BMW 5-Series Sedans
1225226228230231248
  • skobolaskobola Member Posts: 207
    I did not go for the cradle, because BT phones could remain in your pocket, briefcase or wherever you wear them while walking. Of course, if you do not have a cradle, the phone will not be charged, which I do overnight anyway.
    BMW appears to be slow and not really updated on the compatible phones, and I do not know why, as the new phones are constantly coming out. I also know that some phones work even without being on the list of compatible phones, so maybe the best way for you is to try the phone first and then you buy it if it is completely compatible.
  • cassidymcassidym Member Posts: 108
    I have a 2005 545I with HUD and also like it a lot. I got it on immpulse and am glad I did. You get very used to having the speed and NAV directions right in front of you. I do have the same beef about polarized sunglasses.
    Also have Active Steering and swear by it. It came as part of the sports package otherwise I doubt if I would have gotten it. But, two years later, I don't think I could live without it. VERY useful for parallel parking as is the PDC.
    I've got a Bluetooth equipped phone which I routinely use with my 2005 545I and it works fine. Didn't get the cradle and don't think it's necessary. I usually leave the phone in my pocket and it works fine plus it runs all day on an overnight charge. If you want to charge it in the car, be a lot cheaper to just buy a phone charger.
  • markcincinnatimarkcincinnati Member Posts: 5,343
    One of the primary improvements you may notice with the cradle is that the phone can use the rooftop antenna.
    The number of dropouts is sharply reduced when the rooftop antenna. If this is a concern, the cradle has merit.
    Since I don't carry my phone in my pocket -- I leave it in the car 90% of the time -- the recharge feature is also a plus.
    Different strokes. . .
  • dorongdorong Member Posts: 1
    Is any one knows how to adjust the 5 green lights from 1 to 5 ?
  • patpat Member Posts: 10,421
    This discussion has been reopened in accordance with this post: Sylvia, "Forums Software! Your Questions Answered..." #3319, 12 Nov 2006 2:43 pm. :)
  • cmr530icmr530i Member Posts: 278
    I am glad this general forum is back. It felt like I had lost a good friend when it closed. There are always helpful tips here and stories of great 5ers as well.
  • jsanijsani Member Posts: 2
    Does anyone have the Night Vision option, pros/cons. How is the NAV system. I heard it's gotten better???
  • will822will822 Member Posts: 4
    I recently purchased a 2007 BMW 530XI and have noticed that when I start the car, the display for the NAV and radio is delayed anywhere from 10-20 seconds with sometimes no delay at all. During the delay, there are no radio or idrive functions but only the letters "B M W" on the display.
    Is this a normal and annoying "feature" of the display or is there some issue with the electronics? The dealership can't find anything wrong.
  • low_ball_88low_ball_88 Member Posts: 171
    If your car is locked and you unlock the vehicle, the i-drive system will began to initialize. So by the time you start the engine, the "BMW" wording will likely be bypassed and go directly to the "Disclaimer" screen where you have to "Accept" before the i-drive is fully functional.
    Most people do not lock their cars in the garage, so it will take time for the system to initialize, especially when the car is "asleep" in your garage overnight.
    Thanks for the info. intersting stuff...I also have the keyless entry system that I use and never actually press the FOB to enter into the car. I think I will experiement a little to see if this is part of the problem.
    Can't say I have noticed a distinct pattern here but perhaps my car is usually in "sleep" mode? When this happens, it is a 25 sec delay for full power. I tried a few scenarios today and so far the only time I can get the idrive display to respond immediately is when I have just turned off the car and turned back on the electronics (or ignition) within 2-3 min.
    Any further information or thoughts would be appreciated.
    Will,
    I do not have comfort access but it should work the same way. Also, if you were to open any door or trunk before you start the car, the i-drive will come out of sleep mode and initialize. After you do this, you will notice that the "lawyer" screen appears immediately and it never goes to the "BMW" screen.
    25 seconds seems to be longer than I have experienced.
  • brodskybrodsky Member Posts: 14
    I'm looking for clarification on a Bluetooth question. Cell phones allow for several phone numbers under one contact, i.e., home, work, cell, etc. When using the Bluetooth in the 5 Series and scrolling through the address book, which of the several possible phone numbers under a given contact will come up? Is it the first one stored under a particular contact? Is there a way to choose among the two or three numbers you might have stored under a given contact? Thanks.
