BMW 5-Series Sedans
16061636566248
  • snagielsnagiel Member Posts: 750
    You may want to post such a query on the E34 boards at http://www.bimmer.org, since most people here own the current (E39) models ('97-'03). I will say this, though: make sure these are either CPO'd (from a BMW dealer) or are covered otherwise with a generous extended warranty program. Even if these cars in relatively good mechanical shape, you're likely to face expensive (even if minor) repairs on an ongoing basis. Good luck.
  • pen101pen101 Member Posts: 238
    Thank you snagiel for your reply. As you can see I am still learning about the car's many features. I will take your suggestion regarding the radar detector setup. Concerning your reply to my headlight question, I followed your instructions and the fog lights will not go on without the headlights being on. I did not have the daytime running lights activated when I purchased the car, as it was the default setting, however, I see no down side to having them activated. What do most people do with the daytime driving lights?
    Another question: I notice that I can deactivate the DSC. Under what driving situations or conditions would I want to deactivate the DSC.
    One more question: The owners manual says that the fuel tank holds 18.5 gallons with a 2 - 2.5 gallon reserve (depending on the car). What does this mean? Why not just say that the fuel capacity is 20.5 or 21.0 gallons? Why make note of a "reserve"? Is there some indicator that will let me know that I am in reserve? Note of course I do not plan to drive the car with an empty tank, but I am still curious.
  • bmw323isbmw323is Member Posts: 410
    I can take a shot at answering your questions.
    My 3 series fog lights are the same as your 5. The fog lights do not work unless the full headlights are on. I don't have DRL's turned on, but it doesn't seem likely that would make a difference.
    Some people deactivate the DSC to get rolling in snowy conditions or to get unstuck in snow. I also deactivate mine when I take the car on the track or skidpad since I want to control the car and I don't want the computers to do it. Otherwise it is safest to leave it on.
    The low fuel dash warning light will come on with about 2 gallons of fuel remaining (the reserve). I believe the tank is, as the manual says, 18.5 gallons.
    I'm not sure why your fog lights don't come on with the parking lights; they should (even though I couldn't find it explicitly in the manual, I confirmed again in my car).
    DSC off: BMW states you may want to disable the system if trying to free the car if it's stuck, since the system may intervene too much. Owners who race their cars at the track also like to turn the system off, so they can have more control over the car and allow for mild wheelspin and oversteer. But in reality, you should leave it on virtually all of the time. When I picked up my car in Spartanburg, we had the opportunity to drive around a soaked skidpad and trigger both understeer (by turning the wheel too much) and oversteer (by accelerating too hard into a turn). We practiced getting the car back under control with and without the help of DSC. With it on, it was exceedingly easy--the car practically straightened itself out. Without, it took much concentration, effort, and luck just to keep the car from totally spinning out of control.
    As for the fuel tank, the "reserve" isn't a separate tank. It's simply how much gas is left once the gauge registers "0" on the dash. They refer to it as a "reserve" to save your butt if necessary, but they don't want to treat it as the "normal" part of the tank, if that makes any sense. Technically, yes, the tank is 20.5 gallons. Discussing this always reminds me of a Seinfeld episode where Kramer convinces a car salesman to take the car (a Saab) for a spin and keep going regardless of the fuel gauge. Eventually, of course, the car dies in the middle of the highway and Kramer just walks away. Cracks me up every time...
  • riezriez Member Posts: 2,361
    Will the real fuel tank size expert step up? Seems like we have conflicting statements. Has anyone actually put 20 gallons in their tank? Has anyone driven the car into serious negative miles on the remaining fuel indicator of the computer readout? I've never allowed mine to get below about 40 miles range remaining. Then I chicken out! (I tend to concur that the tank is more likely what the manual says and that the reserve is tied to the low fuel light. Otherwise, BMW might have legal issues if the tank is really 2 gallons larger and someone relies on that.)
    Thought I did know one thing: It is not recommended that one run out of fuel. So fuel up at or before the low fuel light and don't let it go below half a tank in cold weather. And it is best to use the recommended fuel. :)
  • vishnu11vishnu11 Member Posts: 59
    If you want to time your ED delivery with the boat bringing your baby back home, try:
    http://schedule.2wglobal.com/GLWebApps.AppSchedules
    Just as a note, all German dropoffs are trucked to the boat at Bremerhaven. If you have plans to visit Belgium, you can drop off in Antwerp and it will be trucked to Zeebrugge. Most boats go via Zeebrugge from Bremerhaven.
