Honda Odyssey Radio Fuses
Battery recently died on 2002 Honda Odyssey so went to Auto Zone to get a replacement since there was still a little time left on the battery warranty. Installed the battery they pulled off the shelves, and went to connect it, and found out when I went to put the negative terminal on that they gave me the wrong battery (someone had put the wrong battery on the shelf where the correct battery was). As soon as I went to connect the negative terminal, the horn went off and ended up blowing a couple of fuses. After finding a blown battery 120 amp fuse in the engine compartment, the radio still did not work, even after I had checked the fuse box inside the van for the raido.
#1 - In hindsight, I should have double checked that the terminals were right, but I trusted that they gave me the correct battery. Won't EVER happen again :-)
#2 - Reversing the cables resulted in 2 blown fuses, the 120 AMP Battery fuse in the engine compartment passenger side (which I had to order and wait 4 days for becuase no local parts store or dealer had a fuse that big), and, after searching for other blown fuses, I located another 20 AMP fusible link blown in the engine compartment driver side that's mounted near the battery. It's easy to overlook the other fusebox mounted near the battery, hence why I spent many hours looking for any other blown fuses.
#3 - I had removed the console and radio looking for a fuse on the radio/CD/DVD player and found none, so do not waste your time thinking there may be one there, there isn't.
#4 - Two other fuses inside the van affect the radio/DVD/CD player. Fuses #9 (labled ACC) and #11 (Radio/Dome) on the passenger side should be checked if your radio is not working. What puzzled me and kept me searching was that they were fine, and #11 also controlled the dome lights, which were still working.
#5 - Basically there are 4 places that have fuses in a 2002 Honda Odyssey; Passenger side of the engine compartment, Driver side of the engine compartment, Driver side kick panel, and Passenger side kick panel.
#6 - Wish I hadn't wastes so much time removing the radio (wasn't really that hard, but still a pain), but lesson learned. 4(!) fuse boxes didn't help make troubleshooting easy. Don't make the mistake of hooking up the battery wrong to begin with, double and triple check before you connect the terminals :-)
Thanks for any help.
Did you figure out your issue with the radio? My speakers are buzzing, only on the passenger side, but all the way down the passenger side in all three speakers - wondering if you had the same issue.
Ian
_______
http://www.downloadvlcplayer.org
I've checked the radio CB but I can't find one for the amplifier.
Any suggestions?
Thanks James
ANY INFORMATION or TIPS would be greatly appreciated
THANK YOU VERY MUCH
