Older Honda Accords
1351352354356357389
  • bimmer4mebimmer4me Member Posts: 266
    Ditto. I have an extremely busy schedule. I don't have the time to burn and follow the ubsurd 3000 mile oil change. I'll stick to the owners manual. :P
  • imidazol97imidazol97 Member Posts: 27,700
    I check and change my oil based on how it looks and feels as well as considering the mileage on a motor. The outside temps, the driving time, the number of cold starts and restarts all contribute to contaminating the oil.
    So my oil changes don't match the book's recommendation. BTW, what are the recommended change interval for the Accords in Japan? Aren't they much shorter than in US? I believe I've read that earlier in these groups. I wonder why they would extend them in US? I'll keep changing my oil based on looks and an anecdotal test I do, even if someone ridicules me for doing so.
    Best regards--Keith
  • breckcobreckco Member Posts: 62
    I have worked with the service dept's of several dealerships (including Honda) and would like to address recent posts regarding oil changes. It seems that many forum regulars think there is some oil change conspiracy from dealerships - there is not. Actually, oil changes are considered a necessary evil. They do not produce profit, some customers set appts and some don't causing difficulty completing oil changes within a timely manner. Bottom line is that service departments would be considerably more profitable if fewer oil changes were performed allowing for other types of services.
    Also consider that manufactures are now promoting items such as low cost of ownership (which includes oil changes) in the marketing of new vehicles - fewer oil changes = lower maint costs.
    My experience is that you can get away with 7500-10k intervals if you plan on keeping your car 100k miles or less. However, most owners who limit mileage between oil changes to 5k or less have much greater success and fewer issues if they intend on keeping their vehicle 150k plus - It only adds about 1 oil change per year. I personally use a 5k interval while many of the area dealerships recommend 3,750 miles.
    The last comment I will make is to address people like avianflu. Refering to the people/humans working on your vehicle as "monkeys" is disgraceful. You were sure to inform everyone of what you do for a living - does that make you better? I agree many car dealerships deserve the negative repuation they have. I have been frustrated at the lack of professionalism and dishonesty I seen. There are however many honest, professional people who trully want to serve you. Give them a chance!
  • aitchpee44aitchpee44 Member Posts: 16
    I agree with Bretco, a 20 dollar oil change about every 6 months or 3000 miles would only help in the long-term maintenance of your Honda Accord. Also I have always respected the maintenance area of a dealership more than the dishonest sales staff.
  • gee35coupegee35coupe Member Posts: 3,387
    Changing it ever 3000 miles is absurd. As I said, if you are going to cut your interval that drastically why not just buy a whole new car every 50,000 miles since you never know if some unforeseen malady might occur.
    Replacing a car is much different than changing the oil.
    If people find their oil is looking bad by 3000 and they don't like the looks at 5000, why shouldn't they have it changed?
    Best Regards--Keith
  • blaneblane Member Posts: 2,017
    "looking bad" is immaterial. All oil starts to oxidize, and therefore change color, immediately after you turn the engine on after an oil change. The color of the oil within the first 5,000 to 10,000 mile of use has little bearing on its lubricating abilities.
    With imported oil at $60 to $70 per barrel, I believe that we shouldn't be wasting it on frivoulously frequent oil changes. Studies have revealed that about half of the oil removed from engines ends up NOT being recycled. It ends up in sewers and landfills.
    Following the engine manufacturer's maintenance schedules will provide excellent vehicle service.
    Do the particles that don't wick through paper fibers as the oil shows darker color mean anything? I have been told those are the oxidation parts and if they are particulates in the oil then they must have an abrasive character to them.
  • stickguystickguy Member Posts: 53,565
    color doesn't really tell you much. If you really want to know, take a sample at 5K and send it out for an oil analysis. That should pretty much tell you whether you need to change at that interval, or can go to the 10K level.
    FWIW, I always used to go with about 3k/4 months (just to be anal). On our 2005 Odyssey, with the oil life monitor, it has hit the change level (15% IIRC) at about 5K and 10K (5 and 10 months also). So, that is when I changed it.
    My new Accord ('05) doesn't have the oil life minder, but I won't go past 5K or 6 months, whichever comes first. i also don't do the long trips with this car that the van gets, so it is harder on the oil.
    So, I will probably do my first change at about 5-6 months, depending on how many miles I put on it. I certainly qualify for the severe use schedule, and no way I would try to stretch it to 10K (over 1 year), especailly for the first change.