  • srfastsrfast Member Posts: 138
    I have the BMW BT phone kit installed in my 2003 530i and use a Motorola RAZR V3i (with iTunes). The BT phonebook downloads all the V3i entries (Home, Work, Mobile, Main), so there are multiple entries for each contact. When I display a phonebook entry, the name appears first and then the associated phone #. The BT system cannot interpret the different catagories so I need to know which number is which before I press the "dial" button. I just scroll thru the entries until I see the entry I want to dial.
    Hope this helps.....JL
  • dabimmerdabimmer Member Posts: 165
    I come back at least once a week here and when it was gone it was as though I'd lost contact with an old friend, glad it's back.
  • shaymasdaddyshaymasdaddy Member Posts: 16
    Thanks for all the feedback on whether I should keep my 525i. After reviewing all of the feedback and sincere prayer, I have decided to keep my 525i and forego the additional warranty. Aside from the routine maintenance, it has been trouble free.
    Thanks again.
    Don't hesitate to check back in should you have any service or repair questions.
    My wife's X3 will do the same thing. It seems to be based on how long it has been since the last time the car was turned off.
    Here is what I notice. If we pull into a gas station, turn the car off, pump the gas and then restart the car, the BMW screen comes up as if there is a re-boot going on.
    However, if we turn the car off, go grocery shopping for an hour and come back out the lawyer screen "almost" immediately appears -- as if, I had assumed, we had been gone long enough for a full, orderly, normal shutdown and re-boot. IN OTHER WORDS, it almost seems backwards to my laptop with Windows XP.
    We do not leave the key in the car overnight, BTW.
    Sometimes, too, we'll notice that the phone seems to have to wait perhaps 30 seconds before the handsfree functionality (we have the BMW in arm rest cradle) comes on line after a shutdown of some short duration.
    Is there a "hard drive" in these things? Remember my wife's X3 with factory Nav and Bluetooth is NOT iDrive (its a 2005.) It almost acts as if there is a sleep mode as if the electronics get shut down and your "settings are saved" to either a hard drive or a flash drive and the transfer speed is not fast, so we wait for the reboot, so to speak.
    I have a HD DVD player from Toshiba at home, it too takes time to boot up from "rest." Maybe since both the BMW and the HD DVD are "computers" the initialization process needs to restart from step "0" sometimes and other times it can restart from a "checkpoint."
    I'm fresh out of ideas, but we have the same situation.
    My Audi A6 (2005) used to have the same issues, but then I got the 2007 MMI software update which now eliminates the lawyer screen and boot up appears damn near instantaneous.
    Perhaps there is a newer iDrive version you are entitled to.
    :confuse:
  • erickplerickpl Member Posts: 2,735
    Does Audi have the update to get rid of the lawyer screen too? I knew BMW's progman updates were doing it, but this is the first I hard of the Audis.
    Did you have to do anything to get that update (as in report some kind of MMI problem)?
    -Paul
  • topspin628topspin628 Member Posts: 373
    Just curious if anyone here considered the 7 series and then opted for the 5 (or the other way around). I was on the BMW site and compared the specs of the 550i to the 750i and they seemed quite similar in terms of interior dimensions. Also, the feature content seemed to be very close. I'm sure that the 5 is a sportier ride vs the more lux of the 7 though. Any input is appreciated.
  • sambo49sambo49 Member Posts: 47
    Funny you would ask this question! I am considering a used 750i with many bells and whistles from an independent dealer in NVA vs a new 525i or xi. Hands down the 750 has more room and a flashier interior, but the value and reliability are not as good. In looking at Consumer Reports, they gave the 06 750 a very low score for overall reliability and interior materials. One dealer (Farid at Passport BMW) in MD gave me a deal I could not refuse, so I am picking up the 525xi tomorrow.
    Good luck with your decisions.
    I've been looking for a new commuter sled, and I've found several nice E39s. The one that really caught my eye was a gorgeous CPO 2003 540iA Sport at my local dealer. I especially loved the color(Topaz Blue) and the M Technic bodykit. It also had a Dinan ECU re-map and CAI. The only drawback was the slushbox(BLEAH!!!), but I figured I could live with it for as little as I'd drive it. I finally got a chance to check it out today and the bloody thing has every BMW option EXCEPT HEATED SEATS! What kind of idiot orders a $60,000 car -in Cincinnati no less- and leaves off the heated seats? Didn't even stick around to drive it. I'm about ready to get in touch with my inner redneck and buy a Charger Daytona or SRT8. Then again, I'm also looking at an E39 M5 tomorrow.