    Side note on Fuel:
    Not a good idea to starve the fuel pump by running the tank dry.
    Cheers!
    Thank you bmw323is, snagiel and riez for your replies.
    Regarding the fuel tank question, today I accidently answered my own question regarding fuel capacity and reserve. Had to run a number of rushed arrands and did not have the time to refuel until nearly out. The trip computer said 12 miles remaining on the tank when I put in 18.825 gallons (did not top-off the tank otherwise may have been more) at $1.859 per gallon. The $35.00 I paid is a record for most spent to fill the tank (but could have been more - am starting to see some stations getting $2.00+ per gallon again for premium). But the car went 461 miles on the tank (24.5 MPG) in combined city/highway driving. I know getting this low on the tank is very bad and therefore is a practice I hope not to repeat again. But I got my answer as to what reserve means (only indication is the low fuel light on the fuel gauge) and also approximately how much fuel will go in the tank.
  • g525g525 Member Posts: 5
    I have run mine below 1 mile remaining, numerous times, and it shows as ---. I've driven about 10 miles or so after this with no problem. I reset the mileage trip meter every time I refuel, and I know my car will go at least 300 miles per tank (I average 17.5MPG and I think someone said the manual lists 18.5 gallons so thats 323.75 miles to be exact)
    Anyways, the miles remaining shown on the computer do NOT include the reserve.
    Whatever "bad" effect (i.e. catalytic converter) this may have on the car is of little concern to my lease.
    I just like to go as far as possible and then fill-it-up.
    Two years ago, while driving the Ohio Turnpike, I was running low on fuel, trip computer said 40 miles remaining, sign said 36 miles to next service area. No problem. After 34 miles, the computer said that I had 9 miles left, however, the sign I was reading said "Service Area CLOSED, next Service 35 Miles". Oh boy, turn the A/C off, crack the windows open, opened the rear moon roof vent and slowed down to about 62. I drove almost 30 miles with zero miles remaining, however, I do not remember how many gallons went in when I finally got to the Service Area.
    Best Regards,
    Shipo
  • g_carg_car Member Posts: 46
    Just got back from a trip to Myrtle Beach, driving 2001 525i Step, SP, 2 adults a kid, full load of luggage plus other stuff wife picked up along the way. 600 mile trip ave 70mph got 28MPG. Couldn't beleive the MPG per the OBC. Calculated the old paper and pen method come up with same number. Best MPG I've ever gotten in car running well north of 80+ MPH for extended periods. Car has 12K miles on it. Amazing!
    PS - Also amazing how fast folks are driving on I95 in NC and VA. Ave. speed must be up around 80-85. Fully loaded mini vans were passing me at 85, even taking in account the infamous BMW speedometer error :-)
  • danddddanddd Member Posts: 1
    My '93 Legend has been a great car, but it is time to get a new car. I love how the 5 series drives and am looking to buy a 3 year old 528 or newer 530. I live in Chicago and this car would be used on the highway a lot. One of my concerns is how does the car drive in snow? Do snow tires make the big difference in traction? Also a concern is maintenance. I've been told horror stories on costs and that even oil changes are expensive.
    I appreciate any information. I know the dealer will probably not be so forthcoming.
  • rlowrierlowrie Member Posts: 30
    When ordering a car for Eurpoean Delivery, how set is the pick-up date? Can it be changed as the time gets closer if my schedule needs to change a week or so? Thanks
    For future reference, it is more efficient to run the A/C (on recirc) than to lower windows (especially at highway speeds), since the increase in aerodynamic drag greatly outweighs the A/C compressor's sap on the engine.
    Yup, that's why I only cracked open the windows about 1/4" and opened the rear vent on the moon roof.
    Best Regards,
    Shipo
    For driving in Northern winters, I'd recommend a good set of snow tires (you can get a good set along with 16" wheels from the Tire Rack). The 528/530 have generally been fairly reliable (although probably not as much as your Legend). That said, if you're not buying a new car (which comes with free maintenance/oil changes), make sure you get a CPO (certified pre-owned) model from a dealer, and look into extended warranty programs. Good luck.
