Visitor Agreement.
The all new 04 Malibu looks to be pretty good as a replacement some day down the road. We shall see what it looks like in January.
Grand total of 900 miles on the the '03 GLS and all is well.
Turns out that the factory put a Grand Am bushing on my Alero. Took the dealer three weeks to get the right part from the factory. Problem Solved, no run around/no hassels/100% Happy with the dealer and Olds.
Will keep you all informed another 53 months of warranty left...
#1748 of 1836 Noise when Turning left. by kelver777 Oct 24, 2002 (07:37 am)
Ok, I've had my 2002 Alero for about 3 months now and have not even put 2k miles on it. Noticed a noise yesterday when I finish turning left and the wheels are aligned back forward, I hear a slight pop or thump. The noise is coming from the right left wheel area. Anyone have any ideas on what this could be? Guess I'll get to see how the repair shop is next week. A friend of mine says it might be the boot, or the steering assembly.
I wonder if the spring isolators are shot or is it just the nature of Aleros?
heng : From what I remember, the Taurus has a very soft suspension so you will get a softer ride. I personally hate soft rides but in 40 years, I may want them!
That said, at times I too have noticed a bit of outside noise coming from the rear doors. If you look at the rear door seals, they only cover a small portion of the door opening.
While water does not get in (I have checked during wet weather) it really should fully seal the door. I may consider doing this myself in the spring. However, since the noise is minimal and I rarely notice it, so I may never get to it.
Regarding engine noise, the quad 4 in the 2000 is much louder than the new ecotec 4 cylinder.
Imagine if you could get an Ecotec v6 Alero with a manual, bet that car would move.
You can program the characteristics of the keyless entry by using the driver's door power lock button and the remote. Check the manual for the particulars. Factory setting is to chirp - I turned mine off - only the lights blink. I think the neighbors appreciate it.
And my 1999 Alero GLS Coupe bites. It's literally falling apart (don't ask). Nothing but trouble. Too bad, because when it works, it drives pretty nicely. And yes, to really solve the brake problem, forget GM, go buy some Wagner (or something similar) rotors and decent (I bought Performance Friction - more dust, but less fade) pads. It's all of $100. 3 warranty repairs to my brakes might SEEM free, but that's money I'm not earning when I shuttle the little beast to the dealer.
Bruce
regfootball, I've been driving a loaner Alero since Tuesday and while not as refined overall as the Intrigue, it is a VERY nimble car. With a smooth revving DOHC V6 and a 5 speed, it would be a blast.
While I don't doubt some have had bad experiences, I think it is just plain bad advice to tell people to steer clear of the Alero...especially with the current deals.
As I mentioned earlier, I bought my '02 one year ago and it remains perfect. To boot, I only paid about $11,500 out the door ($3100 GM card). The car has stuff like ABS/traction control, 4 wheel discs, aluminum wheels, leather wheel/shifter, keyless entry, spoiler...not stripped.
This was my first GM car, but the quality has been outstanding and I would buy again.
Like I said, there are always lemons with every brand and if you get one I'm sure your views will be tainted.
But the Alero is not the only car experiencing problems with the pads and rotors during "normal wear and tear." I have visited other forums here and noticed that other brands are suffering the same problems to include the pricier Mercedes Benz with brakes wearing out at less than 10K to 20K miles. So don't assume that it is a just an Olds problem or GM problem. It's a problem throughout the ENTIRE auto industry.
I like the feel of the Alero and the tight suspension which is awesome on curvy roads and at times, I have outmanuevered more pricier luxury sedans that either the cars could not handle the curves or the drivers could not handle the curves.
Although both are GM products, I've had more problems with my 2000 Alero then I ever did with my 1995 Corsica. So far on the Alero: replaced the resistor for the fan (did it myself CDN$25), fuel tank float for CDN$360. We've owned the car for about 15mths and 38,000km.
Both are "typical problems" on the Alero, and certainly something that could have been addressed through continuous improvement. Comparatively, the Corsica had much higher mileage on it before it required any major repairs and these were not really "typical" for that model, and reasonable wear items: front struts at about 120,000km, one rear bearing at about 150,000km.
First, the Alero likely was the base 4, but I admittedly did not look under the hood. It was somewhat noisier than my '00 Taurus with the 24V Duratec, but not unobjectionable. Handling and ride may have been slightly stiffer, but then Alero is a much smaller lighter car, so this could be expected. Acceleration was adequate. Overall, not a bad car, however I did have two major beefs. The outdated GM multifunction switch with the cruise just has to go. The other objection we had was anyone sitting in the back seat feels like they are sitting on the floor. Way too low and uncomfortable. Otherwise, it's pretty decent.