  • daisdais Member Posts: 9
    The most I had done was changing the distributor cap - 1995 odyssey. This time I need new thermostat. I suppose it is somewhere at the other end of the big radiator hose, but where do I start?
    I'd feel great if i can get this done, not to mention about the huge bucks i'd save :-)
    if you really want to be a DIY, get a shop manual (or at least a Chilton's version). That will show you where stuff is, and the steps for replacing it.
    In any case, I think it is usually in the housing at the top of the radiator hose (on the engine side of course).
    Side advice, if you are taking the hose off to repalce the thermostat, might as well throw on new hoses. I assume they aren't too expensive, and the labor will be the same, so might be some peace of mind not having 10 YO hoses.
    Just use good quality oil filters and oil of the proper viscosity specified by Honda in your Owners Manual. Don't concern yourself with oil color. Just change it in accordance with the Honda Maintenance Schedule that you received with your vehicle.
  • techman41973techman41973 Member Posts: 83
    I have a leak in my radiator on my 97 Accord with 165K.
    I have done other repairs on my car and I am considering attempting this on my own.
    Especially when my dealer want $500 installed.
    I have looked at my Honda service manual and it seems straight forward.
    Basically:
    Drain coolant.
    Remove all hoses connected to radiator.
    Remove all fan harnesses.
    Remove radiator mounts.
    Remove radiator with fans attached.
    Remove fans from radiator and install on new radiator.
    Install in reverse order.
    * Can anyone recommend an aftermarket radiator that installed easily into a 94-97 Accord?
    * To anyone who has done this type of repair and run into any type of complications, any additional tips would be helpfull.
    * One thing I would like to do is find a way to keep the transmission fluid from leaking out of the hose once I remove it from the radiator. I also plan to protect the fins with a piece of cardboard when installing the new radiator.
  • lastwraithlastwraith Member Posts: 350
    There's no arguing against following the manufacturer's schedule of maintenance (in my mind) if all you are worried about is warranty coverage and the mileage numbers that are associated with it.
    But given the facts: 1)I keep my cars for the life of the car (barring some unforseen circumstances), 2)I drive in the same manner and basically in the same conditions for the life of the car, and 3) The maintenance schedule as an general reference document for the masses (North America per se) is not tailored to my specific vehicle usage I see no better way to figure out oil change interval than by getting an oil analysis done and using the hard evidence to create a specialized service schedule (for oil anyway).
    I'm not pointing the finger at anyone because we all are in different positions. Some people will trade in their car every few years, or will keep it only till the end of the warranties, or are just not that concerned with splitting hairs over an engine that seems to take almost anything you can throw at it. If I were one of these people I would just go by the book too.
    On the other hand, since you can sample your oil every year or two with relative ease and low expenditure, send it in, and then receive quantitative data that will not only help you construct a nearly perfect oil/filter change schedule (taking into account both driving style and changing engine condition, ie parts breakdown etc) but will also give you valuable engine health data I really don't see why the owners who are "lifers" don't just disregard it all and do it themselves (as I do). It seems to me a method this tailored and informative would help to extract the absolute best in lubrication performance/value.
    Then again, it's late and I may have missed something in that longwinded paragraph. What say you?
  • kevinvkevinv Member Posts: 8
    I have a 92 accord with and automatic transmission which is difficult to move from Park to any gear and from any gear back to park. The transmission shift and works great except the lever is difficult to move as stated. It moves fine everywhere else (D1 to D2 to D3 to neutral) Any ideas as to why? and if so and ideas as to a fix? Thanks
  • doinwidoinwi Member Posts: 6
    I have a 99 Accord EX. I recently had torque converter problems. American Honda came through and replaced it free because of a known "shudder" problem. Now I have a howling noise in my rear wheel bearings, and my clock light is out. I've been to AllData and see there are service bulletins related to both items. Anyone had a similar problem with the clock and wheel bearing? Have the dealers come through and replaced them?
