Visitor Agreement.
I'm beginning to wonder about the extended warranty myself (or possibly dumping the car). I think the Alero is a great car but all these little things are starting to annoy me... my '00 Alero is scheduled to go into the shop for the following:
Vibrating driver side mirror. Vibrates like crazy on the highway to the point it's almost useless.
Rotors and brakes! I had the original brakes and rotors replaced under warranty at only 15,000 miles. I now have 23,000 miles and the rotors are warped again. I wouldn't mind if I was driving like some sort of manic but I've been fairly gentle with the brakes. When making the appointment, the "advisor" said that they would probably not be covered under warranty... my response was, "Well, if it's not covered under warranty, I certainly don't want you to do the brake job since the last one only lasted 7,000 miles (< 1 year)". Seesh!!
HVAC fan. The two lower fan settings are now inoperable... basically nothing comes out of the vents until I have the fan on the third setting. Thus, I'm either hot or feel like I'm in a freezer.
Rear passenger door. For some reason, the rear passenger door handle does not return all the way back to the "in" position. It also takes a little bit of a tug to get it open.
I think that's it for now. The Alero replaced a 1990 Camry that I put 165,000 miles on. That car basically had three sets of brake pads replaced, one set of rotors, and the exhaust system replaced once.
It's sad because I thought that I would try buying American once to see if the USA could make a decent car... it looks like I'll be returning to Germany or Japan for my next.
The rotors once fixed properly should not give further problems. If there was a design problem there should be a permanent fix.
It is very easy to reach!
The two issues that are causing me much concern are the driver's side window is getting etched with use. I have several noticeable scratches and have had it worked on and replaced one time already. The second issue is the the transmission lever--when put in park it does not "click" into place to release the ignition key. Have to rock it a couple of times before it clicks into place and can remove key. This is a second time it's being worked on.
On a final note, I have had the car into the shop on four occasions. My local dealer used to give me a loaner for the day (through Enterprise rental). This was a major selling point for purchasing the car. When I called to make tomorrow's appointment, they informed me that GM will no longer be giving loaners unless the car stays over night. Now, I feel a bit mad about this. I was told I would get a loaner if the car had to be in the shop for more than two hours when I bought the car am starting to regret that I went back to an American made car. I have had two Mazda's in the previous fifteen years and had both cars in a total of four times with nearly 300,000 miles between the two. I like the Alero and the way it handles and drives, but if I have to take the car in every few months for something, I may have drop out of the Olds family.
Also, check out this picture of the 2003 Grand Am. What does it remind you of?
Grand Am certainly does look a lot more like the Alero which is a good thing in my eyes.
Then I remembered Edmunds. When looking through this site I also noticed the problem with the brakes and rotors. I just had mine replaced. I have 35,000 miles on mine. Called Oldsmobile and asked for them to reimburse for the $ but they said no since I had it done outside the dealership and past the 24,000 mile mark.
I might also be having the water problem but wasn't sure since I left the sunroof open during rain once.
I haven't been here for about 6 months, which is a good sign--my '01 GL1 Alero is running great. No problems so far.
I did get some paint scratched off (looks like someone grazed me in the parking lot) and I wanted to ask if anyone knows where in the car you can find the info about the exact name for the paint color of your particular car. I just don't remember, and I want to figure it out before I go to get some touch-up paint. Thanks!
If you find out where the heck the label is, please let me know--real curious.
Adenn
Hope this helps.
Do you have one of the plug n play models?
infinia1 : You clearly need to find a new service dealer. No excuse for not fixing it right.
This is a common problem with the Alero and perhaps the Grand Am.
If you read previous arc hived post here you will find several failures. Good luck.
Things I like are the most are the 2.2L Ecotec (one of the best four bangers out there), handing, the styling, the very functional and good looking dash and the 4 wheel disc (ABS) brakes which are very strong. Some nit picks include the drivers seat which could be better and the lack of a nice trunk thud.
We are very happy with the car and for the money it's hard to beat. Thanx to the guys here in the forum for helping with the purchase a back in April.
If I were in your shoes, I would feel the same way. Getting a lemon leaves a very bad taste in your mouth. My parents old Mustang was a lemon and I remember it being in the shop a lot which is why they have GMs now.
I just hope that this doesn't mean that Olds employees are getting sloppy now that Olds will be phased out. As you pointed out, it hurts GM's reputation and GM better watch it.
I regret to hear that you were unlucky with your Alero.
I went over my 2002 with a fine tooth comb, mostly because of the comments I hear about GM fit and finish. In all honesty, I could not find one sloppy or even slightly misaligned assembly point.
I did note that the rubber casters for the hood were not adjusted, but even more amazing was that the hood fit perfectly without them. Now that is a good fit, since the rubber casters are often used to compensate for hood misalignment.
For it's price point, the alero is world class. It's still early and things could change, but my experience seems to indicate that GM employees are not getting sloppy. Time will tell.
First of all, the 2.2 is well designed for easy maintenance. You can change the oil filter without spilling one drop of oil, and you don't need a filter wrench to remove it.
When you buy the filter, be sure it is intended for the 2002 Alero. When I bought mine, the directory did not yet list the 2002 alero, so I bought one listed for the saturn ecotec (9018). I had to return it today and exchange it for the Alero filter (9018R, it's now listed in the directory).
The saturn filter does not fit the alero filter screwcap (the part you remove to get to the filter). The two filters are almost identical, but the alero has a slightly larger top bore to fit the screwcap lid.
There has been some debate here about the oil capacity of the 2.2. The manual says 5.8 quarts, but others have said 4.5. I added oil until the dipstick read full, and it took 5 quarts. The drained oil measured out to 5 quarts as well, so we're not using a drop of oil!
I realize that most of you probably don't change your oil at home, but for those that do, the Alero is awesome!
See my post under the tires topic.
Anyone else experience this?
