C'mon, they deserve it, and it's good exercise. OCD Club members find it soothing. ;-)
-juice
-mike
-mike
I think the car wash chains may have the system that pulls you through but I'm too cheap to use those! I had wash our Subie and run the POS Saturn through the car wash.
Steve
Has anyone installed either hitch? How was install and appearance?
Chris
You'll need a wiring adaptor too, it includes some sort of relay. It plugs right in to the OEM wiring harness (located behind the passenger-side interior trim panel in the rear compartment).
Q rated should be fine for snow tires. The Q is a speed rating, really a rating of resistance to heat build up at high speeds. But you drive with snow tires in cold weather, so tire temps are much lower. Q is fine.
But I would stick with 225s, because 215s will lose you some critical-in-winter ground clearance. When snow accumulates, you'll be happy not to bottom out or scrape ice and slush.
-juice
Anyway, any new on up and coming Outbacks? Mine is a 00, nearing 3 years old, and I will be looking for a new vehicle in latter part of 2003.
Luck 11.
The STi will be hard to find, but hyper-powerful and fun.
The Forester is rumored to get a 2.5l turbo. Lots of speculation about this motor, actually. At first I thought it would get the 2.0l 217hp version from the JDM. But reports insist it'll be 2.5l.
So then will it be a turbo version of the EJ25? Some rumors on i-club say no - it would be hard to manage cooling with the large bore of those cylinders. That led to another conspiracy theory - a de-bored version of the EZ30 H6 engine, displacing maybe 2.5l, with a turbo.
Can you imagine, a turbo H6?
-juice
I have run Q rated blizzaks and arctic alpins on my legacies for just over 10 years now, no problems at all unless you want to drive like a madman in winter!
Anyhow, regarding tires and the speedo. What matters is the overall tire diameter, not the width (205, 215, etc). If you're moving from a 215/60 for instance, you can get a 205/70 that's the same size (I'm guessing, but you can go to TireRack's website and look under your current tire's specs, then go to the tire you want in a 205 and see what aspect ratio (65, 70, 75) you'll need to preserve the same diameter. The diameters are all there in the spec section. You can also do the math yourself, but this is easier.
So, simply get the proper taller sidewalls and narrower tread to preserve the speedo accuracy. You can expect a bit less precision in handling due to the taller sidewalls and the softer winter compound, but today's winter tires are worlds better than the snow tires of old for handling.
IdahoDoug
Jon
You may also want to check out our ongoing Subaru Crew - General Maintenance & Repair and Legacy/Outback Wagons - Problems & Solutions discussions. Good luck, and please keep us posted on your ownership experience. ;-)
Revka
Hatchbacks & Wagons Boards
I'm not sure if they make those sizes, though.
Use this tire size calculator if you're trying to decide what size to get:
http://www.miata.net/garage/tirecalc.html
Congrats, hashman. Time to update your profile, which says you still drive a Buick.
The brakes have a dual stage booster that take some getting used to. It's soft at first, for smooth stops, then the 2nd one kicks in for max braking power. The stopping distances are very good, though.
Do get the alignment, but have them inspect your brake rotors too. They could be warped if it pulls to one side while braking.
-juice
Does anyone know where I can't order some plastic cladding for the back door? Don’t laugh but my wife backs our 2001 Outback into my truck and knock off the plastic on the bottom of the back door. I was thinking of just put the old one back on but there are too many creaks in it.
Ray
Purchased: May 31, 2002
Just had: My 7500 mi. dealer service
Gotta go!
I was there for 30 hours before returning. Spent under $200 for gas and eats vs a flight that would have been $550 and required a rental car and airport parking for a total over $650.
Great trip, clear weather and little wind the entire trip. The only "event" was a startling bird hit on the roof's front edge at 3am on the way home that scared the crap out of me. I flinched at seeing it, then the impact right above my head sounded like it dented the metal. No damage.
