Older Honda Accords
1286287289291292389
  • 03accordman03accordman Member Posts: 671
    I have read all these new posts, so there seems to be a more widespread problem than I earlier thought.
    As for V6 only problems, well, as I posted earlier, I have a 4 cyl Auto, so maybe I am an isolated case, or maybe there will soon be others with the same issue with the 4 Cyl. The comforting thing is that Honda is standing by its product and doing this pro-actively.
    I will keep you posted as soon as I get more info.
  • justinjustin Member Posts: 1,918
    yea, still kind of leery about driving long distances, but that is the one thing my Accord excels at! 90 mph on freeways. don't wanna pay for and drive some Impala for my trips.
    besides, i don't plan on keeping the car long, so i am not too concerned. i know i could be causing damage to the car, but as long as it doesn't FAIL and leave me stranded, what the heck!
    the dealer promised that i wouldn't have a failure at such low miles. not that dealer statements are worth much....
  • gee35coupegee35coupe Member Posts: 3,387
    You wouldn't think that 2nd gear would get too much use in a 5 speed tranny.
  • austinman7austinman7 Member Posts: 313
    nw1997,
    Yes, I thought you had a 6-cylinder, but wasn't sure. I will be very interested to hear if whatever they do to your tranny takes the noise away, since we seem to have the same symptoms.
    But as a 4-cylinder owner, I am officially on the sidelines as far as the recall goes. Hmmm.
    Well, all I can do at this point is to continue working with my service manager for a fix. Like you, I want this noise eliminated and to have some degree of assurance that the transmission is operating properly and safely. As of the moment, I have neither.
    03accordman,
    I forgot -- you are the one who had a complete transmission failure -- correct? -- with a 4-cylinder Accord. Well, that just makes you wonder if the recall notice is not inching closer and closer to the 4-cylinder models. It definitely is spreading.
    i wondered the exact same thing! my car is hardly in second gear. but, then i read that long streches on flat roads is what causes damage. and who is in 2nd gear for long periods at a time on flat roads? almost nobody i think.
    so i guess that theory is flawed.
    we will probably figure it out here before Honda does...haha.
    See if they have any manual sedan EX-L's.
  • maxamillion1maxamillion1 Member Posts: 1,467
    Dang. I wish I could afford to do that.
    Well, at least Honda is trying to resolve the transmission issue, my Altima has some transmission shifting problems, and according to Altimas.net, my car isn't alone, but Nissan is doing NOTHING about it.
    At least Honda is taking a stand. Next car will be an Accord EXV6 coupe.
    I did not have a compplete tranny failure, it was that high pitched whistling noise in 5th gear
    Sorry, I forgot what your original post said. I went back and read it, and it does say you will be getting a rebuilt transmission. I assume that hasn't happened yet? Would be interested to hear the outcome.
  • reece1072reece1072 Member Posts: 3
    Thanks for the info. I have a 2004 EX-V6 as well and that noise is extremely annoying. I have been to 2 dealers of which one had my car for 5 days and could not figure out what was causing it. The other dealer said they had a car with the same noise and it was "under investigation by honda". I have been telling the Honda techs that it felt like it was coming from the tranny but they keep saying "I dont think so..." Then they blow me off saying it is a pinging noise and to try a higher octane! I also notice if you put the car in 1st gear, accelerate, then coast you also hear that annoying noise. I will call honda in the morning and let you know what happens... Again thanks for the info!
  • nycanyca Member Posts: 232
    with all this talk - I was wondering, have they fixed the transmission problem this recall is based on in new Accords? when was the cutoff date?
  • jmessjmess Member Posts: 677
    For comparison here is what they do for the Ody recall.
    04-021
    Applies To: See VEHICLES AFFECTED
    Safety Recall: Automatic Transmission Second Gear Inspection
    BACKGROUND
    Certain operating conditions can result in heat buildup between the countershaft and secondary shaft second gears in the automatic transmission. Without enough oil flow to dissipate heat, prolonged operation under these conditions can eventually result in decreased material strength. In higher mileage vehicles, this can result in gear tooth chipping or, in very rare cases, gear breakage. In most cases, transmission noise will indicate a problem, however it is possible for the transmission to become locked without warning. A locked transmission could result in a crash.
