Subaru Impreza WRX
-mike
What wheel width and offset are you running? No rubbing?
Don
-mike
http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireM- odel=SP+Sport+5000+Asymmetrical&vehicleSearch=true&partnu- m=055WR65000&fromCompare1=yes
Are these the tires you like so much? They're called SP Sport 5000 Asymmetric.
I'm thinking of replacing the RE92s, but want to stick with 16 inch for $$ savings.
snead_c Jun 1, 2003 4:28pm
There's quite a bit of us >40 who don't live in a basement, enjoys driving and recognizes a good buy when we see one.
Right on snead_c!!!
And when you think econobox, don't you think of FWD 4 cylinder hatchbacks? Guess which one that is...
-juice
Thanks for your feedback. I was just funnin' around, didn't mean to
take a cheap shot or anything. (I'm actually a big fan of
the WRX' performance). Drove the new STi at California
Speedway a few months ago, definitely a fun, fun ride, though I'm not sure
it's worth another $5,000 or $6,000 over the standard WRX.
Thanks for reading, and writing -- much appreciated.
Lawrence Ulrich"
I decided to try a different replacement to try to get even more mileage out of them so I replaced them with Toyo Proxes TPT, which have the same specs but come with a 60,000 mile warranty.
Anyways, two big thumbs up from me for the Dunlop SP5000's.
The Continental Conti Extreme , a new all season, is getting rave reviews at Tirerack, about the only Continental to do so!Cheaper than the Dunlops I believe.
Ken
The filter itself works great. I've had it for 3 years now, and I have asthma. Just checked it yesterday morning, as a matter of fact, and it was *NASTY*. What was white became black and it's just full of dust.
Guess the alternative is to inhale all that stuff.
-juice
It seems like it would be fairly easy for them (or anyone) to put a thin piece of carbon on the filter for odors.
-Dennis
-juice
Uhhhh...neither. The article was about the TSX, not RSX.
Paul
Anyone know?
-Dennis
edit: Here are installation instructions:
http://subaruparts.com/install/2002iairfilt.pdf
Even so, the TSX is the euro Accord, an economy sedan over there.
It's easy, I did this myself. bitman shared a site that had the photos I took when I did it. If that's not enough I'll e-mail you my originals.
-juice
I'd wait til after you had it for a while and see how you like it. There are plenty of tuners out there that can upgrade you if need be at a later date.
-mike
Getting to know the car and waiting until the "honeymoon" is over before tinkering is also good advice.
When/if you get the itch, some good "starter" power mods are as follows:
* ECU reflash (changes stock parameters to enhance performance within a fairly conservative safety threshold)
* Intercooler hose kit (increases intercooler flow)
* Exhaust mods: 1) catless uppipe, 2) catless or hi-flow cat downpipe, 3) catback pipes & muffler (2) and 3) together are commonly referred to as a "turboback" exhaust).
Like any other car, freeing up the car's ability to breathe is one of the easiest ways to squeeze out more power. In the WRX, that involves removing the "pre-cat" in the uppipe, removing/replacing (with a high-flow cat) the "primary cat" in the downpipe, removing the "secondary cat" in the midpipe, and increasing piping diameter (upping from 2.5" to 3" is the norm).
Unlike most cars, tinkering with the WRX's intake plumbing is generally not a good idea, as the stock setup is better than most of the aftermarket setups that tend to screw up the MAF readings.
Before upping the power, however, you would do well to upgrade the WRX's handling and braking. For handling, the first step is better tires and perhaps larger rims. Performance street pads are the place to start with the braking.
Good luck and enjoy the car!
The Cobb reflash stage 1 will get you to about 260 safe hp. Adding a free flow exhaust will add another 5-10 hp and give you a 270 hp Rex. This is bumping up against the 280 hp limit which WRX guru Mike Shields (www.spdusa.com) says is the safe threshhold for our U.S. EJ205 engines. Any more than that, and you'd better strengthen the engine internally or you are looking at a blown engine somewhere down the line, unless you drive most of the time with kid gloves.
So the good news is doing the Cobb 1 reflash with free-flow exhaust (about $1000) and using synthetic fluids will max out your engine's safe potential (with about a 10 hp safety buffer) without doing any other modifications.
Subsequent reflashes, if needed, are facilitated by calling Cobb and paying them $20 to email the needed map, uploading it to the AccessPort (via serial cable I believe), and finally downloading it to the ECU. No downtime at all.
There's no need to have a spare ECU at all (which I infer is how you got to $1000 for a "complete kit"). Furthermore there's no need to reflash to a "stock" map before visiting the dealer, because the reflash itself is undetectable, according to Cobb.
You are correct that ~30 smooth and reliable HP (from 227 to 260 according to the Cobb site) for $400 (add another $100 for the AccessPort hardware) is about the best deal going. $20 for reflashes is easy to stomach too.
