You can rent spring compressors but make sure to get a good one. You can also take the struts to most tire shops and have them deal with the spring, normally costs no more than 15 dollars per strut.
Labor to have the job done usually runs 50 dollars per strut down where I live.
Another potential problem would be the wiring going from the computer to the solenoid. If it's damaged in any way, it could affect the resistance of the solenoid.
Paid the price, had the solenoid replaced and it's running perfectly now... 860$ later...
Hope it helps!
That'll teach me.
Are these things subject to sudden stress cracks which could cause a major oil leak? Ever hear of one failing? I can get the oil filter by itself for about 8 bucks, the whole assembly at the dealers costs 15 bucks.
The "tick" doesn't increase or decrease with engine speed. It sounds slightly metallic and seems to be coming from the drivers side of engine. Happens once every 10 - 20 seconds. Listened to a friends cavalier running last night and it seemed to have a similar sound, but not as loud.
This makes me a little worried, but I think another chevy I owned had a similar sound and I had no problems with it?
Any ideas?
Any advice appreciated.
Chevrolet Cavalier: Window Motors
However, to my surprise, I discovered that the 16" Trico Winter Blades are almost exactly the same length as the Cavalier OEM 17" summer blades!
Now listen to the rest of the story now that we got past the obvious.
When I bought this car, it came with a 1,000 mile warranty. Well, just like typical, when my warranty was up, the problems started.
What is the biggest, and basically the only problem? Overheating!
It was horrible, it would overheat to the point that it would redline on the temp gauge. Coolant containers all over in the car, 10 foot puddles out in front of the car and one BIG headache! Every time I went somewhere I had to make sure I had plenty of coolant. So I finally decided to just spend one paycheck and take it to a mechanic. The hose had a gash in it.. they replaced the hoses. Oh phew! It's fixed! No.. no its not, its OVERHEATING AGAIN! What the!?? Changed the temp sensor.... I think we're ok for a couple days. Nope.
Later on, Moved out of my Ex's house, and he wouldn't give me the car, even though it was a in bad shape.. he kept driving it, and let it overheat to the point where it wouldn't start. Cracked the block. Engine = Seized.
Year later, got the car back after it sat, seized and unused outside.
Totally revamping went on. New Engine. New Heater Core. New fluids. New brakes. Finally, it was ok. I drove all the way to Burlington County, no problems! For a month it was perfect!
That is until this past friday...
I went to pick up my son this friday, and 5 minutes after leaving my Ex's house, I had to pull over. It's overheating AGAIN. Put some coolant in, made it home.
Saturday morning, was planning on goin to Pensy, until 10 minutes on the parkway, the coolant boiled in the tank, and came gushing out the overflow hose. I had to get towed. I was pissed. INFURIATED!!!
So, later that day, I thought I'd take it out for a spin to see if it would happen again. Oh boy and it did, quicker than I thought. Not even a block, and It was running extremely hot, and gushing antifreeze quite rapidly out of the overflow hose. That leads me to today.
Today I drove it to Adams house, which is not too far away (in the same neighborhood). We went in his car to pick up two bottles of antifreeze, new spark plugs, new thermostat & gasket, and a new temp sensor. Adam installed everything. I took it for a spin around the block..OVER HEAT! OVER HEAT! OVER HEAT! WHY!? Radiator? Waterpump? WHAT IS IT?!
The waterpump was fine when the engine was put in. Spun really nice. The radiator is the only thing that hasnt been changed. Im so mad, so confused, and SO BROKE. This is ridiculous, when I looked at all the empty antifreeze containers, they equalled up to $50 worth! This has to stop!!
I wound up flushing my whole system with a garden hose, radiator and every single hose, then I followed the directions on K&W Permanent Metallic Block Seal. (Course I flushed every single trace of antifreeze out) and I mixed the block seal with hot tap water like it said, then put it through the car, after puttin all the hoses back on. Then it said to let it idle for 20-30 minutes and here im thinkin "My car cant even idle for 10 minutes without it gettin up to 260 degrees, how am I gonna do 30 minutes? But I did it..(I did 25 minutes) and 10 minutes in, for the first time in my entire cars life, the FAN CAME ON!! and then after that I undid the hoses again to let it all flush out, then you let it sit for 24 hours to let the stuff adhese. 24 hours later, I put all the hoses back, I decided to switch my Cavy of DEX-COOL. (It contains ginger that eats away at the gaskets and seals) I put it on green antifreeze, and its been running perfect! I hope this helps.. I know I was so mad when I couldnt figure it out, but I did this and its no longer overheating, and the fan is now coming on when its supposed to. Good luck
goodluck
The cable has become crooked, kinked, etc, and I need to get it replaced, as the car has no defroster, and I live in the middle of the country.
Bad combination right now.
Does anything think the sqeaking is bad suspension? If so, does this model year use all struts or a combination or shocks and struts.
Thanks! :confuse:
If you can get a double row radiator which will fit I'd go for it even if it cost more. You'll get better cooling remember the Ecotech motor can't take much overheating.
