Older Honda Accords
1284285287289290389
  • sockpuppet1969sockpuppet1969 Member Posts: 308
    I just had the 20K service done on my 2003 Accord EX-L today. Cost: $36.72. Called the dealer to see what they charged: $139.95! Basically, my mechanic did all the "inspections" for free. He uses Honda parts and Honda oil.
    P.S. Neither price included a tire balance. Do any of you balance your tires with every rotation? The car rides the same (no shimmy or shake at any speed).
    I will be taking the car in to the dealer to have the seat checked out. (The same dealer who, incidentally, did not tighten my oil drain plug after my 15K dealer service resulting in a big oil leak on my garage floor!) The seat shifts side-to-side when turning. Has anyone else had any success with this problem? Are there any TSB's out there that refer to this? How about the sliding sun-blocker rattle on cars with the sunroof?
  • miss66miss66 Member Posts: 12
    I'm thinking of purchasing a 6cyl accord. I have been reading the various messages and I'm confused. Some say the 6cyl has tranny problems some the 4 cyl. I'm getting rid of my 94 dodge intrepid because of tranny problems so would appreciate advice. Also,the salesman told me that the EX had a better security system than the LX.
    Is this true?
  • talon95talon95 Member Posts: 1,110
    The posts uptopic about V6 transmission problems reference the previous generation Accord ('98-'02) and do NOT affect the current generation Accords. The automatic transmissions for the current Accords are a new and vastly improved design (the new 5-speed replaces the older 4-speed), and there are no major known or recognized problems with the automatic transmissions of either the L4 or V6 Accords of this generation ('03 +). So don't concern yourself with transmission issues for any 2004 Accord.
    According to the Honda brochure, the LX V6 has the same security system as the EX models. The LX 4 cylinder does NOT have that security system. Both cars have the Immobilizer system which requires a chipped key to start. The more advanced security system has an alarm that goes off if doors or trunk are opened while it's armed.
  • whitecloud1whitecloud1 Member Posts: 268
    If you've got no shimmy/shake I wouldn't worry about the tire balance. It is a seperate issue, but some mechanics check balance as a matter of course. No problem with that either. I like to make sure that my lug nuts are tightened correctly after a tire rotation and I have found that at least the Honda dealer I sometimes use has gotten better about that.
  • gregoryc1gregoryc1 Member Posts: 764
    The key words here are "know" or "recognized" problems! The 6 cylinder Accord has a long record of transmission problems. I would not take a chance on a v6 Accord. If I wanted a Honda Accord, I would stay with the 4 cylinder. If a V6 was important, I would go to another brand of vehicle. (Toyota, Chevrolet Impala, ---etc)
  • austinman7austinman7 Member Posts: 313
    talon95 -- in post 14943, you mention an issue with the 7th generation Accord automatic transmission, only seen in 4 cylinder models. I have an 04 4 cyl. LX. What is the transmission issue? Also, in an earlier post, I believe there was mention of 2 TSB's on this generation's transmissions. So are there two issues?
    anonymousposts -- in post 14943, you mention aggressive downshifting when going down hills and suggest 89 octane gas to cure this. How does the octane of gas used affect the transmission's performance? So far (4000 miles) I've never noticed any particularly strong downshifting, and I have gone down some steep hills on the Interstates I drive.
    Thanks to both of you for any information on these questions.
    Oops! Got your post number wrong -- it was 14958 I was referring to.
    The main issue with the 4-cylinder transmission is an "out of spec" transmission case that affects a range of serial numbers. Affected units could experience a transmission failure. The transmission will be replaced on affected units if necessary. Honda sent notifications to owners or lessees of potentially affected units in May, so if you haven't received a notification, you won't be affected at all.
    The second issue is a "No reverse" condition that potentially affects only 2003 4-cylinder units. The problem can manifest itself if the driver shifts quickly and repeatedly between a forward gear and reverse (such as when trying to get out of snow or sand), reverse may no longer engage. This was corrected with a firmware update for the transmissions, and doesn't affect any 2004 models.
    The 3rd TSB is another firmware update that affects only V6 models.
    So it seems like you're in the clear, as long as you didn't get the above mentioned notification letter.