I personally do not think Taurus suspension is too soft. If anything, up until the 2000 redesign, many complaints were Taurus suspensions were too stiff and harsh. Since 2000, I believe they have it just about right, not too harsh, but not too floaty, and still very flat on the curves. Definitely better than Buick Century, which I have also rented on occasion. And the Taurus DOHC Duratec is sweet.
Also, unfortunately, I have a long memory, and can't seem to shake the bad feelings I had for that old 1983 POS Chevy Celebrity with the "Iron Duke" engine. I guess I carry a grudge too long.
I'm on my second Taurus; enjoyed the first one (1990 model) ten years with very little trouble, and my current 2000 SES has been flawless at 23K and 2-1/2 years.
Glad you like the Taurus. It's a decent car, just a little on the soft side for me.
This lured me to the dealership and I bought a 2002 new Alero in the last quarter of 2002--new.
I wondered if what I ran into was common practice??? My dealer said I had to pay extra above the advertised price to get the 5 year warranty ($700 more) and if I didn't, I would only get a 3 year warranty. I also was told that to get 0% interest that I would have to pay about $3000 more. WAS THERE A LOT OF FINE PRINT THAT I MISSED, OR DID I GET DUPED??? I am curious if this is an Oldsmobile policy that in order to get their advertised 5 year warranty that you have to pay a fee extra. Also, I was mailed what looked like an old fashioned "extended warranty" that had so many exceptions, I question the bumper to bumper. A lot of things were excepted that were what I consider more than normal maintenance that I have to do.
HAS ANYONE ELSE OUT THERE HAD A SIMILAR EXPERIENCE?? IS THIS NORMAL OLDSMOBILE POLICY?? This has caused me to not trust my dealership. I like the Alero I have, but I don't want to take it back to the dealership for anything because of my suspicions and what I consider a bad experience with them. IF IF FIND OUT THIS IS NORMAL PROCEDURE, I WILL TAKE MY CAR IN TO THEM FOR REGULAR SERVICE ETC AND WILL FEEL BETTER ABOUT THEM. Any help and suggestions will be appreciated. Thanks
gallen22
As for the "fine print", the actual 3 yr warranty and 5 yr powertrain warranty were explained to me while shopping at the dealership. This information may (??) also be contained in the Alero brochure.
Check your paperwork to see if you got an additional $750. Perhaps the advertised price included the $750 discount? IT seems to me that the rebate was $3000 including the 5 year warranty, but I may be wrong. I bought my car the last day of the $1500 rebate...they went up to $2002 the next day! Both included a 5 year warranty.
Do you mind telling us what you paid? I paid $100 over invoice, minus the $1500 rebate.
As I said, Alero seems pretty decent, however the rear seats are pretty bad, agreed? I assume Grand Am rear seats are about the same, since they are on the same platform.
They fit me well, but maybe that is because I am rather small (5'8, 155#). However, you never want to sit in the middle seat, as it is rock hard and not suitable for a human tush!
I have a friend with a grand am, and his rear seats are very different from the alero seats. Softer and less bucket-like.
My daughter is only 2 so it's not an issue anytime soon.
We purchased a new 2001 Alero GL V6 2 door coupe in June 2001. Car now has about 21K miles. It has been absolutely trouble free! The only time it has visited the dealer's shop is for a recall on some fuel pump gasket. I change the oil every 5K using Mobil1 and the only other service is to top off the antifreeze coolant when light came on this fall.
I really appreciate this little car being dependable transportation for my daughter commuting to the university. With the 60 month/60K mile warranty I think this is one vehicle in our fleet that I will not have to work on frequently.
However, I've never had to top off the coolant on it for as long as I've had it (3 years and 34000mls). Yours' 3.4 V6 may be plagued by a bad head gasket. Check out if the coolant leaked to the crank case oil, for it can cause severe damage to the engine if that's the case.
With the incentives and 5 year warranties on Alero's these days, I personally think it's the best car for the money in it's relative class. The car isn't perfect and some people have had some problems but you can say that about most cars.
The usual reason - a bad intake manifold gasket. Easy to diagnose under pressure check. The check costs about $20-$25.
Replacing the gasket costs about $550 at independent shop, and up to $800 at dealership. Better to do it while under warranty. Even more, than the leak is not good for car.
By the way, GM recommends to have the pressure check every year. At least according to my 98 Malibu manual. Must be the same with Alero.
GM did have a big problem with intake manifold gaskets leaking on these 6 cyl engines back in the late nineties but the problem has stabalized now.
So I bought a new relay and put it in nad its doing good ...knock on wood?
