Visitor Agreement.
I have a good dealer so there was no discussion about charges since it had been done before. Even though out of warranty this time.
I am always amazed that the Alero does not get many hits on Edmunds compared to the Intrigue. We have a 2000 model of each. And yes the Intrigue has been a much more trouble free vehicle. Highway mileage is better on the Intrigue than the 2.4 liter Alero. City mileage slightly better on the Alero.
The factory radio sucks on the Alero. The Intrigue is decent. The problem, as I see it, is the antenna in the rear window and then an amplifier added to increase signal strength. The problem is the all sorts of garbage is picked up and amplified in city driving. But, once on the open road the range is 100 miles or so on FM, further than any FM radio I have owned.
In the past, under warranty, the traction control went off due to a bad fuel injector. Strange!! fouled injector shuts down the traction control.
We just came back from a trip to Southern Indiana (their tulips have dropped all their petals, and our buds have not even opened yet! Quite a difference.) and by my calculation we got 33mpg (U.S.). This is for a 2000 Alero, 3.4L V6, almost all highway mileage, and running at 60-70mph.
Ho-hum, that's pretty consistent with every other time I've measured hwy mileage with this car: 32-34mpg (U.S.) in the summer, A/C or not, regular unleaded or the "90% Regular:10% Ethanol" fuel they sell around here.
Pretty good resistance to hydro-planing I'd say. Just FYI in case you were wondering how these tires handle heavy rain.
The wind was gusting strongly as well, and directional stability was also very good. That's a compliment to both the tires and the "tightness" of the steering and suspension, in my opinion.
Happy motoring,
Rick D.
The potential for where this stuff is going is starting to sound very expensive. Anyone else have this problem or any ideas.
Scheduled to have a pressure check May13.
Man, I wish that there would be a recall about this issue on this engine and on the 3.8 V6... <tt:-(
JRagan
I had the same issue in another car of mine with the 3.8 V6 (same problem, different causes) and the dealer told me that they usually do 1 or 2 cars per day with this issue!
JRagan
"you are not alone"
this problem is very frequent on the GM 3.1, 3.4, 3.8.
My father in law had the problem and it was a costly fix. He's lives in a small bo-dunk town of about a 1000 and called the guy at the local non-dealer repair shop. When he started to describe the problem, the mechanic guy described back to him in exact detail what the problem was and virtually was able to describe in exacting detail over the phone what was needed, how long it took to fix, etc. The mechanic had already repaired quite a few and said they were seeing the issue on a regular basis. If a mechanic in a town that small is doing those jobs on a regular basis I hate to think of how frequent the issue is where there is actual population.
But its good that you've found the issue relatively early. Good luck on the fix.
I looked on some buyers guide sites before I bought this car and never found this sort of thing. Is it OK to post on these sites and warn other people? I am new to this kind of thing. I had a Dodge Caravan for 8 years and it was a workhorse. I wish I still had it!!
JRagan
bottom line- if you have a 3.8 (like my father in law did), a 3.4 or 3.1
and
your intake manifold is plastic composite...
chances are very good it will happen to you. Keep an eye on it. Very frequent is accurate enough.
Yes, typically people come to this site to look for help with problems and discuss cars, not to repeat over and over that their car is running well. Counting complaints on a internet board is meaningless.
As for warning others, I think it's fine. I had a '99 Alero V6 for 36000mls and didn't have that issue and many others that some have had. I can only recommend the car.
OTOH, my Bonneville with the 3.8 V6 needed a new intake manifold with just 17000mls. It's actually been the single dark spot on an otherwise fine car. I still recommend the car.
Composite upper intake manifold - bad.
Rest of car - fun!
Sorry, I'm a bit punchy today. :-) Still waiting on word about the Final 500 Alero!
I've noticed in the new "24-Hour Test Drive" TV campaign that the Alero is represented. Almost gone, but not yet forgotten by GM.
If it was another make besides GM that was having this problem, what would your feelings be about it? For example, if it was Toyota v6's that were leaking coolant that way would you consider a problem or not a problem? Or, if GM was having engine sludge issues like Toyota has been how would you view that?
CORRECT ME IF I'M WRONG here but I am sensing you are cutting GM some slack on this issue because you really like GM cars a lot and I am suggesting that perhaps you would not cut other manufacturers the same slack, if the same issue was happening to their car. Throwing it out for you to verify....correct me if I'm wrong.
What year is your car, what's your story?
See "Colector's Edition" the main site page
Thanks to you all, especially Greg, for your help in our Alero turn signals not working. You were of course, quite right. It was the hazard warning switch. I've also managed to get the driver's door to lock as well! Things are now looking good! Sorry about the delayed reply, been to England for 2 weeks to see my family. Paid $5.75 per gallom of fuel. I'm used to that of course! Traffic everywhere, but the roads overall are so much better regarding the road surfaces and sings. Still prefer drinving here though! In Kansas City, they don't know what a traffic jam is!