  • simonsez5simonsez5 Member Posts: 21
    Because I’m on a tight budget I’m strongly considering the DX with a stick (basically the cheapest Accord one can buy), as weird as this may sound, I’m comparing this to a fully loaded Mazda3 Hatch (the 6 doesn’t do it for me). Problem is I know I could live with the manual adjustable side mirrors and the 4 speaker sound system but would I notice a strong difference in the handling department compared with the LX since the DX does not have the rear stabilizer bar? I like my cars to handle well so it is kind of important for me. Does anyone here own one or driven one?
  • rampedramped Member Posts: 358
    In normal driving, you won't notice much of a difference between the LX and DX, but if you corner aggressively there will be more body roll.
    My unsolicited advice to you is to opt for the Mazda 3 for two reasons: First, the 3 is an excellent, although smaller car, that is fun to drive, which seems important to you. Also, you will enjoy many accessories, such as the upgraded stereo system, not available on the DX. Second, the resale on an Accord DX model will probably not be as good as a loaded 3 when you decide to sell.
    The only reason I can see you choosing the DX in this comparison is that you need more room for a family.
  • gee35coupegee35coupe Member Posts: 3,387
    The higher octane gas doesn't anything to do with the tranny. What it does do is give the engine a little more power which makes it able to climb hills without downshifting. I noticed my SI has a little more power with mid-grade gas so we tried it in her Accord. The engine seems to run smoother with a little more power.
  • maxamillion1maxamillion1 Member Posts: 1,467
    Handling will only be noticed during hard cornering.
    And I have to agree with Ramped about the Mazda3.
    Get it, you will get many more features and a less spartan interior with the Mazda3. The Materials in the Accord might be slightly better, but the 3 has more appealing things (metallic trim,etc.)
    Also, the Mazda3 will have all the power accessories you would need, as well as air conditioning, because air is an OPTION from the dealer on the Accord DX if I am not mistaken.
    Resale value would probably be similar to each other, but it would be harder to sell an Accord DX over any other Accord IMO.
    Also, don't forget about the added versatility of the Mazda3 hatchback...
  • justinjustin Member Posts: 1,918
    that is an interesting set of cars to cross shop. one is a refined sedan, one a kind of over-styled SoCal type car.
    both are tops in their respective segments....gotta decide which way you wanna go.
    I agree, the cross-shopping of the Accord/Mazda3 is a weird one for sure, don't ask me how I ended with these 2!! I'm confused as hell, gotta make a decision soon!! I'm in Canada and our DX comes standard with A/C, pw locks & windows as well as cruise, not sure if the U.S. spec gets all that? You're also right about the extra utility of the 3 with the hatch, although I heard you can still put lots of stuff in the trunk of the Accord. The deals (financing) on the Accords up here are much more favourable than the 3 right now, the mazda is a very hot commodity at the moment !! I just turned 30, got married 2 months ago and kids will probably be coming in the near future (as per the wife), so the question is, which one will serve me best as a family hauler and still bring smiles on my face while I'm behind the wheel??
  • badgerfanbadgerfan Member Posts: 1,565
    You are in for a rude awakening. With all the stuff you take along with a baby, I see a minivan in your future. If you have two cars in the family, one might work as as a "fun" car, but you will definitely appreciate a stuff hauler, or at least your wife will. My wife opted for a minivan in 1985 and she has driven one ever since, even though our kids are grown. She likes that upright driving position great visibility, and it fills the occasional need to haul stuff from the lumber yard, garden center, etc which comes in handy for both of us.
    More so than just cornering, in any type of evasive manuver, "tail-wag" will be much more pronounced in any vehicle without a rear stabilizer bar. My Civic lacked a stabilizer, and was really tail happy, causing a scary spin-out once. Historically, cars without rear stabilizer bars door more poorly than those with in tests like that of CR's advoidance manuver. Reference the last generation Corolla, which performed fine through the course with the stabilizer bar, but was "difficult to control" without. (March 1999 issue, I believe).
    Hondas typically have better (sharper) suspension geometries than Toyotas, though.
    Id say- take a DX then an LX/EX out for a spin- literally, if you can go somewhere open and without a dealer rep.
    ~alpha
  • ghuletghulet Member Posts: 2,564
    The U.S.-spec Accord DX has power windows, but manual locks, dealer-installed (~$1100!) a/c, and only two (front) speakers for the CD stereo. By the time you equip the car for normal human use, it's smarter to just get the LX.
