lexus gs300 rpm surges at cruising speed
I have a 1998 GS300 with only 16,000 miles. It has started to have oscillating 200 RPM changes at cruising speed. This occurs with or without cruise control engaged. The dealer has had the car for 5 days and can not tell me what the problem is. Any help?
SOMETIMES people mistake an unauthorized downshift for a surge, when actually the rpm counter is going up but the car is not actually accelerating...this could happen if the car is dropping out of overdrive.
200 rpm is pretty subtle. The dealer may have a tough time with this one.
redf1: converter clutch apply is controlled by the powertrain control module, which monitors various sensor inputs to determine engine/vehicle operating conditions and decides when to apply/release the tcc. Inputs may include vehicle speed, throttle position, engine vacuum, mass air flow, engine rpm, coolant temp, trans oil temp, gear selector position, brake pedal status, etc. If any sensor input is outside specified parameters the PCM will disable the tcc. When it releases, engine rpm increases as does manifold vacuum. I'd be checking TPS adjustment and manifold absolute pressure/mass air flow sensor inputs. Most tcc hunting concerns are directly engine driveability related.
