Take it in to an Autozone and they'll diagnose it for free.
hurkfixer
stopped, would buck forward and then stall out. I took it to the dealership the
1st time and they stated that maybe the type of gas I used caused it to do just
this. Later that day I had the same experience, while on my way to the
dealership, my vehicle began to buck forward on the highway while cruising. the
dealership fixed the problem by replacing some eletronic module. Just this week,
the same problem occured, but this time my vehicle struck another vehicle and
caused excessive damage to both my vehicle and the vehicle I hit, my car is
currently under investigation at my local Jeep dealership. Please notify me if
anyone has experienced a similar problem, maybe we can MAKE D.C. fix this
problem before someone gets seriously hurt!
It is all wheel drive and runs great,any help appreciated..Oh it has 99,000 miles.
Thanks Jimbo611
I think I will just keep driving and add oil when it needs it. I appreciate the info..
jimbo611
Check for any blown fuses in the fuse panel under the engine hood and behind the passenger kick panel on the right side. My son replaced a blown fuse in each of these locations and restored power to the coil. Engine then ran fine
Techgeek
There's a rubber hose about 3" in diameter which originates between the belt and what i presume is the engine block, and goes to the front of the car where the fan is by the grill. It popped off from the grill side when i was driving, smoke was everywhere becase some kind of fluid was coming out of the hose. I reattached it, hoping it will stay.
I haven't driven the car yet, I was wondering if I needed to replentish some kind of fluid that might have been lost? Also, can I be sure that hose won't come off again? Was it a freak thing?
Thanks for any help
Stuart
0200604 - SPECIAL OFFSET BALL JOINT - ALLOWS ADJUSTMENT TO CASTER AND CAMBER ANGLES
Date: August 20, 2004 (supercedes 0200102 dated June 10, 2002)
Model year(s): 2001-2004
Description: This bulletin involves the replacement of one or both front upper ball joints when front end alignment specifications can not be obtained using normal alignment practices. The customer may experience a slight lead or drift to either side of the road. This condition may occur when there is no driver input to the steering system, or when the driver must maintain a constant input to the steering system in order to maintain a straight ahead direction of the vehicle.
NOTE: THIS BULLETIN WILL NOT EFFECT SITUATIONS WHERE A LEAD OR DRIFT CONDITION IS PRESENT ONLY WHEN BRAKING.
Details: The front end caster and/or camber angles on certain Jeep vehicles are fixed. For Grand Cherokee vehicles both the caster and camber angles are non-adjustable (fixed). For Wrangler and Cherokee vehicles only the camber angle is non-adjustable (fixed). The offset ball joints listed in this bulletin allow for the adjustment of these “fixed” front end alignment angles by an amount of up to 1.5 degrees. The offset ball joint should be used only as required.
F
The tranny seems to "whistle" in first gear though jeep shifts fine. I also have '94 that doesn't sound like that.
Also, the front end "squeaks" sometimes on bumps or while turning. Not bad, but the '94 doesn't do that either.
Any cause for alarm?
Just yesterday and today BADLY, it has begun to have a tremendous sharp banging sound (like I just ran over a small curb) when I accelerate from 0-20mph. I can tell it is coming from the transmission when it clunks (almost like the gears are mis-aligned or a cog is missing), the sharp bang is also seen in the 4wd hi/lo gear shift and vibration in the automatic transmission shifter. If I throw it into neutral and coast it goes away.
At first is was just one, but today it's happening with regularity and I'm afraid to drive it now.
Can anyone tell me what's going on and what would be the likely senario for the repair...including (gulp) costs?
Thanks so very much for your help!!
Very concerned
My guess is that either your front shocks are worn or you have a bad steering dampener (the sideways shock absorber).
Take a look at the shocks and see if you see any fluid leaking out of them.
That is the first place I would look at.
Also check all of the bolts on the front suspension components to see if any are loose.
Have a 1994 GC Laredo with 200,000 miles. 5.2L V-8 with NP-249 all-time 4wd. VIC just started resetting the clock by itself (service interval not changed). Has been displaying "Service 4wd switch" for the past couple of weeks.
When all 4 wheels are lit, it means the transfer case is either in 4wd Hi or Lo. Not lit, allegedly means it's in neutral.
See many posts in many forums with no clear solution. Sometimes replacing the switch work, sometimes not. Some dealers suggest the VIC is shot and needs to be replaced at $1,500. Not.
Also saw suggestions it's a bad ground on the 4wd switch (neither Chilton's nor Haynes don't show a 4wd switch on the transfer case and I haven't crawled under to see yet). Others suggest "freeing up / adjusting linkage." Another brave soul disassembled the VIC and glued the loose sides together. Another simply removed the power to the VIC via fuse #19. Take your pick. Jim
They replaced a control arm. Still squeaks. Now theay are going to replace the spring...In other words, they have no clue. I'll let you know if it works. Please let me know how they handle your issue.
Eric
