Maybe we are just OLD BLUE HAIRS.....LOL!
That can't operate these new fangled gadgets !
Matbe its true we are not holding our foot steady on the gas pedal while trying to push all the buttons.............Hmmmmmmmmmmmmmmmm
In any case, my seville generally is never off by more than about 1 MPH when I set it, and that is probably because it rounds off to the nearest whole MPH (no fractional MPH).
BUT the 04 Taurus I rented a few weeks ago in Minn. had steering wheel controls worked as screwy as my Caddy losing and gaining mph.........Hmmmmm
With my cruise control, punching the accelerate/resume button 5 times will result in the Seville adding 5 MPH to the cruising speed. Hitting the set/coast button a few times will reduce speed by a few MPH. This is how it should work.
I do plan on buying a 7/100k mile warranty just to be safe.
What year should I buy 2000-2004?
No hits or complaints about the cruise problems post I put up over at cadillac forums....Hmmmmm
Heck 03 base Devilles in my area (ex rentals) are $25k. A extended GM warranty is a good idea.
I Can supply you witha list dealers that sell them at discounted prices over the net. You have up till the end of the Caddy mfr. warranty to purchase a GMPP warranty.
As with any used car. Shop carefully and have it checked out by a trusted mechanic before purchase!
Good luck keep us posted.....................
I need a Nav system so I will have to look hard. What year did they offer Nav? Is the same 300 hp motor in all Deville thru 2004?
A Nav. system will be hard to find in a base model.
Shop carefully.....Lots of used Devilles out there to choose from. A sunroof is a MUST !
Look for one with A BOSE sound system....IT cranks !
Also, what kind of fuel mileage can I expect from a base DeVille?
ALL got better than 25 mpg plus cruising around !
My 02 I only had 6 months. The boss said the dark blue interior was too hot.
My 03 is just a year old with 17k miles and not a problem yet !
Some people here are having complaints about the cruise control. My seville has been trouble free thus far. One thing to watch out for are coolant leaks. They should be repaired quickly or bad problems may develope. If you keep an eye on the coolant level, you should be able to spot a water pump failure before it happens.
I bought a new 2000 DTS and experienced 1 qt/2000 miles oil burning during breakin - which was up to 15000 miles. Have been using synthetic 0W-30 and now use less than a quart in 5000 miles. Have 50000 miles on the DTS (all highway) and it is AWESOME> Only engine problems have been crankshaft sensor went out at 5000 miles and replaced under warranty. Service manager said they had some bad ones that were showing up in the 2000 model but I haven't heard of the problem in later model years.
My 2000 DTS developed a "cold carbon knock" - loud clicking at cold startup much like a noisy lifter - which service manager said was caused by deposits from mid or premium fuel. This was at 35000 miles They ingested a GM product through the throttle body which corrected the problem under warranty. I was told to use regular or midgrade fuel and every 1500 or 2000 miles give it a good dose of Techron through the fuel tank.
Run it to redline in the first 2 gears. This will break up carbon, and freeup the rings. Carboned up rings is the cause of the oil consumption.
Other than the dozens of problems that can occur with the complicated electronics on such a car, the main other problem is blowing a head gasket. If there is a loss of coolant, with no external leakage, (or of course running hot), the Northstar may have a leaking head gasket. It does not leak into the oil, it goes into the cylinder and is burned out. If this happens, you have a multi-thousand dollar repair. The motor must be pulled. When the heads are removed, the headbolts will strip in the alumium block. The bolt holes will all have to be redrilled and retapped and a special insert screwed in. Big money. Some dealerships don't even want to do this job. It will be from $2,500 to $5,000 or whatever they think you may pay. I've read of headgaskets going on less than 50,000 miles. When 100,000 miles come up, this can turn a Cadillac worth a few thousand dollars into something not worth rebuilding.....
If he had paid attention to the coolant level, he would probably have noticed the water pump beginning to fail, and perhaps everthing else would not have happened. But, a new northstar is now about $5000, so the cost of replacement is not too bad.
A fella over at cadillac forums had a heck of a time with his.................
