-road situations than the PT system of the Rodeo.
The ride in the H6 outback will be superior to the Rodeo for sure, much more car like and handling will be improved as well.
Cargo capacity will drop significantly, especially with the rear sloped window of the outback. Height will also drop way down. Gas milage will jump up even with the H6 over the rodeo. Warranty will drop (3/36 and 5/60 v. 3/50 and 10/120). Lease deals will be better than Isuzus. Financing will be significantly worse since Isuzu has lots of incentives and 0% financing often.
I'd personally go with an Axiom, only because of the space/towing/height issues. If gas and handling are more your cup of tea then go with the subie. They are both pretty bulletproff vehicles as far as reliability and I'd give the "hardiness" a slight advantage to the framed isuzus.
-mike
You get full-time 4WD (AWD) which is excellent year-round—rain, snow, gravel, dry roads; and the excellent on-road ride and handling of a good sport sedan (or wagon).
No, you don't sit up as high as you do in a traditional SUV.
Bob
Greg
The OEM Michelin MXV4's on my 91 Accord were notoriously bad (I believe there might even have been a recall in the early 90's regarding this?). My 99 Civic also shocked the hell out of me every time I got out until I switched the OEM Firestones for from Potenza RE910's, which seemed to decrease the charge.
My 01 Outback has shocked me a few times, but not too bad.
It must be something to do with the cloth seats and the friction between one's bum and the seat as one gets out. Either there is more twisting/sliding about because of the height of the seat from the ground or the nature of the fabric itself is contributing to this. The only time it doesn't happen is now, during the winter monsoons, when the humidity is about 95%.
Some of my previous cars had cloth and some had vinyl. Both my daughters' cars have cloth. They are/were 10 years old or more. But none of them shocked me.
I wonder if leather seats are better in this regard.
You can also hold the keys in your hand and touch the metal with your key - the key gets the shock, not you.
AFAIK, it's related to the tires. My Z71 did it a lot more than our '00 Outback does. Some of those shocks can hurt!
-Brian
Lunch is a great idea! Any day should be ok except Monday. Where do you park for B/650? The only Winestone OB I've seen in the East lot is a sedan equiped with spoiler.
-Lyn
That will work!
People may also try one of those antistatic sprays for clothing. Spraying your clothing with it or, possibly, the seats should eliminate the shocking behavior! :-)
tidester
SUVs
-mike
I fear it has far less romance than the woderful suggestions about tyres etc. IT usually has to do with the charge built up between different materials, particularly woollen and synthetic fabrics, during dry air conditions. It tends to be more obvious during su-zero conditions where most of the moisture has frozen out of the air.
It is much more common in cars with fabric seats (my Merc was lethal for it) or synthetic carpets.
One partial fix is to grab a used sheet of Bounce and rub it over the fabric. The primary function of fabric conditioners like Bounce is to take the static out of things.
Cheers
Graham
Rodeo vs. LL Bean: if you plan to lease again, the warranty won't be much of an issue. The Rodeo will probably cost less, but price out and drive both, and then pick the one that feels right to you. The LL Bean may have lower operating costs (fuel and insurance) that offset the higher lease payment, I'm not really sure.
Troopers are being discounted to a point that their price is lower than the Axioms and close to the Rodeo, so also consider that for the extra room you may desire with those kids. Like paisan said, I'd pick full-time TOD over part-time 4WD any day.
-juice
My Forester has the same problem, but usually it's because the rubber cargo area protector slides back and sort of interferes.
-juice
On reinstall, I had a bit of trouble putting the upper trim panel in. Didn't seem to want to snap back in and after several attempts it went in easy. I wished I'd paid very close attention to exactly what the trim panel alignment at it's top edge was - you should. I think the resistance was the vent tube not aligning correctly into the dash tubes.
-Mike
Steve
(OC-1, C-1, OC-2, K, IK, whatever....)
If it is the mat, try putting Velcro under it, secured on the centre lift-up section, to keep it in place
Cheers
Graham
Re: the hatch: my new Bean and my older Outback (now my Dad's) are the same way -- the hatch can shut and latch but still be open. I also found that it was usually due to the rubber mat getting in the way. The mat doesn't have to be very far back for it to interfere with the hatch -- it sticks up enough to block the interior panel, which in turn keeps the hatch from completely closing.
A few other times, I noticed that my wife hadn't closed the hatch hard enough, and the light stayed on. Otherwise, you couldn't tell. If none of that works, the dealer can easily adjust it for you.
Craig
-mike
Steve
Steve
David
-mike
Eric
-juice
-mike
There are some towing topics here in the Town Hall where trailer brakes (add-on kits) are discussed. With those you ought to be fine.
-juice
Craig
-mike
I bet the auto is better suited for towing.
-juice
That is, can the ac be turned off during manual mode. It seems that the ac turns on briefly when choosing the mode, which can't be good.
Also, we want to tint the rear windows, and I wonder if window tinting may affect the frameless window seal..... Anyone have experience with this?
And, anyone have the Bridgestone Potenza's in snow?
We use Nokian Hakkapaliita's for snow usually, and they are the best. If the stock tires are ok, I would love to save $500.
Thanks....
-juice
Steve
If you start off in full auto mode, the temperature is the only setting you can change without forcing it into semi-auto. Once you hit the AC, fan speed, or vent mode button, the system gives you manual control over that particular mode, but maintains auto on all the other settings (hence my semi-auto label). As you fiddle with more settings, the system relinquishes its auto control. If you twiddle with all the settings, the system will finally go into full manual mode.
I usually turn on the system by hitting "auto" once or twice (2 times puts you in econ mode which cycles the AC compressor less). If the AC light comes on (depending on the ambient temp) and it's cold and dry outside, I immediately hit the AC button to turn it off. Then, the system will have auto control over the mode and fan speed (to maintain the desired temp you set) without the AC running (again, not an issue in cold weather).
I usually end up setting the fan speed and mode manually, so the only thing the climate control system does is try to maintain the temp I set.
One other thing -- though it is not documented, you can put the system in a fan-off ventilation mode by hitting the OFF button, and then selecting a vent mode. You can also change to fresh or re-circ in the ventilation mode. Whatever temp setting was dialed in before you hit OFF will govern how much the vent air is heated. If you just want a cold vent, turn the temp down to 65 before hitting OFF.
Craig
-mike
Having towed about 8,000 km so far, my opinion is that the weak spot for towing is probably the clutch. Hill starts or slow speed manouvering such as backing up an incline with the necessary deliberate clutch slip can make the clutch smell mightily. Others have complained about this.
I have driven dozens of standards since 1964 and have much experience of juddering, slipping, falling-apart clutches, but have never experienced that burning clutch smell unless dishing out extreme abuse of the most foolhardy kind. The OB seems to do it quite easily.
-mike