    I don't know what your prices are like, but a fully loaded Mazda 3 here costs over $20k (the hatch with leather and all options is like $23k) while the Accord DX without air is about $16k, and one can generally pick up an LX manual for about $18-19k.
  • anonymouspostsanonymousposts Member Posts: 3,802
    If you plan to use it as a family car, get the Accord. Not sure how it will be in Canada but in the US all 2005 Accords will have side curtain and side impact air bags standard.
    I also agree that maybe you should take a look at a van. You may have to buy used to keep the price down but that extra space might come in handy.
    I was afraid someone here would bring up that dreaded word of mine "minivan" I know I'm getting older but I just can't see myself in one of those!!! Is it possible in today's society to raise a family and not have a minivan? Anyone? How were they doing it 20 years ago?? Damn Chrysler!!....but I agree, I can easily see how they have so much more utility compared to sedans or small hatchbacks!!, I guess a wagon is always an option, wake-up Honda, are they going to bring it back perhaps? They seem to be making a comeback, I said earlier that I'm not a big fan of the Mazda6 but I don't mind their new wagon, too bad it only comes in a thirsty V6!! but you can get a stick!! my finances will have the final say.. I'm going crazy...thanks for the feedback guys!!
  • patpat Member Posts: 10,421
    or maybe it was more likely 30-40 years ago, there were station wagons aplenty with a third row back seat that faced the rear of the car. There wasn't a requirement for seat belts or for car seats, so there wasn't a rigid limit on the numbers of children who could be seated in any one bench seat.
    Unless of course the parents tried to seat three children in a row on a long car trip. In that case, inevitably an adult would end up having to be planted between the children to keep them from driving the driver crazy with their constant bickering.
    And yes, I am speaking of my parents' personal experience with me, my younger sister and my three younger brothers. I, of course, was never the source of the problem. THEY DID IT, NOT ME!
    :D
    While I can't argue that a minivan is unrivaled as a kid/stuff hauler, I will say that you can raise a couple of kids and never set foot in a minivan.
    My wife and I have two kids and never had anything bigger in the family than a Maxima SE for the first seven years the kids were growing. It's amazing how much stuff you can pack into a sedan if you have to.
    My wife won't be caught dead in a minivan. She opted for a midsize SUV a few years ago, but primarily because she had to haul a lot of stuff around for her job. I can pack almost as much stuff into the Maxima as I can into the SUV, except, of course, for very large and bulky objects.
    The gist of this is that I am pretty confident that you can haul 99 percent of what you will need in the Accord. It is a very roomy vehicle.
  • snakehairsnakehair Member Posts: 120
    Due to budget restraints and moving a lot in the milatary, I raised three kids (a year apart) and drove an Opel station wagon (also known as the "green latrine"). they fit in the rear seatr somehow and were close enough that an adult didn't have to sit between them. we recently had a large Grand Caravan and no kids (empty nesters). Loved the ride and space especially on long trips. Traded it because we never really needed it (the wife has a Highlander) for a V6Ex Accord. Have stated here before, I am somewhat disappointed in the build quality, but the Accord has never disappointed in the driving category. Love the power, smoothness and sheer exhilaration when I step doen on the gas at 70 and it just goes. different strokes as they say.
    talon95 -- thanks for the response on TSBs for automatic transmissions -- very helpful information. I have received no notices thus far.
    gee35coupe -- thanks for your response to a question I had about a post from anonymousposts about downshifting. You know, I was actually misreading that post -- I had in mind downshifting when going downhill, to keep the car from going too fast. When I was shopping around for cars last fall before buying my '04 LX, I'm sure I came across the idea of "grade logic" wherein an automatic transmission would downshift automatically when going downhill if the car seemed to be gaining excessive speed. I guess this wasn't the Accord -- can't remember which car it was.
    The higher octane to give the car more power going uphill to keep it from downshifting so much sounds interesting. May try it. I'm using 87 octane now and the car runs great. It typically downshifts from 5th to 4th on some Interstate hills. Once or twice it has kicked down to third, which really jacks up the rpms at 70 mph. Other than that, it's been a very quiet highway cruiser.
    the old Acura V6 transmissions and the old Accord (the boring looking Accord as i call it) V6 models had tranny probs, as well as Ody vans.
    but the NEW Accords don't have issues with V6 trannys. i don't even think the 4 cylinder "no reverse" issue is a HUGE problem.
    i have a feeling that the transmissions in the new Hondas will be bulletproof BECAUSE they have the bad image to improve from last gen Accords.
    i would hope so anyway.
