Visitor Agreement.
In the right, rear compartment, where the jack is stored, there is a black plastic box (approx. 3.5"X2.5"X1") with a wiring harness plugged into it. I carefully opened this box and found a small circuit board containing two relays. One relay activates the solenoid to release the glass hatch and unlock the right dutch door. The other relay locks the right dutch door about 2 seconds after the the hatch is closed. The second relay had blackened contact points from arcing. It seemed that if the second relay failed to lock the right dutch door, then the first relay would not activate the solenoids to release the glass hatch. I carefully cleaned the contacts on both relays and also cleaned the the circuit board contacts where the wiring harness plugs into it. I have not had a failure since I did this, but if I do, I will replace the entire black box. I hope this helps all who have experienced this problem. Please write if you find the solution to this problem to be anything other than this.
Thanks again,
AstroLTMan
Steve
The replacement radios they're installing are defective, and Chevy Customer Service doesn't care!
Please help!
David
Steve
Does the 98 have the GM security key. I have starting problems occasionally with Oldsmobile's with the security key. But is usually a minor inconvienance.
There are two things to check to start isolating the problem.
Is it not getting fuel or spark? Or possibly neither.
It is a strange one in that the check engine light doesn't come on.
After checking for fire and fuel.
My approach would be check plug in wiring connectors by unplugging and plugging back in. Possibly a corroded or bad connection.
Just an opinion.
Good luck
I know you probably already knew this, but any spark when removing a gas tank is not going to turn out good. Be careful.
Jim
I store my 97 a lot and get misfire on startup after 1 to 2 months.
There are three (3) count em O2 sensors at $70.00 per ea. at Auto Zone. Which one????? good question. But if you have 70,000 miles or so on the van What's $200.00 or so.
I would also buy the special socket at about $7.00 and go to work. The anti sieze is on the new Bosch O2 sensors.
All three are easy access from underneath. But a little van elevation is recommended.
The heart of the system is the O2 sensors at GM. Let an O2 sensor malfunction and GM shuts you down. If you have been using premium fuel. Shame on you. the fuel pressure regulator tires out. the assembly including all injectors is about $550.00 material cost. The injector system is an assembly. The problem component is the fuel pressure regulator. But it is replaced by removing the top intake manifold, there are two, upper and lower.
Welcome to the wonderful world of modern technoligy.
I have been hesitant to use extra injector cleaner due to the plastic injectors and the known problems with the fuel pressure regulator. But perhaps the cleaner is the solution to all the problems. That would be wonderful. I know that California fuel, and premium fuel cause fuel system problems.
Anyway, I'll try some injector cleaner and see if it helps.
Steve
Hope this helps someone in the future who has these problems, it's a cheaper fix than a fuel pump replacement.
Went to a 2nd dealer, don't know exactly what he did, but called me over at the end to show all 4 wheels turning up on the lift. He claims the front wheel sensors the other dealer looked at were for the ABS brakes and were not related to the AWD.
I have located the broken section laying on top of the intake manifold, however have no clue as to the connecting points.
Thanks in advance.
Enjoy the room inside and load it up, if you have enough stuff.
Comparing the mid sized GM vans to the FWD mini vans is like comparing apples and grapefruit. Hook a 5500 pound travel trailer behind one of the mini haulers and see what happens!
When I start the van quite a lot of smoke blows out, but then it seems to run fine. From reading the posts I figure it is valve seals? Is this any thing to worry about?
The front foot of the frame is rusting. The guy at the shop says this is nothing to worry about for a few years, but it does bug me. Should I spray some anti rust paint stuff on the frame, or just figure it would take years to cause any real damage?
I sometimes think about new vans, but this one seems to far exceed its "trade-value" in "real life value". It need paint as it is flaking in spots, I just wax it and hope it keeps working. It has big sticker stripes that look like some strange Starsky and Hutch nightmare. My kids affectionally call it "the man van". They are too young be bothered about old or new car stuff.
Chevy redesigned the sliding door lock on the 2003 Astro vans. IT FEELS LIKE IT LOCKS IN THE OPEN POSITION, BUT IT WILL CLOSE WITH ONLY FINGER PUSHING PRESSURE APPLIED AT THE REAR OF THE DOOR. WHOEVER OWNS ONE, PLEASE, PLEASE!!! HAVE SOMEONE HOLD THE DOOR OPEN WHILE ENTERING OR EXITING. IF ON A HILL THE DOOR WILL SLAM FAST AND HARD SHUT.
PLEAE BE CAREFUL.
I contacted NHSA and filed a complaint with GM. The complaint number is #1-697668689. The dealer admitted that the new design sucks , but he cannot adjust or tweak it beyond the established GM Manual requirements. i understand his position.
Please be careful out there.
I had a 2000 AWD Safari and just traded it in on an order out Red/Tan 2003 AWD Astro. The 2003 Chev Astros and GMC Safaris are Clones: same price, same features, same colors. Best buy is who has the best price.
They are made on the same Baltimore assembly line, just depends on what day it is. Differences are grille trim and some labels/badges.
They are going to make them at least through 2005.
They took out the second seat fore-aft adjustment so it is now impossible to get into the 3rd seat. I am having the dealer find me a previous year adjusting mechanism.
You cannot sit upright in an Astro/Safari in a wheel chair and there is no legal way to secure it on a factory model. Removing the two seats is a two person job. Do it alone and you will scratch up the trim and the vehicle. They are REALLY clumsy. I added rubber strips to the rear sill so it doesn't get all scratched up.
The high pitch whistle is likely the alternator bearing. They have a new alternator from 2003 onward (previous years DO NOT FIT) and the bearing on mine made a high pitch faint squeal/whistle that came and went until the dealer finally pinned it down.
They also don't supply the under passenger seat storage box any more on LS even though the factory specs call out that item as included.
I have installed aftermarket wheel wheel chrome, front and rear spoilers, mud flaps in rear, (vehicle has factory running boards so you cannot put mud flaps in front), moved the front seats back 2" for more leg room, put in a center console for arm support (factory arm rests are junk).
Cheers
Dennis O