    ED delivery can always be postponed, but never advanced. I think in the initial status of the order, there is some flexibility, but approx 2 months before anticipated build time, the exact date must be committed to. As I said, once the car is built, your pickup can be moved out, but here also there is a limitation. You can't, for instance, call up a week prior and move it out two weeks because they have a set schedule for shipping the vehicle to the delivery center, and more importantly, creating a license plate that expires 1 month to the day that you are supposed to pick the vehicle up. They also seem to pre-book your car on a boat back to the States, though this is completed only after dropoff. Sure that there's room for the unexpected, but that's probably the exception rather than the norm.
  • jwilson1jwilson1 Member Posts: 956
    snagiel, is this possible? You mentioned it to the poster who asked for opinions, but I've always heard that CPO wasn't for 8-year-olds. Am I wrong?
    Take care.
    Joe W.
  • dl7265dl7265 Member Posts: 1,381
    I just recived the May 2002 issue of R@T and there is a photo of a 2003 5er WOW what a change up, I can see Mr. Bangel seems to favor quite modern and art designs...
    I suspect most of you will not be happy campers.
    In a way its quite striking but, i cant get used to a flat hood on a BMW.
    DL
    I was just recommending CPO if available; you may very well be correct that 8-year-old models are ineligible for the CPO program.
  • pap5pap5 Member Posts: 144
    When you refer to a "newer" 530, I assume you're still talking used. That would mean no older than MY 2001, since that's when the 528 evolved into the 530 and 525. That's one strategy to avoid the cost of a new car. However, for close to the price of a one-year-old 530, you can get a new 525, especially if you opt for the European Delivery (ED) program. ED is priced at 7% off U.S. MSRP, and further dealer discounts (not all will discount further) can push savings up to 12%. Of course, you have the expense of picking the car up in Munich, but you can either use it as an excuse for a great vacation (and a chance to drive it faster legally than you ever could here), or do it on the cheap and still realize handsome savings. With the new car, you will get 4 yrs/50K mile warranty, and 3 yrs/36K mile scheduled service.
    When equipped with a manual transmission, the 525 moves out nicely; others here have put its performance roughly on par with a 528 automatic.
    While there might be some variation in a couple models, isn't the general CPO term 6 years or 100,000 miles from the original date of in-service (with the first 4 years or 50,000 miles already covered by the original factory bumper-t0-bumper warranty)? Don't think any '94s would qualify unless it didn't get into service until '96 and then you'd be out later this year (at least on time).
  • gearmangearman Member Posts: 30
    In addition to echoing snagiel's cautiionary comments regarding maintainence / reliability, I'll add a couple of additional points for your consideration.
    Unlike many Japanese cars, Legends and the like included, the high speed composure of many German sedans sets the standards for dry road performance suspension tuning. It's a cliche, but the home market conditions have a very strong influence on the product design decisions. In Japan, low speeds, infrequent / weekend usage, glass smooth roads, and long periods idling in stopped summer traffic with the a/c on full blast has produced comfortable cars that seldom overheat and function very reliably up to the mandatory and very rigorous 100,000 km inspection. Lots of japanese cars are exported to third world countries with 90-99k km on their odometers just to avoid that inspection.
    German / European conditions put a premium on high speed highway composure on a variety of road surface types. The 528 you're considering will be a relevation as compared to the Legend the first time you have the chance to tackle some curvies at extra-legal (in the U.S.) speeds.
    On the other hand, fwd and a serious front biased weight distribution have significant advantages when driving during an Illinois winter. Snow tires provide huge benefits, but not as much as fwd or awd. Therefore, you may wish to consider fwd alternatives such as a newer acura product, a vw / audi product, or (thinking way out of the box) one of GM's cars, such as a Saab 9-5,the mid-size Buicks with a 3.8 liter v-6, or a Suburu. The audi or saab would provide the best driving experience, but at the cost of vw's and saab's long term maintenance expenses. The Buick would be the cheapest to maintain in the 100-200,000 mile range, but you'd have to live with the inexpensive fabrics and plastics that GM uses on many of its domestic sedans. perhaps some Buick - labeled slip covers would add a dash of living room sofa panache?
    Or going further down that track, there are some awd cars to consider. At the low end of the cost scale, the newer suburus are a very good value and offer good reliabilty . the audi A4 / A6 quattros provide exceptional slippery road performance, but are a wallet buster to maintain after the warranty is gone.