    CORRECTIVE ACTION
    Vehicles with 15,000 miles or less:
    Install an A/T oil jet kit.
    Vehicles with more than 15,000 miles:
    Do a photographic, not visual, inspection of the A/T second gear:
    • Using the digital camera and camera mount in the A/T Gear Inspection Kit, take five clear photos of the second gear through the countershaft speed sensor hole.
    • Load the photos onto an iN workstation, then display them on the monitor.
    • Compare the gear color in the photos with the gear colors in the A/T Gear Inspection Guide that came with the camera.
    • If you determine that the color of the gear in your photos matches gear level number 1 on the inspection guide, install an A/T Oil Jet Kit.
    • If you determine that the color of the gear in your photos matches any gear level other than number 1 on the inspection guide, submit a completed A/T order form, with your digital photographs, to RPO Tech Line.
  • chucko3chucko3 Member Posts: 793
    My friend's Odys had 25k miles when they installed the jet kit to its AT. I guess the 2nd gear is OK.
    I called this morning. I am also part of this recall. The Honda Rep said that notifications will be mailed starting in July and end in September. Why can't they get their trannys right?
    I have a technical question for anyone who may know the answer.
    Since the Odyssey/Pilot/V-6 Accord recall has to do with second gear, why the dire warning (see post 15076, above) about a possible transmission lockup and crash? At 70 mph, what would be happening with the second gear mechanism to lock up the transmission?
    Or are we talking about a transmission lockup while in second gear at 15 mph, which, of course, is a whole lot less risky.
  • jrct9454jrct9454 Member Posts: 2,363
    ...and see how the gears spin on the shafts, even when second gear is not engaged. Second gear is on the same shaft as one or more of the higher gears...if it is shedding metallic particles....bad news...
  • htthtt Member Posts: 75
    I just called today and was told that my '04 accord v6 was not part of the recall. Mine was manufactured in Dec. 03. So that I think all the new accords should be OK... until other problems pop up.
  • atlantabennyatlantabenny Member Posts: 735
    Not exactly sure how it happens mechanically, but the 99-up Acura TL/CL with a defective tranny while running 80 mph on 5th would suddenly downshift directly to 2nd. This - happening particularly on a slick road - would have serious consequences. That it affected "only 2%" of those models' population prompted Acura/Honda to extend the tranny warranty to 7 years/100k miles instead of implementing a safety recall.
    I'm guessing that with the multi-passenger Odyssey and Pilot, the higher risk & consequence level has warranted a recall this time.
    Thankfully they're including the passenger cars. It's encouraging to know that Honda seems to have finally determined the cause and treatment, and is taking steps to mitigate. If the handling of the Tylenol debacle and recovery is to be an indicator, Honda should come out OK on this one.
    jrct9454,
    I see. Thanks for the insight on second gear.
    atlantabenny,
    I agree it's a good step for Honda to be proactive with a recall, and I hope it's effective for every vehicle they see. But I'm still on the outside looking in, since they're just recalling V-6 models. I'm hoping Honda is sure that the automatic transmissions in 4-cylinder models do not have this same defect. It is pretty much the same transmission, as far as I can tell.
    Plus, my situation, with my 4-cylinder, is that my car is making a whining noise that my service manager believes is coming from the transmission. He called again this morning, and he may wind up doing the oil jet kit fix or a new tranny for my car, which is the same fix for those under recall. So it just makes me wonder if the recall will eventually include the 4-cylinder Accords as well.
    I hope Honda does come out of this looking good, because I'm enjoying owning and driving this car so much. Would love to keep it for many years.
    Does anyone know how it gets installed?
  • jrock65jrock65 Member Posts: 1,371
    "I just called today and was told that my '04 accord v6 was not part of the recall. Mine was manufactured in Dec. 03. So that I think all the new accords should be OK... until other problems pop up."