And the heads usually don't warp. The shop people were stupid in not knowing the head bolts have to be timeserted if the heads are removed.
And, yes, water pumps fail a lot. A Cadillac dealer will definitely have one in stock and can very quickly change it out, since they see a lot of this.
My friend had his 99 towed after it got hot rather than drive it in. It is hard to say if the brief overheating caused the problem, but most likly did make an existing head gasket problem worse. The shop people were able to get one head put in, but the other would not go. They were in contact with Cadillac and Cadillac paid for part of the out of warrenty engine to be replaced. I am quite sure that everything that could have been done to save the old engine, was done.
Watch for coolant at the left front of the car. Which is the left rear portion of the motor. The pump is on the rear of the motor, driven by it's own little belt off the left cam.
You might try any strong magnet you can get ahold of and run it around the stem.....
In the future I would like to get my tires rotated at a tire store (free) and avoid the extra charge.
You have the error probably because the tires were rotated and the sensors need to be reset.
And, I previously said you could get your own strong magnet and wave it around the tire stems, which is how they are re-set.
The only thing, when the message about doing this was posted (maybe in another Cadillac forum), I think they said there was a certain sequence (LF, RR, etc)the resetting had to be done. And I don't remember what that was....
BTW: What procedures and parts did they use ?
They want the Cadillac specialist to look it over this time. I am doubtful that they will find the problem in that it is intermittent and not constant although the car ALWAYS loses at least 1 mile an hour and as many as 7 miles an hour after the cruise set green light comes on.
I can live with it if I have to but with the new
Chrysler 300C, Cadillac better watch out in that one reason one buys Cadillac is for build quality. Having a defect is one thing but with Cadillac unable to resolve after three visits my patience is wearing thin. I owned a 1997 Chrysler LHS for three years and never had any problems with it. No question the De Ville is a finer, better made car than the LHS but for me the reliability in the LHS was better because of this problem not being resolved. Needless to say I wouldn't want to get into a race with a 300C
(340 horsepower vs 275 for De Ville). Given the price of the 300C vs the De Ville, Cadillac better hope that there are few situations like mine or they may see a fall in future sales to the competition.
Thanks very much for you continuing interest, I will keep all posted if and when this is resolved and what the problem was in the Cruise system.
But I figure the cruise control "glitch" is something I can live with. As long as I get my 5-6 yrs./100k+ miles like my other Caddies and that is my only problem besides a few cheap oil changes, 1 tune up, a brake job or 2 and a set of tires.
I will be satisfied...................
rear to the new Malibu??? I saw that at night traveling behind a 300.
One MPH off of what you were trying to set is not bad. My car is sometime right on, and sometimes 1 too fast or too slow. In my case it is because I have not stabilized my cruising speed. I just hit the set when I am near the right speed and then adjust up/down as needed.
Will be heading back from Poughkeepsie NY to Syracuse this Sunday hauling 1000 lbs. of Magic Salt, 2 fellas, and our gear and that cruise won't vary 1 mph. either way on my Chevy truck !
Sure it will be hunting gears at 70 mph and getting 10 mpg.
The Deville would just loaf along getting 25 mpg. plus.....Minus the salt of course..........LOL
Set cruise at 70 and it rarely varied 1 mph either way..................
I set the cruise buttons carefully and held the gas pedal steady when setting the cruise.
Brem........Maybe its just US !!!! Not the car...LOL................
or any other car I have owned have done this. I have tried several variations of using this cruise system but have been unable to figure out what the problem is, failures are intermittent and unexpected. The car always loses 1 too 2 miles an hour after cruise light goes on. I could live with that but for some reason it sometimes loses as much as 7 miles an hour after cruise set light comes on. This can be a hazard
if someone comes up too close behind.
Local giant used Caddy dealer in Palmyra NJ has a used CTS-V advertised................
Gonna go down for a test drive...maybe a overnite in that bad boy ! Gonna take my aunt with me and tell the salesman its my wife and SHE needs to make sure SHE can drive it ok................LOL !!!!!!!!
03 Deville 17k miles here.