    Conclusion: go drive a few of these cars and broaden your search horizon before making a decision. In particular, try a couple of the audis, and let us know what you think.
  • mschukarmschukar Member Posts: 351
    I strongly disagree. A well balanced RWD car outfitted with winter tires will do much better in snow than FWD with all season tires. I also believe that a RWD car with winter tires is safer than a AWD car with all seasons since stopping and maneuvering (read, safety) are both greatly enhanced by the tires and not which wheels are driven.
    I haven't driven my BMW in the snow yet, but my Miata with winter tires was great.
    -murray
  • kidswainkidswain Member Posts: 7
    Has anyone had a positive experience or reasonable pricing with a Houston dealership?
  • sanand5sanand5 Member Posts: 33
    I got a 2001 530i from Rudy Steiger at Advantage BMW of Clear Lake about 6 months ago. He is a helpful guy who has been selling BMW's for years instead of weeks and I got the car for $2000 over invoice (plus $800 MACO). This was with very little haggling so maybe you can do better.
    They are going to hate me for saying this but you don't have to pay the approx. $400 fee they try to tack on at the end. I forget the name of it but it will be there when you sit down to sign the papers. Supposedly, "everyone" in Houston pays this but if you threaten to walk away from the deal, they should back down.
  • 530bmw530bmw Member Posts: 130
    Whoa! you gotta be kidding. It is hard for me to believe MACO to be that high. I know it varies from area to area, but that is outrageous. I think your dealer jacked this one up and he also tried to add on "prep/doc fees" of $400 on top of that,luckily you refused to pay the $400. I hate it when we have to deal with an unsrcupulous dealer.
  • kdshapirokdshapiro Member Posts: 5,751
    A 4WD beats them all. RWD in the snow stinks even with good snow tires, I know I spent a few years in the snow capital of NYS. AWD or FWD or better 4WD will win hands down in the snow everytime in acceleration and braking.
  • vanaldervanalder Member Posts: 29
    If I understood your note, this amounts to $ 2800 over invoice. One can see why there
    would be no haggling. This seems to be MUCH higher than what can be obtained by
    looking around. Perhaps not in Houston, but.................
  • nyccarguynyccarguy Member Posts: 17,486
    Please not again!
  • millerro3millerro3 Member Posts: 136
    I can see how the added weight of 4WD will help you stop better, you really 'dig' into the snow better! LOL!
    I am not sure that there is much merit to the FWD vs. RWD vs. AWD argument, and that all things being equal, there is not much difference in the drivetrain configurations at cruise speeds.
    Consider a panic stop situation - you're standing on the brakes and there is no power to any of the wheels - does it matter whether the car is FWD or RWD at this point? Its also disputable whether engine braking will help in a panic situation.
    Having said that, BMW points out at bmwusa.com that RWD offers better handling by making the argument that FWD puts both tasks of steering the powering the vehicle on the front wheels. They say that by powering the rear wheels and steering with the front, you are dividing the tasks more efficiently. They also make the point that understeer and oversteer is better handled by a RWD configuration and that's why police cars are RWD preferred. I don't know from personal experience and find this debatable.
    What I *do* know is that weight distribution makes a heck of a difference. I crashed my Integra (which has a 62-38 front-rear distribution) a few months ago during rush hour - they guy in front of me stopped suddenly on a curvy road. I stood on the brakes, but watched in slow motion horror as my car understeered all the way into the guy's rear end and onto the curb. This was at 30mph. I strongly believe that my Michelin XGTV4 tires were also culpable (but that's the subject of another flameout).
    More than FWD vs. RWD, it is traction control that helps more. Don't be fooled by AWD - once underway, AWD is subject to the same physics as another 3000+lb vehicle (ask me - I have a Lexus RX300 AWD). Perhaps you can avoid situations if you can detect them sooner, such as if you have the help of traction control. That's why the 5-er with its ASC/DSC is a much safer option than just having the RWD configuration. There have been tons of auto reviews where drivers have tried to cause the car to under/oversteer on the skidpad with traction control on, but found it incredibly hard to do so. Not that traction control is infallible, but it does offer a compelling argument and better safety net than drivetrain configuration alone.
    Not your usual point of view on FWD/AWD/RWD huh?