    That means that Honda KNEW of the problem in December 2003, or earlier, and only now are they announcing the recall. A couple months delay I could understand, but a seven month delay?
    Pretty disappointed with Honda about this. Not about the recall itself, since recalls can happen to any car, but the fact that they delayed for so long.
    So they let people people drive around for seven months or more, knowing that there was a defect which REQUIRES a kit to be installed? Thanks...
    well, it likely took some time for develop the repair kits, time to manufacture and distribute them and setup a process by which they would be installed and notifications sent, etc. fixing the problem on new transmission parts being used to assemble new cars is easier then doing a fix in the field for cars already deployed.
    but seriously, there should be something moving to get Honda to provide an extended warranty to 100K miles on these transmissions for all owners.
    Not necessarily true. My car was manufactured in January 2004. My VIN indicates that I am part of the recall.
    "Not necessarily true. My car was manufactured in January 2004. My VIN indicates that I am part of the recall."
    Odd that a later built car is affected, whereas an earlier built car is not.
    Really hope that no one gets hurt from a transmission lock-up while waiting for Honda to send them the letter.
    from what i understand, none of the transmission on ANY of the Honda cars (Gen 6 based) or the new ones ever locked up before 60k miles. the beginnings of damage has been seen at 15k, but the failure (lock up) not before 60k, from what i understand.
    any pics out there of what this oil jet thingamijig looks like? what is it exactly?
  • nw1997nw1997 Member Posts: 227
    Hey,
        Has anyone seen or heard from Isellhondas, I think we would all like to hear what are his thoughts on this recall on the transmissions.
    doesn't have enough torque to develope the heat required to damage the gears.
    If the V6 and 4 cyl trannies are the same unit, the 4 cylinder engine shouldn't stress it anywhere near as severely as the V6. Well below it's torque limitation.
    The jet assembly replaces the ATF filler plug on the Ody. Some feel it could make ATF changes a little more awkward for do it yourself types.
    I lucked out and got a 04 Ody that has the updated auto. The rumor is they increased the ATF pump pressure on the later automatics so more fluid would cool the gear.
    We have an 03 Accord EX 4 banger auto also. Not part of this recall but time will tell?
  • richards38richards38 Member Posts: 606
    Here is my guess:
    Anything stressed enough will break and if excess heat weakens 2nd gear in the Accord transmission, perhaps the gear could break under enough stress after some period of time exposed to extreme heat.
    The Accord V6 engine generates over 30% more torque than the 4 cyl. and perhaps the more powerful, V6 engine could break a heat-weakened gear under conditions that would not occur with a 4 cylinder car.
    The 4 cylinder engine simply might be unable to generate enough torque to do damage to the gear as would be the case with the V6.
    So, if deterioration from heat could cause 2nd gear to disintegrate under hard acceleration in a V6 but would not under far less stress imposed by the 4 cylinder engine, then there's no problem for owners of the 4 cylinder--at least up to some high number of miles beyond which few 4 cylinder Accords are likely ever to be driven anyway.
    Again, this is one explanation (guess) why the recall is for V6 Accords and not 4 cylinder ones......Richard
    back when they recalled the 4 speed autos in the old Accords, they only recalled the 6 cylinders. for the same reason. the 6 makes torque - the 4 just doesn't make enough to do any harm.
    it would make me nervous if i owned a 4 cylinder model, but what can ya do?
    The theory that the 4 cyl. doesn't stress the gears enough to cause a problem, whereas the 6 cyl. does, certainly sounds logical.
    The ultimate outcome of my situation might provide some insight. If my dealer winds up installing the oil jet kit, and the whining noise goes away, that would possibly link the 4 cyl. and 6 cyl. problems. And provide evidence that the recall should extend to 4 cyl. models.
    Or maybe not. Who knows? I'm no mechanic, much less a mechanical engineer. I'm just an owner looking for satisfaction. In my personal situation, all I know is that I'm determined to have this abnormal noise fixed under the terms of my warranty, regardless of what's causing it.
