When I test drove it monday, I found the receipts from the oil changes the woman who owned it first did--every 3000 miles like clokwork. I did not, however, find a receipt from getting new spark plugs at 30,000 miles or a new air filter--so I made an appointment with the service department to get these things done. If it didn't need them, then new ones won't hurt. If she didn't get them done, then I need them. I will also get them to check the brakes. I think it's like $149 to change the front brakes. They gave me more for my trade than I knew it was worth, so I may just get them done, too, while it's there if it's anywhere close to needing them. The car was originally sold at the dealer I bought it from--so I figure if she liked the car so much that she traded it for another Saturn, then she probably liked and took care of it. We shall see; but, I feel good about it being a good commuter for 3 or 4 years at least.
To say they have a life expectancy of 100K is incorrect.
When in doubt check the owners manual - or ask a friendly Saturn service tech.
I would be pissed too if I were you - but have you taken the car to a Saturn retailer and gotten an estimate? I would also suggest you go to an independant with a good reputation and get an estimate.
Sounds like you just got a rotten car. Recognizing that it is YOUR car that is bad while many other people are very happy and have never had a problem doesn't make YOU feel any better - what does going to another manufacturer going to do? Just make you feel better. Imgaine if you had bought a Camry in 99 and needed a new engine at 30K but it wasn't covered under warrenty because you didn't service at the dealership?
No car is perfect - how is the engine and tranny doing on yours? We have a car in our showroom with 292,000 miles on it. Original engine and transmission.
Again I would contact Saturn corp - it doesn't cost anything but time -
Hope things work out for you...
Mike
I had the brakes done, which I now feel was a mistake. According to dealer, the front pads were at 5/32, according to my Haynes repair manual, 1/16 is the minimum thickness. They feel better, but could have gone longer. I love the fog lights so I replaced it. The housing was completely rusted and stopped working even after replacing the bulb. What's the story with spark plug wires arcing? I can't figure out how to diagnosis this. I declined this and figure I'll take care of when I do the 120K mile service myself. Flushing the automatic transmission fluid? I've been changing it as scheduled so I declined this as well. Replace upper engine mount? I did this 18 months/25K miles ago. It looks fine to me and I remember what a collapsed mount looks like. My car is running fine so I'm not terribly concerned about any of the issues, but would appreciate some feedback.
"I'm now at 117.5K miles (Feb 19, I was only at 115K; damn I drive a lot) and just took my car to the dealer for some service. They told me $1600 of work should be done! Is this a load a crap? Here are the major issues: new front brake pads and rotors ($350), fog light replacement ($140), replace spark plugs and wires, clean throttle body, to correct and prevent carbon buildup ($300), flush automatic transmission fluid ($350), replace upper engine mount ($250), and some other minor issues."
I'm not an expert on service issues. The prices you mentioned are about right for a Saturn dealer to charge - except they are on the very HIGH side of what I have seen. In particular $350 to flush the tranny fluid and (I assume) replace the filter. Thats about a 70 dollar internal job.
My advice would be when it comes to big repair issues or when your car is still low in miles and worth more its not a bad idea to pay the extra money for actual Saturn dealer work.
When your car has that many miles I would suggest you find a local reputable mechanic who can proably do the same work for
New front brakes and rotors (200)
Fog light replacement (80)
Spark plugs and wires - clean throttle body (100)
Transmission flush and new filter (100)
Replace top motor mount (80)
Also if you are handy at all you could do the majority of the above work at home. The most difficult part would be new front brakes and rotors - and thats not too hard.
I guess I will keep the tires. I went out over the weekend and tried to make them squeal or slide in turns (not in heavy traffic), and they would not. Maybe the Affinity is a good tire for the size and weight of the Saturn SL class.
Then it's bye-bye S!
Ive tried several remedies including having the fuel injectors cleaned and changing the spark plugs, but nothing seems to help. If anyone can help me please let me know!
Evildead2
The clincher with the SL Special Edition is Saturn is selling these for a price $2000 below the standard price for the base SL (although you cannot get the 0% financing promotion). I made an offer to buy the one they have, and they will have it prepped up today. It will replace my 1995 white SL which has almost 180k on it.
Besides noticing that the newer SL has power steering and a drivers-side mirror, I notice the ride quality is smoother and the interior noise is substantially quieter than my 1995 which is still in good shape.
Is there any reason I should NOT buy the 2002 SL Special Edition as a reliable daily-driver commuting car?
My 95 has had a few glitches (like the passenger-side seatback anchor failing, needing a $200 repair, and the oft-cited problem of leaking oil gasket seals) but this has been a very dependable, economical, safe and high quality vehicle overall. Any thoughts out here?
The replacements I selected were Toyo 800 Ultras, and I heartily recommend them. These are not heavily advertised products, but on the small 1995 Saturn (with limited sound insulation) the Toyos provided about a 6-db reduction in road noise compared with the Firestones, generally better roadholding and cornering, noticeably improved braking, and dramatically improved driving in rainy conditions. I had some exceptionally positive experiences driving the Toyo 800 Ultras through snow and ice conditions, they are in my view a genuine "all season tire", not just "kinda-sorta all season".
