Is the '01 Express LT good or not? My mini-van is rough riding besides hard to fit into;
However the LT is on a 1/2 ton chassis;
We won't be towing with it, however, just hauling the family around;
Would a conversion van from a decent converter be better/not?
Thanks for the time;
Good Luck.
Right now there is again an intermittant rattle from the exhaust and I am again dropping it at the dealership. It has been about 3000 miles since the new muffler was put on. I could not recommend this van.
Try another brand! Good luck!
Bottom line........ I wouldn't hesitate to buy either GMC or Ford except for my preference for leg room. So I oredered the GMC 2001 Savana 2500 extended passenger van, 5.7L, 3.73 axle, loaded, a few months back.
Improvements for 2001 on GMC include a improved torque converter on the 4L80E heavy duty tranny, improved longer lasting brakes, more robust door handles and ignition lock, upgraded audio, quieter alternator, introduction of 8.1 L, and more advanced powertrain control modules for the other gas engines. This was the biggest year since it's introduction for changes!
What do you mean more robust door handles and ignition?!! They look and feel the same to me. My mother in law just got a '01 Savana SLT on the 6th, it all looks ant feels like my fathers '98 conversion as far as the handles and ignition, unless they changed the key to the one with the big head on it and I didn't notice. That key head change would force an ignition switch change, besides GM probably only changed the key because it was the only vehicle left with that style of key, and it's cheaper to have all or most car lines use the same type of key cylinder, they get a better volume discount. I work for GM so I know how they think. I do like the van other than the mirrors, my fathers conversion has only had the front brakes done once and he has 65k on it, rears are at 70% roughly. We do our own work so I know for sure, not just what a shop tells me.
I have heated mirrors and so far their is a very slight vibration on rough roads, and I was aware of it only because of the reported problems I read in the past. I do not consider it to be a problem at all, although time will tell. It only has a bit over 4000 miles now.
Steve
I have had solid performance for the past 2 and a half years with the 7.4 liter engine. Recently I drove a Silverado 1500. The half-ton silverado's are more quick than the van from the start. I don't know about the power curve for the 8.1 liter. I wonder, how does it compare with the 7.4 liter?
Power steering pump leaks;
Instrument panel problems;
Engine oil cooler lines on 6.5 diesels;
Light problems, especially signal,marker light sockets at $ 60.00 or more a pop!
Sliding door mechanism that is made out of plastic and difficult to change. (read high labour charges)
Other than this they're GREEEAAAAAAT!
Please help. Thanks.
To avoid the window not going up, I pulsed it going down that first year. I did not want the dealer to fool around with it even under
warranty. Braking is better now than after the last service at 30K, new pads + resurfaced rotors.
I have linked this discussion into that folder, but it will always reside here in Vans.
Looking forward to meeting everyone!
KarenS
Owner's Clubs
What do you guys think about the Ford Explorer sport? hehehe.
please respond to maybesantafe@yahoo.com
http://209.61.155.43/division/gmc/news/releases/020306_redesignedvans_gmc.html
I believe either the Ford or the GMC are pretty good, and I accept the fact that both will have their own repair problems, but I bet in the long run both will average about the same for total maintenance costs over the years. I'll take the huge leg room advantage of the GMC, and bite the bullet when it comes to any repairs smaller or larger. I want the comfort when travelling, and the ease of getting around the dog house, to me that is more important then anything else in a full size van. I'll live with minor complaints or costs, or wobbly mirrors (although mine does not wobble).
Good luck with whatever full size van we may have! Lets just enjoy what we got. I also prefer it for the huge cargo space, load capacity, towing capacity that mini vans cannot match. This is when I appreciate it even more considering the limited choices we have.
A 1/4" spot near the gutter on the roof was missing paint. Clearly, the spray guns at the factory must have been out of adjustment. It is tough to see this spot since the van is 7 feet tall and the paint is light brown. However, I noticed this the first time I waxed it in 1999 and reported it.
Now nearly 3 years later, I had it fixed. they re painted the entire big roof. Sure, the van was in for a week but I had a great free loaner to drive. Now the paint and clear coat on the roof is new and the thickest. This paint should last longer than the rest.
The cassette deck plays only one channel (right). I'll take that in to get fixed next.
I like the warranty and my service center. Together they are keeping a 3 year old van in new condition without direct cost to me.
As far as the reliability, it has never failed to run well. Other than the paint, I haven't experienced any other problems than I would expect from a similar vehicle.