    I'm really posting all this, and following your all's thoughts, partly for my situation, but just as much for all the 4 cyl. owners.
    And finally, you would think there are engineers at Honda who could answer all these questions for us in a heartbeat. Is there an American Honda Motor Co. representative monitoring all this on this thread? If so, how about pitching in with some solid information?
    There is at least one precedent for this that I know about, and that some of you may be aware of, too. I was monitoring the Camry thread two years ago when I was comparison shopping, following the discussion about the oil gel issue. A Toyota corporate rep. finally weighed in with some comments, and actually received and answered questions on the Edmunds thread.
    Maybe this isn't Honda's style, but I think the willingness of Toyota to do that was appreciated by most of the posters. Honda could win some points with me by engaging us on this thread. But I'm probably dreaming to think that a car company would be that customer oriented.
  • vonnyvoncevonnyvonce Member Posts: 129
    I understand the Nav Accords have a trip computer. What parameters does it offer?
    Oh, I'm here, doing a lot of reading and trying to resist the temptation to jump into the fray.
    But, since you asked....
    So far, our buys shop has examined and done the recall on a whole bunch of these. We found ***ONE*** high mileage Odyssey that was questionable. As I understand it, several techs looked at the photos and one tech thought second gear may have looked questionable.
    So, they downloaded the photos to Honda who authorized a transmission replacemnet. The Odyssey looked like it had been well used and beaten. It had a Class 3 (Big) hitch on the back.
    Personally, I think it's a tempest in a teapot since so few cars will ever experience a problem.
    Still, not a great thing for Honda to have to deal with.
    It has to be remembered that in forums such as this one, problems tend to become amplified beyond reality.
    Thanks for your comments.
    Actually, I had in mind someone from America Honda Motor Co. who would have a company-wide perspective. I think that would be much more helpful than someone such as yourself, who's looking at it from one dealer's perspective, though whatever factual information you can offer would certainly be appreciated.
    Since you work for Honda, could you suggest this idea to someone at the corporate level?
    I wouldn't characterize a recall program now involving about 1 million vehicles a tempest in a teapot. Especially one involving a key drivetrain element.
    If you're suggesting I'm not dealing with reality, you'll have to go back and check my posts and let me know where you think I've strayed. Otherwise, kindly don't direct those kind of comments my way.
    My goal in every post is to be realistic, along with helpful, polite, optimistic, and constructively critical, primarily because I really like my Honda. So far, no one but you has been critical of my approach. Your comment that I am amplifying the problem beyond reality has a condescending and patronizing tone to it, a kind of weary, "Well, I have to remind them again that they're making too much of this," when in fact we're trying to exchange information in an intelligent and considerate way.
    All you offered on your last post was the idea that one minivan with a trailer hitch indicates this is a really small problem, being experienced mainly by those who abuse their vehicles ("well used and beaten, with a big hitch on the back."). That's an incredibly narrow view of an issue involving a recall with an initial pool of a million Honda products.
    Opps, I forgot, I meant to end that last post by asking again if you could help us all expand our perspectives on this transmission issue away from just what we're seeing at individual dealerships and help us get the American Honda view. Any chance you could swing that?
  • talon95talon95 Member Posts: 1,110
    I think you were more than just a little bit hard on isellhondas, especially since his response was to nw1997, not you. Nw1997 asked specifically for input from isellhondas in his post #15090, so isell's post was NOT in response to your post asking about official representation from HAC.
    His comment about a tempest in a teapot was a general one, not an evaluation of your posts in regard to the recall. And his comment was NOT based on an evaluation of that one van, but on his dealerships evaluation of many vehicles that were inspected as part of the "first phase" of this recall. His point was that of the many vehicles that were inspected, only one met the conditions that required a transmission replacement. So by calling it a tempest in a teapot, he meant that in his opinion (which, let's not forget, he's entitled to), the likelihood of transmission replacement being required as a result of the defect covered by the recall is small.