  • nyccarguynyccarguy Member Posts: 17,596
    '03 V8 powered E39s are sweet cars! Dude, there is no way you'll be happy with a slushbox (maybe an '03 540iA) or an American car. The E39's driving dynamics would help ease the pain of owning a slushbox, but the Charger...I don't know.
    I'd love to get my hands on an '03 540i Sport or '03 M5 in a couple of years!
    In addition to the M5 I'm going to check out a 2003 530i Sport tomorrow. The knock on the 530 is that it's painted that boring Sterling Gray color. I can't understand why everyone wants a Bimmer in black or silver. Bleah!
    "What kind of idiot orders a $60,000 car -in Cincinnati no less- and leaves off the heated seats?"
    Hey! I resemble that remark! I ordered my 2002 530i 5-Speed, PP, SP, Xenon and Premium Audio and specifically didn't order either the heat-seaters or the CWP. Why? I had them on one car, used them once, HATED the uncomfortable feeling and never used them again. So, no heat-seaters for my cars unless they are standard equipment. ;-)
    Best Regards,
    Shipo
    Funny you should say that. My Dad's '04 X5 3.0iA SP is Sterling Grey/Black Leather while my Mom's '05 E60 530iA (non-sport) is Black/Black Leather :P The Sterling Silver on the X5 looks really sharp with the black trim from the Sports Package. After over 58,000 miles it still looks near perfect after it is washed. One of the many "perks" when you work for your Dad and it is the day after Thanksgiving and business is a little slow...."Here, go get my truck washed."
    I do agree that there are too many silver cars out there. I was behind a 996 911 Turbo coming home from work today in Silver... Don't get me wrong, it was pretty, but with colors like Speed Yellow & Lapis Blue on the Porsche Pallet how do you pick Silver?
    I really dig white BMWs, the blues are nice too. The black BMWs look downright sinister with Sport Packages.
    No offense intended, it's just that I like heated seats. Whatever car I buy will be my commuter sled for at least five years, so I'm going to make darn sure it's equipped EXACTLY the way I like it. On top of that, I was ready to buy the car Friday -just in time for a nice weekend trip- and finding the heated seats missing was just incredibly frustrating.
    When you have a long gravel driveway a black car NEVER looks clean. My black M6 was gorgeous but it only looked pristine for maybe ten minutes out of the four years that I owned it... Stirling isn't a bad color, it's just that it seems 99% of newer BMWs are either silver or black. Anyway it's a moot point; today I arrived at The BMW Store just in time to see the Stirling 2003 530i manual Sport being delivered to its new owners. And that was after being ignored at Jake Sweeney BMW, which you can read about in the "Stories From the Sales Frontlines" topic. Hopefully I'll be able to tell you how the Charger SRT8 drives tomorrow. My wife says that I'm getting in touch with my Inner Redneck... ;)
  • kegman0406kegman0406 Member Posts: 1
    I am currently in the market for a new 2007 5 series vehicle. I've narrowed down my wish list to either the 525 or a 530. I have a couple of questions that I hope folks can help me with.
    1) HP
    I am not a performance nut, however I like to have adequate power while driving. I am a little concerned that the 525 w/ the 215hp is potentially underpowered especially w/ A/C on and a full load of passengers. I've driven both vehicles and I really can't tell the difference on the performance side.
    Should I buy the 530 or go w/ the 525?
    2) AWD
    I live in VA and we get bad weather from time to time. Is purchasing the Xi version of these cars worth it? I'd like to be able to drive the vehicle in the winter and I worry that the RWD i just won't cut it.
    Should I opt for the AWD version?
    Thanks in advance for your help and recommendations.
    Live in NVA and just picked up a 525 xi from Passport BMW. Had very good experience with Farid (salesman) and his manager. No pressure and willing to negotiate. I heard from another dealer that you can boost the engine horsepower output by installing a chip, as both the 525 and 530 have the same engine. Not sure if this true, hopefully someone out there can let us know. The 525 xi has decent power and we do not have many moutains to climb around here. The all wheel drive ought to help in the winter. Watch out for the add-on costs.