  • imidazol97imidazol97 Member Posts: 27,720
    Perhaps it's the past reputation and past handling of problem transmissions that gives people a reason to not trust the statements now that there are NO transmission problems in Accords, v6 or 4s.
    Check the current discussions about the Odyssey trannies and in the Pilot discussions too. Are those V6 transmissions?
  • nw1997nw1997 Member Posts: 227
    Gentlemen,
         The bottom line here is that we are all loyal Honda consumers, reason being is that Honda makes great vehicles with exceptional value. This was one of the main reasons we went from a Lexus to an Accord. No vehicle is perfect, and it does not matter the cost of that vehicle. If the transmissions have problems, I am sure Honda will extend the warranty in this generation's line. I have read that the Camry's as well have their flaws as nearly all manufactures have some type of drivetrain malfunction, no vehicle is bullet proof to human error. We should not be slamming each other over something that has and may always occur, malfunctions/defects, etc. LOL
    "Check the current discussions about the Odyssey trannies and in the Pilot discussions too. Are those V6 transmissions?"
    These transmissions are of the same design family as the gen 6 Accords. The transmissions in the gen 7 Accord are a new design and a new design family.
    If you drive a gen 6 V6 Accord and then drive a gen 7 V6 Accord, the fact that the new automatic transmission is a totally different animal is abundantly clear. The gen 7 transmission is dramatically smoother and it's also far more responsive. Does this ensure that there won't be any problems? Of course not. But it certainly helps to assure me that problems with the previous generation were not carried over.
    Whether or not you trust the statements that no transmission problems exist with gen 7 Accords is your choice. That some people are hesitant to do so is understandable. But that doesn't change the fact that there are no problems at this time.
    the Honda trucks are old school - they use old troublesome transmissions.
  • 03accordman03accordman Member Posts: 671
    Today a bombshell was dropped on my, in the form of a failed transmission. As posters here would know, I own a 2003 LX Auto. I dropped in the car for a regular service/check-up, and was called on and told that the tranny is going, and they would be putting in a Honda rebuilt tranny.
    Even though I agree that things like this can happen to any car, I am particularly devastated that it has happened to me. I truly, truly love this car, and that makes it all the more harder. For now, its pen down and feeling blue
    03accordman,
        Man unbelievable. Is your vehicle a 4 or 6 cylinder? How many miles on it? Did it show any signs of tranny failure? How did the dealer come to this conclusion, special testing, etc.?
    Its an I-4 with around 33k on it, and there was a constant high pitch whistling noise for at least the last 8-9 months, when I first logged in the problem.
    I thought they fixed the tranny issue with the 03, but, at least in my case, it doesn't seem so. I hope it is not widespread becuase that would hurt a lot of Accord owners.
    It's weird, we have a slight whistling noise on our V6 04 Accord, approx. 3000 miles on it. The whistling noise happens when I take my foot off the gas at around 40 - 50 mph. No other speed causes this noise. Was your noise at a particular speed or throughout the entire MPH range.
    sorry to hear that. perhaps the rebuilt unit will be fixed? do they know what component is wearing prematurely in the transmission?
    "and they would be putting in a Honda rebuilt tranny."
    Sorry to hear about this...
    If it makes you feel any better, what they have done in the past is to install a remanufactured transmission, rather than a rebuilt. With a remanufactured transmission, all of the "guts" of the transmission is brand new, they just re-use the very expensive transmission case. Whereas with a rebuilt transmission, they replace only parts that were determined to have failed, so many used parts could be reused.
    And I had a 2000 Accord that had its transmission replaced, and it worked just like new afterwards. Hopefully that's a bit encouraging.
    Could you ask them what prompted them to decide to replace the transmission? Is there some kind of new TSB, or was the decision made just for this specific case?
  • boxman1boxman1 Member Posts: 2
    04 v6 ex 5k Build quality isn't what I expected from Honda. Headliner rattles in different places, front drivers door has a harmonic buzz when you hit any kind of bump or imperfection in the road. Passenger seat rattles, front passenger door noise, front part of the front door makes noise, brakes grab.
    I also wonder what engineer decided to make the arm rest come into a point with hard plastic when you lean your leg against it. The Acura RL which is built on the same frame have a nice flat arm rest like just about every other car. Engine and everything else are great.
