Honda Civic Care and Maintenance
Any advice GRATEFULLY accepted!!!
How do I change the "Oil Life" to read 100%?
Any and all replies appreciated...
The Sandman :sick: :shades:
2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
I have been thinking about doing some improvements but wanted to make sure the drivetrain was in good shape before investing in suspension & cosmetics. I generally am not a hard driver, about 60% of my mileage is 2-4 mile trips in uncongested urban traffic, rest highway.
Here are my fluid analysis from Blackstone:
Tranny fluid: Copper was the dominant metal in the first sample from your Honda's transmission. This metal tends to show wear at the clutch plates and at 154 ppm, it is well above average, especially with only 5,500 miles on the oil. This is something to watch closely next time. All other metals read below universal averages, which are based on an oil run of about 16,000 miles. We suggest changing this oil and resampling in another 5,000 miles to monitor. No moisture or insolubles were present.
Motor oil (Motorcraft semisyn blend 5W20): Lead increased in the latest sample from your Del Sol. Lead is 45. Was 8 at 73K, average for this unit is 4. This level shows some lower end bearing wear. If the air filter is clean, check for cracks or leaks past the air filter. You mentioned that you. do mostly city driving. That can contribute to high bearing, but likely doesn't explain this big of an increase. These aren’t failure levels, but it is something to watch. We suggest having this oil changed and resampling in 3,000 miles to monitor. The TBN read 2.0 so you still have a little active additive left. Check the CEL code to rule out anything there. Changed oil when this analysis was done.
Despite these depressing reports, the car seems to run fine, averaging 30- 32 mpg. The only obvious problem is the CEL often comes on after 3-5 miles on the highway.
I plan to keep this as a daily driver for 2-4 more years & average about 4,000 miles a year & planned to change to oil once a year. I am not into engine & tranny swaps. So what do you suggest in terms of oil & ATF to help nurse as many good miles out of this drivetrain as possible? Thanks
any suggestions? also for a integral affordable good honda mechanic in the Hayward ca area. i am researching car maintenence on inet. but would like to hear from people with experience..
Whether you want to take the chance again is up to you - but from the sounds of it he is not licensed by your states Motor Vehicle Department and his liability to you is virtually nothing unless you sue him in civil court.
I'd take it to a functioning auto repair shop that is licensed by your state DMV - so you'll likely have some sort of gurantee and more recourse should things get worse, as opposed to "my neighbor down the street killed my car" scenario.
Good luck !
1. What is the recommended oil change schedule
2. Is synthetic better, i know they say it does not matter short term, but over the life of the car does it make any difference
3. How does the maintenance minder monitor just tracks mileage or some more parameters
4. Is it worth spending more on expensive oil filters
As i am unable to get the answer to these questions in the manual it would be very helpful to get these answered once and for all. Thanks!
They put a sticker, 15% or some date.
But I drive few miles (short commute) so it takes a year or more to get it down.
I think I must buy the 3 knob Auto controller but how do I get to it?
How do I get the radio/CD/Cassette player out?
Any advise is appreciated.
EJO
I own a 2009 Honda Civic which I bought in Jan '09. The car is in excellent condition and I have taken the car regularly to the dealer for maintenance whenever the maintenance lights have come on.
I last serviced the car ~27K Miles and at that point of time the dealer made some noises about additional work when the car hits 30K.
Yesterday at ~33.5K miles I got the 15% oil life message along with the A 1 maintenance codes. Before I go to the dealer I wanted to know what maintenance are truly required at this time. Oil change and tire rotation goes without saying but is there anything else that must be done? I definitely do not want to avoid any required service but I do not want to be taken for a ride by the dealer because of my lack of knowledge
The manual is vague about anything other than the maintenance minder codes so help on this from the forum would be appreciated. I do about 80% of my driving on the free way.
Thanks and Best Regards.
It now sits at 15,000 miles and I was wondering if there's any way to guess what codes will be displayed when the oil life reaches 15%? It's currently at 30% oil life. I know A & B are oil changes, but as for the number (1-6), does anyone here know that has taken their Civic between 15,000 and 18,000 miles for service?
The reason I ask is because I have 2 upcoming road trips, 2 weekends in a row, and if I were to guess I can easily put in 1,000 miles, maybe more, in less than 2 weeks. I don't want the maintenance light in the dash to come on while I'm far from home and from my dealership.
I loved my civic, with D15 stock engine and with the new head gasket on 235k while I bought it. Gas consumed around 32-35 mpg. The problem i forgot to asked previous owner how many miles last time he changed the timing belt:(.
Can anybody share how many miles change timing belt recommended?? 60k/80k or 100k??? Thanks:)
Good luck guys!
I have an upcoming appointment at my dealership for a state inspection and I'll check if they'll do an early oil change before my trips. I may pass up on the tire rotation as I don't think it is absolutely necessary for a tire rotation, even though Honda recommends it. Don't think it would hurt to skip one and save some money at the same time.
