Chevrolet Impala Audio
12526272830
  • quietproquietpro Member Posts: 702
    Frank,
    Would you agree with Martin as to the performance of your stereo? No hiss at all? Would you care to run any of the little experiments that I listed a few posts back?
    Thanks buddy!
    Ron
  • mymittiesmymitties Member Posts: 242
    Hi there Ron.. For you my friend, ...Anytime..!!
    Well, my 8 speaker Premium Bose Sound System has been working flawlessly from day one (October '06). So, as a little background, there hasn't been any reason at all for me to replace my amplifier !! It's still all the original "stuff"....
    Now then, after reviewing your post one more time, I went through the list of tests for you, and I have to honestly say that there is absolutely No HISS or any other noise or distraction in my system at all!! You know, in my opinion, both the volume control and sound quality here are every bit as good as any so called upper scale GM radio/sound system I have ever had. FYI.. About 30-40% volume on mine can be very loud..!!
    Not wanting to be "puffy" here, but I do have somewhat of a discerning ear when it comes to the quality, clarity, tone, etc. etc. of music & system....So, this Hissing sound thing would drive me absolutely crazy and staight to the GM dealership for sure..!! Some say that enjoying Sound quality and enjoying Music are usually two different goals....
    Geeeeee, I sure do miss my full-set of EQ's....
    Have a great Easter....
    Frank ;)
  • colchester47colchester47 Member Posts: 261
    my wife hisses at me sometimes....is that the same hiss that you guys are talking about? :confuse: .............Love my Impala,and my wife....when shes not hissing at me!! :mad:
    Hey Bryan....... HER HISSING!!!!
    Now, remember the words of Elmer Fudd here...
    BE WERY, WERY CAREFULL......!!!!!!!!
    Happy Easter
    Frank ;)
    PS. Gee, I better say something about my car here or,
    i'm in deep ********* Ok...Love my Chevy..!!
  • wesleygwesleyg Member Posts: 164
    Several times in the last 6 months my SS has had a humming noise in the radio, this happens when I am sitting in the running car with the drivers door open several minutes, no seat belt on. The humming is quite loud and even shutting the radio or CD player off and then back on does not stop it.
    The cure I found is to switch on the turn signal for several flashes, and bang it's gone. Since it's so infrequent and I have a cure, I don't want the dealer to mess with it. Any one else have this? Thanks
    Frank,
    You don't sound "puffy" to me. I would put myself in the same class, as a matter of fact. Now that a few of you are telling me that the Bose system actually SHOULD be a quality system, I will be looking to find an '06 Bose system on the Chevy lot to compare mine with so I might be able to get some warranty work done. Mine definitely doesn't meet the standard of premium. I just wish we lived closer together so we could compare "face to face." But, I do thank you for your help...as usual.
    Thanks and I still welcome other '06 Bose owner opinions. The more the merrier! I think we're 2-2, currently.
    Ron
    P.S. - Frank, one more thing, would you be willing to either take a picture of the amp in your car or give a good physical description? I'll post a picture of mine soon.
  • zappalandzappaland Member Posts: 5
    This is the definite fix i had to take out all the trim and the rear seat but here it is. The amp had no power also the chimes did not work, key in lights on and the like. On the passenger side is a wiring harness the wire that runs off the radio fuse splits at about the area of the post between the two doors( called the b-post)it is orange in color and where it splits is a factory connection.this connector is in the wiring harness and it will be wet just because of the weather and where it sits. I pulled off all the trim and rolled back the carpet. I pulled on all of the orange wires untill one came free not hard but a firm pull. I then used a butt connector and some shrink tube . and i fixed the problem.
    1 if your radio appears to be working and the cd tracks
    2 if you have no chimes
    3 if you have no power to your amp GO TO A SHOP AND HAVE A MECHANIC USE A TEST LIGHT
    THIS IS YOUR TROUBLE SPOT
    YOU WILL HAVE TO GO TO A BODY SHOP TO GET SOME NEW PLASTIC PINS TO PROPERLY RESET THE CARPET,USE A SHITLOAD OF ELECTRICAL TAPE TO GO OVER THE HARNESS TO KEEP IT DRY AND AS LONG AS YOU HAVE IT OUT CHECK THE GROUND IN THE FOOT WELL OF THE FRONT SEAT FOR CORROSION AS MINE WAS STARTING. I GREASED THAT AS WELL.
