Platinum. Catalytic convertors have a ceramic honeycomb structure inside them that is plated in platinum. Who's giving you the $2,200 price, a Jag supplier? Shop around at different exhaust shops, suppliers, ect, and see what kind of price you can get. It might help if you just tell 'em you need a cat for a size X exhaust pipe, and not mention it's going on a Jaguar ;-)
http://www.discountconverter.com/
or
http://www.all-catalytic-converters.com/
A local muffler shop can instal it/them.
Then I brought the car into Rosenthal Jaguar for a 35000 mile checkup three weeks later.. They rotated my tires and the shimmy began! It was only really noticable at first above 65. But it was so bad at 80 that it made open highway driving downright nerve rattling.
I brought the car back THREE times specifically for tire service. And because I didn't buy the tires from Jaguar, I was charged around $400 for the rebalancing service. They did a realignment as part of the process.
For the last 4 months, everything has been fine, but in the last week, a slight vibration is starting to happen again between 40 and 60MPH. I'm also due for another 5000 tire-mile rotation from JustTires. I'm cringing just thinking about what's comng. I suppose I won't notice any shimmy for a while since its due to start snowing here soon. I doubt I'll be hitting "highway speeds" for a while.
But to echo other posts - Rosenthal Jaguar service sucks. They took over 4 months to replace the seat potentiometers in the drivers seat under warranty. They had to order parts twice and both times, I had to verify the parts had come in - they never called me. The first time, they found that they had received a defective part AFTER they had my car for 2 days. Then they had a 4-week lead-time. And both times they had my car, I had to call them only to find out my car was done and ready - nobody ever called me to tell me it was done.
Now that I work in Gaithersburg, maybe I'll check out Manhattan Jaguar in Rockville.
I don't think my next car will be a Jag either. I'm thinking more along the lines of a Lexus or BMW SUV.
Cheers!
Does anyone know under what conditions the light will come on? I've got an appointment to go get my computer code read, but that's not till the end of next week.
Smells like clean leather to me! My '97 VDP is immaculate inside!
I had the car detailed once too. I'm not sure what they used, but I assume it was "the good stuff"...
I had my car detailed by Mobile Auto Detailing (http://www.waxmycar.com). They service the Northern Virginia area. You can bring your car to their shop, or they will send a mobile van to your work or home. Their prices were around $190 for the whole car (inside and out) with either going for around $95 ala carte. If at all possible, have Billy do the work. He's very thorough. He drove to my work and spent about 4 hours working on my car. I would highly recommend them - especially once the spring thaw gets here!
How did you manage to get a '97 with a Select Edition? You were lucky. My VDP was originally purchased in 10/96, so when I bought it used in March 2001, it was just passed the cutoff and I had to shell out around $2800 for the Warrantech coverage!
Hopefully, my problem will just be the sensor too! If not, I hope all that other stuff is covered by Warrantech!!
I wondered about the fluid levels. I'm due for another interval service soon. I've got 46K miles on it. I'll check my Tranny fluid level tomorrow.
Cheers,
Ron
Bill
the service technician when opening the transmission to replace speed sensor found metal particles and the trans fluid was quote burned. well the car has 69,000 miles. His conclusion put in a new transmission for 6,000.00. This with no road test after putting in the speed sensor.
with no prior problems, slippage for example, or fault codes, my decision is to replace the speed sensor, put in new transmission fluid and go.
Cost 800.00
Never ignore the warning lights, but look beyond the obvious-the harness or cables could be grounding out if not properly installed, light goes on but no problem exists.
Hope my experience helps
LT
Shortly thereafter, I parked in the same spot again and pulled a little too far forward...rrrrrrippp! Doh!
A little duct tape over the tear holds the two pieces together just fine. I never parked in that spot again!
If you drive without one, you'll be kicking road dirt up into the engine compartment.
Mine has started to come on intermitantly about 2 days ago. Sometime its on right away. Other times its on after operating for a few miles, other times not at all.
What is the best way to troubleshoot this, and is there an easy solution?
Aaron
Now, DO NOT LET THE DEALER BE "somewhat elusive." Find out what the heck is wrong with your car. Remember, this is YOUR CAR, and you have the rights here. The dealer can't even do so much as an oil change, much less an engine swap without your permission, and if it were my car, I'd have a very detailed technical explanation of why my engine is bad before they replaced it.
It is not likely an issue with the cylinder liners as this would not be "lower end". The only way to know for sure is to tear the engine down and do a close inspection. Since this is never cost effective to do (unless you're talking about a top circuit racing engine), you will likely never know exactly what the problem is and will have to rely on your Jaguar mechanics ear that the noise coming from that area of your engine is not normal and indicates imminent doom.
My greater concern would be having a catastrophic failure prior to the new engine coming in. I'd ask the dealer for a loner if I were you.
1) How much should I pay for one of these? I'm seeing the same model anywhere from $9k on eBay all the way up to $18k in dealer newspaper ads. (I know what the book value is, but I also know from past experience that book value doesn't necessarily reflect market prices of the more exotic cars.)
2) Should I stay away from the v12? Besides paying twice as much for a tune-up and getting worse gas mileage, is the 12 that much more troublesome/expensive to run? I know the AJ16 is a great engine, but know little about the v12 other than the problems with the Marelli ignition on earlier models & the XJS. If I find a deal on an XJ12, should I be afraid of buying it?
3) What's a ballpark figure for annual maintenance and repairs? $1k? $2k?
Blake
The dealer again checked out the tranny warning light. This time no fault code was stored, so they topped up the fluid level and bid me "Good Day". The thunking really doesn't affect the car's performance but it is annoying. How did you make out with your problem?