    I live in b NVA and bought a 2005 545 from Passport (Joern is an excellent salesman). Anyway, I agonized about all wheel drive but it wasn't available on the 05 so I went with the rear wheel drive. I was unsure of this decision as my previous car (86 325) was a pig in the snow.
    But I've found this car to handle very well. It is much better balanced than the old 325...about 50-50 front-to-rear and the traction assist and DSC render it very stable. I've been through two winters and, so far, am perfectly happy with its ability to handle the snow. My car did come equipped with Summer tires and so I bought a set of snow tires which I swap out for the season. When they wear out I plan to get all season redials.
    Definitly recommend the 530...the more poweer the better. I almost out the 530 but I took my wife for a ride and afterwards she said it was the best car she'd ever ridden in but seemed a bit underpowered. Didn't take me long to change my mind!
    As for color, I got the Olivene Green and gets lots of compliments. Very pleased with it.
    And do the PDC. Don't think I could park the thing without it.
    Mike C
    The 525 IMHO needs to be driven ONLY if equipped with the stick shift -- otherwise it is not very peppy -- not bad, just not very quick. The stick cures much of this issue.
    And, if you know me, you know I am going to swear by AWD espeically where you live.
    I am not certain the chip will do much since the car is non turbo. If it improves the so called throttle tip in, well that is not doing much for the power, just making you give it more gas with less pedal travel.
    I'd look into that.
    The 525xi with a stick shift and the 18" wheels is pretty sweet and often can be had at a good price with BMW financial's ever willing help.
  • bargamonbargamon Member Posts: 302
    Mark,
    been out of the x3, allroad, and audi forums myself and low and behold you is here now too!
    Just placed an order for a 530i with MT, comfort seats, logic7, sirius, premium in monoco blue with Auburn interior. No Sport as I don't want to deal with runflats. I do need allseason capability and with only oneflat choice I don't want that kind of limitations and the way I eat tires Im looking at changes at 15-17k, 30-32k, and again before termination at 45k. Don't want to buy new shoes right before turning it in! I bought used tires for $165 for the allroad and they had 70% tire tread left before I turned it in!
    In NC, I can't justify the X drive (no crazy lease money on x drive in winter!) and BMW is more than willing to help me on my new lease. Money rate is .00050 and residual was 60% with 15km miles. No money down pmt is $630 with tax on a 55k car!
    The 530i is more than enough power and the incentives right now are way to good to pass up. From what I read the Spring refresh is not that intense and while the 535 will be sweet, the incentives are just too tempting. I just feel very good about my deal for this car.
    Its on order due for a late february delivery in South Carolina. I'd do a euro but im actually going to be in munich in 2 weeks and don't have time to go back.
    Given my preference to MT, I never even looked at the A6. All my choices at this time are manual trannys, the choices were all BMW 3's, X3's or a 5 series.
    funny, BMW has incentives all over the place and they are flying off the shelves yet Audi has relatively none but still seem to be doing well. BMW locally is expanding the dealership. Again!
    I hope to be back in an Audi one day as I enjoyed the experience. All these companies seem to run in cycles and this seems to be BMW's time. Im sure Mercedes will one day shine again. The consumer wins with good competition!
    That sounds like a really great car. As you might have read above, I'm considering an E39 for my new work hack. Right now I'm really giving a lot of thought to a 2002 M5. They seem tobevery reliable,and not all that hard to work on. I've also checked out a couple of E46 M3s. And, while I hate to admit it, that Charger SRT-8 is one fabulous car. How can anything SO big be SO fast? I just know I'd go through a set of pads every track day, but at least they are as easy to change as the ones on my old M6...
  • flyguy8flyguy8 Member Posts: 8
    Any information on the 2008 5 series. I hear there is going to be a 525 and 535.
    A dealer in Oklahoma City told me the 08 would not be out until Nov 2007 and a dealer in Austin told me that the 08 would be out in the May 2007. Do you know when they will be released?
    I wrote BMWNA a few days ago and asked them "what was the truth" but have not received a reply.
    Thanks for your reply
  • 0audilicious00audilicious0 Member Posts: 47
    This is just a pure educated guess from me, but with the cheap money rates on the 5 series right now I think we will see updates sooner than later. Seems like they are trying to clear out some inventory prior to the updates.
    Also, not sure but I think we will see a 528 and a 535... no more 525.
    We'll also probably see a twin turbo 535d, since NA has finally decided to import some of their oil burners.