    Huh??? :confuse:
    Holy Butt Connector, batman..!!... Ripping, tearing, rolling back carpet, removing trim, etc. etc. etc...... and a big load (the "S" word here) of electrical tape you say..!! :cry: Waaaaay Toooooo scarey for me..!!
    Hey Z, by the way,....What year Impala are you working on here...'06/'07 or...???
    Anyway, Congratulations on your fix.
    Frank ;)
  • mjagsmjags Member Posts: 4
    Thanks for the reply. Do you happen to know which terminal at the amplifier is the power feed? I seem to have power at most amp terminals but I don't have a wiring diagram to know for sure which is the main power feed. Thanks.
    You were absolutely right!!!! Pulled up the rug on the passenger side and the backing was soaked with water. Pulled the harness out of the black plastic conduit and found the orange wire splice corroded. Repaired the splice and all is well again. I've got tunes after 3 months of silence. Many thanks zappaland.
  • capo33capo33 Member Posts: 6
    Zappaland is THAT DUDE. I fixed my radio too. Now, I don't have to talk to these females on dates!!!!!!!!! Thanks a million bro.
  • itsmetk2itsmetk2 Member Posts: 3
    Our radio locked on our 2002 Impala. The dealership said it was the battery. So, we replaced the battery. Still locked. They said it was the battery cables, maybe. For $400, I wanted a for sure..so they said it was a bad radio. $500. Still locked. Now they say, we will see what next it could be. Anyone else had to pay for their guesses? My husband the electrician has told them it has to be the wires not talking to the computer correctly, or the computer itself at this point. They keep telling us, no, it could be an infinite number of things, we will just keep trying. Any ideas?
    I'm no expert but I thought it was a security thing that was VIN dependent and had to be programmed through the vehicles computer when it became locked out. Have you sought out a second opinion from another dealership? :sick:
    When they replaced the new radio, they reprogramed the computer, and it still locks out the radio. A dealership in another state that we were visiting in, said it was the computer. This is dealership today got all offended, and said there was no way it was the computer.
  • montessmontess Member Posts: 1
    Hey just wondering if there is a way to bypass the amplifier? My Monte Carlo came with a stock amp and has seem to have gone bad and now I don't get any output from my speakers but radio is fine. Before I buy a new amp I was just curious if you found out how to bypass this amp.
  • jntjnt Member Posts: 316
    One type of GM radio theft lock (newer type): Every radio when put in a vehicle is given the VIN number of that vehicle via the vehicle data bus. This information is stored inside the radio's computer. Every time you start the vehicle, the radio expects the VIN info from the vehicle and compare it with its VIN number. If that info is not sent or wrong info is sent, radio will be locked. Any competent dealer should be able to fix this problem. So there may be problem with the vehicle module that sends out VIN info (BCM ? since it controls all other security aspect of the vehicle).
    Older theft lock scheme: no VIN data is sent. Owner has to enable this feature and then enter his own security code. And that code is stored locally in radio's computer. As soon as Battery is disconnected from the radio (someone steals the radio and uses it somewhere else), the radio will be locked until the owner enters the correct code. For this type of theft lock, the dealer could also clear it for you for a small fee ($50)
    For your 2002 Impala, you could buy an Aftermarket radio and stick in the dash to be done with. This vehicle supplies typical Aftermarket radio with essential signals to make it work (12 V battery, Ignition, Ground, and speaker connections) and forget about the vehicle bus. Circuit City is selling vehicle adapter harness ($15) for all types of vehicle. A decent Japanese radio could be had for less than $200. You probably have to buy antenna adapter too (Circuit City or Radio Shack) since GM radio uses smaller connector vs. typical Motorola type.
    jt
    The chimes for the car all run through the amp. When you leave the signal engaged for an extended period (forgetig it after a lane change) this also has a chime to it.The buzz could be coming from that.When you turn off the radio and the car, the amp stays engaged to provide the chimes.You could have a bad amp or just to much input for an extended amt. of time.
  • 06impalalt206impalalt2 Member Posts: 1
    I have a couple of questions concerning my car. It is a 2006 Impala LT1. 1) Is there any way to put in the higher-end factory radio, and if so, any idea on the cost (I'd also like it to have XM)? 2) Is there any way to add on the steering wheel audio controls, and if so, any idea on the cost?