    If you really want him to pursue your request about representation from HAC, I humbly suggest that you may want to ask him a little bit nicer... ;)
    At a later date though. It's just a matter of time. I don't really mind as long as Honda has my back. The reason I stick with Honda is that they have never let me down. I bought a 98 Civic with a crappy paint job. Terrible. Corporate Honda gave me $1000 toward a new Honda. And the dealership I purchased it from sold me a 99 Accord at invoice while giving me a great deal on the trade.
    They won me over with that. Since then we have bought 7 new Hondas. One of our 02 Civics had a weak parking brake and our 03 Accord had the obligatory wrinking of the window trim. That's it.
    What's the deal with loaner cars when you're getting the oil jet pack installed?
    Will the dealer arrange everything for you? Or do you have to call American Honda?
  • slawendaslawenda Member Posts: 101
    The trip computer offers miles, miles per gallon, I believe some factor of time (how long your "trip" was), and trip "history"--this latter is very interesting. It allows you to compare all of the above for your previous trips. It's pretty nifty.
  • swordfish555swordfish555 Member Posts: 28
    Does anyone know if the fix will in any way hinder changing your trans fluid yourself?
    I have an EX-V6 with leather, and I am not sure if the dash, which seems to be composed of several "pieces", contains leather or not. I am trying to decide what kind of cleaning or protectant products could be used if I so desire. Of course, the main distinction as far as cleaning and protectant products go is whether you're dealing with leather or not.
    My best guess is the dash has both leather and plastic, but the other possibility is that it's all plastic. If anyone knows for sure, please let me and the rest of us know. The manual doesn't seem to discuss this. Thanks in advance.
    I don't think there's any leather on the dash. There is leather on the seating surfaces of EX-L 4s and EX V6s, but also plenty of vinyl in those interiors, too. That's not a bad thing because the vinyl is of high quality in the Accord.
    I think there is an Armor All product made for dashboards--don't use the regular Armor All because it leaves a shiny surface that will reflect the top of the dash into your windshield......Richard
    Thanks, Richard. I still am a bit wary of using something that could damage leather, without knowing absolutely whether or not there is leather on the dash. I know there are Armor All products for leather, and of course for those without. Of course there are many other brands out there besides Armor All--I am just referencing them as an example.
    It's too bad the manual doesn't discuss "how to care for your interior". At least I haven't come across it yet. If anyone has come across this in the manual, or otherwise knows the truth about this, please let us know.
    Your caution about materials is well taken, but there is NOT any leather on the dash of these cars. Period.
  • anonymouspostsanonymousposts Member Posts: 3,802
    I think that most products suggest testing them in a small, preferably hidden, part of the interior before using them all over.
  • rhard49rhard49 Member Posts: 226
    just picked up my 04 accord coupe 6 speed and had the wing spoiler installed. I'm not sure they put the heavier duty springs for the trunk lid because it will only stay up in the full up position. If its at any angle toward being closed it slams shut. has anyone had the wing spoiler put on and can tell me if this is normal?
    Rich
    My post was NOT directed to you. It was strictly my viewpoint and my opinion on this since I was asked.
    Just because cars are recalled, this doesn't mean that they all have problems. The recall is simply to inspect these cars in order determine if they may have a problem.
  • mrelocmreloc Member Posts: 25
    I just installed the wing spoiler on my sedan and it came with the upgraded springs which I installed. They definately compensate for the extra weight... The original factory springs in my car were beige in color and the heavier duty springs are black... check that out. Also, you might check that they installed the additional square rubber bumpers on the closing edge of your trunk. They should have stuck them right next to the original ones.
    Although installing this myself was a bit intimidating, and the spring switch was the hardest part, I at least felt confident that I would do the job as good or better than the kid at the dealer would have.
    I'm impressed. That's not an easy job.
    And, they don't let "kids" install spoilers at the dealerships. Drill the holes wrong and you are in deep trouble.
    Also, those springs can be nasty to install depending on the model. I know the Preludes were enough for the most seasoned tech to turn the air blue trying to get them in place!