  • zzzzzz Member Posts: 17
    I recently bought a 2001 accord EX from a private party. When I test drove it, it felt ok. Now that I've had a few weeks, I've noticed the following:
    a) The car seems needs some extra push to get going, especially in low gears. I have to push the gas pedal harder than most cars I've driven. Since this is my first Accord, i don't know if this is normal. Note that this problem is only obvious in lower gears. Once on the highway, it's pretty responsive. I've also noticed that if I stop at a stop sign or red light, the gear seems to downshift quickly back to 'zero gear' -- that is, the car seems to have no power/desire to move forward and i need to push the gas pedal hard to get it going. I know that Honda has a recall on the transmission, but I don't know if my issues fits the description for the recall.
    b) The car doesn't start right away when I turns the ignition for first time in the morning. I can hear a few more cranks before it starts. I assume that this isn't a big deal. But I've haven't had this problem in other cars I've had. Does this mean that the spark plug has worn out or I have a starter problem? Note that this only happens the first time you start the car in the morning.
    c) The light for the clock went off, so I can't see the clock at night. How much does it take to fix it?
    d) I'm getting about 27mpg on 85% highway driving, is that normal? I was hoping for better, as my old 99 camry can get about 30...
    thanks.
    Is this the 4 cylinder engine (your title says v4, so part of that is wrong!), and I am assuming it is an automatic trans.
    Also, what is the mileage on the car? It is old enough that it could be due for a tune up. In any case, having a once over done by a mechanic doesn't sound like a bad idea, plus maybe you can find another one of the same vintage to drive for comparison.
    Hard to really comment on the items you mention, since they could be totally subjective, and I have never driven an AT Accord.
    I do know that the clock light issue is fairly common, and there may be a TSB out on it. Also try the Accord problems thread, since I think it was discussed over there.
    it's an automatic tran, it has about 54k miles on it. I'm more concerned about my issue #1 (the hard push on gas pedal needed in lower gear). I can live with the rest.
    But thanks for the info on clock light, i'll check it out.
    Really the only way to tell if it is normal is to try another car with the same drivetrain. Might just be the way they are. if not, find someone to take a look at it.
  • richylrichyl Member Posts: 20
    Today while sitting at an intersection I noticed that another Accord with the same color, same look and same model that has an amber turning signal on the rear, yet mine is red. Did the person mod his car or do Accords come with two different flavors for rear turn signal lights
  • familyhaulerfamilyhauler Member Posts: 1
    I have had three Accords (98, 00, 00 again) and on ALL of them the clock light failed. It's easy to fix: the clock itself can be removed from the dash, just grab it on both sides with your fingers and pull it out, using a side-to-side rocking motion. There is room for your fingers between the AC vents. If necessary, use channel locks with a rag to prevent scratching, be careful, don't squeeze too hard and crack the plastic! Once the clock is out of the dash, unplug the cable and you can remove the clock from the car. Then it's easy to access the bulb from the back to replace it. It's around $4 at Honda.
  • ken972ken972 Member Posts: 162
    Must have been a different year. I think they went red in 05. I have an 04 and they are amber..the 03's are amber as well.
  • djm2djm2 Member Posts: 712
    I found your comments very interesting. Yes, an oil analysis is the correct way to go with regards to setting up oil & filter change intervals for a specific vehicle. But, I do not have the time, or the interest to engage in this activity, so I simply take my vehicle to the Honda dealer every 3,000 miles, and have them perform the required service. Sometimes, if I am going on a long road trip, and I know that I will be exceeding the 3,000 mile interval on the trip, I will start the trip with a fresh oil and filter change. The Honda dealer that I use has an express oil and filter operation, so I am paying a competitive price for this service, and the dealer does recycle the used oil, so the only negative part of this activity is the extra cost to me, the owner of the vehicle, and I just consider this to be the cost of good maintenance. ------ Best regards. ----- Dwayne :)
    I kind of figure the $50 for an oil analysis every couple of years can pay for a lot of oil changes. I don't do mine at 3000 when I know the car has had long drives and fewer short trips in cold weather. I still believe looking at the oil and using common sense and the paper test helps me judge the detrioration and particulate load in the oil.
    I may also try changing the filter at 2500 when I plan to drive further and see if the new filter cleans up the oil where the previous filter had partially clogged and was bypassing more than when new.
    Others are very free to do as they please and I do not criticize their choice.
  • creinholzcreinholz Member Posts: 2
    The Maintenance Light "the wrench that lights up" should be an indication of real oil life. It is based off a system that was first introduced in the Odyssey van. Its based off a light that is sent in your oil pan to a sensor. As your oil gets used it gets darkened and the light sensor get less light sent to it and keeps track as a rough estimate in a percentage. In theory it should adjust depending on the way you drive and the condition of the weather automatically. So in the Northeast or the Southwest it shouldn't make a difference. Follow the Minder System no need to waste more oil than you need to.
