Need instructions to replace fuel pump 1994 Caravan 3.8L
johnhubertz
Member Posts: 1
in Dodge
I need to remove and replace the fuel pump on my beloved AWD 1994 Caravan
Vehicle runs well for about 10-20 minutes, then begins to sputter, then stalls,
restarts after 15 minutes - i think my pump is overheating
Questions:
1. Anyone have the shop manual on PDF or that they can link me to?
2. If it is pretty basic - I just need step by step instructions
3. If it is a tough tank to drop, can I cut an access hole inside the van or would this be dumb to do?
John H
Ft Wayne Indiana
Questions:
John H
Ft Wayne Indiana
The metal is pretty thin and I had no trouble using sheet metal airplane snips.
I used a piece of sheet metal to cover the hole and sealed the edges.
Start with a small hole where you think the pump is and enlarge it carefully so you don't damage the fuel lines running across the top of the tank.
Disconnect the battery before starting the job. Took me 2 hours to do, I probably can do the whole job now in 20 minutes.
I haven't had a seconds worth of problems since I did the job.
I would do it again in a heart beat. Saved time, saved aggravation, saved money too. :P
