This get's better mileage than my 92 Festiva
did and it had a 1.3 liter engine, not to
mention it was like 1000 pounds lighter. :-)
http://www.toyota.co.jp/Showroom/All_toyota_lineup/CorollaSedan/index.html
By the way, I always went down the shore when I grew up in the Philadelphia/southern New Jersey area!! In fact, every time I am there I pay a visit to the ocean.
Thanks again.
good luck. :-)
Now I need help choosing the right tires for my '99 corolla. After 3 years the treads are gone. I'm looking for tires that will be good especially for rainy days and also be the right size and fit and provide a comfortable ride for everyday. Any input would be greatly appreciated. Thanks.
I'd go with Michelin X-One.
The Sandman :-)
Check out the Tire Rack link for more info on tires and if you want to see what the treads on diffferent brands look like.
Good luck!
The Sandman :-)
If so, could you explain the physics of this?
~alpha
~alpha
As a rough rule of general thumb, IF you are staying with the same diameter wheel [14"], then to keep the rolling diameter the same, you go DOWN one aspect ratio for every increase of 10 mm in width. That is, to maintain the same rolling diameter as the 185/65-14s, you could mount 195/60-14s, and these would have about the same rolling diameter [and better handling at the expense of ride quality]. By sticking with a 65 aspect, and going to 195 width, you are getting a slightly taller tire.
tire........sidewall...change....%change
185/65R14....120.25mm...-.........-
195/65R14....126.75mm...+6.5mm....+2.2%
195/60R14....117mm......-3.25mm...-1.1%
205/60R14....123mm......+2.75mm...+0.9%
The % change is based on tire and rim total stock radius of about 120+178 = 298mm. (178m is about 7 inches, the radius of 14" rims)
Anyway, my question is, does anyone know the width of stock rims for a 96 corolla DX, or where I can find that information? I suspect they are 14x5.5 inch rims, but I don't know. I want to figure out if the 205/60R14 tires would fit. Thanks for help.
how's the manual tranny? smooth?
i just ordered a indigo ink 2003 CE 5 speed (base)today. hope to get it by the end of this month.
I think 205s would be stretching it on these wheels - I could see 195s with no problem.
If it was rough at first then went away after running the engine awhile, then something just got wet, chances are somewhere along the ignition system. Good luck.
This is also on other cars as an idiot reminder for service at certain milestones like 60k and so on. Maybe somebody else might know some tricks to the engine light. LOL! Glad to help.
if something is really wrong, that light will come back on. it sounds like water got into your vacuum hoses (maybe).
i spray the engine with engine degreaser while the engine is warm. then i start up the engine to make sure the engine stays warm and start spraying water. i do this coz with the warm/hot engine, water dries up very quick and chances of water going into your ignition, etc. is very slim.
i've been doing this for years and never had any problems at all.
http://www.alldata.com/TSB/0359_mo.html
can't believe that the 2003 models already have tsb/recall. anyone had problems with these?
And if you get in a sweat every time the notorious OBD II software raises its ugly head, you're going to spend a lot of time perspiring. Toyota and Honda and everyone else told the EPA that the OBD II problem thresholds were too low, and that owners would be subject to meaningless OBD alerts, but Our Govt didn't listen, as usual...
hopefully the car i ordered won't have to go back in the shop for these two things.
~alpha
i ordered my indigo ink corolla but none is in-stock and if i really want that color, have to factory order it and wait until oct. to get the car!
so i had to settle for a silver colored one. still waiting for the car though.
Mine was built in Japan. Maybe that's the difference, or maybe they changed the design in July when mine was built.
Anyone else with body color window frames?
I am very glad to have the painted frames. They should hold-up longer than the black paint. My Camry had the blacked out frames and after 150,000 miles the black paint was thin and discolored.
Thanks for the info.
all canadian models have painted window frames, oem mud flaps. what we dont have is standard a/c on all models. i believe a/c is standard for all models in usa.
canadian CE models have black door handles. sport, LE models have painted handles.
Painted window frame by rlander01:
"Also, on Toyota.com the pictures show a black window frame.
Mine was built in Japan. Maybe that's the difference, or maybe they changed the design in July when mine was built."
i didnt know corolla's still come from japan. i thought they are all built in canada and usa.
Only had one "S" available (in red). Car looked real good, outside of the many bird terds left overnight!
Gauges in white were great! Elbow and headroom (no moonroof) were also exceptional. Armrest too far back and a little low.
Only had Auto there (&%$#!), but the torque was good from a start! Quick pick-up.
I've spent a lot of time in the current Dodge Neon, and it reminded me a lot of it, especially in the engine noise! No quieter than the Neon! Shocked! I was expecting the "Baby Lexus' treatment.
Steering and handling were fluid, friction-less.
This car suffered from a mechanical whine whenever the car was in motion. Sounded like a supercharger, without the power or anything nice.
I was in for service at a nearby dealership, so I wasn't buying anything, but they sent me thru 3 Toyota Closers, and had me there for almost 2 hours (couldn't find the key to the car).
And I asked specifically for a stick! Not the best car experience in the world, huh? Still dig the car! But it is louder than I thought it would be. It had a lot of "personality" for a Corolla!
i've seen this black out tape on other cars (vw,etc.). they look great when new but they start to peel and crack when they get old.
window frames on my CE..they are body
colored (charcoal). I guess the black
makes it more chip resistant or something,
but I actually prefer the body colored frame.
However, as stated, the regional manager is coming due to the fact that all 3 service people did notice the constant vibration in the rear-view mirror. While that's an annoyance that I do not want to have to deal with, it's the handling that affects me the most and I want that issue dealt with first and foremost. Therefore, my case is now a "potential arbitration" case now (they already tried replacing the rear-view mirror one time and it is worse).
I was wondering if Vicarouza has ever gotten the handling issues taken care of, or if they had to go through arbitration? If so, what was the result of that?