IdahoDoug
Alland
The topic has been beaten to death, but hasn't gone away. As it gets colder up here in Wisconsin, the cold clutch shudder on my '02 base is getting worse - to the point I no longer look forward to driving it. The dealer, zone, and 1-800 Subaru customer service all acknowledge a problem; I even have a case number.
But no one can tell me when they expect a fix for this. I also have a Miata. Mazda has a TSB for this - they replace all the clutch components with updated part #'s. So far the Miata is fine. If Mazda can do it, why can't Subaru???
Any strategies for prodding SOA into action? Or just live with it, and be patient? BTW, just turned 6k miles, and love the car otherwise, but this clutch thing is spoiling my experience.
David
I called the 1-800 number last year and started a case file, but there has not yet been a resolution. I need to call again and see if they will send someone out to look at it...my dealer is totally apathetic to the situation. I was in yesterday and brought it up again and the service tech told me there was nothing they would do now that the car has almost 40K on it...even though the problem was documented since the car was new, and in spite of the 60K powertrain warranty and the 100K extended warranty I have. I just shook my head and left.
Good luck, and start saving your pennies to go buy an aftermarket clutch. I'm to the point of shelling out about $600 to have a non-subaru clutch put in to see if it helps the situation.
Doug: now that's a road trip. I just went to the beach and back, about 150 miles each way.
Alland: not bad at all for a 6 cylinder AWD. In fact that's about 50% better than the average SUV.
Dave: I didn't realize Miatas had this problem, my '93 is fine (original). I guess some do, some don't?
If yours is an '02, it may have all the latest part numbers. I wish I could help more.
FYI: Ludespeed's clutch is $460 for parts, but that is designed to withstand even turbo applications.
-juice
My dealer and the 1-800 folks have acknowledged there is a problem, and they say they're working on a fix. Before settling for an aftermarket clutch, call the 800 number and have them update your case. With a documented 'in warranty' complaint, they should fix it (as soon as they have a fix). The zone can force your dealer to take care of it for you.
ateixeira -
My Miata is an '02. The TSB is for '01's and '02's within a specific VIN range. Mine is in it, but (so far) the clutch is fine. I wish SOA would be as proactive in satisfying their 5-speed customers.
David
-juice
The NE is generally a pretty good market for them.
The frameless doors are fine. The M3 and 911 use them, too. Look closely and you'll find they are double sealed, so even if water gets by the first seal, there is a channel to let the water drain out. My 1300psi pressure washer has never caused a leak.
Not many people have complained about sagging doors, maybe it's just an abused rental?
Any Subaru radio will fit, and you'll find plenty of 6CD changers on E-bay for $250 or less. I bought two, so both our Subies have a cassette AND a 6CD in-dash, hard to beat.
Both our Forester and our Legacy average 25 mpg overall, and neither one broke the $20k price barrier.
-juice
I forgot to mention that I got about 24 mpg over several hundred miles, which is of course better than the 16 I get in the Tahoe (that's in 2WD mode) and the 20 or so I get in the supercharged Bonnie (it should be a few points higher, but for some reason it isn't).
As far as the window seals, I think about GM products like the Eldorado that have traditionally had problems, but if the Subaru can withstand 1300 psi I guess that's pretty good. But what about when it's zero degrees out and the seals are rock solid?
I just traded off a problematic 2002 Olds Bravada(hence my login name) for a 2003 LLBean Outback Wagon. I know I can trust Subura for AWD. I have owned a Forrester and GL Wagon in the past. The GL had that pull up lever in the center console that would lock in the 4WD...it would pull like a tractor...a small tractor that is in 4WDlo. That Olds SmartTrac system sucks. I gave the the group a going over about AWD before I signed off..some of the folks joined in and agreed with me that Subaru is the king of AWD.
The triplet town hall site (Trailblazer, Bravada, Envoy) is filled with horror stories about these vehicles.
'Getting used to the smaller surrounds in the Outback but almost all the goodies as the Olds...and they work.