  • jstylejstyle Member Posts: 129
    I just read an article in a German auto mag that showed a spy shot of the next 5 series. Styling looks like an off shoot of the new 745i and the article stated that the i-drive nob and screen system will be standard because having two production lines (standard and i-drive) would be much to costly. What do you BMW experts think of moving the sedan that direction? I think it will loose something.
    I thought about it, and voted with my pocket book, now. I am picking up my new 530i next week in Munich.
    Best Regards,
    Shipo
  • chesdin4chesdin4 Member Posts: 22
    One advantage of FWD over RWD (w/o traction control) is that if your wheels break loose and start to spin, with FWD you won't tend to fishtail.
  • mcq7159mcq7159 Member Posts: 20
    ... I just downloaded the delivery checklist and will study it with GREAT interest tonight. Thanks for the link. Only two weeks and two days until I lose by BMW virginity!
  • jobiejobie Member Posts: 47
    Any feedback on how long it usually takes for a car to get from factory to dealer? My dealer said my car was built March 11th, still not in.
    Boy, hearing and seeing the latest info on the next 5er, I'm so glad I opted to jump to the 530i now instead of going with another 3 series and moving up later. If the I-drive rumor and styling cues on on target, I don't think I can overlook the interior and exterior for the "BMW feel" when this lease is up.
    You and I seem to be of like mind. Given the pending change to the 5-Series, I may have to keep my 530i until the E60's successor comes out, assuming that is, that said successor has a Manual Gearbox available.
    Best Regards,
    Shipo
  • mod62mod62 Member Posts: 38
    My dilemma is that I want the Sportswagon and can not afford the 540. I have read numerous times that the 525 is underpowered compared to the 530, but since their is no 530 wagon, I am in a bind. Comments on the 525 wagon with manual transmission? I saw a post from g-car that he enjoyed his recent trip with his 525. How will the power feel in the mountains of VT,NH and ME.
  • TSchrammTSchramm Member Posts: 106
    Sadly, I just turned in my beautiful '99 Titanium Silver BMW 528 after the 3-year lease was up. It was one of the most enjoyable driving cars I have yet to own. It's only been a week and I miss it terribly. But, my company now provides me with a car, with complete fuel and insurance provided, so it just didn't make financial sense to get another one right now.
    Yes, I would buy another, but, I would follow the advice of the guys on Car Talk and lease one, and not keep it one day longer or one mile over the warranty period. These are some of the most expensive cars in the world to fix. And mine was not particulalry reliable.
    I had a complete automatic transmission replacement at 3,200 miles (yes, 3,200 miles -some major electronic failure that took the car out of commission for 2 weeks, although they gave me a nice 330 to drive); a thermostat replacement at 7,000 miles; three trips to the dealer to reset "check-engine" lights; one "very careful" trip to the dealer replace the airbag sensor switch after the airbag warning light came on; and on one trip, the mechanic noticed the jack plates on the side-bottom corners of the car were missing - they were never installed, which meant it would have been impossible to use the jack to change a tire had I had a flat! Not a very good post-build inspection.
    All in all, 7 non-scheduled dealer visits in 3 years and 34K miles. The service manager did a thumbnail estimate that they did about $7,000 worth of warranty work on it (granted the new transmission was the largest chunk).
    So, yes, I loved driving the beautiful 528, and was darn glad all the maintenance and repairs were fully covered. And that's the only way I'll drive another.
  • postoakpostoak Member Posts: 537
    Not to beat this to death, but based on my own experience and all the posts I read here -- I'm getting fed up with the attitude of the dealers in the above Texas cities. That's why I've been recommending Garlyn Shelton in Temple. If you look at a map and visualize the triangle formed by Houston - Dallas - San Antonio, you'll see that Temple sits on the western side of the triangle -- along with Austin -- so it's not that far from all of these cities. It's farthest from Houston, but the drive up there takes you through some of the most beautiful countryside in the State. (But perhaps I'm prejudiced since that floral region is named the Post Oak Savannah ;-).) Give my salesman, Jef Sims a call at 254-771-0128 and see what he can do. He's young and hungry right now, let's keep using him until he's fat and sassy! BTW, Garlyn Shelton has an automatic price advantage in that they don't have to pay BMW an advertising fee -- so they don't charge you one.
  • joseph40joseph40 Member Posts: 17
    I spoke with several dealers in Houston and got the best price from Rudy Steiger @ Advantage Clear Lake. However, I ended with an even better price from Coastal Motorcars (Corpus Christi, see Art Allen (800-250-2343)), and Garlyn Shelton (Bryan/College Station; see Larry Smith (979-774-2610)). Both were willing to do european delivery invoice plus $2000.