  • mrbill1957mrbill1957 Member Posts: 823
    Something to keep in mind when playing CDs
    From collegehillshonda.com
    General
    NEVER Play CDs with Adhesive Labels
    By American Honda Motor Company / College Hills Honda
    Thu, 7 Apr 2005, 15:30:00
    Do you like burning music on your home computer or audio recorder for use in your car? If you do you may want to take special care and avoid using adhesive labels for marking your CDs. Honda audio units are built with some very tight clearances compared to aftermarket CD players. CDs with adhesive labels should never be played in your Honda vehicle as the labels can curl up and jam the unit resulting in expensive repairs.
    Mark your burned CDs using a permanent marker or a specialized CD printer instead. Adhesive labels should never be used, no matter what type.
    Mrbill
    another important notice
    General
    Aftermarket Leather and Side Airbags Don't Mix
    By College Hills Honda
    Sat, 26 Feb 2005, 13:59:00
    Are you planning on installing aftermarket leather in your Honda that has standard side airbags? You may want to read this warning that was supplied to dealers from American Honda Motor Company.
    "Never install aftermarket leather seat covers on Honda vehicles with side airbags. Here’s why:
    • The occupant position detection system (OPDS) sensors attached to the seat-back foam are calibrated to sense through the seat cover. If the cover material changes, the OPDS could malfunction or turn on the SRS indicator.
    • Side airbags that deploy through the seat bolster seam are sewn with a special thread that bursts and positions the side airbag to protect the occupant. This thread isn’t available to the aftermarket, which means you must replace the seat cover whenever a side airbag deploys or a seat cover is damaged.
    • Side airbags that deploy through a plastic lid still have OPDS sensors that are calibrated to match the seat cover material."
    Mrbill
    Accord
    2003-2005 Accord Low Fuel Indicator
    Sat, 8 Jan 2005, 14:10:00
    On 2003-2005 Accords the low fuel indicator is designed to come on when the gauge reads just under a 1/4 tank and when there is approximately 3-4 gallons of fuel left.
    Mrbill
    Accord
    2003-2005 Honda Accord Keyless Entry Programming
    By College Hills Honda Parts
    Thu, 26 Aug 2004, 19:50:00
    NOTES:
    • The system accepts up to three transmitters. The transmitter codes are stored in a stacking-type memory. If a fourth transmitter code is programmed, the code for the first transmitter is erased.
    • Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must
    reprogram all of the transmitters once you are in the programming mode.
    • You must complete steps 1–6 within 4 seconds of the previous step to keep the system from exiting the programming mode.
    Programming the Transmitter
    1. Turn the ignition switch to ON (II).
    2. Press the “Lock” or “Unlock” button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
    3. Turn the ignition switch to LOCK (0).
    4. Repeat steps 1, 2, and 3 two more times using the same transmitter used in step 2.
    5. Turn the ignition switch to ON (II).
    6. Press the “Lock” or “Unlock” button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode.
    7. Within 10 seconds, press the “Lock” or “Unlock” button on each transmitter. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the
    transmitter’s code.
    8. Turn the ignition switch to LOCK (0) to exit the
    programming mode.
    Ordering a Transmitter
    You may order direct from College Hills Honda. Simply call 1-888-244-6632 and ask for Internet Parts.
    Batteries for the Transmitter
    The battery number is CR2025. Each transmitter uses one battery.
    The last one,
    Mrbill
    So the sensor is actually using the darkening of the oil as its measure of life of the oil?
  • jaxs1jaxs1 Member Posts: 2,697
    I don't know if what was posted about the oil sensor is true. May not be true, but people like to say that change in color means the oil needs to be changed.
    Some people like to say so, but it's immaterial, since the color of any oil starts to change the day it is poured into the engine. The engine manufacturer's engineers know best, since they've performed those million mile test regimens.
    Were those million mile test sequences like the day-to-day driving most people do or were they long term runs with continuous driving? Remember Toyota's sludging.
  • thoonthoon Member Posts: 74
    I have a 2005 Accord EX-Navi 4cyl. Whenever I drive on the highway at speeds 55mph+ My car is really smooth and quiet except for a high pitch whinning noise. Do any of you guys experience the same thing? I can only hear it with the radio off and when I'm pressing on the gas slightly. Is it the air rushing into the intake?
    You said "The Maintenance Light "the wrench that lights up" should be an indication of real oil life. It is based off a system that was first introduced in the Odyssey van. Its based off a light that is sent in your oil pan to a sensor. As your oil gets used it gets darkened and the light sensor get less light sent to it and keeps track as a rough estimate in a percentage."
    No, it doesn't.
