Ray
On my wife's 03 Forester with auto trans, you can't do that trick -- the DRLs come on anytime you take the transmission out of Park.
Craig
Message 9461 has been posted across more than 25 boards by tudor. Suggest usual response of deafening silence until the Hosts catch up.
Cheers
Graham
Nice rant, though - made my Saturday morning.
Christmas cheer to all!
Ken in Seattle
Like the guys in big SUVs thinking they can barrel along at high speeds because they have 4WD. When they hit their brakes, the 4WD acts like it isn't there! 8~O
Jim
Seriously, all new cars have a full array of warning lights...I see no reason the Sube should be any different, especially since some (like the check engine light) are mandatory (ODB II, and all that.)
And they ALL light up when you turn the ignition ON and they all go off -- hopefully -- when the engine starts.
-Mathias
Craig
Seatbelt warning light
SRS airbag system warning light
CHECK ENGINE warning light/Malfunction indicator lamp Charge warning light
Oil pressure warning light
AT OIL temperature warning light (AT vehicles)
ABS warning light
Brake system warning light
Low Fuel Warning light
Outback also has a light for VDC if so equipped, and may have a couple others I'm not thinking about.
Craig
I love discovering smart little features like that.
I hope the slow-dimming lights didn't go away. Do they still do that?
-juice
Bob
I think they have a 5/100 warranty, see if that's cheaper than the 7/100.
-juice
Funny thing with the rear wiper set up when I first discovered it was that I thought it was malfunctioning. I'm thinking (whilst I was still in reverse gear) why aren't the rear wipers wiping intermittently. It's on intermittent on the switch yet it's going all the time? What the hells going on? So I put it in park ready to get out of the vehicle and then it goes back to being intermittent. Then the penny dropped.
I remember a few years back on a previous car thinking, wouldn't it be a good idea if they DID wipe all the time when you're reversing. Obviously somebody suggested it to Subaru.
There are alot of things in the new spec Subarus that have been given alot of thought or they've been suggested by customers as cures for problems.
After I had my previous spec Outback H6 for a few months I told my Subaru service representative that the H6 should have a few features like:
1) trip computer - now in the new spec.
2) different wheels to differentiate it from the 2.5i as more "upmarket" as they both had 16" rims - the new spec H6 has 17" rims as opposed to the 2.5i's 16"
Apperently, from what I've been told, the service reps were to ask their customers here in Oz what features or things could be done to improve the Subarus.
Maybe they listened to me. lol
17"s would be sweet, too.
This type of stuff is what's keeping me on the fence, vs. just buying a Forester XT now.
-juice
1) Kms/lt (mpg for US I suspect)
2) average kms/lt (ave mpg for US)
3) kms till empty (miles in the US)
4) outside temp
Another feature you may not be aware of is there is a small screen (2.5" x 1/2") on the map light/rear view mirror console that displays the seat belt status. The front passenger seat has a sensor that detects whether someone is sitting on the seat or not and displays whether they have their seat belt done up via a red "person on seat with seat belt on" icon.
The rear seat passengers display a green light when they are buckled up. If you have, say two people in the rear seat and only one has their seat belt done up then only one green icon is displayed and you therefore know that the other person has not put their seat belt on. Quite a nifty little set up.
-juice
As for the 30K diffy. I'd do em, but then again we charge a lot less thn $440 for the 30K service. We usually charge $265ish for the 30k with the diffys it bumps to like $300.
-mike
It'll be hard to resist!
-juice
At Home Depot I found large ladder/shelf/utility storage hooks that I modified. They are tubular, white painted w/foam on the lower section and a black plastic cap on the end. The lower section is right angled for about 6", with an upturn for the last 3". They are rated for 50lbs. I cut off the upturned section, and replaced the black cap on the end.
I mounted some lumber high on the wall to bridge the 16" studs, then mounted these brackets along them. A few layers of duct tape cover up the wall and screw sides of the bracket to prevent any possible wheel scratching. Carefully knock out the center medallions on the alloys (light tap from the inside with something large and soft), and mount the wheel on the brackets with the front side facing the wall. The foam (and tape) cushions the wheel contact points. This reverse mounting also puts the load spot very close the the wall, so the bracket load rating of 50lbs anywhere along its span is really now optimized.
I clean and wax them prior to putting them up, and store the center caps in a baggy. Maximum garage floor space restored, as I can now walk under them!
Steve
Time to play with the search tool I guess.
Still, it takes some expertise to heft 50lbs up over your head and on to the hook.
(after that trip, anything can seem easy.....)
Steve
Luckily my designated storage area on the back porch is more of a utility than public area and it's a short roll to get the tires out there twice a year.
I am inclined to take a rubber mallet to the spare tire holder in the Outback so the full size spare will ease in there a little easier.
-juice
I just had the pleasure of test-driving a '98 Legacy Wagon, 5sp, 79k, well maintained and fairly clean. Asking $6,700; wholesale value -- as appraised on another board, and by the local Toyota dealership -- is $4,500 "real money". So I went and looked at it.