    I had a car picked out, but when I went to the dealer and told him the one I wanted, he sold it about 2 hours before I got there. The dealer only had one Impala left, and this was during last year's 72-hour sale with 0% financing (around July 4th). So, I took the car that didn't have exactly what I wanted, figuring I'd save the extra money to get what I want later. Am I stuck with what I have, or can I add these things?
    I feel like the dealer's giving me the run-around, so I'd like some honest answers and advice.
    I don't have a good idea on what the costs of upgrades will be but I'll bet it will be pricey. For the steering wheel controls, at a minimum, you'd probably have to get the upgraded steering wheel...assuming the wiring is there...which it may not be. The same would apply for the XM in the upgraded factory radio. You'd have to get the XM antenna and assume the wiring is there. I think because of those reasons, it would likely be cost prohibitive. You're best bet would likely be to go with a nice aftermarket stereo system. For the money, you could probably get something nicer than the factory systems anyway. I have the Bose system myself and I'm not overly impressed. You're only drawback would be that it wouldn't be factory. But, a professional installation would be just as nice or even better. :)
  • pbaranellopbaranello Member Posts: 36
    jnt
    It is ironic that you state that the 2002 Impala radio can be changed without a problem and the 2006 radio needs the VIN to match among other things that would prohibit someone from doing this.
    I have a 2002 Impala and that radio is outstanding, I would not even think of changing it.
    My 2006 Impala radio in my 3LT or LT3 however you want to say it, sucks.
    I have all options on this car just like the LTZ except the upgraded radio? The 6 speakers are great but the stock radio cannot push them. If I have too much back speaker, I have to literally turn the volume all the way up to maximum to blend the front and rear properly.
    I am 55 but I still like to crank it up now and then and the 2006 stock radio is just so limp.
    Why would Chevy put all available options in this car and not an upgraded radio, it is beyond my comprehension. I just did not catch it when I got the car.
  • zaeevanszaeevans Member Posts: 1
    My wife and I have a 02 Imapla whose radio keeps locking up but will unlock when the car is turned off and the door is opened. A dealer in Topeka, Ks told me that it was a problem in the Body Control Module and that the car would need to be reprogramed at a price of $100 - $150. I went for a second opinion in Lawrence, Ks and they said that the radio was bad and I needed a new one. They also said that the BCM doesn't have anything to do with the radio locking up. I was wondering if anyone has found a solution to this problem other than an aftermarket system.
    Impala 's BCM is virtually controlling all security aspects of the vehicle including horn sounding, power door lock, ... So it may be responsible for the locking up of the radio as well
    So you may have a bad BCM unit and I do not know if the problem is software or hardware. If it is software related, then reprogramming the module seems to be a logical choice. If the hardware is bad, replacing module may be the only option. That will set you back $200-$300 for the replacement unit
    The second dealer could be right on the bad radio also. If the replacement radio did not do the trick then the first dealer may be right.
    There is also a third theory: pinched or intermitten vehicle
    bus wire that somehow keeps on disrupting the communication between the radio and the BCM module. In this case, replacing either radio or BCM module would not fix the problem permanently. This theory is only valid as long as the vehicle VIN info is required by the radio
    Some newer GM radios need VIN info from vehicle to unlock. That info is from another module outside of the radio. Every time you power up the car, the radio requires VIN info and compared with what it had last time. If the VIN info is not there or incorrect, then radio would lock up. It is their version of theft deterent. Older GM radios requires you to enter a code and that code is stored locally inside the radio. In this case no communication is required with vehicle's module to get VIN number. So consult your vehicle's Owner manual about the radio's theft lock to see if the code is required or not. That will tell you what scheme is being used on your Impala.
    Good Luck
    jt
  • vsztulvsztul Member Posts: 1
    I have lost my sound in my 2000 impala radio. It would flicker on and off for a few days, but now it does not work at all. The information shows up on the radio and the cd player is working but there is no sound. What do you think it is? Has anyone else had this problem? The dealer wants $80 just to tell me what is wrong and if I need a new radio. How could my radio be bad?
  • ferranteferrante Member Posts: 6
    We have an 01 impala and have been trying to figure the same problem out for over 4 months now. we cahnged the radio and had it coded at dealer , still didn't work , we changed the amp in the back , still didn't work , we were told there a coaxial module in the back above speaker deck, changed that and still no sound , we are lost . our dealers told us they cannot find the problem. becuase th eradio does work just no sound , so when scaned comes up as working, go figure. we're at a stand still and singing to ourselves on long drives. hope u have better luck.