    The car also does not do a chemical analysis of the oil.
    The 'computer' keeps track of starts, temperature the coolant hits, lenght of time running, rpm, speed, time in gears, etc. From all this info, it calculates how the oil has been 'used'.
  • kc_flynnkc_flynn Member Posts: 45
    On my 2001 Accord LX 4 cyl 5 speed, I cracked 97,000 miles yesterday. This morning as I was driving, I noticed for the first time that the Malfuction Indicator Lamp (the engine light) was lit up on my dashboard. I know that my gas cap is on properly and clicked three times after each fill up.
    Does anyone have any idea why this went on? The car was running fine, with the engine light on. I've had ZERO problems with this car, which I've had for over 5 years.
    Any ideas what this could be or potential cost estimates would be appreciated. Thanks!
    the only way to know for sure is to pull the codes out of the OBD port. The dealer can do it (for a fee of course), as can most independant garages. Some autoparts stores (autozone?) will do it for free, but all that gets you is the name of a part to look at (which they of course hope to sell you).
    Cost depends on the part(s) needed. A common reason is a bad O2 sensor, but I have no idea what one of them costs on an Accord.
    Good news is, since you were smart enough to get a stick shift, it isn't because your auto tranny crapped out!
    since that proves nothing. Even a short trip to the Quaker State site will quickly put rest a few oil myths, color being one of them. Although they do seem eager to have you change your oil often and do some other obvious self-motivated operations where oil is concerned. Still....informative.
    I'd tend to agree with bolivar, since your car analyzes other conditions in much the same manner. Taking aggregate data to best estimate a few specific things.
    One more thing. I wasn't suggesting that what other people are doing for oil change intervals are wrong, just that I think using the analysis yields invaluable engine data and let's you set a very accurate schedule yourself. And $50 per analysis, yikes, that's steep! I don't pay anywhere near that.
    happy motoring all
    Yup, the monitor has nothing to do with the oil itself. It is just a computer algorithm that tracks usuage patterns, and decides when you probably need an oil change.
    Hey, that is gotta be more accurate that a "one size fits all" mileage figure in the owners manual.
    FWIW, we have an '05 Odyssey that sees a lot of local use (on/off, short trips not warmed up fully, etc), sombined with some long high-speed trips. basically tough on the oil usage. The first 2 oil changes, per the monitor, were at just about 5 and 10K (also happend to be about 5 and 10 months).
    So, based on that, 5K on an Accord seems about right. No way I would go longer than that if it was pushing 6 months. Of course, if you drive 100 miles a day all highway in a nice climate, you might be able to stretch it.
    On my Accord, it will probably end up doing changes at 4K (I have a 2005, no monitor), since that will be about 6 months.
    There is also no need for an analysis each time you change the oil, but might not be a bad idea at your next change to see if your intervals seem right (that is, if the oil is like new, you are changing too soon, and if it is shot, waiting too long).
  • bobstbobst Member Posts: 1,776
    Is the Malfunction Indicator Lamp the same thing as the Check Engine Light?
    The CEL on our 1999 5-sp Accord came on several years ago and we haven't done anything except put a piece of black tape over it. The car still runs fine and passes our Virginia emissions inspection.
  • jenicajenica Member Posts: 2
    Hey hommies, so i am new to the world of owning a honda even though i'm a long time lover. so after much soul searching i decided to go with a 2006 accord. "Sake!" (that's what i decided to name him) is my one and only i want to provide the best for him. so i want to protect him with some seat covers, but frankly i don't know where to start looking. any suggestions..........
    Jen :confuse:
    Jen,
    Whatever you buy, it is critical that the covers do not interfere with the emergency deployment of the side airbags that pop out of the edges of the seatbacks.