Two things turned me off, one which I understand and another which I don't.
(i) There was some seepage of oil, not enough to form drops, from the very front of the engine... looked like a black cover just behind all the pulleys and the serpentine belt. Much crud accumulated at the underside of the seal and on the lower radiator hose... looked like a thermostat housing, but shouldn't that be near the top? Anyway, didn't look like a big deal, but I was wondering if that was a frequent problem on the 2.2l
(ii) This one was odd. I revved the engine in neutral, and beyond maybe 2000 rpm, heard the typical whiny Subaru valvetrain noises, but underlying all that a deep growl that sounded mechanical, and a touch too loud for my taste. Then I drove the car and after a couple blocks pulled over again and raised the hood to listen some more.
There was a definite vibration that seemed to come at 1/2 crankshaft speed. Reminded me of another Subie I drove over a year ago (95 legacy) taht was running on 3 cylinders, but that one didn't do the growling thing. It sounded metallic and pretty deep. Also, the shifter vibrated with it fairly hard.
It is quite possible that it is "normal" for the car -- I don't have enough experience with these engines. If my 1.8l 4cyl in the Vibe made that kind of noise, I'd KNOW I got a problem, though. The engine pulled reasonably strong, but the vibration made it feel rough.
FWIW, the check-engine light lit up when I turned the ignition on and went off when the engine started. Under OBD-II, it has to have complex misfire detection. So that would argue everything OK, but man....
Any ideas?
TIA
--Mathias
I've had a variety of cars tested for emissions in a number of locations since the late 1970s, but today was a new one (I'm in Washington State). There has always been a tailpipe "sniffer" as the main test component, but today the fellow had me hop out of the car, at which point he hooked up his diagnostic analyzer to my OBDII port. His and my computer conversed for a few seconds, and he pronounced the test over. I did pass, which I expected, but I was both surprised and a bit concerned about this procedure (testing provide by Agbar, a contractor to the WA DOL).
All the "results" were systems tests of my OBDII system (MIL, O2 sensors, misfire detector, etc.), and no actual chemical measurements, such as HC, CO, O2 and NOx that I've been accustomed to.
Now, not being a total troglodyte, I realize that if OBDII says that everything is cool emission-wise, it probably is. But if the bottom line is what is actually going into the air, this indirect methodology bothered me. Not only is it qualitative (yes/no) rather than quantitative, but the precision of the relationship between OBDII functionality and a [legally] non-polluting engine is unclear.
Comments? Similar experiences?
In any event...Happy New Year to all!
Ken in Seattle
I know snow performance is low on the "All season" chart, but a recent trp to the ski slopes left me disappointed.
I found that when the car wags its back end, it was surprisingly hard to bring under control, and in some instances took at least 5 or more subtle yet definate corrections to set it straight.
Now, the car does have 28,000 kms on it, so I don't know how this much wear affects the snow handling.
It almost left me wanting, oooo, let's say an '05 H6 with VDC...
Ciao
Seberry: I've found the OEM Bridgestones to be poor in snow -- enough so to negate the value of having AWD in the first place. I've toyed with the idea of getting a second set of rims and snows, or switching to something like Nokians year round. RIght now I'm leaning towards riding out the Bridgestones (I'm at 38k miles now) and getting the Nokians to replace them.
Jon
Was the car fully warmed up when you tested it? My dad's '97 2.2L makes a racket til it's warm, as does my '97 2.2L as well.
-mike
-Mathias
Lyn
-mike
How about this: I know the 60k (incl. t-belt) was done at a corner-garage-type repair shop, not the dealership. They either overtightened the timing belt OR didn't replace the water pump and tensioner. Therefore, now one of those two components has developed a knock (most likely the water pump) and that is what I'm hearing. I like it because it fits the facts: Goes with camshaft speed, doesn't rob power, computer won't pick it up -- and the owner didn't notice it because it came on gradually.
What's nice about it, it's basically a redo fo the t-belt for, what, $350? Unless I do it myself...
Whaddaya think? You like? You buy?
-Mathias
-mike
You really want to know if it's worth buying? Do a compression test, look for no more than 10% variation. If you have a leak it's prolly the head gaskets, in that case run, don't walk. It may have had a history of overheating.
OBD2 will sniff out (pardon the pun) any gross polluters, so yeah, it should be effective just to read that data.
-juice
The reason the states are going to this method of testing is because it saves them big bucks and it proves they don't really care about emissions.
From the vehicle owner pespective, it saves then time and money. The O2 sensor is upstream of the catalytic converter, so you can remove the cat converter and the OBDII system won't know the differece. Replace the conveerter with a similar shaped can and even a visual inspection won't reveal the corrupted emission control system.
-Jim
There are at least 2 O2 sensors on these cars, one before and one after the catalyst. The second one monitors the catalyst's function.
-M
-juice
Many (all?) modern engines have the first O2 sensor in the exhaust manifold. That means two sensors for V and boxer engines. Anyone know how many sensors there are in Vokswagen's W-12 engine :-) ?
-m
