Vocus..we all know you had a bad Cavalier and so has everyone you have known, good, now let those who haven't had an issue post their experiences without having you come back and paste the same information you have pasted on this board everytime someone with a good experience comes by.
That said, if I was to buy a new GM compact now, I would likely wait for the ION due out next month. It looks to be excellent and as good as anything out there.
I had always wanted a Cavalier when I started driving, because they were pretty cheap. It wasn't until later that all the little niggling problems starting happening to them.
You MAY have to be a DIY'er to own a Cavalier -- but not all low-priced cars are in the same league.
Meade
Regarding your cute little comment about Ford and Mazda ... Ford owns a controlling interest in Mazda, much as they do in Volvo and Jaguar. It doesn't keep the company from doing its own thing, however. Amount of Ford input depends on model. My Protege was (and current models still are) built in Japan using Mazda parts. Other models are different; the B-series pickup is nearly 100 percent Ford Ranger. The new Mazda6 is all Mazda unless you buy the 6-cylinder version; that has Ford's Duratec V6 in it. And the influence works both ways; the highly popular Ford Escape that's been such a hit for Ford was designed by Mazda and is also sold by Mazda as the Tribute (same price with better warranty, go figure). The Miata is 100-percent Mazda, as will be the new RX-8 next spring.
There. A little primer on Mazda. Maybe you should go check them out. Our Protege and Protege5 are problem-free at 45,000 and 10,000 miles respectively.
Meade
The 97LS has 44K in mostly brutal, short distance northern VA driving (similar for the 92). I just had the 5yr coolant replaced and had the tranny fluid replaced (pseudo 50K hard mileage service). Under warranty, the rotors warped (and seem kind of off again - either based on size or incorrect lug nut torque), the transmission linkage rattled from a misinstallation at the factory and the tranny gasket was defective.
So, in 15 years of Cavalier, they've been good to us. Except for the expired batteries about every 4-5 years, the cars start every day and get us where we need to go.
This is just anecdotal - the sample size is obviously small - your mileage may vary.
The biggest issue for a prospective buyer of a new vehicle is to survey (interview/interrogate/whatver it takes) the service department. There's no question that you will need warranty service at least once, and the Chevy, maybe GM, service departments have been weak for me.
I still have not had the ignition recall done - do I really have to let the dealer touch my otherwise well-maintained vehicle? Ugh.
I have never needed wet pavement to activate the system - just enough speed (40 or so) and press the pedal through the firewall, assuming no one is close behind. The pedal does not vibrate hysterically - the vibration is fairly light.
Without looking it up, I think that if the ABS is malfunctioning, the traction system will also be out, and the No ETS light should be on.
This one has 120000, but is clean inside & out & seems to have been cared for very well. I changed the valve cover gasket & when I had it off, the top of the head was spotless, no sludge or buildup. I got it at a used car dealer & bought a 6 month 7500 mile powertrain warranty for $150. It's with a company called "CARS" & covers everything on the powertrain. Plus I can take it to any shop. They just sent me an offer, in the next 30 days, for another $99.00 I can extend the warranty to 1 year & 15,000 miles & with that it also extends the coverage to seering , suspension, & brakes (major components, not pads or rotors) including all ABS components so I think I might go for it for the peace of mind. Also includes towing & rental car allowance.
Overall, these are very easy to maintain vehicles, and parts are cheap and available when needed. I still think the Achilles heal is the dealer service, but the third party providers like Goodyear and your neighborhood mechanic do know the cars....
http://www.thehollywoodextra.com
http://www.cheersandgears.com/
Just where is that "2003 Mercury" for sale?
Never did I have to do any transmission work...not even a front seal...
What was the reason? I honestly believe that it was the Amsoil synthetic fluid that I always
used. (This is a superior product!)
So, when I bought my 2002 Cavalier, I went to the parts department and bought a "pan gasket"
so that I could "start" the Cavalier with a fresh "fill" of Amsoil. (the salesman, in so many words, said I was "crazy".)
All I'm saying, try Amsoil....you might be surprised.
(No, I don't sell anything.)
The salesman that sold me the car said (in so many words) that I was "crazy". He warned me
that I would void the 36,000 mile warranty. I just grinned.
I'm about to sell my 97 Cav. to someone I know. It's been a reliable but not very exciting car. I really noticed what a competant small car should feel like when I bought my Elantra GLS last year. Before that purchase I was satisfied with the Cav.
The next gen. Cav. (if that is the one) looks a bit clumsy in the C-pillar area. Front end of all new platform Chevys looks quite nice, however. Far better than the 03 car which took a fairly nice styling theme and made it ugly front and back.
electrical system, I've been asked,"What's that 'all about'?"
I don't know what to say. Can someone "explain"?
And I've always wondered whether 24 volts might be more hazardous to work around than 12 volts?
for race cars where the alternator and charging systems have been removed to lessen engine
drag. A 16 V battery also seems to "soup-up" the ignition systems for the racers.
This is the first time that I've known of a passenger car to be so equipped.
Maybe GM has some race car drivers doing some of their new engineering.....
leaks".
Just like engine oil, transmission fluid breaks down over time, and should be changed.
I highly "disagree" with the owner's manual on this subject.
Anyway, there is an oil pan on the transaxle for changing the fluid. A new gasket is $35.09
from GM.
I'm sure that GM uses a "high grade" fluid, but, still, it ought to be changed occasionally.
Just my opinion......
and this
http://www.thecarconnection.com/images/gallery/6338_image.jpg
from this report
http://www.thecarconnection.com/index.asp?article=5489&sid=176&n=156
not bad for a cavalier.......that yellow 2 door is actually nice. what a change, huh? If they redid the interior and tightened up the chassis this would be ok.....especially with a real motor like the ecotec.
Just learn the old adage:
"Three wrongs may not make a right, but three rights make a left."
You may want to take that literally!
As for the red herring comments, all red cavaliers are extremely ugly, wrong color for a cheap sedan. Otherwise, I like the new look, much better than the ones around 96/97
I do have a warning, a couple of months ago, I took the cav for a 2000 mile drive in two days, at about mile 1700 I pulled into a rest stop, the car was running great when I turned it off, but it would not turn on five minutes later, it would not even turn over. Luckily it started with no problem four hours later, when my ride arrived (I had been trying it every 15 min and it still wouldn't work). The mechanic said some part just got too hot, so if this happens to you, don't freak, just give it a few hours before you toe it.
You have a problem,if not repaired it will fail on you again.Most likely ignition module.
