Subaru Outback VDC
Mileage on car when it blew whatever circuitry was 9400+.
Warren
I doubt whether there is a wide spread problem with this. I am still really enjoying the car.
Mike
...at 6-7pm Pacific/9-10 pm Eastern. Hope to see you there!
http://www.edmunds.com/chat/subaruchat.html
Drew
IMO, depending on one's sensitivity, I think hesitation can be felt on just about every car out there. I have a Toyota and Lexus that both display a small bit if I press just the right amount on the gas at just the right time when the transmission is thinking about shifting - but never in an amount I considered a risk at intersections. Only an annoyance that is noticed only when thinking about it. Coincidentally in the last week or so, the Toy is exhibiting real hesitation due to some malfunctioning sensor, causing the tranny to shift into top gear at very low speeds causing the engine to bog. THAT is hesitation!
Although I have only driven my new Bean less than 1K miles, it hasn't yet shown even the small amount that I describe on the other two cars. Power is always there, smooth delivery, quick shifts.
I'm very happy with my car.
Steve
I'm driving a LL Bean that I took delivery of in February. The second day of ownership I experienced a cold start problem. Being from California, the weather got warmer the following week and haven't experienced that problem since.
I have noticed the acceleration problem numerous times as I go up an on ramp to access the freeway. As I step down to get up speed to merge with the flow of traffic the car just seems to cut out. On a recent trip in the mountains I was traveling at 50 and went to pass a slower vehicle and as I stepped down the car seemed to literally die. I was about to coast off to the side when it seemed to regain power.I've also been keeping my gas mileage since I've owned the vehicle and in a combination of 50%freeway and 50% city driving I'm averaging 19.67 mpg. I expected to have gotten much better gas mileage than this. I traded in my explorer, with the best seats I've ever had in a vehicle, for the better gas mileage I thought I'd get in the LL Bean.BTW..The explorer got 21 mpg with a combination of 18mpg.
Yesterday I took my vehicle to Clawson Honda in Fresno and told them exactly what I've just mentioned. Their response was that this is just normal and everything checks out. If they wanted to check out the gas mileage then I would have to leave the car for their mechanic to do even though I've kept accurate records since the day I bought the car. I asked for a loaner vehicle as I thought would be furnished in the warranty and they refused.I live 60 miles from where I purchased the vehicle.
Patti... I would truly appreciate a response regarding these matters.
The excitement of owning this vehicle is quickly fading.
Re gas mileage mine has been in the 25 to 26.5 range. It is almost all highway (living in Mammoth )
Never experienced the start problem but of course it has been warm since I got the car. It was March 01 production.
Wondering if you have experienced the whine problem (See my posts on the Legacy/Outback section)
That's nothing, though. My Miata reaches peak torque at a sky high 5500 rpm. Below 3000 rpm it's like the engine is off. It's geared much shorter with its 5 speed manual but I still need 4th and sometimes even 3rd at highway speeds.
-juice
I'm happy to say that I haven't experienced a Subaru whine, only our Napa wine. If I do, you can be sure that I'll mention it.
As for the torque, I must admit I had been conservative in my driving for two reasons. The first being the break in period and second I was trying to get better gas mileage. Mammoth, I think it's great that you are getting such wonderful mileage, but don't tell me you only check it after you've driven down the mountain
I read in other posts that our formulated gas or oxygenated gas that we have in California doesn't seem to result in very good gas mileage. I wonder if the ECM can make the appropriate adjustments. I'm also thinking about going to regular to see if the mileage improves. Any thoughts or suggestions would be greatly appreciated.
T_Zak
Warren
Try this experiment: put the tranny in '1' and try the light pressure acceleration method you described above. Does it hesitate at all? I think others have pointed out that the Sube tranny probably shifts to '2' or even '3' during the light pressure acceleration. So maybe a more aggressive tranny shift map is the answer.
I believe even our H4 Outback shifts quick into '2' during regular driving. I usually don't notice this much since I tend to drive 'manually' (ie. shifting the gears on my own).
-Brian
When you do a light acceleration ('D'rive position), observe where the rpm/speed is at when it jumps and when the hesitation occurs. Then compare with hard (or slightly "heavier foot") acceleration, note (if you can) at what rpm/speed it shifts to 2nd and see if there is any commonality.
Knowing more about the hestitation aids to the resolution.
i.e. "car accelerate to x mph @ x rpm then hesitates then regains power @ y rpm" would probably be more informative versus "I lightly accelerate and the car hesitates".
Warren
-Brian
another experiment.
Put the car in Neutral, parking brakes on.
Very lightly and slowly accelerate and 'decelerate' (is there such a word?). Watch the rpm.
There's this guy at another board some time back (his handle is 'Rich in NAPA'), could not get in touch with him to learn if he found the cause or if it is fix. Anyway, he'd notice when he played with the throttle there is a void at a point in the rpm band where it neither rose nor drop.
Just wondering if your hesitation fit in there.