The light hasn't come back on since Thanksgiving. I figured I would make sure all my fluids are topped off and see if it lasts a while. I just turned over 47,000 miles. I think I'll either take it to one of the mechanics that's been recommended here or to the Jag dealer in Maryland. The service and quality at Rosenthal in McLean is starting to fall off.
Best of luck with your car. I hope your light stays off too!
-Ron
Assuming everything else is equal, except of course selling price, wouldn't a 98 represent a better buy?
Also do you know if it's possible to get an extended warranty if you buy the car from a private individual?
You can't get the Select Edition warranty on a private sale vehicle, but the Warrantech warranty is available to anyone. It costs around $2800 and it covers the car for 5 years from the date of purchase (of the warranty) or up to 100,000 total miles.
After having the car for almost 2 years, I can say that the warranty hasn't saved me much. The one item that was covered (driver seat potentiometer motors) would have cost me around $1200 to have replaced by the dealer (parts & labor). They did it for free. Everything else has been very minor or was a mileage interval service, which the warranty doesn't cover anyway. So at this point, the policy has still cost me more than I would have spent if I hadn't bought it.
One thing to consider about buying a used vehicle from a dealer.. if you bring it in for service, you get a free rental/loaner car ONLY if you bring it back to the same dealer you bought it from. So, if you're considering Manhattan for your service, you might want to consider them for sales too.
I have had the opportunity to visit two different Jag dlrs in Connecticut and both provide free loaners without having to ask for one. One dealer, Crest Jaguar of Woodbridge, Ct, the dlr I bought my 99 XJ8L from, provides a Merc. Sable because they are also a Lincoln/Merc dlr. The other dlr is Thomas Jag of Hartford and they provide an Enterprise vehicle since they have an Enterprise franchise on prem. This dlr is a Jag & Cadillac dlr and I am sure they can't afford to provide "free" Jags or Caddys. However, my friend who has a Lexus LS400, gets a free ES300 when he goes in for svc at his Lexus dlr. Well, who cares, I still get a free vehicle when I go in for svc. And I get it from either Jag dlr. Bill
Cheers
Ron
http://www.edmunds.com/reviews/roadtests/firstdrive/83151/article.html
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Mike
I'm looking at a 1999 VDP, 57,000 miles, Emerald Green with Cashmere interior, CD changer, traction control, heated seats, no service records. 30 day limited warranty, $31K. It appears to be very clean and seems to runs well. For sale at a non-Jaguar dealer.
The Carfax report shows this car spent its life in Utah as a lease vehicle and sold as a lease return to the current dealer.
I do not own a Jaguar yet and would like to know if this one is worth considering? Is the color combination OK? Should I be concerned with the mileage? What should I realistically have to pay for this car? Anything I should look for in particular? Heard bad things about engine problems. Should I look for a 2000 model to avoid this issue? Any other tips would be appreciated
SAJD
Any comments on the color I should be looking at? I really like the Spindrift White and the Emerald Green. Are these OK. I'm concerned about how well the green will hold up in the hot Arizona sun. What color is better to hold the value of the car?
I called the local Jaguar dealer to ask about service records on this car and was told that they do not have access to records on any car that was not service at the dealer. I thought I read on some post that the dealers service records were networked throughout the country. Can anyone comment on this?
SAJD
I have a 2001 VDP I bought it at Galpin Jaguar
in CALI. for $42,900 w/20,000 mile and it is a Star Marked. I like it the more I drive it. Its like a small RR but you do not see me comming from miles away. Any other owners have advice for me
DAVID B.
MZ did that and now if you see a E class and a S class they look the same DUM
I have a question, our VDP has a coolant leak - not so much a leak, really, but more of like a pin prick somewhere along its coolant tubes. We cannot localize it, but we know it's there because of the orange puddle we're getting. Do any of you know of common places for this to occur? I suspect it's around where the hose attaches to something, perhaps as if the clamp has come loose or something. Thanks for any advice. Getting car to dealer as soon as possible, but don't want to loose too much coolant before then.
seats, roof and sounds that I purchase a year ago with 34,000 miles for $26,000. Winter is a good time to go shopping for a Jaguar.
I have since acquired the service records on this car and was a little surprised at the number of repairs this car received in a 30 month period. I'm not sure what to think of it since I have no experience with Jaguars yet. The repairs are listed below in chronological order:
* 13K miles
Front tires
* 19K miles
Front brake pads
* 20K miles
Antenna Mast
* 27K miles
New Battery
* 34K miles
New water pump,
New Front tires (seconds set)
* 41K miles
Rear tires
* 42K miles
Replace steering wheel cassette reel
* 45K miles
Replace cam cover gasket
* 46K miles
New Battery (2nd time),
Replace front brake pads (2nd time)
New water Pump (2nd time),
New thermostat,
New engine set,
New timing chain tensioners left & right
* 48K miles
Replace starter motor,
Replace battery (3rd time)
* 49K miles
Replace engine assy ancillary equip,
Replace all three O2 sensors,
Replace ABS control module,
Replace throttle assy,
Replace mass airflow sensor,
Replace cam cover,
Replace Engine assy and ancillary equip.
I can read this as; 1) the car has had too much work on it and is not reliable. OR 2) the car was abused by the previous driver and will be trouble. OR 3) The car has had most of the major repair already completed a therefore is now more reliable and a better value. OR 4) All the above.
Only two oil changes show on my service history. The service manager at the dealer said the drive utilized a different shop for oil changes so I don't know how often it was changed or what kind of oil was used.
How would you experience Jaguar people read this history?
It looks like the engine was replaced in April 2002 at about 49K miles. Records show the engine had excessive back pressure. The car now has 57K miles (only 8K miles on the new engine!) What are the chances the new engine does not have Nikasil lining?
What would be a good price to pay for this car?
I would really appreciate any help in evaluating this information. HELP!
SAJD