  • maccarmaccar Member Posts: 10
    Does anyone have a suggestion for an independent shop they have used in Dallas and been happy with? Any suggestions on how to find an independent shop in Dallas?
    I apologize if this type of solicitation is frowned upon in this forum. I searched the discussion archive and did find anything similar to this thread.
    It's a fine question, no apology necessary. :) Hope someone has a suggestion for you.
    Maccar,
    I have a 2001 525i and I have received great service from
    German Motor Works in Richardson, TX. The owner is on-site, they do great/quality work, and the prices are more than reasonable. Here is the contact info below:
    German Motor Works
    1352 S Plano Rd
    Richardson, TX 75081
    (972) 690-6623
    http://www.gmwdallas.com
    Hope this helps.
    Any thoughts? I'm looking at one with a 6MT. Basically debating between this and an 05/06 GTO.
    Thoughts, Ideas, etc welcome.
    -mike
  • dillonjdillonj Member Posts: 2
    I currenly own a 1985 BMW 535i. There is a computer-like device on the right hand side of my dashboard. My BMW came without a owner's manual. I'd like to learn how to operate this device: set the time, date, etc. I've familiarize myself with the timer and mph limit. Also, there is a 'code' button- how am I to find the code to my BMW? And with the code, what does it enable me to do?
  • macdadmacdad Member Posts: 75
    What does BMW do to increase the horsepower in the 530 compared to the 525? For those who have driven both - can you tell the difference?
    I have an '06 525 (automatic)and am considering a 530. Can the horsepower in the 525 be improved and not void the warranty and is it worth it?
    Any response would be appreciated.
    Macdad
  • sixpaqssixpaqs Member Posts: 21
    macdad,
    I don't know exactly what it is they do to the car, but I have driven both the 525 auto and the 530 in manual and auto (I have a manual, friend has the auto). You can definitely feel the difference between the two. The 530 is a torque-ier engine than the 525. As for improving the HP in the 525, I am sure you can "chip" it, but that usually voids the warranty. Personally, I wouldn't do that to my car, but that is my opinion.
    For the 2006 models, both the 525i and 530i have 3.0 liter engines, however, the 525i has only a "Single-stage" induction system while the 530i sports a "Three-stage" induction system. What that means in real world terms is that the path the intake charge takes through the induction system can be adjusted based upon engine RPM to obtain optimal volumetric efficiency (more air and fuel into the cylinders at any given RPM). Chipping a normally aspirated BMW engine won't get you squat in extra performance.
    Other things to consider, the 530i has a more robust manual transmission than the 525i and the brakes are larger and more capable as well so not all of the extra cost of the 530i goes into that trick intake system.
    And yes, the difference between the two engines is quite noticeable (at least in manual transmission trim, I've never driven a BMW with an automatic).
    Best Regards,
    Shipo
    Thanks for this info, Shipo. Very informative. I drove both the 525 and 530 in automatics, and there is a difference, especially off the line. For the money, I say go with the 530. I got mine with the a manual last week and I am very happy with the choice.
  • jb_shinjb_shin Member Posts: 357
    It is the onboard computer to calculate distance to destination, elapsed time, etc. I think you can probably find a reference on the net (try posting at mye29.com). Or you can always buy one from ebay ( I just saw one there, search for "e28 manual"). Also, 3/5/6/7 shared the same/similar OBC, so if you have friends with those cars, you can take a look at those.
    How does one check the level of oil in your engine? Does your car have a dipstick or do you check your oil level via your iDrive interface?
    Best Regards,
    Shipo
  • pdmpdm Member Posts: 1
    Greetings. I am a former 2002 530 owner and recently bought 2007 550 MT, great car, adjusting to iDrive -- but am baffled by the center console set up. I use my cell phone constantly in and out of car and with (excellent) bluetooth system find no real benefit for me to the cradle. Does anyone have any experience with removing the cell phone portion of the center storage console?
    any input appreciated....
  • jlbljlbl Member Posts: 1,333
    With more power, less consume and little re-styling. Consume for 530i should decrease between 1.6 and 1.8 (manual and automatic) liters•100km——with 272 hp and 31.36 miles per gallon on the average (automatic). Also, it will have an Automatic Pilot for the traffic jams (which shall be not the Auto Stop & Start System).
    More details (Braking Energy Regeneration) in poster #630 in BMW Series-1 here in Edmunds.
    Jose