As a solution for the problem I am wondering if a dab of clear silicon at the four corners would hold it, I will have to look more closely at my mirrors. Then if a change is ever needed you cut through the silicon and add some more. Considering one position is usually enough , it might be a temporary answer, or the only solution for now. Considering silicon is one of the few safe materials used to glue mirrors to walls (other glues dissolve the mirror coating),I think it should hold just nice, and would be quite invisible if a small amount is used.
Although having power mirros is nice, and we paid for the option, I can see that clear silicon (very little) on the 4 corners is the only option for now. I set mine once and have never reset them, so it is not a big deal to me. But since we paid for it, someone needs to take the initiative to complain and get a recall started. That is hiway robbery in my book. Another option to drive the manufacturer crazy is to keep asking for replacements while under warranty. Guaranteed after about 3 replacements (both sides), and if everyone does the same under warranty....they might get the message. Otherwise I love the vehicle so far, and expect repairs in the future like everyone else. With only 2 choices...Ford and GMC in full size vans, were going to have to live with accepting all the imperfections from both companies. Maybe I should hang plastic lemons off both my mirrors (call it lemon mirrors). It should get some attention at a dealership when you drive in to look at some cars.
But so long as the tranny and engine are good, this is more important to me and much more costly. So far everyone seems happy in here.
My 1999 mirrors are ok. No bug deflector on my van. A little wobble at above 70 mpg. After reading the posts, I considered wedging a bit of black closed cell foam between frame and mirror as a temporary vibration damper. Haven't tried it yet because, for me, the wobble is tolerable.
I like the black foam idea over silicone if other drivers use the same vehicle. It allows quick changes, but if it ever got behind the mirror, the stuff might cause more problems. I think we need to be writing this stuff to GMC so they know about it.....Shees!
balanced tires, rotated tires, and replaced driveshaft. Any suggestions out there. It's driving me nuts. Took it to another dealer and they said they didn't have one on the lot to compare it.
Told me that might just be how it rides!!! Please help.
I think it's best to see as many dealers as you need. I got a feeling this is an area not always easy to diagnose and you might be brushed off, there is no money in it for them to spend hours looking for a problem they can't easily find. By seeing more dealers someone might have the right answer or be energetic enough to look carefully.
I would start with test driving another vehicle to confirm your really have a problem, a cargo or passenger van makes no difference so long as engine size and vehicle size are the same. IF there is a noticeable difference, they have to fix it. I've notices smaller dealers love to find things to fix for you while it is under warranty, they will spend more time I think diagnosing the problem.
You might want to buy those manuals and read up on the problem yourself. There not cheap, but there is a lot of information there to save you money in the long run (simple or advanced repairs). You might be the only one to read through it all to give them some ideas.
New for '03 are the following:
1 Left side 60/40 doors, like the passenger side.
2 All wheel drive availability
3 Engines 4.8L, 5.3L, and the 6.0L(3/4 and 1 ton only) ditching the old 305 and 350 engines.
Returning for a repeat performance are the Mickey Mouse wobbling mirrors! They never learn.
I think most here are complaining about the glass itself, not the whole mount. My mounts are solid, and if your looking at a mounting problem, take the door panel off and tighten it. Either way, it does not make good sense to hit the mirrors directly with a high pressure power wash. Touch the glass and you can see how weak they appear in design. High pressure spray is well known to have damaged many radiators, and I bet mirrors are just as susceptible.
By the way, the root cause is not the power washing, but the poor design of the mirrors! It looks like the 2003 models will have the same mirrors, but with the improvements introduced....I bet people will buy even more of them regardless of the mirror problem. I guess there are more important issues then mirrors when buying, and GMC has done a good job in that dept with all the new updates. I can't wait to see one.
Did you know it was basically the same vehicle as the other?
Why did you choose it over the other?
Please submit your response to jfallon@edmunds.com no later than Wednesday, May 15.
MODERATOR /ADMINISTRATOR
Review your vehicle
I recall an odor that faintly smelled of ammonia. I reported it, they replaced a filter, it eventually went away.
