Only problem I have is that the car came with a cassette player, and I want a CD player.
Anyone have any idea what it would cost to switch the unit to one with a CD player? Also, would I be better going to the dealer or to a car stereo shop? Any input is appreciated.
I was looking to do the same thing on my Alero, and the dealer said it was not as simple as swapping the radio. I have my doubts about this, but that was his "enlightened" opinion.
Maybe it's the acoustics of the Century, but the 6 speaker system sounds awesome. In my opinion it is superior in sound to most other 8 speaker systems, unless you really need 200+ watts.
You may want to check Ebay, they usually have relatively new units for sale from people who upgrade. THey may be able to answer some questions too.
Reason why I say that is there are tons of buicks availbale on the used car market. They are a popular fleet and rental vehicle so there are tons of 1 year old Buicks around.
Art
However, GM replacement radio must be expensive.
Just bought a 2001 Century Custom today for $11,999; 27,000 miles; rental return. Beautiful automobile. I'm a little concerned about earlier posts about the defective pistons from the 2000 model year run, this 2001 has what sounds to me like a noisy lifter when started cold (15 deg F outside), but it quieted down within 30 seconds.
The car is nicely equipped, I especially like the driver's side power seat's range of adjustment. My wife is only 5'0" and she can raise and move forward the seat to just where she needs it.
Art
My 2000 Regal bumpers, or at least the rear bumper, is of a bit different shade. The car is maroon, with a bit purple shade on the bumper(s).
We bought the car new, but is was built some 11 months before sale. Probably, the plastic bumper discolored somewhat different from the sheet metal, while parked on dealer lot.
I can see it under bright light only, like a good sunny day. Noticed some 9 months after buying. Our son have much better vision, and he told us he knew this from the very beginning.
It does not bother us, though. Even my wife, who pays more attention to appearence.
Art
I drove down to L.A. with my wife and my dad. Some positives: Very quiet and comfortable interior, decent space for 4 people, smooth ride, good power from the quiet engine and incredible fuel mileage...33 miles per gallon driving at a steady 70 mph.
Some negatives: No tachometer (only because the other cars I drive have tachs), the volume is weird when playing a cassette. At a certain point of the volume knob, one notch (detent?) louder and suddenly it's too loud. And the gaps in the steering wheel where the upper and lower sections meet the center part are just too large as if it didn't fit.
Overall, we were very happy with the car. I'm only 30 yrs old so I'm really curious as to how Buick Regal might be compared to the Century.
It is easy to do. Just test drive one :-).
However, it can be addictive. We bought Regal GS after test driving. Took 5 minutes for cooling, and put our deposit.
There is substantial difference between LS and GS, though. GS accelerates much faster.
By the way, GM used to send $40 or $50 cash cards just for visiting dealership and test-driving.
It is for engines with the J designation. [the eighth digit in the VIN ]
It says that the ticking starts 15 or 20 seconds after starting a cold engine. It says to replace the pistons on the affected engines.
It also states that this is a customer satisfaction issue and will not affect the longevity of the engine. I am to drop off the car tommorow night so that they can listen to it in the morning when it is cold. The car runs good and uses no oil. I cannot hear the ticking from inside of the car so maybe it is not worth pursuing. Anybody have any ideas on this?
Regarding the Air Conditioning smell upon startup, I have experienced the smell upon startup with virtually all makes of car I have driven...especially if it has not been used for awhile. It goes away very quickly and never indicated a problem.
It seems that they changed the radio knobs on the 2002, but the Fader control should still be labeled.
I really miss the quiet buick ride. Let us know how you make out.
Bill Sapp
Bill
To me, the Buick offers good power, handling, safety, and features at a fair price. If you want to have some fun, test drive a Buick Regal with the supercharged engine. It might kick your Infinity's you know what.
and now I have a small leak from engine gasket because of the type of long lasting fluid gm uses plus I have to have radiator taken out and cleaned thoroughly and blue anti-freeze put in all these repairs are going to cost me$800 my car is a 99 century. Has anyone else had this problem?