  • traumertraumer Member Posts: 19
    jenica Try the folling sites for seat covers:http://www.great-covers.bigstep.com/homepage.html and
    http://www.gtcovers.com/
  • bridgej1bridgej1 Member Posts: 1
    DO you know any good websites that give good directions on how to take out your head unit to install an Ipod hard wire? I have a 2004 Accord LX
  • haefrhaefr Member Posts: 600
    Blane, you've held steadfastly to the notion that Honda's engineers are sure that 10,000 mile oil changes are perfectly safe. That might be fine, if true, though I happen to be of the opinion that these recommendations are more likely due to the influence the U.S. marketing department has over what goes into the U.S. owner's manuals than the engineering department's input. Toyota recommended 7,500/1 year oil changes from the mid-nineties through the early two-thousand models. Guess what - their advice backfired bigtime and Toyota's still paying out claims on extended warranty claims the company was forced into under threat of numerous class-action lawsuits for oil gelling (sludging) that caused ruined engines. Toyota's been recommending 5,000 mile oil changes for the past three years in "normal" service and 3,750 miles under "severe" service. Are you suggesting that Honda's engineering staff is smarter than Toyota's? Considering that both companies, as well as Nissan, Mazda, Suburu, etc. hire their engineers right out of the same Japanese universities and engineering schools, this is indeed a stretch in assumptive logic. Honda even goes one better - recommending that the oil filter be changed every other oil change. Are you actually leaving the same oil filter in service 20,000 miles? Really? (Have you even ever seen the size of the currently used Honda oil filter? Riding mowers use a bigger filter for a 13 hp two-cylinder air-cooled engine.) Some synthetics (at $8.00/qt and up) do seem capable of life to and beyond 10,000 miles. But every conventional used motor oil analasis I've read the results on over at BITOG show the detergent package is toast by 5,000 miles. No remaining active detergent equals NO sludge protection whatseover. You, and others of like mind, do what you want. But, I'll take a wait and see attitude about how well Honda's recommendations hold water over the 10,000 mile term the company suggests in the U.S. for conventional oils. And, no, I won't gloat if Honda's oil and filter service recommendations blow up in Honda's face. (Like Toyota, Honda has a good track record of extending warranties when necessary - to wit, their most recent response to replace their bum 5-sp. automatic transmissions beyond the stated warranty.) You, and the others who disagree with me, can't seem to understand that I have no vested interest in being "right" - I'm simply attempting to caution y'all that history has a nasty habit of repeating itself. If that makes me the site pariah, start likin' it.
    (Studies by Consumer Reports have also shown an alramingly high percentage of motorists are blithely going with the "normal" service recommendation when their driving habits and climates really dictate the shorter "severe" service intervals.)
    Honda is fully aware of what happened to Toyota and their defective engines.
    It is not the same engine. Honda designed the engine to be able to handle the intervals they set. Honda has even recently extended their powertrain warrantys up from the old mileage limit of 36,000 miles.
    They are not so stupid as you make them out to be make oil change recommendations based on what marketing department people tell them to do.
    You didn't mention the accumulated miles on your car, but for a seven-year old car, I suspect the lubed-and-sealed-for-life rear wheel bearings Honda uses died a natural death. (That's life of the bearings' seals, not the life of the car. Once the seals eventually tank and begin spewing the grease, PHHhhhht, bearings!) Given the car's age, that'll be a replacement service that YOU pay for. Probably so for the clock, too, though you can replace the light in the clock relatively easily yourself once you pop the clock out of the dash. If you let the take-yer-money-ship do it, expect $50.00 - $60.00 for a lightbulb you can get at any auto parts store for ~$1.69 and "shop labor".
    "Honda is fully aware of what happened to Toyota and their defective engines."
    There are NO secrets in the automotive industry and every manufacturer miscalculates from time-to-time. Yeah, even Honda, though I hasten to point out that whether these recommended 10,000 mile oil changes turn out to be problematic for Honda's 2003 and 2004 models remains to be seen. Having gone to a service light in 2005 may be a sign that Honda's hedging its bets. Honda builds very good engines. I NEVER maligned Honda as "stupid", so I resent your attributing that assessment to me. (You're skating on VERY thin ice by personalizing this discussion.) As to Honda's oil service intervals, Honda Accords sold in the rest of its world markets neither share the U.S. 10,000 mile interval nor the 5W-20 oil viscosity recommendation. No one outside the company can say with any certainty that 10,000 mile oil change intervals in the U.S. were not a marketing decision by Honda, rather than an engineering decision as so many poster have assumed. Good as they are, Honda's engines are not eternally bullet proof, though. They can be and are destroyed by improper operation and servicing. Nor were Toyota's engines fundementally "defective" as you incorrectly claimed in your post. The successful "fix" at the manufacturing level, such as it was, merely involved Toyota enlarging the oil return passages to prevent pooling and resultant "coking" in the hot cylinder head(s). Isn't it odd that Toyota Camrys, which consistently outsell Honda Accords, have surprisingly fewer owner complaints on the Edmunds Camry discussionss? Personally, I prefer the Accord, and an Accord will probably be my next ride in several years. But aren't the Camry's continuing higher sales and lower owner complaint statistics at least interesting? Despite past problems? ;)