Warren
A few others with the H6 here and in the Subaru Crew have mentioned that after the ECU was fixed that they didn't have the startup problems anymore. So, you should be good to go now!
-Brian
Try driving the car more briskly... maybe the mileage will get better
Oh and only use 91 or 92 octane
This hesitation problem is real. The transmission is not shifting into 2nd. There is a diffinate flat spot at around 1500RPM. I believe this is a new system for Subaru and I think we're seeing some of the bugs. I really love this car....It just has this very annoying glitch!!
I currently own a '92 loyale. I am looking at buying a 2002 VDC wagon when they come out in a couple of months. I am very concerned about the hesitation problem, as well as the cold start problems with the 2001's. Should I look at an Audi, or other wagons instead? What guaranteees do I have for Subaru fixing these problems if they come up with my car? I have not seen one post here indicating that they completely fixed the problem. What do you all think?
I really like those new xenon bulbs you see in cars nowadays. Are they easy to put in a VDC without warranty problems? Any recommended vendors?
Down side, you lose your high beam, lens pattern may not be suitable (glaring oncoming traffic).
Upside, bright.
I have an auxilary mounted (Hella DE Xenon), and trying to get pics for Ken.
Drew
David C.
If you installed the HID from Japan; since they drive on the left, would not the focus and beam pattern be wrong?
T_Zak
Thanks for your feedback.
Drew
I drove a lot of beans and VDC's during my test driving and I didn't notice any hesitation on any, but I didn't do any light footed acceleration either.
Overall, I have been more impressed with this car than any I have ever owned against my base requirments: comfortable, smooth, very very quiet, compliant suspension, great cornering. This is so much better a car than my Volvo 850 turbowagon, and I thought I loved that car. And of course, for an audiophile, the cd performance of the McIntosh is in a league of it's own.
I must admit the plastic wood dash bugs me.
Some rambling thoughts
Mike
Warren
If reliability concerns make you hesitant, I would not look to Audi instead of Subaru. Their long-term reliability scores are worse, not better. Volvo's are also not as good (but don't take my word for it, ask around right here in the Town Hall).
You could probably buy the HIDs from Pam at iSR Subaru, since she imports just about anything from Japan. It's autocaresubaru.com.
-juice
PS These electrical issues seem minor compared to the early troubles other manufacturers have encountered. Blazers' suspensions could collapse, and Fords wheels could fall off.
Why is there so much activity on the Subaru forums versus the others? I must admit I am participating in this forum, but I never did before. Do Subaru owners somehow need to defend their decision not to buy a Volvo or Audi, or are we just a little quirky, or do we just like defending the underdog? I don't have an answer, but I am enjoying my glass of wine. I wonder, do we like different wines from Audi owners?
hmm,
Mike
bit
In my opinion, there is more activity here because our community is strong with caring people. There are no slams nor is there an overall feel of a complaint session. Just good information sharing.
When I was asked to start posting here on behalf of SOA, it was an extra responsibility. After a year, it is now a place that I like to visit and share information. It turned out to be a nice place to "visit" with friends who drive similar cars.
Hope to see you post more.
Patti
I've wondering whether SoA's taking the step to mingle with their customer was a decision made on its own, or was it as a result of an overwhelming customer request/suggestion. I know I made such a suggestion when testing the "my.subaru.com" beta site.
Anyway, it is a very very good move. And I believe SoA is first (pioneer) in this new frontier.
Cheers
Why are these boards active? A few good reasons were already mentioned, and I'll toss in a few more. For one, we welcome all models of Subaru from all years, so noone is left out. Even visitors and enthusiasts that do not own a Subie (yet?) are welcome.
Also, as owners many of us are techies, so we have access to computers all day long. We're affluent and educated, hence the tone of civility. Even our gracious Edmunds hosts have chimed in about how our boards are among the best.
Speaking of wine, we and the SCOA toured the Oakencroft Vineyard in Virginia last year, and the consensus was with the Cabernet Sauvignon. It offered a smooth texture, light bouquet, an an Episcopalian behavior.
Whatever that means! ;-)
-juice
PS The Oakencroft Vineyard owner owns a 2000 Outback. Anyone want to guess what color?
-juice
My question is about other's driving habits...How many of y'all allow the motors to rev to the red line?
I personally like the sound of the H6 at high rpms. I don't red-line the car in every gear every time I accelerate, but every once and a while, it is nice to let that motor just rev away. I know the Outback is not a sports car but its nice to take advantage of the full rpm range of the motor.
-r
Plus, you'll never feel peak power and torque if you stay below 4000 rpm all the time.
-juice
Hmmm... I think there may be a possible bumper sticker lurking here.
Bob
1. either a turbo or supercharger. I live at about 5000', not losing power at altitude would be nice.
2. A manual shifter, such as Tiptronic as on the Audi's. This would take the Audi Allroad off my list.
My 2c worth.
Cheers
Pat
Warren
Bob
