Visitor Agreement.
12 mo = $99, 24 mo = $199, 36 mo = $299, 48 mo = $399
I'd only keep it if my area was served by Personal Calling, because I happen to live in the 5% of the country where they don't offer the service.
How about you, did you get yourself another monthly payment?
TIA
If it were $10/ month or pay per use, I would get it maybe though.
Oh yeah, called the dealer today and my car will go into production next week! Estimated delivery date is December 6. That's only four weeks from order! Now I just need to sell my '99 Malibu which hits the local paper this Sunday.
Hope your next car has better luck.
Thanks in advance ....
Through it all, she's had an old s-10 (bought it used) that has run without a hitch. For her next car, she's looking at buying American now.
After 11 months, I still have nothing but praise for my '02 alero.
I haven't checked lately, but if the GX lost ABS brakes as a standard, did they also lose traction control? I must assume so. Did they also lose the 4 wheel disc as standard?
By the way, my buddy is at nearly 100,000 miles on his '99 GL2 and still has not had any quality issues. He still loves the car.
Oldsman : I agree but, the Alero is a lame duck now and I guess they need to cut prices to be competitive. I hope down the road the ABS / discs on our car will yield slightly better resale.
I got the Alero on a heart beat because of standard ABS and TC. Besides, what other compact car can be had with a V6?
I just hope that GM doesn't go the way of the Japanese manufacturers when it comes to contents...
Also, how does everyone find the Ecotec 4 cylinder vs the 6 cylinder? Currently driving 2000 Alero GL 6 cylinder. Considering dropping down (for economic reasons) to GX with 4 cylinder. Would some of you be kind enough to share your advice and experience re: this change?
Thanks a lot, everyone!
GX has crank window, not sure if you can get power unless you upgrade to a GL.
Question: Does anyone know the specific cause of this? Is there a fix we can do at home, or does it have to be handled by a service tech?
Some cars have a removable cut-out either under the seat or under the trunk lining directly over the fuel tank that can be removed to access the sending unit. Not sure if Alero does but if not, just remove the two straps that hold the tank (empty it as much as possible before starting) and lower the tank enough to reach in and disconnect the fuel lines and wiring harness.Be careful not to spill gas on yourself! With a new car there should be no corrosion issues to worry about and should come apart easily.
Once these are disconnected, remove the tank and you'll find the sending unit under the pipes that the fuel lines were connected to. Simply twist off the retaining clip and pull out the unit. Replace with new part and reverse previous steps.
The easiest way is if there is an access hole from inside the car though. Maybe someone who knows more about Aleros specificaly can chime in here. Good luck and I hope all goes well.
If you look @ www,haynes.com you can find one there. They are sold @ most auto parts stores. If not, take a look @ www.books4cars.com and you will find a manual for the 99-2000 Alero for $17.95 that you can order by mail. Mine is a 2002 and is under warranty for 5 years. They don't publish one for this year yet but with the warranty, no need for one yet
So I took it in to our local GM service centre today. Turns out the problem was not the fuel sending unit, itself, but the sensor for the fuel sending unit. Good thing, too. They said that if it had been the fuel sending unit, it would've doubled the nearly $400 (Canadian) I paid for today's repair.
In the year we've had our Alero, we haven't had a lot of things go wrong: (1) the plastic knob on the gear-shift handle broke off; (2) the fan resistor wore out; and (3) the sensor on the fuel sending unit went flaky. But our Corsica, while not nearly as nice a car, didn't have as many things go wrong with it over the several years we had it.
Re: buying a Haynes manual for our 2000 Alero, I went to Canadian Tire and was told that it's not available yet because it's "too new."
However, I think he's dead wrong decontenting the cars as he did in Chrysler. Chrysler prices are pretty high and the equipment level is among the lowest in the market. This is especially true when the Japanese brands started adopting standard ABS or TC in their models (e.g., Camry and Accord).
It's all about perception of value. GM never mentioned that in its marketing, shooting at its own foot. Now, other brands put that in head letters and are praised for doing so... That's why I bought my Alero and my Bonneville: more value for my money.
I'm just waiting to see the press of likes such as CR, C&D and R&T criticize GM cars for not having such features as standard equipment like "oh, the imports" after having failed to mention this when they did sport them...
:^P
But there's hardly any point threading these remarks. Lutz doesn't read this forum; he's probably in a office in one of the ivory towers of the Renaissance Center...
I highly recommend the car!
Dindak- good to see you still love your Alero.
With respect to not buying a car based on the information on this board, I defy you to find any board here at Edmunds in which people are not airing their dirty laundry. This is the nature of the beast - if everything is working fine you probably will not be sitting in there typing in glorifying posts. At least I hope this is the case. I'll be sure to pipe up when I have a problem but I do not plan to report on my good fortunes every week/month ....
There are many of us on this board who think the Alero is a fine car but unfortunately only post when we have a problem. I have a 2000GLS with 31k on it. To date the only problem has been with the rotors which were replaced under the warranty at 13k. My other car is a Lexus RX300 and I do comment about the Alero over on the RX board, mentioning some the features this car has that are missing on the RX at about twice the price (tire pressure monitor, low fuel chime, turn signal chime, 150k coolant,smooth ideling engine, great 6 cyl gas mileage, geared high for smooth low reving highway crusing) Well anyway, you get the point.
Mike
evandro, you are dead on! One of the reasons why I bought my Intrigue was due to the features it offered for the price. If I'm not mistaken, Honda now offers ABS standard on all but base level DX Accords.