I have a '99 Savana 1500, 5.7 liter engine, 43,000 miles, never towed anything, no extended warranty. The tranny is slipping, and when cold, does't want to shift out of 1st gear. The dealership has looked at it, run a diagnostic, and said they think a valve is sticking in the valve body. However, they can't tell more without taking the tranny apart. That alone will cost $300 (which would be deducted from the final cost of the repair if I have them do it right then, while the tranny is opened up, otherwise I'm out $300 if I tell them not to fix it, even if I end up having them do the work at another time). I was also quoted $1200 for a new valve body if it can't be fixed, or $2500 for a new tranny, if necessary. No price quote for a rebuilt tranny.
I've read this message board, and I know that a lot of the owners here have had similar tranny problems, also at low mileages, like mine.
Anyone here been able to get GMC to fix it without charge? Are there any secret warranties on transmissions for the Savana (or the same transmission in, say, a GM or GMC pickup truck)?
The service rep and the mechanic I spoke with were both surprised that I hadn't had the tranny serviced yet; apparently they advise all their customers to get their first tranny service at 30,000 miles. I had been following the owner's manual fairly consistently regarding what services to do when, and the first transmission service isn't scheduled until 50,000 miles. BTW, I bought this van at a different dealership - who never said anything about getting the tranny serviced 20,000 miles before GM's owner's manual says to do it.
Never had any problems with my mirrors - they're solid. I also never power wash the van. Also, my ac smells musty if I haven't run it for a while, meaning several days to several months.
If anyone here has any advice or comments on dealing with GM regarding anything I've mentioned here, I would appreciate it.
PS - Should I have the tranny work done at the dealership or at a transmission specialty mechanic?
YOur problem with the tranny is common with the 1500 series van, not the 2500/3500 vans that come with the heavy duty 4L80E transmission(not all 2500 cargo vans have this tranny, it must be ordered, while it'standard on passenger vans in this class). I would also prefer a tranny shop to the dealership once your out of warranty. Most dealers do not do tranny work and contract it out and will bill you extra. Unless the dealer tells you they do it themselves, why pay them to send it out.
My dealer says the 2003 Sav will not be avl until Nov 2002 because of a drive train problem. Problems starting already....
Your profile is a better, if not foolproof, place to stash them.
Steve
Does anyone have experience with the 2500 series in GMS or Chevy vans? Towed with them? Reliability? Should I go to an Excursion or Expedition? Thanks in advance.
Remember that only the 2500 extended "passenger" vans come standard with the heavy duty transmission and heavy duty axle, it is an option with cargo vans (at least in Canada).
Good luck
There is a big difference between the AWD and 4WD systems. Check it out in the SUV section.
I bet you that they will have '03 models on the lots very very soon. You just won't see the AWD units until the bugs get worked out of the tranny.
www.motortrend.com/news/stories/020306fl.html
For 2002 the 4L80E remained unchanged for the heavy duty version. Why would they change it after a major upgrade in 2001 (torque converter), then go back to it in 2003.
_______________________________________________
First Look: 2003 Chevy Express and GMC Savana
March 6, 2002
When GM engineers embarked on redesigning the 2003 Chevy Express and GMC Savana full-size vans the mission was clear: deliver more. With the addition of features like all-wheel drive, a left-hand-side 60/40 entry/load door, and unique side-access panels on Express Access and Savana Pro models, these vehicles should impress even the hardest-working commercial customer.
"We're delivering more by providing solutions to our customer's individual business challenges," says Dave Kanous, brand manager, commercial vans. "All-wheel drive allows more efficient travel to and from the job site, while left-hand door and unique side access provides improved on-the-job productivity."
The 2003 Express and Savana also feature upgraded mechanical systems and powertrains to further enhance durability, dependability, work efficiency, and safety. A 200-hp Vortec 4300 V-6 is now the base engine for light-duty G-Series vans in all 50 states, featuring new multi-point fuel injection for smoother, longer-life performance than the injection system previously used in the 49 states outside California. The ugraded "Gen III" V-8 range includes a heavy-duty Vortec 4800, a spirited Vortec 5300, or brutish Vortec 6000.
With 275 horsepower, the Vortec 4800 V-8 produces 50 more horsepower than the Vortec 5000 it replaces and is mated to a standard 4L80-E four-speed electronically controlled automatic transmission with overdrive. Rated at 275 hp @ 5200 rpm and 285 lb-ft of torque @ 4000 rpm, this 4.8-liter engine is primarily used for heavy-duty service applications such as in 2500 Series regular- and extended-wheelbase cargo vans (8600-pound GVW), or as the optional engine on 3500 Series commercial and motorhome cutaways (available with regular wheelbase only).
