Visitor Agreement.
Cheers!
Paul
newbie: my guess is the dealer just had more Beans in stock, or that they know those are good values and you're more likely to buy them. VDC would be better in the snow because both axles are managed, vs. just the rear axle on the Bean.
-juice
Craig
* H6 with its "butter smooth" 212 Horses
* Automatic Climate Control
* Interior Air Filtration
* Leather Wrapped Wheel
* Color keyed mirrors and door handles
Am I missing any other differences?
- Lou
I'm buying tomorrow and want to know what the real invoice is before I drive the 50 miles down to the dealerships. I don't have a fax machine to get a copy from the dealer so I'm hoping someone on this list is in the know!!!!!!!
Thanks a bunch.
The invoice I have from a dealer this weekend puts the LL Bean @ $27,349.
Hope this helps!
Good Luck in getting the beaner!
Subaru has actually stated that the H6 makes 208hp on 87 octane, so I'm sure you could use it.
I don't like the premium requirement either, but someone pointed out to me that it only adds up to $145 per year, or $2.79 per week. Brown bag one lunch per week and you come out ahead.
-juice
Bill
-mike
-mike
-Dave
--jay (the other one)
(jays are making a week attempt to crack into the number of Daves and Ks in the group...)
-juice
Any advice on what else to look for or what actions should be taken would be appreciated.
Do have rental that dealer is paying for very concerned about car.
Thanks Mike
Hissing sound?
Coolant in oil?
Poor performance?
Bad smell?
Loud engine sound?
Just curious as to a common failure point and what symptom(s) to look for on the Sube. Also curious if it's a leak to the 'inside' or 'outside' of the engine.
I've had head gasket failure on 3 other vehicles (not Subaru's) and the each one showed different symptoms.
My 2001 is leaking on garage floor and bad smell of antifreeze
mike
Subaru does cover them under the 5/60 warranty, and maybe even if you're a little outside that mileage.
-juice
My 2000 OBW with ~41K miles is at the dealer now for the head gasket. (See my post at Legacy/Outback Wagons Problems & Solutions (Wagons) #1224 ). The symptom I was having was a burning smell. My dealer mentioned they have had a few in for the same problem.
Let us know how it goes.
Mark
Never the same and minimal
Just wondering
Changed the plugs on my 2K H4 yesterday (first time, just shy of 30K), along with the air filter (second change). Pondered this job awhile, never having had a Subie before with its "outboard" plug locations - but decided to give it a whirl. Bottom line - no problem, and the next time, could probably do it in around 30 minutes (took about twice that time yesterday as I scoped things out and took extra care).
Tools needed: 3/8" drive rachet, 6" extension, 10" extension, 5/8" plug socket (7/8" max OD), 10 and 12 mm sockets, gapped plugs.
Right-side plugs: remove the black ducting obstructing the plugs. Remove a couple of obvious hold-down screws (10 and 12 mm) and the rest just pops apart by hand. I expected the plug boots to be tough to get off, and was not disappointed - just a bit more pulling and wiggling than average does the trick. I was surprised by the deep sleeve in the engine to access the plug - hence the 6" extension. Shorter won't reach - much longer might not fit in the work space. Also, the 7/8" OD on the plug socket didn't leave much extra space in that sleeve.
Left side plugs require removing the windshield washer reservoir (two screws on the strut tower, unplug the two washer motor motors, unhook the reservoir from the battery cable and windshield line, and pull off the two washer lines from the base of the reservoir - then wiggle the thing out. If I'd thought about it earlier, I'd have let the reservoir get pretty empty. You could always siphon it out - I just let it dribble a bit then dumped it out the top refill hole into a clean bucket.
Both these exercises make the plugs easily accessible, which had been the major question I had. Considering that most "tune-ups" consist of not much more than a plug swap and inspections (for $59.99?), just wanted to give the do-it-yourselfers some encouragement.
Ken in "$2 gas" Seattle
Same here, Ken, thanks for sharing the tips with the community, hopefully we can pay you back some time.
-juice
Jim
Steve
We are really enjoying our Outback. We've had a lot of snow here in Arkansas this week, and it has been nice not to be stuck at home. Once I was even behind a Jeep that had trouble getting up a small hill. But our OB went up without any slips at all. It was wonderful.
But, our gas mileage is not so great. We are getting 19.3 mpg in all city driving. The brochure for the OB suggest we should expect closer to 22, so this is a bit of an unpleasant surprise.
The only thing I could think of checking was the tire pressure. It looks like it is 30 psi all the way around. Is this too low? It is what is written on the door sticker. What else should I check? How else can I get the gas mileage up?
TIA,
Tamara
My mileage statistics for our Outback show 18-20 city mpg in the SE Wisconsin winters. That changes to 21-22 city mpg in the summer.
FWIW, YMMV ;-)
-Brian
B
I have gotten 28mpg on a highway trip once, but typically my Outback gets short city miles (except on the weekends ;-).
-Brian
Sorry to hear of the head gasket problems some are experiencing. Symptons do vary, I had a Buick that only showed that the antifreeze was always being used use din the reserve tank. The key that got me was milky gunk in the cylinder cover. Never got it fixed but the car had 100K miles at the time.
Two things with the subaru now: Check engine came on and I noticed from the manual that a tighten gas cap may be at fault. Sure enough, it was not tight. Light went out after several days just as the manual states may happen. Now the brake comes on intermittently which may be the need for new brakes. Car has 25K on it.
-mike
I too have been keeping track of the mileage, and it has been around the same level as the 2 Brians and yourself. I have gotten approx. 18-21 in the city and 23-25 on the highway. I do notice that in the winter it is lower, but I believe that is due to the oxygenated fuel as mentioned above.
Mark
The last couple weeks have been well below average - about 20-21 mpg due to oxygenated gas and very low temps in the Chicago metro area.
A friend at work is getting 9 mpg in his Navigator, LOL!
-juice
Brian
-juice
According to the sales guy, the H6 Outback won't be available until around August of this year, possibly as my2004 car, and will be special-order only. I would welcome any news to the contrary. Even better news would be if it were to be available in the Legacy GT.
But I guess I should wait for the 2005 Legacy redesign. 2005, right?
-juice
I know this isn't the Future Models thread, but I'm waiting for a 2.5T in a Legacy as well. I've read that we may get the redesigned Legacy later this summer or early fall as an '04 (I can only hope). I guess I figure the more I talk about it the more likely it will come true.
FWIW, over on the NASIOC boards Paul Hansen of www.apexjapan.com has posted that they've quit taking orders for the current Legacy's.
-Ian
I'm going. :-)
-juice
-Ian