I like the dual moon roofs. The rear spoiler does create some wind noise...or is it the roof rack rails. The use of 91 octane gas caught me by surprise.
The 3.0L engine is great....much more pep up to 40mph, but not a race car in passing on the interstate.
That's my story...I need to change my login name to make it more Subaru related.
I know GM owns ~20% of Fuji Heavy Industries. I hope their influence does not compromise the Subaru quality. This Olds Bravada experience has left me negative on GM products. I should of known better....my first car at age 16 was a Chevy Vega.
SubieJon...I'll try that
So tell us more 'bout your new pride and joy.
Colour? Any nice goodies?...
-Dave
-mike
Also talked a little about the infamous Sube clutch shudder some people have had, he said he had seen some flywheels which needed replacing which fixed the problem.
-mike
Sharon: do you have a moonroof? Maybe the drains are clogged.
Subiejon: welcome back to the Subaru fold. Nice to hear Subaru's AWD is superior even to systems in much costlier trucks.
I've sampled a Rendezvous, and wonder if that's the same SmartTrak system. Thing is - it feels like FWD, and works like FWD 99% of the time. I want power to both axles all the time, true full-time AWD.
You can use 87 octane with the H6, it'll just make 208hp instead of 212hp. The knock sensor retards timing automatically, if necessary.
You and me both (about GM not having too much influence on Subaru). I hope GM provides the capital and maybe, just maybe, the purchasing network.
paisan: your tranny probably won't blow now that you've installed a tranny cooler. Though as quick as you drive, all bets are off!
-juice
Hopefully I'll be giving the WRXs a run for their $
-mike
Jeff
Congrats. Those must've been highway miles, unless the previous owner used it as a taxi! ;-)
Jeff: we have a Wintergreen Legacy L, in fact it's not two-tone so we have about twice as much of that color paint as you. I haven't notice anything (we bought it in May), nor have I heard anything from others (I asked how others liked the color before I purchased it).
I actually like the color a lot, it's easy to clean, and never looks dirty. I wash my Acadia Green Forester and the Legacy on the same day, and a week later the Forester looks filthy, while the wife's car still looks clean. No regrets.
You think the previous owners might have buffed the finish a little too hard? Or gone through too many car washes with brushes?
-juice
Any suggestions on how to minimize any further crazing?
Cheers,
Jeff
-juice
I can feel them with my fingernail, but they are not visible from afar. Each time I wax the car, which is about every 2 months, it seems like the cancer is spreading. I don't know if it's the clearcoat or if the flaws go all the way down, but I'm starting to get concerned.
Also, has anyone's plasti-chrome grilles started flaking off? Mine started bubbling last year and is getting worse...I think this winter will do it in and the "chrome" will flake off the grill. It, too, is spreading...it started in one little bubble on the grill and has spread to most of the lower horizontal part of the grill. Just bubbles now, but will likely get worse.
I think I'd like the Legacy L grill on mine if I replace it...the black looks better to me than chrome anyway! If the extended warranty covers this, I'll be surprised...
You can paint the chrome grille, one of the Crew members did that and I actually kind of liked it in the flat black he used.
-juice
Juice: No accidents listed on the title search and no evidence of repainting. Far as I can tell the car is clean.
Jeff
I had some "crazing" on my repainted Escort, a couple of years after an accident. The clear coat eventually peeled.
The car was totalled before I went back to the body shop, which may or may not have done anything about it.
-juice
My dealer has been totally apathetic about every problem this car has had (faulty clutch, 2 new window regulators, etc) that I have no faith that they would even care about the paint. "They're all like that" is what I can expect to hear!
I thought about letting an independent paint shop look at it to diagnose the situation -- I can live with crazing (or whatever this is) as long as the paint doesn't start coming off or rusting. Now that I see I'm not alone with this, I may take it in to get looked at and I'll keep you posted.
Brian
I'm also planning to go to a local body shop to see if they have any suggestions. If I find out anything I'll post it here.
Jeff