    Hmmm, Jef Sims did $1200 over ED invoice on my 3-series.
  • bodegajoebodegajoe Member Posts: 3
    Can someone give me reasons for getting a 540 over a 530 knowing that the 540 is not that great on mileage. Is the extra HP worth the extra costs? I read on this forum someone felt the only difference was the pickup going from 80 to 100 mph. I have test driven a 540ia and it was awsome though never going over 65.
    Joe
    Compare 540i6 to 530i5. All I know is my 540i6 is an absolute blast to drive. She'll go from 60-140-60 effortlessly. And I get great highway fuel economy. Fuelled her up today. Went 449.3 miles on 18.01 gallons. 24.95 mpg. Not too shabby!
  • cmr530icmr530i Member Posts: 278
    My car was built in March of 2001 and it was at the dealer by mid-May. It is a long wait, but ever so worth it! Hang in there!
  • chrism124chrism124 Member Posts: 134
    Only you can determine if the extra hp and torque in the 540i is worth the extra cost. You will find people on this board who are passionate about both models. I test drove both but decided on the 530ia. For me it was a budget thing. I wanted a new car rather than CPO. The 540i was just beyond what I was willing to spend. Plus the 530i has enough power in the 0-100 mph range. Either way both models are good choices.
    One recommendation is to consider the Sport pkg. While my 530i doesn’t have this option, I do regret not ordering it. The standard setup is good but the Sport pkg adds to the driving experience.
    Good luck on your decision.
    Chris
    I've made a couple of posts the last few days on 530 pricing and dealerships in the Texas area. I ended up choosing Jef Sims at Garlyn Shelton. He was helpful and honest and I paid $1800 over invoice and got exactly the car I was looking for. He has even offered to deliver it to my doorstep in Houston. It arrives in 2 weeks!
    I appreciate everyone's contributions.
    I had a 93 Legend Sedan which I sold before leasing my new 525 manual w/Sport-Premium Package & xenons. I sold my Legend to a private party for $10k and leased a new 5 for $525/mo.
    I drove both cars for about two months before I was able to sell the Ac' and they have similar performance, with the BMW being slighty faster and more substantial feeling (I had a friend race me) but the Ac' engine feeling stronger (more torque and hp).
    I wouldn't recommend a used BMW, period. I've said it a few times on these boards. If your used to the reliability and cheap maintenance of the Legend, you'll be angry and broke with a used BMW. New ones come w/full warranty and free maintenance (including the $100 synthetic oil changes).
    However, I don't know much about that snow/RWD issue. (I'm in Los Angeles) But, I would say the FWD on the Legend was definitely more predictable and I'm still getting used to RWD. Good thing there's std. traction,braking, and stability control systems on the 5 for times when I forget its RWD.
    Good Luck.
  • habitat1habitat1 Member Posts: 4,282
    Let me start by saying the 540i is absolutley the best "drivers" car in its class. Bar none.
    That said, the 530i is a significant improvement over the power of the previous 528i and, equiped with the sport package, handles as well as any sedan I've driven, other than the M5. The roughly $8-10k difference in purchase price to jump from the 530i to the 540i would be difficult for me to justify. I had considered both cars before postponing my decision by buying a Honda S2000 as a third car last fall. I will likely be back in the sedan market in another year or two and, if I had to make the choice now, the 530i 5-speed sport would be my pick. Good acceleration, great handling and relatively affordable to purchase, insure and maintain.
    P.S. Supposedly the redesigned 5-series will include an even more powerful V-8, and a V-10 M5. Having driven the current M5, I find it hard to believe that someone would need even more power in a two ton sedan that can already keep pace with a 911. How much power you need is up to you, but beware that we are in a bit of a horsepower war and that whatever you get today will probably be surpassed in a year or two.
    As I've pointed out before, many, many 530iA dealers and buyers load up on the options. Easy to push the MSRP close to $50,000. Now you're getting real close, only a couple thousand dollars difference, in price to a no-options 540iA. I'd rather buy a $53,000 MSRP 540iA vs a $50,000 MSRP 530iA. There is a significant and significantly noticeable difference in power and performance between a 540iA and 530iA.