    I have a 2002 with 78,000 miles, (premium radio) and a 2006.
    So far other than the lousy volume power of the 2006, (with standard radio) both radios are working fine.
    I just have to make one comment:
    What is wrong with this picture, when GM/Chevy cannot diagnose OR fix their own cars...???????????
    Sometimes radio's computer suffers braindead incident. Try disconnect the radio fuse(s) and then reconnect them after 2-3 minutes.That will reset the radio. If your radio requires some sort of theftlock code, then you will have to remember the code and enter it to unlock the radio.
    Another possibility: if the system has external Audio Amp, that module could be bad.
    If there is no Audio Amp, then sometimes short on speaker coil could cause the radio's own Amplifier to shut down. And therefore no Audio
    jt
    May be in your case, there is speaker problem: short more likely (between the pair or to Ground). In theory, the speaker coil if shorted would blow the Audio Amplifier (internal for base radio, external Amp for up level). In practice, these amplifier has protection: it shuts down to protect itself in such a event
    To figure it out, you will need to disconnect one speaker at
    the time. If you disconnect the bad speaker from the system, the system should recover (provided its protection work).
    If doing so is dificult, you could try to take the entire radio off the dash. You only needs 3 wire to power up the radio: 12V Battery, 12V Ignition and Ground (Ground is tied to metal chassis). So basicall, both 12V Battery and Ignition can be tied together and they are next to each other on the Main power connector. Next step is to find any portable speaker and connect them to at least one pair of Speaker output (Front Right+ and Front Right- for example). You should hear some white noise or even music if you tune to a strong local FM station. You should be able to find the pinout of this radio in some previous posting.
    jt
    There are good dealers and bad dealers. I doubt that GM engineers could not figure out the problem. If not, their suppliers enginer could in no time. You can find incompetent dealer tech among Toyota, Ford and others too.
    jt
  • p62480p62480 Member Posts: 8
    I recently purchased a 2005 Chevrolet Impala LS with Onstar, but no factory XM. I want to purchase the XM direct kit, and I was wondering if anyone knows if the Onstar antenna also includes the XM antenna. If so how or where are the connections for the XM part?
    Yes, the On-star and XM antenna is the same, located on the rear middle roof.
    The only other antenna you have is for the remote start feature and that is located on the top of the front wind shield where you see the web like design across the entire top of the glass with a small button located in the drivers side corner.
    When and if you replace the wind shield, this needs to be taken into consideration.
    As far as installing after market XM, I have no clue but I know others have done this with Sirius radio.
    Good Luck.
    Does anyone know where the wiring for the combined antenna would be if its available? Thanks
    check out my previos posts i found the problem and fixied it
    Chances are its wet because of your Hepa filter , Under the cowl sita a filter for the cabin , after time the ruber around filter weathers out and un seats from the box wher filter sits , get new filter and use black atv siicone and make sure when put back a perfect fit , Try this , we spent 2 months driving around with no carpet trying to figure out where teh water was coming from.
  • fathertyriciusfathertyricius Member Posts: 116
    I have the 103 amp in my 2001 LS and my stereo has great sound and performance. I had it replaced over a year ago due to the original amp shorting out and it was replaced with the same amp # 103. The sound quality is excellent. Good deep bass with the setting set two notches positive from center and excellent highs three notches positive from center.
    I cannot say what the problem with the locked radio is but allow me to give you my insight to GM dealers from years of experience. I know that Warranty's are a crap shoot but when you have a warranty on a GM vehicle, whether factory or extended warranty the dealers do what is required and whatever the repairs are it is paid for. If you don't have a warranty they take you to the cleaners.....
    I have never had a purchased extended Warranty from GM dealers that has not paid for itself, whether the repairs are actual, bogus, or pin the tail on the donkey repairs.
    I am not condoning extended warranty's but this seems to be the way dealers operate.
    Just a side note:
    MY wife lost her key and key fob to our 2002 Impala. (this is not under warranty)
    I called my dealer and they quoted me the following:
    1 Key fob - $63.00
    1 - Key, non chip type - $7.74
    Program new key fob - $40.00.
    Bottom line approx. $110.00 to replace a lousy key and key fob.............
    I went on line and purchased a key fob for less than $28.00 and programmed myself. I did pay $7.74 for the actual key but approx $35.74 is a far cry from $110.00 if I went to the dealer.
    For you anti American car buyers the foreign car dealers are no better...................
