Nissan Pathfinder Owners Care & Maintenance
Question: Did you find any performance/smoothness/noise inprovements with the synthetic?
Timing2
Actually, I -think- it may be quieter, but it probably is the same. The important thing to me is the limited slip is happy with the Royal Purple oil. I suspect the Royal Purple is less expensive than the Nissan oil and additive the dealer would have used.
Coincidentally, last week I ran into a service tech/manager who used to work at a Nissan dealership (he now instructs the techs for maintenance of BC ambulances). He noted that they (Nissan) did have some problems with bearings and wear in Pathfinder diffs. He thinks my use of Royal Purple can only do good! We got along well.
I have a 2003 Pathfinder LE with close to 36,000 and the original warrantee is about to expire. I have found a bumper to bumper extended warrantee to 100,000 for $1950.
Do I need this extended warrantee or should I pay off a credit card?
Thanks for your help
I had a very similar thing happen to me twice on my 2001 Pathfinder. It turned out to be the hub assembly and brakes. The first time I had to get the hub bearings lubed and brakes adjusted ($127.00). The second time I had to get the hub assembly replaced and breaks adjusted again. About $600.00 for this. Both were done at the dealership which was a rip-off. I suspect a good garage in your area could do it for much less. The parts were only about $200.00 with the rest being labour. By the way...prices are Canadian dollars - cheaper of course in the U.S.
During this year the Pathy has acquired a rebuilt transmission (with less than 1000 miles I may add prior to death), four brand new tires and new windshield. So I ask of you the die-hard Pathy owners....do I invest USD3000.00 to USD4000.00 to recuscitate?
Personally I love the damn thing and neither she nor I are in the best financial shape to buy a new/used vehicle with less mileage/years. HELP! Thanks for any/all insights and advice possible.
Sincerely, Tortured in NJ
I keep putting off doing mine, and I may pay for that! The rear ones can be difficult to reach - he (former service manager) tells me you will need two extentions and two 3/8" drive universals. Drivers side is the worst, I'm told.
Oh, and $10 each is not bad for a plug that lasts that long. Price out plugs for a rotary engine. :O
The front plugs aren't too difficult to get at, but the rear ones require "U" joints and extentions on the ratchet - use 3/8" tools (ratchet, extentions and "U" joints). Drivers side is the worst. If the plugs are really hard to turn out, "gently" work them tight and loosen and use penetrating oil.
Good luck!
I'm trying to replace the in cabin microfilter for my 05 Pathy SE off road. The problem I'm having is trying to get the glove compartment door fully open for access. The manual says to squeeze both sides of the glove door to get it loose (and hanging by the string). But the left side of the door won't give, and if I squeeze any harder, the thing will crack. Anyone else on this board having a problem like this? Or should i just take it to service and have it done there.......seems like an easy thing for me to do, but of course there's always one stupid obstacle in the way. I thank you guys for your help.
I'm new to the group and my first question is as follows:
In my 95 Pathfinder , the center console is very loose. What is the best remedy for repair, Do I tightened ? if yes, how ?
or
Do I replace ?
Did you look from underneath? Often it's easier to get to the freeze plugs where they usually install the block heaters when the rig is on a lift.
Anyone?
(p.s. I drove the Dempster about 15 years ago - nice trip, but a bit far just to visit the dealer!)
Does anyone have a mechanic/shop to recommend in the San Francisco area (North Bay preferred)?
RK
Thanks alot
ER
Gates shows a belt for the Pathfinder for 1996-2000 - they also say my engine is interference when it's not, so I don't fully trust them either. (link)
I'll send a note in - feel free to contact us with the Help link below and it'll get routed to the right department.
Changes to the missing optional transmissions should be fixed in the maintenance guide in the very near future.
I'm afraid to ask if the VQ is an interference engine in the Pathfinders from 2001 onward.
I'll reply to the CSR email. :shades:
1) Are there different types of fittings and could my grease gun have the wrong one?
2) If I haven't been greasing it what damage could this do & what symptoms might it cause?
3) How much grease should you give it on a regular basis and if I haven't been getting any grease in how much should I give it now.
4) Is it typical for grease in a grease gun to seperate and a yellow liquid to leak out of the grease gun? Thanks...
Grease is oil held in a jelly. It will separate over a period of time. That is how it lubricates. It's really oil lubrication held in jelly for "timed release". Nothing to worry about - it's normal. My guns leave little puddles of oil where I store them. I say "guns" because one has molybdenum grease, one has teflon grease, and the third has a special waterproof grease for my motorcyle swing arm.
If you can't get any grease in the fitting, just smear some where the spline shaft goes into the rest of the driveshaft. It doesn't need a lot. If you ford streams a lot you want to be greasing it a lot, but for most of us, these are "main street" 4WD vehicles and don't require a lot of greasing.
I grease mine successfully per the maint. schedule and have a nice coating of grease on the underside of the body in line with the part of the shaft where the spline goes into the rest of it.
If you get a grease gun end that will work, pump it until you see a little come out at the spline junction, or three or four full pumps, whichever is less. There is no seal involved that you can damage with too much grease.
BTW, molybdenum grease contains molybdenum disuphide (fine powder). It's there in case the grease dries out, in which case the powder gets forced onto the metal surfaces when they rub together under force. This is also a good lubricant. It actually bonds to the iron, giving it permanant emergency lubrication (until it sees forces high enough to melt the steel that is).