1. Generally it's a quiet car. But from A pillar there is a very obvious wind noise at 45 MPH and above.
2. 12V socket is in a pull-out drawer in the front. When I plug an accessory in, the drawer slides in, not the plug. Have to use another hand to hold it.
3. The rear two doors close with a loose sound.
4. Doors have very strong spring action. Very easy to hit the adjacent car, even myself sometimes.
5. Overall interior look and touch are cheap.
Other than those I don't have much to compain.
For a rental car it's good enough. For a car to own, no.
Have you had your radiator repaired? We had the same problem with a '95 Chev. conversion van and the first generation Dex-Cool fluid. The service people refer to this problem as Dex-Cool gelling. Unfortunately, by the time it appears, you (and we) are out of warranty. We replaced all clogged hoses & had the radiator flushed several times at 40 to 41,000 miles, and the problem continued. Lots of solid brown chunks in the coolant. If we had kept that van, we would have taken it to a radiator shop and had the cooling system acid-washed. I have a 2001 Chevy Silverado now, and although the dealer tells me the "new" Dex-Cool is improved, I'll be flushing it out, maybe acid washing the cooling system at a radiator shop, as soon as the warranty ends and relacing it with non-Dex-Cool coolant. The 5 year/150,000 mile stuff is just sales hype.
The 3.1 motor in the Century is a good motor. I would change the Dex-Cool every three years regardless of mileage to avoid problems.
Regarding the soft seats, I prefer them for long trips than firm seats, and I only weigh 155. I had a Taurus last week and the seats were flat and firm..I wish I had the Buick. For around town, I kinda like firm buckets like in my Alero, but a little cush for the tush is pampering on a long trip. The buick is much quieter than most of the other cars in its class/price range.
By the way, why should you change the Dex Cool every three years?
The Dex-cool clogs the radiator passages when it deteriorates and causes overheating. (That could have a negative effect on AC, LOL.
GM says Dex-cool is good for 5 yrs. so I draw the line at 3. I also put a little extra in the overflow tank cause it's so hard to see the level in that narrow tank near the firewall.
I came across a 1999 ex-opp white Lumina for 5 thousand Canadian. It has the 3800II, 4t65e transmission, recaro seats, stiff suspension, H rated tires(max speed 130mph) and the odometer says 147k km (92k miles). After taking it for a drive last week I found no apparent flaws such as pulling to one side, engine whine or rough shift points. To my surprise when I check the dipstick for the automatic transmission fluid, it is showing bright pink fluids which indicates the fluid is fairly new.
What do you have to say about this folks? The price is right and the car is in relatively good shape, I know it would be hard pressed to find a late model vehicle in the 5000 dollar (CDN) price range, and this one has the 3800II in it which is a big plus. I have always enjoy the power the 3800II outputs, and its smoothness and reliability. Anyways, I would like to take the car home next week unless somebody comes with a convincing reason for me not to.
This is my first time car shopping, I would appreciate any suggestions and comments. Thanks in advance.
Basil
Heres my questions:
1) The dealer wants to replace the whole heated power mirror assembly at $131, but only the mirror itself was damaged. The way these mirrors are assembled, the glass (and heating element) is just glued to a plastic frame in the color-keyed housing. Does anybody know of anywhere to get just the mirror (and probably heater element) to re-attach (website, part #, anything)? It's got to be a cheaper than replacing the whole unit.
2) The damage on the door is fairly minor, just a small, smooth depression. It's unfortunately on the lower accent line (bend/crease) on the door. The paint has minor scratches. Again, the dealer seems to want to go crazy with the body work and bang it out from the inside and repaint most of the door... at a cost of about $350. It seems that if it can be pulled out smoothly no repainting would be necessary. Anyone have any experience with this type of work know if this would be possible?
For pictures of the damage, please go to: http://home.earthlink.net/~druep/century.html
Thanks in advance.