  • apetersseapetersse Member Posts: 1
    I have the same exact issues with my 06 Impala LTZ. The hissing, hiss, or distortion is to me unacceptable. When I buy a vehicle with premium sound I expect just that. Any reasonable person would agree that the amount of distortion in the Bose premium sound system does not fall within the specifications of premium anything.
    I have attempted to fix this issue though 2 Chevy dealerships. Each attempt brings no resolution just frustration and them telling me that I’ll just have to deal with it and there is no fix.
    This is why I am looking for people with the same problem willing to bring a class action law suit against Chevrolet. All I am after is a replacement radio or a monetary amount to fix the issue myself.
    Please contact me via email apetersse@gmail.com if you are interested.
    Andrew
  • prigglypriggly Member Posts: 642
    Hi Andrew,
    I am sorry that you are having hiss in your Bose system. I have an '06 Impala SS with the Bose system and it has no hiss or distortion or other problems. The sound quality has been truly premium from day one. I am very happy with it.
    Has either of the dealers you went to replaced the amp? If not, I would suggest this is a place to start. There must be a solution to your problem but I am not sure a class action suit is it.
    Andrew,
    Have you had any work done on the stereo in your car? There was a fix for the stereo and I had it performed on my car. While it did improve the problem, it was by no means a real fix. The hiss is still there and the overall sound quality still leaves much to be desired. I actually refrain from listening to much music, especially at higher volume levels because there are certain tones that just seem to resonate through my skull. This doesn't happen with any other stereo, just my "premium" Bose system. I've adjusted my bass, mid, and treble all that I can to try to alleviate the problem but it just doesn't help.
    As for a class action suit, it's a great idea in theory but I just don't think there are enough of us. Most of the folks who have shown up on this board either don't have the same problem or don't hear it. The Better Business Bureau may be a better option for us although I've pretty much given up. I will just never buy a Bose product again. Please let us all know if you make any progress.
    Ron
  • connersdad19connersdad19 Member Posts: 1
    I have an aftermarket cd player installed in my 2003 impala 3.4l.....well its been in for about 3 months now....i accidently hit a pothole the other day and all sound cut out....the cd player is still working and everything...so i am thinking it could be the amp....i want to do the bypass to see how it works but i have not found detailed instructions to this anywere even when i search...can someone help me out please....i need some music....lol
  • bigjim5bigjim5 Member Posts: 3
    Why did you have to replace your amp? My sound recently died (radio.cd.tape still show as being on) and we are trying to decide if amp replacement in necessary.
    Jim
  • kgblackkgblack Member Posts: 1
    I own both a 2000 LS and a 2001 standard sedan and both have the top line radio with both CD & Cassett. I bought the LS for my son used after really enjoying the Wife's '01 bought new. Both sound systems were very good until I decided to fix the boy up for Christmas and get a stronger amp and better speakers.
    Knowing less than nothing about these super sound systems in cars I relied on a couple of my employees who were always installing systems in their, and their friends cars. (Bad move) They told me what to look for in equipment and off I went to the stores. I got speakers and a good amp and some supplies on their list and they were all fired up. A week or so later they still had the car torn apart and nothing was working at all. They had burned up the first amp and I got another on warranty. I realized that they had no clue how to deal with the stock system which I insisted on retaining since the thing programs the whole car!
    I finally made them put the thing together so I could take it to a professional shop and it cost me a ton to get it straightened out (suposedly) and it did work pretty well for about two days then one speaker after another quit. I'll not bore you with more details but I decided to try to get it back to the stock system with just some improved speakers (as the originals were destroyed by now) and it was restored by removing the output units needed to bypass the original amp. It worked for a few days then one side of the original amp fried. I called the local Chev store parts and found it cost nearly 400 bucks to replace the stock amp. NO WAY!
    So, you guys in Chevyland that know all the good stuff, where should I go from here other than to my nearest Ford dealer? I have checked around for a used amp and had no luck locally. I am soon going to get the car back from my son (and his wife now) and get them into a nice minivan for the new grand daughter. I recently dumped a load into the engine and accessories so I will probably hang onto it because it is such a nice ride for me. I do need sound, if for nothing more than to listen to Rush Linbhaugh on AM.
    I'll be listening to your suggestions.
    If the whole process has not fried your radio 's internal audio amplifier yet, you could just hook the 4 speakers directly to this Chevy radio and restore the sound without buying the new amp.
