My '98 OB does shut-off lights and accessories momentarily when starting up the engine.
-Dave
Other OB owners: do your headlights "cut-out" during starting or not? If I find that everybody's OBs do, then maybe I'll ask over on the Forester forum to see if this is just something that's peculiar to Foresters or maybe just my Forester.
Thanx
--'rocco
-Dave
-mike
I never even knew it had a sensor up front until I drove into the sunset one evening, which caused the mirror to change tint.
Craig
-mike
2" has many better options for load carriers, also you can get a cush-receiver, one that has dampening mechanism inside for a smoother towing experience. (sounds like an ad)
As for the bumper fasia, I did not have to cut any for the GT wrap-under cover with a draw-tite (u-haul) hitch.
good luck
steve-v
Greg
I took it into the dealer, quite concerned, but no damage was done. They did need to adjust the parking brake (no charge) and you should have this checked.
Unless you are into handbrake turns ;-)
there is little or no wear to worry about with a parking brake.
Tom
Thanks for the info. After reading your experience, I'll think give up on installing a trailer hitch. Next time, I'll get the Outback.
chuck
Don't give up on the trailer towing just yet.
Steve V (mortpeaberry), I agree with you in not understanding the Subaru Parts Guy's comment on the converter interacting with the ABS system. I just can't see how the brake and taillights will feed data BACK to the ABS. In fact, they should be completely independent. Taillights illuminate when the lights are turned on, brake lights illuminate when the brake pedal is depressed. Whether or not the ABS works with the actuation of the brakes does is not affected by the lights.
All the converter is doing for you is converting the "European" independent turn and brake taillights (bright red brake and amber turn) into the old style "American" combined (bright red shared by brake and turn signals) that are probably on your trailer.
I admit I'm not the last word on this subject, but I have a VERY strong suspicion that the Subaru is just like any other car in this regard. Double-check with a hitch installation place, and I'm sure that there are other experienced trailer towers reading this forum.
Good luck,
Steve in So Cal
As for the heated seats, the heating elements (blanket) just installs in the factory seats. The wiring is in the car already. Laf.
-Mike
-mike
Well it was not a bad experience, I did get to know my car, it just took 2 months to find the time to wire the lights. It took an hour to do the hitch and in between I went sailing half a dozen times (the harbor is 2 miles away - I made sure that I was home By dark) The subaru is a GREAT lighter duty tow vehicle. I just thought it was real weird that vehicles that share the same platform, with minor differences would not use the same harness.
If you don't feel like doing it yourself, just make sure the hitch place does a clean job (often this makes me more nervous - maybe a high end car stereo installer can do the wiring ("Yeah, I'm going to put a jillion watt amp in the tire well..."))
Life is an adventure (On your tombstone will be two dates, and all your friends will read 'em, All that matters is the little dash between 'em - some C/W song)
Steve-V
So they'll have to splice, I believe. But that's included in the price of the install, usually. For the price of the OE kit, you can get a Draw-Tite or a Hidden Hitch installed.
It's only rated to tow Class I, so a 1.25" receiver is usually what comes with those. A 2" receiver is more universal, but keep in mind you still have a 200 lbs tongue limit and Class I ratings, so don't go overboard. There are adapters that convert from one to the other and vice-versa.
It's actually a torx-driver for the roof rack. :-)
-juice
Just thought I'd run a poll of my fellow OBers. How many of you use your fog lights as a matter of course; you put them on automatically at night with your headlights regardless of the weather?
I don't, but wonder how many of you do?
David
-mike
Bob
The few times I have driven through dense fog at night, the "foglights" didn't do a damn bit of good because the regular headlights reflected back so much. I'd rather see a good set of driving lights installed with a narrow beam that goes beyond the normal low beams or at least have the existing fogs wired to come on with the parking lights rather than the headlights. Oh well...it's just a fashion accessory anyway...
You might look at http://www.alldatadiy.com/ for an alternative to regular shop manuals.
To be honest, I'd rather use my high beams in the fog. They're not great either, but I prefer them to fog lights.
Bob
[Just kidding :^)]
-juice
If there was a simple way to rewire them to allow them on without headlights I would do so, but believe in California its probably illegal to have fogs on without headlights! What's a body to do?
Converters - thanks for the update. The idea of a powered converter did cross my mind, but I've never come across one.
Steve
His point was that they illuminate the area immediately in front of the vehicle, reducing the ability and inclination to see WAY down the road... where the driver should be looking. Unless traveling very, VERY slowly, in heavy fog, fog lights are worse than useless.
Having said that, I must confess that I used to install auxiliary lights on my cars because I thought they "looked cool". I got over it.
-James
I agree - they don't seem to make a difference in what you see past the bumper.
-Brian
Bob
Ron
I wouldn't call the Outback's aux lighting fog lights either -- to me, they are driving lights. In my book, fogs would be independent of the headlights and have an amber/orange lens.
Craig
Citroen made a maseratti-powered model, the SM, back in the seventies, that had "steerable" lights that moved in concert with the front wheels. I believe that U.S. gov't regulations now prohibit such innovations.
-James
Thank you for taking the time to contact us. No, the trailer hitch available for the Outback is not applicable to your '00 Legacy L Wagon
nor is there a wiring harness within your vehicle. You would need to purchase
the trailer hitch and wiring harness from a professional Hitch Supplier or
local Auto Supplier. Best wishes!!
John J. Mergen
Subaru of America, Inc.
I find that using high beams in a fog produces a lot of backscatter and washes everything out so I can see nothing but bright fog.
tidester
SUVs
Got and used auxilaries instead.
-Dave
edited: I'll admit, if I didn't aim the auxilary properly, it'll glare hell to broad daylight.
True, but I can still generally see further down the road than with fog lights. If the idea behind fog lights is to keep your speed down in the fog—granted, a good idea—then fog lights are way to go. I find myself over-driving (going too fast) the fog lights. If you keep your speeds under 25 mph, they're fine.
Bob
Could use some sage advice and/or solution.
Thanks-John
-mike
Best lights I had were some custom long-range pencil beams that I had on my Audi in Norway. They would only work with the high beams (had a toggle switch on the dash), and were a real asset in a country that turned pitch black a few miles outside of Oslo - with some pretty crummy roads and steep drop-offs to boot. Almost everyone had extra lights - white, amber, pencil-beam - whatever (some had them all!).
Ken in (rainy) Seattle
Ross
tom
If the Legacy 6 isn't showing up for 2003, I like to get one for the '98 OB, and the Hella Xenon Comet to go with it :-D
-Dave
Craig
The Bean is a fantastic, quiet car with what I think is one of the nicest looking interiors on the market. Strangely, our other choice was a Jaguar x-type. I believe the interiors are comparable.
ecb@iace.com is the address
-mike