One caution though: DO NOT substitute a different tire size for the 175/70 R14 on the mid-90s SLs. If you use a 185/70 R14, the front tires may produce a low-level audible scraping against one of the pieces of the tire wheel well when you execute sharp turns, and your tires will wear excessively. Insist on the exact 175/70 R14 tire size even if it means shopping around for a tire store that carries this size.
Fortunately my Toyo dealer (Les Schwab) was very cheerful about giving me full credit for the incorrect tire sizing and giving me the correct size. My present Toyo 800s have given me excellent performance for 90,000 miles and there's still enough tread for about 5,000 to 10,000 more good miles if I want.
My 94' SL2 auto has 119,000 miles on it. I bought it in 98' with 58,000 miles on it.
it has needed alot of work but runs well and handles great and the polymer body looks fantastic for a 8 year ols car.
Alot of the problems with my SL2 have been fixed since 94' by Saturn. After 12 years they should have the SL perfected by now.
I wan't to replace mine in the fall/winter. I wan't to wait for the ION to come out. But I am keeping my options open. I don't wan't another SL just because I wan't a change. I am just hoping my A/C last thru this summer!!
My saturn dealer already told me my lower front control arms are loose and it won't pass state inspection when due in Novemeber. Dealer cost to replace them is $600!
It's been a decent car but....has needed a ton of work to keep it going. Since I got it with 58k miles.
New altenator, top engine mount, engine temp sensor, struts (all four), muffler & hanger, water pump,serpetine belt & tensioner.
And it is starting to use more and more oil.
The repair cost have been off set by the low insurance cost though. we have the highest insurance rates in the country here in NJ. Proably due to the most people per square mile of any state in the union and the most lawyers per square mile!!
My 95 SL (with almost 180,000 miles) tends to make a knocking-like sound under hard acceleration, and it doesn't seem to relate to gasoline at one time I tried using mainly premium gas in my car, it made a minor difference. A Saturn tech says it's the timing chain but his estimate for the repair work is around $700, mainly in terms of labor. I do have a reputable independent shop which could do the work, but want to know what others' experience has been related to Saturn timing chains.
I've had slow oil consumption problems from the gasket seals ever since the car was new, and the Saturn facilities kept claiming that was a normal consumption level. It is my understanding that if I had been more assertive during the warranty period (i.e. gone through the complaint process) it might well have been remedied, and I understand newer Saturns have improved gasket sealants.
My car has the original struts, original alternator, original exhaust system including muffler and hanger. I've had to replace the water pump at 140,000 miles, the serpentine belt & tensioner at 170,000 miles, the battery at 120,000 miles, the clutch at 100,000 miles, the engine temp sensor at 155,000 miles.
It's been a VERY reliable car, overall. Maybe that's an advantage of having bought it brand-new, in that I wasn't inheriting a previous drivers' erratic or careless driving and usage style on the car.
Cheers! Seattlenative
A Saturn facility replaced the ratchet assemblies for a cost of $197. I now have learned there may have been a recall (or a technical service bulletin) on certain 94 and 95 Saturn SLs for this issue. Is there any way to find out if my car's VIN is included in the recall series, and if so to obtain a refund if this was a repair included in the recall?
That was the only other really major complaint about my history with my 95 SL.
I was surprised at all the work my SL2 needed also. I have taken it back to my dealer every 3,000 miles for service letting them do pretty much whatever they thought was needed. i bought it as a used certified saturn from my dealer. it came with a 12 month/12,000 mile warranty from Saturn. The altenator went out during warranty but everything else went within the last year.
Luck of the draw I guess. It still has a fun to drive aspect to it though. Proably more than other compacts from 1994. With all the work it's had it is running smoother then ever before but having it since 98' I am ready for a change.
As for recalls check with the NHSTA. They have a website but I don't know the address.
Problems which are deemed dangerous or very common will end up as a recall in which case all affected vehicle owners must be notified.
There is no grey area. TSBs are just helpful fixit hints.
The 2002 I drove for a day while my L300 was getting the oil cooler coolant leak fixed. Was a much smoother engine than my 94 SL2. It diddn't have the performance/normal switch on the automatic like mine does which does do alot for quicker throttle response. Actually I notice a big diffrence. I do use oil in the SL2 but I just add a 1/3 of a quart usually on fridays just to make it a habit so I don't let it go to long. But I drive alot each week.
As for the single cam engine with auto. We took a bath when we traded in our SW1 for a L300 but the power of the V6 L is fantastic. I am never at a loss for power in any driving situation.
With the SW1 you got going ok but once we had to slow down , then get back on it it just made noise. it was downright dangerous, we just couldn't live with that car anymore although it was very reliable.