    This particular radio can drive 4 Ohm speakers directly since it has internal amplifier. Besides, the original cheapo amplifier is a lousy one so you will not miss it anyway.
    At the location of the original amplifier, you basically bypass the amp by connecting its inputs (from radio) to its output (to speakers)
    Four pairs of speaker outputs from radio :
    1. Left Front +, Left Front - : to Left Front speaker
    2. Right Front +, Right Front -: to Right Front speaker
    3. Left Rear +, -
    4. Right Rear +, -
    Each of these wires (on radio side) are has DC voltage on them. They are normally set at 6-7V (1/2 BATTERY voltage). If you have Voltmeter, you should be able to double check.
    To check if radio internal amplifier is OK: Since I do not know the physical connection at the external amp, my info is generic only.Amplifier box typically has inputs from radio and output (to speakers) located in the same connector. So you need to go to Chevy dealership to ask for help (electrical pin-out). This is available in their Electrical diagram
    Here are basic steps
    1. Turn radio on
    2. Find the Left Front + and Left Front - pins (from radio).
    3. Connecting each pin with each pin of speaker (known good one). If you hear sound , that radio speaker driver is OK.
    4.Repeat Step 2-3 again for the remaining driver pairs
    The above steps are to confirm that your radio internal amplifier is not dead yet.
    After that, just connect these pairs to the corresponding vehicle speakers directly. Again the connections to the vehicle speakers are at the connector. If you suspect original speakers are bad, disconnect them, then try one at the time. Note that two terminals of each speaker must not short together. If that happens for long, the radio amplifier drivers will be damaged. Bad blown speakers could have their terminal shorted (causing radio amplifier to shut down or burn up) or open (no sound)
    So basically, you need to get the electrical pin-out of the external amplifier's connector(s) for this experiment. Some people in this forum may be able to help. If not, stop by a Chevy dealer and ask them. From there, you could do your own experiment and save you $400
    Another way: stop by a junk yard and they may sell you an used one for a lot less. Make sure they can let you return if it is not working.
    Good luck
    jt
    Sorry to hear about your problems, kg. I love my Chevy and the one I had before it but one thing I decided early on after CONSIDERING a stereo upgrade was to forget it. The GM systems are just too integrated into the car's other systems and until GM separates them (which they may have somewhat with the '06+ Impalas), I will never mess with it. The repair costs of something going wrong just aren't worth it to me.
    One bright side to your story, though. You DON'T have to listen to Rush in the interim. :P Sorry...couldn't resist!
  • maijinstingmaijinsting Member Posts: 5
    I read through some of the messages in the Impala Radio thread and am experiencing the same letdowns everyone else is.
    I decided, after owning my 2004 Impala, for the past three years, to finally upgrade to a touch screen.
    I heard through a customer in my store that the chevys have something called an information module/system that hooks into the factory radio. it basically controls the on-board monitor system/light in your dash about your oil/tire pressure/etc.
    after the guy installed the new system and amplifier, all of my speakers in the car died. the customer, who had been through a similiar issue with his malibu, told me i have to find an aftermarket information module so i can access my car's electronic functions.
    has anyone gone through this? and if so, did you you have to buy the aftermarket module, how much and from where?
    any information would be greatly appreciated. thank you
  • damagedradio1damagedradio1 Member Posts: 1
    I am having problems with my 2004 impala ss i put an aftermarket cd player in and it worked for a couple months then it started to pop out at high volumes then it just completly went out and then i put my stock radio back in and it still didnt work . Then a few weeks later i shut my door hard and it poped back in and worked for a while and then only worked low it started to sound like all the speakers were blown then i lower it and it works again . I moved a couple wires and it worked perfect for a coupoe days now it makes a wooping noise and i lower it all the way it stops then i turn it up with no bass and it works almost all the way up then woops again. Does anybody know wtf is going on please help me im a music freak with no music. and i dont want to replace the stock amp and thats the answer i keep getting from everyone.
  • 01_1mpala01_1mpala Member Posts: 2
    Hey...I can barely hear any sound from the speaker on the driver side of my 01 impala.....I can only hear a faint sound when I have my ear up to it and its set to the highest volume.....I know its not the actual speaker since i had two different ones installed and they both worked fine....I can hear the sound from all the other speakers just fine.....Everything in the car is still factory......I've heard it could be faulty wiring or the amp going bad.....Has anyone else had this problem or know how to fix it without my having to spend a whole lot of money?.....I need help please!!