I did a lot of studying on exhausts, trying to find a setup that would avoid the harsh noise and highway droning you mention. I also wanted a near-stock "stealth" look. Two systems that meet these objectives and also free up significant amounts of power (another ~25 HP) are the MRT turboback, and the TXS "stealthback" mated to a prodrive muffler. I've got the MRT pipes sitting on the floor in the garage, waiting to be installed.
You are correct that for an otherwise stock car, a 2.5" system may be superior to a 3" system for providing better gains on the low end. The ScoobySport system is the best going in this regard, but it's got a distinct but loud tone. The 3" system will be better at higher revs, or with a more modified car.
-mike
How much torque does the AccessECU add below 3000RPM (the main area where WRX owners complain about turbo lag)? Is it noticeable with the butt-dyno?
Ken
Cobb Stage 1 AccessECU creates a little extra torque in the 3000 range, but the butt-dyno probably won't register it much. Engine pulls a lot stronger from 5-7,000 rpm though. This is going by what owners have said on the Cobb WRX forum and here on Edmunds.
You have to go to the Cobb Stage 2 to get a big bump in low-end torque, but personally I'm not comfortable exceeding 270-280 hp for reliability reasons.
-mike
I have driven cars with both the stage one and two (which requires you to obtain a turbo back exhaust, Cobb recs. to leave the uppipe) and even my numb butt dyno can tell a diff., the top end is MUCH stronger. The biggest gain is how much smoother the car runs. The Stage two (the one I drove had APS turbo back) makes it feel like it has added displacement.
Now the questionable parts...I have heard that Subaru CAN detect reflashes...and even if they can't, anyone who is familiar w/ wrxs will know just by driving the car. There also is some device that is part of the stage one that is inserted into a tube in the engine compartment that is a physical sign of modification.
As for me, I figure if a modification I did causes something to break then it's not Subaru's obligation to repair it...If they won't repair an unrelated item then I'll have to fight them. The 'grey' areas are going to make for some interesting arguments.
It's a risk I choose to take.
Don
Cobb's FAQ says that a dealer cannot detect them. Have people been saying otherwise?
-Dennis
Then i-club became nasioc. The other co-founder created a "new" i-club.
That's the short version. :-)
-Dennis
I guess maybe AFTER the stage 1 ...
2centz...$395 for the reflash but add shipping both ways and its more like $450. $100 more when the accessport comes out and you can reflash stage 1,2 and stock up to 100 times by yourself.
Cobb claims 195 hp at the wheels with stage 1. Same dyno was 170 hp stock. so if 170 whp = 227 crank hp, then 195 whp = 260 crank hp. $11.97 per hp sounds pretty cheap! Stage 2 is around 300 crank hp!
Now all these claims seem almost too easy but all the good reviews have led me to try them. I will keep you all posted...so far I can say that the stage 1 portion is all true.
Don
Kevin
Have about 20,000 + miles on my stock Potenzas (33,000 on the car so far [2002 WRX wagon in black]. Don't like the stock tires and have been drooling over 17's with lower profile.
Started running Dunlop Winter tires on stock 16 inch rims (it is Winter for 6 + months here) and had just swapped out those winters for the stock all season potenzas for the summer (same stock wheels).
Wasn't anxious to spend another summer on the stock Potenzas, but they have a lot of wear left. But I'm turning a slight bit of bad luck with one tire into lemonade after I found my excuse to extend myself and go for new wheels and tires: A slow leak on one tire that wasn't holding after repair.
Never had a car I cared about the performance or handling like this car, so had to stretch the brain and the pocketbook. I've been saving posts about tires/wheels for over a year. I'm hoping it paid off.
I Based my choice of tires on the many posts on this site: Bridgstone Pole Position S-03's: 215/45/17.
I based my choice of wheel from limiting selections on Tirerack that would fit the car. There are a million rims out there! Choice of rim: Mille Miglia Actions in 17 inches.
Priced out a wheel/tire package on Tirerack: $1284.50 with shipping.
A new Discount Tire franchise opened up nearby across the river in St.Paul. Went in to see them, too. As soon as I told them what I was looking at, the guy says, "you researched this on Tirerack, didn't you!" Told him I had.
He pretended to do some checking on his computer with the excuse that they don't stock these tires or wheels in the store and he would have to order them. "fine," I said. What a coincidence: he could get the same exact wheels and tires for the exact same price, but would have to charge me tax of course. He quickly added that if I purchased with him, I would have a place to change out my summer tires to winter tires, a place to get balancing, and repairs: things that would require shipping with Tirerack and would likely cost more overall.
Result: I did order from him, paid about $200 more with tax and the insured replacement of problems with tires, and had them mounted on the car today (48 hours after ordering).
As I was about to drive away, the technician informed me that he had put the lugs from the stock wheels in the same package that the new wheel lugs came in. He handed it to me. On the package was the shipping info for the tire/wheels just installed on my car...
... They had ordered the tire/wheel pack from Tirerack!
Before I got home, had three stares at the wheels (I home that's good) and one honk and thumbs up. Now we'll see how they handle. Happy summer driving, everybody!
Thomas in Minneapolis.