Take care
Ian
Could you tell me what the mechanic found and what was replaced so that I can tell my dealer when I bring it in next?
Over all we are very pleased with the car. It's comfortable, smooth, well built (rattle free) and fun to drive. I highly recommend the car, too bad there is only 1 year left in production.
Just put a coat of Zaino on her last night...makes the black really look wet.
I am still very pleased with this car, and still look forward the times I get to drive it (it's my wife's car). Get one while you can! The rebates are incredible.
I never got a chance to wax in the fall. I am going to try to do the Alero the weekend after this one coming. Managed to avoid scratches for the most part this winter which is good.
Alero's with auto are being advertised for as little as C$18,500 cash here (about U$13K). Of course they don't have ABS/discs standard any more, but still a heck of a deal.
Get a coat of wax on that thing! I saw a Ruby Red one last week, all waxed and looking great. I really like the ruby.
Have you seen the new Red color offered on the Alero? I forget what it is called, but I got the idea it was a bright red.
You can get a GX with auto tranny for about $13,500 here. I still am glad I got the '02 since it is configured more as I wanted.
bridgeman : Odd. Are you sure they were all GX models? 5 speed is standard on the GX but maybe a delete on the GL? Go with the best price in the end.
However, if you select the "Sport Package" you get the 5-sp plus 15in aluminum wheels, spoiler, and leather wrapped wheel and shift knob. With the extra goodies, the 5-sp "credit" drops to $150.
In case you're only interested in the spoiler, that is a no-cost option on the GX, so you can get the 5-sp and spoiler for the $850 credit price (probably tough to find on a lot though). The wheels, tires, and leather wraps effectively end up costing you $700, but are more available in dealer stock.
I have a 2001 GL2 w/ the Getrag 5-sp, and it is a pretty nice tranny. IMHO, the current offering of the Ecotec-4 w/ the Getrag 5-sp is GM's best powertrain for cars. (with the exception of the Vette of course!)
Note, the 5-sp is no longer available on the GL model.
You are right, the 2.2 with 5 speed is a world-class match...get one while you can.
greg : Unfortunately I live in the Toronto area which tends to be a parking lot during rush hour. My wife wasn't crazy about the 5-speed idea either so I passed on it. Someday I will get a manual summer car for just me.
dinkak: Interesting info. Could be true? I was in Belgium a couple weeks ago and saw a Chevrolet Alero on the highway. Looked exactly the same but had bowtie logos.
The Alero is a great car. I say let it die a dignified death and go out in style. To slap a bowtie on it and bring it down to Chevy's level is demeaning in my opinion. Chevy hasn't put out a decent car (again, with the exception of the Vette)in decades.
Between the Aurora, Intrigue, and Alero, Olds had engineered some pretty damn good cars for reasonable prices, and I like to think that they went down fighting.
For us Alero fans, that means the Opel Vectra. For those who have not seen these, go to www.vectra.de. It's all in German, but to see pictures click on "Galerie", and to see powertrain options, click on "Motoren u. Getriebe".
These cars are sprung tight on a very solid platform, have an interior that comes close to VW/Audi standards, and a number of powertrain options including the 2.2 Ecotec, a 2.0 Turbo Ecotec, and a 3.2 V6 Ecotec, all available with a 5 or 6!-speed. They look nice too. I rented an Ecotec w/ a 5-speed and it was sweet.
Bob, bring these over!
The Vectra is really the same as the 04 Malibu coming out in about 2 months. It will be interesting to try one of those out though I don't think a 5-speed manual will be available.
As for a Chevy Alero, I also saw them in Europe. I hope they don't either, but it still sells well so I can see why GM probably doesn't want to kill it either.
Anyway, I don't care what they call it, but if they call it a Chevy, they'll likely give us squishy suspensions (even if the platform is solid), lackluster styling, and only autoboxes.
Maybe the next Grand Am (which will no longer be called Grand Am) will be a decent car. I believe it is also to be built on the Epsilon platform. Though their styling has improved, it'll probably still look a bit too boy-racer for me and not have simple, clean lines i.e. the Alero and euro sedans.
greg : The new Malibu looks promising, we will have to wait and see how it drives. The G6 (Grand Am replacement) may be the best hope. Pictures I have seen look fantastic, very clean lines like the Alero but it will only have a V6.
Apologies for the delay in getting back to you. The paperwork stated that to cure the turn indicator "replaced fuse, but still not working. Turn signal hazard flasher has an internal short, replaced turn signal hazard flasher". Also, the intermittent drivers door lock not working turned out that they had to replace the lock and unlock relays. Both problems have been fine since, but we still get an annoying "squeek! from I think the right front sispension area, but only at low speeds over Kansas City's discraceful road surfaces. Thanks for your help again. Ian