  • lmacmillmacmil Member Posts: 1,758
    2003 TLs seem be going for low to mid-20s. The higher price will get you a Type-S with the 260hp engine. Although somewhat bland styling, it's arguably better looking than the current Accord sedan. Longer warranty means there could almost as much mileage left as a new Accord with 3/36. You certainly won't see one everytime you turn a corner. Any opinions?
  • chucko3chucko3 Member Posts: 793
    talon,
    does your 03EXV6 engine make a light noise when the car stopped and you turn the steering wheel?
    Check out Acura TL vs Honda Accord EX V6 and/or Acura TL. They would be better places than here to get into that tranny discussion, which is what's coming!
  • blaneblane Member Posts: 2,017
    boxman1:
    I've owned a 2004 Accord EX Coupe since December. I cannot get my knee anywhere close to the armrest in my normal driving positions. In fact, there is about 5" - 6" of leeway there. I would have to contort my hip joint in order to "lean" my "leg against the armrest" for more than a few seconds. Perhaps its different in sedans.
    Additionally, my arm rest is soft and rounded, not "hard plastic" as you describe yours.
    I've experienced NONE of the noises that you've described, nor do my brakes "grab". Great car!
    I posted over there but that seems more geared to the new TL than the last generation. We'll see what kind of response I get.
  • wood142wood142 Member Posts: 11
    My 1990 Honda Accord EX occasionally wont start right away.However,if I wait up to 10-15 minutes ,it will start and run just fine.It never stalls or cuts off,so I dont think it would be the fuel pump.I havent changed the fuel filter in a few years,so maybe it could be that.I am the original owner of the car and want to keep it running a bit longer,but am getting leary of driving it more than a few miles from home.Your suggestions and ideas would be most welcome.
    I'm not sure I'm tracking with what you mean by a light noise, but when I try that, I don't hear anything that I'd classify as unusual.
    If you put your leg back and lean it to the left as I and I'm sure many other people do your leg will be resting against the center portion of the arm rest which is beveled into a point instead of being flat and is made of hard plastic. I'm 6'1" and have the seat back a little bit. The arm rest on the Acura TL is flat on the side. As to the brake grab and noise problems they seem to be common problems as well. Please read the quality control forum under Honda Accords. I'm pleased you are having good luck with your car, thats one of the reasons I purchased a Honda.
    My wife used to own a 92 Accord LX. Same problem, sometime she had to wait for 1/2 hr to start the car again after driving it.
    The dealer replaced the starter relay, the problem went away.
    I'm sitting here wondering WHY you just wouldn't take it to a dealer or other shop to have it checked out?
    Otherwise, you'll continue to worry about it not starting and you'll be afraid to take it any distance.
    Instead of guessing and worrying it just makes sense to have it checked out!
    It's fourteen years old. It could be anything.
  • bobrienbobrien Member Posts: 1
    Can anyone give me direction regarding where to put the jackstands on me '02 Accord ? I want to change the oil, but can't seem to locate a solid area on the frame. Would if be possible to jackstand the same location as I would if I simple had a flat tire ?
    The noise on my car comes when the gas pedal is pressed, at all speeds above 45MPH. As soon as I let go of the gas pedal, the noise goes away, so I think what you have is something else.
    I have not yet been told details about the actual reason the tranny is being replaced, but I intend to find out in detail this week. Will keep everyone posted. I trust Honda to stand by their product and am sure all assistance will be provided to me.
  • slawendaslawenda Member Posts: 101
    Hello everyone--
    Just wondering-many dealers like to include mud guards, in fact many cars seem to come with them already installed. Since I don't care for them in terms of their looks- was wondering how easy it is to remove or uninstall them, and if uninstalling them would leave any "holes" that shouldn't be there. I heard that installing them requires drilling new holes, so perhaps uninstalling them will reveal holes that may show? Any thoughts or comments appreciated.
    I don't know which year your speaking of, but I installed the mud guards on my '03 V6EX and there are no new holes to add. There are screws that must be removed and then reinstalled with the mudguard in place. Removing them should not leave unsightly holes. Go to HandA site and download the installation instructions for the mudguards and do the reverse. Well within anyone's ability if you have a very short philips screwdriver at hand.
    Look in the owners manual that came with the car.
    There are at least 4 recommended places.
